bee395 Posted September 9, 2022 Posted September 9, 2022 Hey all, I'm unable to boot Armbian from the SD card of my Radxa Zero 1 GB. When I download one of the official Armbian Radxa Zero images I always get the message "ALERT! UUID=eba52b2e-b77a-47b9-9619-ebda85946883 does not exists. Dropping to a shell!" Previously I ask the Radxa community on Discord, were I received the suggestion that the CMA memory maybe was configured too high. I tried to make an image from master (4b21499534, after https://github.com/armbian/build/pull/4151 was merged) but that didn't help. When I run `dmesg` I get the following repeating error "mmc1: error -84 whilst initialising SD card" When I run `blkid` I do not get any output But when I insert the SD card in my laptop and run `blkid` I get: "/dev/sda1: LABEL="armbian_root" UUID="eba52b2e-b77a-47b9-9619-ebda85946883" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="9a366be2-01" So the uuid seems to be correct. I'm not able to boot into Armbian, but the official non-Armbian images from the Radxa site work just fine on this device with the same SD card. Does anybody know what could be the problem, or any ideas how it can be solved? (The file upload was not working for me, so this is a link to the screenshot image: https://imgur.com/a/UPakZPm) 0 Quote
Luis_D Posted January 10, 2023 Posted January 10, 2023 Hello bee395, what kind of SD-card do you use? 0 Quote
Igor Posted January 10, 2023 Posted January 10, 2023 This was most likely solved by now, but don't have a device to test. @monkaBlyat @Yakov 0 Quote
Solution Yakov Posted January 10, 2023 Solution Posted January 10, 2023 I was able to boot Armbian on Radxa Zero only with built-in flash memory (2 and 4 GB versions). 1 GB and 512 MB versions constantly reload on boot. I tried several SD cards (SanDisk, Adata, Samsung and noname), cards running on 2 and 4 GB versions do not run on 0.512 and 1 GB boards. I have on hand 512 MB, 2 and 4 GB versions of the boards. How can I help? https://armbian.atlassian.net/browse/AR-1148 1 Quote
Yakov Posted January 10, 2023 Posted January 10, 2023 The last image that normally boots on the 512 MB version of the boards is: Armbian_21.08.0-trunk_Radxa-zero_focal_current_5.10.58_xfce_desktop.img 0 Quote
Sajeev Sankaran Posted March 29, 2024 Posted March 29, 2024 dear sir, I tried this image but keeps on rebooting on radxa zero 512mb non emcc version. currently only manjaro Gnome is the only one that partially works. always freezes on manjaro. Is there a known fix Regards Sajeev 0 Quote
technik007_cz Posted June 20, 2024 Posted June 20, 2024 This is unfortunate thing for 512MB versions of Radxa Zero and latest Armbians. Mine is doing this: bl2_stage_init 0x81:00000000 BPDDR4_PHY_V_0_1_18 buil21:45 board id: 2 Load FIP HDR farse done Load ddrfw from SD, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0 Loa000, size: 0x00004000, part: 0 Pa verify ve: 266 Cfg max: 2, cur: 1. Board id: 255. Force loop cfg LPDDR4 probe ddr clk to 792MHz Load ddrfw from SD, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0 dmc_version 0000 Ct INFO : ERROR : Training has failed! 1D traioard id: 255. Force loop cfg LPDDRully! Checad delay center optimization INFOO : End of read delay center optim00048200, ded of 2D writ=1 RxClkDl01a 00000018 0000001a 00000017 00000019 000000000018 0000reg_value 0x 00000059 2D training succeed aml_ddr_fw_veB DMC_DDR_Ct pass 1081 result raccess LoaL3X from SD, src: 0x000se):4fc40b1 U-Boot 2021.07-24139-gdb6738fed92 (Jun 17 2024 - 21:13:15 +0100) radxa-zero Model: Radxa Zero 5 Skipped No140 NbrPorts 3 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 1 USB Dscanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 2 did not resp: -110 Scanning mmc 1:1... Found U-Boot script /boot.scr 8147 bytes read in 2 ms (3.9 MiB/s) ## Executing script at 08000000 U-boot default fdtfile: /meson-g12a-radxa-zero.dtb Current variant: ** Reading file would overwrite reserved memory ** Failed to load '/armbianEnv.txt' "Synchronous Abort" handler, esr 0x96000010 elr: 000000000105f154 lr : 000000000105d34c (reloc) elr: 000000001dfb3154 lr : 00000000100402 x7 : 0000000000000000 x8 : 0000000000000008 x9 : 0000000000000008 x10: 00000001bf3e2c x17: 0000000000000000 x18: 