Odroid C1
sgjava
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Reached target Late Shutdown Services.
[  OK  ] Finished System Reboot.
[  OK  ] Reached target System Reboot.
system hangs after a sudo reboot/sudo systemctl reboot and does not come up without power cycle. I think problem is in dtb and exists since long time.
Link to comment
Share on other sites
@Tomasz Grzegurzkocan you give the command line you used? I'll try now. After git pull I get:
odroidc arm aml_meson odroidc hardkernel m8b hardkernel/odroidc:DDR3_1GB
[ error ] ERROR in function compile_uboot [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:278 -> functions/main/build-tasks.sh:145 -> functions/compilation/uboot.sh:131 -> functions/logging/traps.sh:0 ]
[ error ] U-boot compilation failed
[ o.k. ] Process terminated
Using:
sudo ./compile.sh  BOARD=odroidc1 BRANCH=current RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img
Link to comment
I get same error on u-boot compile, but found a workaround to use prebuilt u-boot:
# u-boot compile breaks for odroidc1, use REPOSITORY_INSTALL=u-boot (but only
# legacy/current no edge! or copy deb to ./build/output/debs/linux-u-boot-edge-odroidc1_23.02.0-trunk_armhf.deb)
mkdir -p ./output/debs
wget -c -O ./output/debs/linux-u-boot-edge-odroidc1_23.02.0-trunk_armhf.deb http://apt.armbian.com/pool/main/l/linux-u-boot-odroidc1-current/linux-u-boot-current-odroidc1_21.02.3_armhf.deb
# without CLEAN_LEVEL= linux-image-*.deb will be deleted and new kernel/deb created
./compile.sh CLEAN_LEVEL= KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=sha,xz EXPERT=yes
Link to comment
@Markus_ Using current and jammy I get:
sudo ./compile.sh BOARD=odroidc1 CLEAN_LEVEL= KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=sha,xz EXPERT=yes REPOSITORY_INSTALL=u-boot
[ .... ] Installing from repository [ linux-u-boot-odroidc1-current ]
And debug install.log:
E: Unable to locate package linux-u-boot-odroidc1-current
Link to comment
OK, I got it to build. The secret is REPOSITORY_INSTALL=
REPOSITORY_INSTALL (comma-separated list): list of core packages which will be installed from repository
  • Available options: u-boot, kernel, bsp, armbian-bsp-cli,armbian-bsp-desktop,armbian-desktop,armbian-config, armbian-firmware
  • Set to “” to use packages one from local output or build if not available
I'll do it from scratch and post final instructions.
Link to comment
Sorry I didn't get notified of the question!
Anyway I didn't use anything fancy, just used the text/console tools to build, no command line options given at build time I entered them in using the TUI.
Have been running the C1 for a long time now, aside from being unable to reboot from command line, other than that it works fine.
Link to comment
