Posted (edited)
I'm using the firefly-roc-pc board as a base as indicated by @maka
Base image: Armbian_23.08.0-trunk_Station-m2_jammy_edge_6.2.16_xfce_desktop.img
H96 Max RK3566 4gb 32gb
boot from SD-CARD Soldered ✔️
linux regular boot ✖️     it shows initframfs "can be USB bad assign for sd-card"
serial ttl summary:
  Quote
Expand
rk3566-firefly-roc-pc.dts rk3566-firefly-roc-pc.dtb
Edited by hotnikq
Posted (edited)
  On 6/3/2023 at 7:31 AM, maka said:
What if you try with sdcard and usb
Expand
need to patch USB....
no USB ports...
Base image: Armbian_23.08.0-trunk_Station-m2_jammy_edge_6.2.16_xfce_desktop.img ✔️
Detect SD-CARD ✖️
Detect USB ✖️
Need to fix:
  Quote
[    0.000000] efi: UEFI not found.
[    0.068405] DMI not present or invalid.
[    0.746776] iommu: Default domain type: Translated
[    0.746806] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.747553] usbcore: registered new interface driver usbfs
[    0.747616] usbcore: registered new interface driver hub
[    0.747678] usbcore: registered new device driver usb
[    0.748104] pps_core: LinuxPPS API ver. 1 registered
[    0.918178] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    1.106517] ghes_edac: GHES probing device list is empty
[    5.074356] Registered IR keymap rc-cec
Expand
rk3566-firefly-roc-pc.dtb rk3566-firefly-roc-pc.dts
Edited by hotnikq
Posted (edited)
Fixed USB3.0 port
Boot on Linux ✖️
Detect USB 2.0 port ✖️
Full dump:
  Quote
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.2.16-media (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.3                                       😎 #1 SMP PREEMPT_DYNAMIC Wed May 17 08:59:13 -03 2023
[    0.000000] Machine model: Firefly rk3566-roc-pc
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x1ff764100-0x1ff769fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009400000-0x00000000efffffff]
[    0.000000]   node   0: [mem 0x00000001f0000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s83944 r8192 d30744 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=UUID=8bffa7ed-2f1c-40d8-9e74-a674058d0110 console=ttyS02,1500000 console=tty0 rw no_console_suspend consoleblank=0 f                                        sck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3705476K/4175872K available (14784K kernel code, 3392K rwdata, 5100K rodata, 3776K init, 1029K bss, 208252K reserved, 262144K cma-rese                                        rved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] Dynamic Preempt: none
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001669] Console: colour dummy device 80x25
[    0.001693] printk: console [tty0] enabled
[    0.002593] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002637] pid_max: default: 32768 minimum: 301
[    0.002985] LSM: initializing lsm=capability,yama,safesetid,integrity,bpf
[    0.003085] Yama: becoming mindful.
[    0.003182] LSM support for eBPF active
[    0.003419] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003530] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005538] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.006827] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006866] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007041] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007407] rcu: Hierarchical SRCU implementation.
[    0.007432] rcu:     Max phase no-delay instances is 1000.
[    0.014563] EFI services will not be available.
[    0.015332] smp: Bringing up secondary CPUs ...
[    0.017206] Detected VIPT I-cache on CPU1
[    0.017334] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.017359] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.017422] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.019253] Detected VIPT I-cache on CPU2
[    0.019364] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.019387] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.019437] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.021280] Detected VIPT I-cache on CPU3
[    0.021387] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.021411] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.021457] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.021599] smp: Brought up 1 node, 4 CPUs
[    0.021770] SMP: Total of 4 processors activated.
[    0.021790] CPU features: detected: 32-bit EL0 Support
[    0.021806] CPU features: detected: 32-bit EL1 Support
[    0.021823] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.021845] CPU features: detected: Common not Private translations
[    0.021863] CPU features: detected: CRC32 instructions
[    0.021879] CPU features: detected: Data cache clean to Point of Persistence
[    0.021902] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.021919] CPU features: detected: LSE atomic instructions
[    0.021935] CPU features: detected: Privileged Access Never
[    0.021951] CPU features: detected: RAS Extension Support
[    0.021970] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.022111] CPU: All CPU(s) started at EL2
[    0.022135] alternatives: applying system-wide alternatives
[    0.029046] devtmpfs: initialized
[    0.059248] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.059323] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.067579] pinctrl core: initialized pinctrl subsystem
[    0.068597] DMI not present or invalid.