000000001bf51dd0x21: 000000001bf7a4a0 x22: 0000000000000000 x23: 000000001dfd89a8 x24: 0000000000000000 x25: 0000000000000001 x26: 000000000000000a x27: 0000000000000000 x28: 0000000000001fd3 x29: 000000001bf3e330 oot reason: 0xd bl31 reboot reason: 0x0 system cmd 1. G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;:0;x01 bl2_stage_init 0x81 hw id: 0stage_init 0x02 no sdio debug bed L0:00000000 L1:00000703 L2:00008067 L3:04000000 S1:00000000 NFO : End of 2D read delay Voltage center optimizationn INFO : End 0==216 ps 11 TxDqDly_MClkDly_Margin_A1==0 ps 0 TxDqDly_Margin_A1==Dly_Margin_Agin_A1==0 ps VrefDac_Margin_A0==30 DeviceVref_Margin_A0=1==0 dwc_ddrphy_apb|(2<<16)|(0<<12)|(0xb0):0004 soc_vref_reg_value 0x 00000017 00000019 000000100017 00000000018 00000019 00000019 00000014 dram_vref_r DMC_DDR_CTdrBus test pass 100bdlr_step_size ps== 493 result rep ddr reg ac SD, src: 0size: 0x000ec000, part: 0 ze: 00001e4K:0;cm4_sp_mode 0 MV35 36 32 43 46 50 [1.193808 Inits done] secure task start! high task start! low task start! run intmal boot! ERROR: Error initializing runtime service opteed_fast 2A (S905Y2) Revision 28:c (30:2) DRAM: 00: 2 In: serialonment from nowhere... OK Out: serial Err: ller USB X for device1 USB Dev Storage 1 0 Quote
technik007_cz Posted June 20, 2024 Posted June 20, 2024 (edited) or when I copied content of boot partition to /boot folder of same partition: INFO : End of read dq deskew training INFO : End of MPR read delay center optimization INFO : End of write delay center optimization INFO : End of read delay center optimization INFO : End of max read latency training INFO : Training has run successfully! 1D training succeed Load ddrfw from SD, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0 Check phy result INFO : End of initialization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : Training has run successfully! channel==0 RxClkDly_Margin_A0==216 ps 11 TxDqDly_Margin_A0==256 ps 13 RxClkDly_Margin_A1==0 ps 0 TxDqDly_Margin_A1==0 ps 0 TrainedVREFDQ_A0==74 TrainedVREFDQ_A1==0 VrefDac_Margin_A0==31 DeviceVref_Margin_A0==40 VrefDac_Margin_A1==0 DeviceVref_Margin_A1==0 channel==1 RxClkDly_Margin_A0==216 ps 11 TxDqDly_Margin_A0==256 ps 13 RxClkDly_Margin_A1==0 ps 0 TxDqDly_Margin_A1==0 ps 0 TrainedVREFDQ_A0==74 TrainedVREFDQ_A1==0 VrefDac_Margin_A0==30 DeviceVref_Margin_A0==40 VrefDac_Margin_A1==0 DeviceVref_Margin_A1==0 dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004 soc_vref_reg_value 0x 00000017 0000001a 0000001a 00000017 0000001a 00000017 00000019 00000017 00000018 0000001b 00000019 00000017 0000001a 00000019 0000001a 00000015 00000017 00000019 0000001b 00000018 00000017 00000019 00000019 00000018 00000018 00000017 00000017 00000017 00000017 00000018 00000019 00000014 dram_vref_reg_value 0x 00000056 2D training succeed aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_18 build time: Aug 28 2019 13:53:31 auto size-- 65535DDR cs0 size: 512MB DDR cs1 size: 0MB DMC_DDR_CTRL: 00c0002aDDR size: 512MB cs0 DataBus test pass cs0 AddrBus test pass 100bdlr_step_size ps== 493 result report boot times 0Enable ddr reg access Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3X from SD, src: 0x0006c200, des: 0x0175c000, size: 0x000ec000, part: 0 bl2z: ptr: 05129330, size: 00001e40 0.0;M3 CHK:0;cm4_sp_mode 0 MVN_1=0x00000000 MVN_2=0x00000000 [Image: g12a_v1.1.3390-6ac5299 2019-09-26 14:09:46 luan.yuan@droid15-sz] OPS=0x30 ring efuse init 28 0c 30 00 01 1f 25 00 00 17 35 36 32 43 46 50 [1.196461 Inits done] secure task start! high task start! low task start! run into bl31 NOTICE: BL31: v1.3(release):4fc40b1 NOTICE: BL31: Built : 15:57:33, May 22 2019 NOTICE: BL31: G12A normal boot! ERROR: Error initializing runtime service opteed_fast U-Boot 2021.07-24139-gdb6738fed92 (Jun 17 2024 - 21:13:15 +0100) radxa-zero Model: Radxa Zero SoC: Amlogic Meson G12A (S905Y2) Revision 28:c (30:2) DRAM: 512 MiB MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2 Loading Environment from nowhere... OK In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. starting USB... Bus usb@ff500000: Register 3000140 NbrPorts 3 Starting the controller USB XHCI 1.10 scanning bus usb@ff500000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Edited June 20, 2024 by technik007_cz 0 Quote
