sgjava Posted September 11, 2022 Posted September 11, 2022 Are there any images for the C1? The archive download link is broken. 0 Quote
SteeMan Posted September 11, 2022 Posted September 11, 2022 Here is the link for archived builds for the C1: https://archive.armbian.com/odroidc1/archive/ 0 Quote
sgjava Posted September 11, 2022 Author Posted September 11, 2022 Thanks, I was hoping for a Jammy, I'll have to setup the build env again... 0 Quote
Markus_ Posted September 12, 2022 Posted September 12, 2022 https://forum.armbian.com/topic/13888-odroid-c1-s805/page/2/#comment-145817 0 Quote
sgjava Posted September 12, 2022 Author Posted September 12, 2022 @Markus_So sudo reboot doesn't work? Does sudo systemctl reboot work? 0 Quote
Markus_ Posted September 12, 2022 Posted September 12, 2022 [ OK ] Reached target Unmount All Filesystems. [ OK ] Reached target Late Shutdown Services. [ OK ] Finished System Reboot. [ OK ] Reached target System Reboot. system hangs after a sudo reboot/sudo systemctl reboot and does not come up without power cycle. I think problem is in dtb and exists since long time. 0 Quote
sgjava Posted September 12, 2022 Author Posted September 12, 2022 Yeah, I'm trying to remember. I used the C1 for years. Can you try: sudo systemctl start reboot.target and sudo shutdown -r now They may resolve to reboot command, but worth a try. 0 Quote
Markus_ Posted September 12, 2022 Posted September 12, 2022 no change, I think the reboot problem is based on dtb and can only be solved with an editor and dtc 0 Quote
sgjava Posted September 12, 2022 Author Posted September 12, 2022 Does this work on the archived focal img? Then maybe diff the dtb? I had to hack the Duo dtb, so I could use the builtin button. 0 Quote
Markus_ Posted September 12, 2022 Posted September 12, 2022 problem exist since kernel 5.x for sure, I don't remember if it worked with kernel 3.10 0 Quote
sgjava Posted December 21, 2022 Author Posted December 21, 2022 @Markus_ Just a FYI, the focal image with 5.10 kernel allowed reboot. You can freeze the kernel and upgrade to Jammy that way. Reboot still works. 0 Quote
Tomasz Grzegurzko Posted January 24, 2023 Posted January 24, 2023 Hi, I today managed to build and successfully deploy an Armbian Odroid C1 (previous days there was some compile error in das-u-boot, but a git pull today sorted that). I've had it running for half a day, seems OK so far. So while there are no builds, compilation and deploying of a standard console jammy image seems to work! 0 Quote
sgjava Posted January 24, 2023 Author Posted January 24, 2023 @Tomasz Grzegurzkocan you give the command line you used? I'll try now. After git pull I get: odroidc arm aml_meson odroidc hardkernel m8b hardkernel/odroidc:DDR3_1GB [ error ] ERROR in function compile_uboot [ functions/cli/cli-entrypoint.sh:109 -> functions/main/build-tasks.sh:278 -> functions/main/build-tasks.sh:145 -> functions/compilation/uboot.sh:131 -> functions/logging/traps.sh:0 ] [ error ] U-boot compilation failed [ o.k. ] Process terminated Using: sudo ./compile.sh BOARD=odroidc1 BRANCH=current RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img 0 Quote
Markus_ Posted January 27, 2023 Posted January 27, 2023 I get same error on u-boot compile, but found a workaround to use prebuilt u-boot: # u-boot compile breaks for odroidc1, use REPOSITORY_INSTALL=u-boot (but only # legacy/current no edge! or copy deb to ./build/output/debs/linux-u-boot-edge-odroidc1_23.02.0-trunk_armhf.deb) mkdir -p ./output/debs wget -c -O ./output/debs/linux-u-boot-edge-odroidc1_23.02.0-trunk_armhf.deb http://apt.armbian.com/pool/main/l/linux-u-boot-odroidc1-current/linux-u-boot-current-odroidc1_21.02.3_armhf.deb # without CLEAN_LEVEL= linux-image-*.deb will be deleted and new kernel/deb created ./compile.sh CLEAN_LEVEL= KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=sha,xz EXPERT=yes 0 Quote
sgjava Posted January 28, 2023 Author Posted January 28, 2023 @Markus_ I'll try this tomorrow, thanks! 0 Quote
sgjava Posted January 28, 2023 Author Posted January 28, 2023 @Markus_ Using current and jammy I get: sudo ./compile.sh BOARD=odroidc1 CLEAN_LEVEL= KERNEL_KEEP_CONFIG=yes COMPRESS_OUTPUTIMAGE=sha,xz EXPERT=yes REPOSITORY_INSTALL=u-boot [ .... ] Installing from repository [ linux-u-boot-odroidc1-current ] And debug install.log: E: Unable to locate package linux-u-boot-odroidc1-current 0 Quote
sgjava Posted January 29, 2023 Author Posted January 29, 2023 OK, I got it to build. The secret is REPOSITORY_INSTALL= REPOSITORY_INSTALL (comma-separated list): list of core packages which will be installed from repository Available options: u-boot, kernel, bsp, armbian-bsp-cli,armbian-bsp-desktop,armbian-desktop,armbian-config, armbian-firmware Set to “” to use packages one from local output or build if not available I'll do it from scratch and post final instructions. 0 Quote
sgjava Posted January 29, 2023 Author Posted January 29, 2023 @Markus_ I created a new post that has all the steps 0 Quote
Tomasz Grzegurzko Posted March 29, 2023 Posted March 29, 2023 Sorry I didn't get notified of the question! Anyway I didn't use anything fancy, just used the text/console tools to build, no command line options given at build time I entered them in using the TUI. Have been running the C1 for a long time now, aside from being unable to reboot from command line, other than that it works fine. 0 Quote
sgjava Posted March 29, 2023 Author Posted March 29, 2023 @Tomasz Grzegurzko That's good to hear. I had the same results. 0 Quote