[    0.069611] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.071335] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.072115] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.072582] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.072715] audit: initializing netlink subsys (disabled)
[    0.072992] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[    0.074257] thermal_sys: Registered thermal governor 'fair_share'
[    0.074269] thermal_sys: Registered thermal governor 'bang_bang'
[    0.074296] thermal_sys: Registered thermal governor 'step_wise'
[    0.074315] thermal_sys: Registered thermal governor 'user_space'
[    0.074408] cpuidle: using governor ladder
[    0.074481] cpuidle: using governor menu
[    0.074888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.075097] ASID allocator initialised with 65536 entries
[    0.077174] Serial: AMBA PL011 UART driver
[    0.091356] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.117390] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.118029] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.118508] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.118896] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.119285] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.119658] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.120074] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.120428] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.120890] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.121248] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.122707] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con
[    0.127493] KASLR disabled due to lack of seed
[    0.128883] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.128924] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.128947] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.128966] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.128986] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.129005] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.129026] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.129044] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.197766] raid6: neonx8   gen()  1420 MB/s
[    0.265935] raid6: neonx4   gen()  1452 MB/s
[    0.334096] raid6: neonx2   gen()  1339 MB/s
[    0.402286] raid6: neonx1   gen()  1091 MB/s
[    0.470451] raid6: int64x8  gen()   910 MB/s
[    0.538613] raid6: int64x4  gen()  1049 MB/s
[    0.606759] raid6: int64x2  gen()   937 MB/s
[    0.674970] raid6: int64x1  gen()   673 MB/s
[    0.674993] raid6: using algorithm neonx4 gen() 1452 MB/s
[    0.743046] raid6: .... xor() 1097 MB/s, rmw enabled
[    0.743072] raid6: using neon recovery algorithm
[    0.744105] fbcon: Taking over console
[    0.744193] ACPI: Interpreter disabled.
[    0.747347] iommu: Default domain type: Translated
[    0.747377] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.748193] usbcore: registered new interface driver usbfs
[    0.748257] usbcore: registered new interface driver hub
[    0.748320] usbcore: registered new device driver usb
[    0.748729] pps_core: LinuxPPS API ver. 1 registered
[    0.748755] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.748798] PTP clock support registered
[    0.749286] EDAC MC: Ver: 3.0.0
[    0.749965] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.750190] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.750280] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.752229] NetLabel: Initializing
[    0.752259] NetLabel:  domain hash size = 128
[    0.752277] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.752387] NetLabel:  unlabeled traffic allowed by default
[    0.752662] vgaarb: loaded
[    0.753355] clocksource: Switched to clocksource arch_sys_counter
[    0.754132] VFS: Disk quotas dquot_6.6.0
[    0.754231] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.754697] pnp: PnP ACPI: disabled
[    0.769286] NET: Registered PF_INET protocol family
[    0.769768] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.774259] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.774370] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.774415] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.774708] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.775864] TCP: Hash tables configured (established 32768 bind 32768)
[    0.776356] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.776550] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.776680] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.777085] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.777155] NET: Registered PF_XDP protocol family
[    0.777192] PCI: CLS 0 bytes, default 64
[    0.778013] Trying to unpack rootfs image as initramfs...
