I've tried multiple time on different cards. Both images, give me the same result. At first I'm able to edit files then after a restart or two I'm no longer able to edit files. Can't even touch a new file as root.
I have tried at least 10 times today with both images. Every time I end up in the same situation unable to edit the sd card.
Patriot and MicroCenter cards are using cheap internal controllers and flash to hit cost low cost. Stick with Tier 1 like SanDisk and Samsung. Even Kington uses crappy flash in some products.