[    0.800547] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.801615] kvm [1]: IPA Size Limit: 40 bits
[    0.801673] kvm [1]: GICv3: no GICV resource entry
[    0.801696] kvm [1]: disabling GICv2 emulation
[    0.801737] kvm [1]: GIC system register CPU interface enabled
[    0.802155] kvm [1]: vgic interrupt IRQ9
[    0.802869] kvm [1]: VHE mode initialized successfully
[    0.805311] Initialise system trusted keyrings
[    0.805790] workingset: timestamp_bits=39 max_order=20 bucket_order=0
[    0.805955] zbud: loaded
[    0.807418] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.807509] fuse: init (API version 7.38)
[    0.861289] xor: measuring software checksum speed
[    0.867119]    8regs           :  1721 MB/sec
[    0.873432]    32regs          :  1576 MB/sec
[    0.879306]    arm64_neon      :  1690 MB/sec
[    0.879335] xor: using function: 8regs (1721 MB/sec)
[    0.879377] Key type asymmetric registered
[    0.879400] Asymmetric key parser 'x509' registered
[    0.879585] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.879969] io scheduler mq-deadline registered
[    0.880123] io scheduler bfq registered
[    0.895800] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    0.902069] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    0.907101] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 23, base_baud = 1500000) is a 16550A
[    0.908567] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 24, base_baud = 1500000) is a 16550A
[    0.908900] printk: console [ttyS2] enabled
[    1.027502] Serial: AMBA driver
[    1.031328] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.045701] brd: module loaded
[    1.056652] loop: module loaded
[    1.062435] thunder_xcv, ver 1.0
[    1.062805] thunder_bgx, ver 1.0
[    1.063140] nicpf, ver 1.0
[    1.065202] usbcore: registered new interface driver usbserial_generic
[    1.065873] usbserial: USB Serial support registered for generic
[    1.066464] usbcore: registered new interface driver ch341
[    1.067019] usbserial: USB Serial support registered for ch341-uart
[    1.067625] usbcore: registered new interface driver cp210x
[    1.068158] usbserial: USB Serial support registered for cp210x
[    1.068725] usbcore: registered new interface driver ftdi_sio
[    1.069274] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.069988] usbcore: registered new interface driver pl2303
[    1.070525] usbserial: USB Serial support registered for pl2303
[    1.071889] mousedev: PS/2 mouse device common for all mice
[    1.074937] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    1.084505] ghes_edac: GHES probing device list is empty
[    1.086779] ledtrig-cpu: registered to indicate activity on CPUs
[    1.088820] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    1.089532] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.094993] NET: Registered PF_INET6 protocol family
[    2.804104] Freeing initrd memory: 32564K
[    2.861003] Segment Routing with IPv6
[    2.861543] In-situ OAM (IOAM) with IPv6
[    2.873215] registered taskstats version 1
[    2.873883] Loading compiled-in X.509 certificates
[    2.878259] zswap: loaded using pool zstd/z3fold
[    2.892343] Key type .fscrypt registered
[    2.892741] Key type fscrypt-provisioning registered
[    2.895130] Btrfs loaded, crc32c=crc32c-generic, assert=on, integrity-checker=on, zoned=yes, fsverity=yes
[    2.923235] Key type encrypted registered
[    2.923694] ima: No TPM chip found, activating TPM-bypass!
[    2.924210] ima: Allocated hash algorithm: sha1
[    2.924673] ima: No architecture policies found
[    2.925198] evm: Initialising EVM extended attributes:
[    2.925715] evm: security.selinux
[    2.926030] evm: security.SMACK64
[    2.926339] evm: security.SMACK64EXEC
[    2.926675] evm: security.SMACK64TRANSMUTE
[    2.927049] evm: security.SMACK64MMAP
[    2.927385] evm: security.apparmor
[    2.927699] evm: security.ima
[    2.927975] evm: security.capability
[    2.928302] evm: HMAC attrs: 0x1
[    2.981537] rk808 0-0020: chip id: 0x8090
[    3.058822] rk808-regulator rk808-regulator.1.auto: there is no dvs0 gpio
[    3.059493] rk808-regulator rk808-regulator.1.auto: there is no dvs1 gpio
[    3.060115] rk808-regulator rk808-regulator.1.auto: max buck steps per change: 8
[    3.122100] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.123675] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.124329] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4e).
[    3.124851] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2c).
[    3.125422] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.126057] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.131631] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.132541] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.133202] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    3.133708] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.134389] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.135066] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.135702] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.136363] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.136870] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.137616] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.138270] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.138818] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    3.293005] psci_checker: PSCI checker started using 4 CPUs
[    3.293581] psci_checker: Starting hotplug tests
[    3.294015] psci_checker: Trying to turn off and on again all CPUs
[    3.295388] psci: CPU0 killed (polled 0 ms)
[    3.299558] psci: CPU1 killed (polled 0 ms)
[    3.303258] psci: CPU2 killed (polled 0 ms)
I/TC: Secondary CPU 0 initializing
I/TC: Secondary CPU 0 switching to normal world boot
[    3.307196] Detected VIPT I-cache on CPU0
[    3.307654] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.308215] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.308908] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.312360] Detected VIPT I-cache on CPU1
[    3.312866] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.313431] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.314137] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.317701] Detected VIPT I-cache on CPU2
[    3.318207] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.318773] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.319476] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.321751] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    3.322904] psci: CPU0 killed (polled 0 ms)
[    3.326640] psci: CPU1 killed (polled 0 ms)
[    3.329013] psci: CPU2 killed (polled 0 ms)
[    3.332593] Detected VIPT I-cache on CPU0
[    3.333054] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.333615] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.334308] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.337570] Detected VIPT I-cache on CPU1
[    3.338073] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.338635] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.339341] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.343008] Detected VIPT I-cache on CPU2
[    3.343511] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.344079] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.344787] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.347051] psci_checker: Hotplug tests passed OK
[    3.347496] psci_checker: Starting suspend tests (10 cycles per state)
[    3.348150] psci_checker: cpuidle not available on CPU 0, ignoring
[    3.348715] psci_checker: cpuidle not available on CPU 1, ignoring
[    3.349273] psci_checker: cpuidle not available on CPU 2, ignoring
[    3.349927] psci_checker: cpuidle not available on CPU 3, ignoring
[    3.350493] psci_checker: Could not start suspend tests on any CPU
[    3.351050] psci_checker: PSCI checker completed
[    3.355820] Freeing unused kernel memory: 3776K
[    3.365570] Run /init as init process
[    4.478772] rk808-rtc rk808-rtc.3.auto: registered as rtc0
[    4.483411] rk808-rtc rk808-rtc.3.auto: setting system clock to 2017-08-05T09:00:10 UTC (1501923610)
[    4.523597] panfrost fde60000.gpu: clock rate = 594000000
[    4.524176] panfrost fde60000.gpu: bus_clock rate = 500000000
[    4.540832] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    4.541658] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    4.542432] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    4.543509] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    4.555185] rockchip-vop2 fe040000.vop: Adding to iommu group 2
[    4.555833] iommu: Failed to allocate default IOMMU domain of type 11 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    4.568138] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    4.573484] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.580046] Synopsys Designware Multimedia Card Interface Driver
[    4.592511] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.593251] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.593997] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.594136] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.594362] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.594434] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.594448] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.594520] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    4.594547] dma-pl330 fe530000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.594588] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[    4.597219] sdhci: Secure Digital Host Controller Interface driver
[    4.600124] sdhci: Copyright(c) Pierre Ossman
[    4.601308] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.602100] dma-pl330 fe550000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.604374] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.604490] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.607991] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.609596] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.612638] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.618271] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.625724] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.626443] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.627065] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.627608] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[    4.637665] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.639383] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.640134] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.640758] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.641313] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[    4.647301] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.648041] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.648662] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.649224] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[    4.678725] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.679441] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.680052] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.680604] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[    4.683368] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.683935] mmc_host mmc2: card is non-removable.
[    4.685414] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.701098] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.735427] mmc1: new HS200 MMC card at address 0001
[    4.816228] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.822553] mmc2: new high speed SDIO card at address 0001
[    4.883145] Console: switching to colour frame buffer device 240x67
[    4.987553] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    5.064058] Registered IR keymap rc-cec
[    5.064905] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    5.066174] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    5.101058] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    5.102022] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1
[    5.103359] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    5.104824] xhci-hcd xhci-hcd.9.auto: irq 70, io mem 0xfd000000
[    5.106040] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    5.106893] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 2
[    5.108017] xhci-hcd xhci-hcd.9.auto: Host supports USB 3.0 SuperSpeed
[    5.111554] hub 1-0:1.0: USB hub found
[    5.112256] hub 1-0:1.0: 1 port detected
[    5.113869] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.117921] mmcblk1: mmc1:0001 032G00 29.1 GiB
[    5.117929] hub 2-0:1.0: USB hub found
[    5.118026] hub 2-0:1.0: 1 port detected
[    5.128739]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[    5.136985] mmcblk1boot0: mmc1:0001 032G00 8.00 MiB
[    5.143699] mmcblk1boot1: mmc1:0001 032G00 8.00 MiB
[    5.148170] mmcblk1rpmb: mmc1:0001 032G00 4.00 MiB, chardev (240:0)
[    5.369392] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[    5.563453] hid: raw HID events driver (C) Jiri Kosina
[    5.576323] usbcore: registered new interface driver usbhid
[    5.576965] usbhid: USB HID core driver
[    5.590164] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/fd000000.usb/xhci-hcd.9.auto/usb1/1-1/1-1:1.0/0003:17EF:6099.0001/input/inp                                        ut1
[    5.649815] hid-generic 0003:17EF:6099.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.9.auto-1/input                                        0
Expand
Edited by hotnikq
I'm understanding why this image is falling in Initramfs
On my last build kernel4.19 i use to boot into the internal MMC
  Quote
    chosen {
        bootargs = "earlycon=uart8250,mmio32,0xfe660000 swiotlb=8192 mem=4096M console=ttyFIQ0 root=PARTUUID=614e0000-0000-4b53-8000-1d28000054a9 rw rootwait";
        phandle = <0x000001d7>;
Expand
Now the Armbian_23.08.0-trunk_Station-m2_jammy_edge_6.2.16_xfce_desktop.img
trying to tank with
  Quote
    chosen {
        stdout-path = "serial2:1500000n8";
//////////////    serial2 = "/serial@fe660000"; it's fine! same console that we used to.
////////////      so we need to set rootfs by UUID
Expand
and the kernel 6 read an internal value for console from file
  Quote
append: root=UUID=8bffa7ed-2f1c-40d8-9e74-a674058d0110 console=ttyS02,1500000
Expand
Posted (edited)
If you like what you see here and want to help: Donate Armbian the like button only costs a few dollars.
Armbian Needs you help!
####################### WHAT IS  THIS? #######################
This is an SD-card image!
to use it in an SD-Card You will need do solder an SD-card Reader.
check before if your device has the regulator: fan53555
check before if your device has: tcs4525
check before if your device has: RK809-5
works with 4gb and 8gb  devices
####################### HOW TO BUILD IT! #######################
https://docs.armbian.com/Developer-Guide_Build-Preparation/
Runtime [ 6:05 min ]
[] Repeat Build Options
./compile.sh build BOARD=h96-tvbox-3566 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers desktop_tools editors internet multimedia office programming remote_desktop' DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=noble
####################### HOW TO USE IT #######################
using the T95 Method
flash the Wipe_part on Boot partition
flash the Wipe_part on Recovery partition
Connect the power cord...
wait 1 second
and in a fraction of second, connect the sd-Card on device.....
if it doesn't boot, try again in a different timming 2 seconds after power.
####################### SOLDERED READER EXAMPLE #######################
#######################WHAT IS  THIS? #######################
Base image: Armbian-unofficial_25.02.0-trunk_H96-tvbox-3566_noble_current_6.12.11_cinnamon_desktop.img  ✔️
H96 Max RK3566 4gb and 8gb ✔️
runs kernel 6.2 DESKTOP ✔️
Boot on Linux  XFCE Ambian✔️
display video HDMi ✔️
detect internal MMC ✔️
Detect SD-CARD ✔️
Detect USB 2.0 port  ✔️
Detect USB 3.0 port ✔️
####################### HOW PUT IT ON MMC #######################
 you can use it to make a v0.7 ROOT image.
how?
  On 6/8/2023 at 10:16 PM, hotnikq said:
any resemblance to this topic is mere adaptation
Mount that image virtual device like /media/armbian_boot
fdisk -l your-armbian-image-for-sd-card.img
mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot
if you can't "like WSL2"
sudo apt-get install kpartx
sudo kpartx -av your-armbian-image-for-sd-card.img
sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot
Second Step:  prepare an sd card or usb flash dummy , can be anithing with 6gb
fdisk /dev/mmcblk1
N
default
default (lower this value to match the size of your root image)
T
1
W
third step: format that flash drive for ext4
mkfs.ext4 /dev/mmcblk1p1
fourth step: mount that clear partition and copy the entire virtual drive to the flash device
mount /dev/mmcblk1p1 /mnt
rsync -avx /media/armbian_boot/ /mnt
fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1"
blkid
nano -w /mnt/boot/extlinux/extlinux.conf
sixth step: make an hardware RAW.img from hardware flash drive with these parameters
sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress
PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1
now you have an ROOT IMAGE MADE BY YOURSELF!
./mkupdate.sh
Uboot Legacy, Parameter.txt to create the Rockchip image
Expand
Edited by Hqnicolas
Posted (edited)
what needs to be done?
need to put an sd card image inside the internal mmc
because originally this board does not have SD card reader
the only way i know of to do this
is the old and fashion @thc013 method for FIT images....
instead of building the entire kernel on it,
we just do a comand
./build.sh updateimg
This comand will create a rockchip image with the android files that you extrated previously
or the linux 4.19 that we compile in 2022....
all files need to be inside " /rockdev " folder
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x28b,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x701c0,userspace=0xe1
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x71800,size=0x1f4,userspace=0x1
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x72000,size=0x400000,userspace=0x800
Add file: ./Image/misc.img
Add file: ./Image/misc.img done,offset=0x472000,size=0xc000,userspace=0x18
Add file: ./Image/boot.img
  On 11/10/2022 at 5:40 PM, hotnikq said:
BUILD CUSTOM SDK - shaggy013 - 02-14-2022
Made this bsp/sdk because the beta wich is on the site don't makes a image wich you can flash and boot from sd/emmc
and while mainline is cool a working bsp/sdk makes it more complete for me
I looked how raxda and firefly made their bsp/sdk and made a custom one for the Quartz64
used some scripts of them and adjusted so they work to build a image
Most sources are from rockchip and the just 2 or 3 comes from other sources (from firefly: rawimg script, qsetting and camera_engine_rkaiq package)
So i tried to keep it some kind rockchip original and those packages were not on the rockhcip site or other open places so if it is a problem i can remove them
Expand
  Quote
*** ADDED ***
Added buildconfigs for other pine boards with a rk356x  PineNote ,Quartz64-b and Soquartz
!!! DTS files not included only added a pinenote dts the soquartz and quartz64-b are just quartz64-a dts !!
so if you got a dts for dowmstream kernel bards you can add them
so instead of
quartz64-rk3566-buildroot-k4.mk
 you do
quartz64b-rk3566-buildroot-k4.mk        For building a Quartz64-B image
or
pinenote-rk3566-buildroot-k4.mk         For Building a Pinenote image
or
soquartz-rk3566-buildroot-k4.mk         For building a Soquartz image
and same for
quartz64-rk3566-raw-k4.mk
quartz64b-rk3566-raw-k4.mk        For building a Quartz64-B  SD-image
or
pinenote-rk3566-raw-k4.mk         For Building a Pinenote SD-image
or
soquartz-rk3566-raw-k4.mk         For building a Soquartz SD-image
*Needed*
Time
Ubuntu 18.04 or 20.04
at least 200+GB of free space (yeah it likes to grow maybey more)
*Building*
#Packages Needed on pc
sudo apt-get install repo git ssh make gcc libssl-dev liblz4-tool \
expect g++ patchelf chrpath gawk texinfo chrpath diffstat binfmt-support \
qemu-user-static live-build bison flex fakeroot cmake gcc-multilib g++-multilib \
unzip device-tree-compiler python-pip ncurses-dev python-pyelftools
*Download BSP*
#make bsp/sdk folder
mkdir Quartz64
#go to Quartz64 folder
cd Quartz64
# make .repo folder
mkdir .repo
#go to .repo folder
cd .repo
#download repo
git clone https://github.com/rockchip-linux/repo
or
git clone https://gerrit.googlesource.com/git-repo repo
#make repo executable
chmod a+rx repo/repo
#go back
cd ..
# Download repo manifest
.repo/repo/repo init -u https://github.com/Shaggy013/manifests -b master -m rk356x_linux_custom_v1.2.8_20220309.xml
# Dowload bsp/sdk
.repo/repo/repo sync --no-clone-bundle
***** trouble ****
if it gives trouble about github account
https://elinux.org/Buildroot_how_to_contribute
configure section
**** only by trouble ****
Now you see that your Quartz64 folder is full with new folders and files
your Download is finished
*Building*
There are 4 distros you can build Buildroot,Debian,Ubuntu and Yocto
You can choose to make the distro against the 4.19 or 5.10 kernel
First you choose wich kernel
#for 4.19
./build.sh quartz64-rk3566-buildroot-k4.mk
#or 5.10
./build.sh quartz64-rk3566-buildroot-k5.mk
For the first time you have to do it twice the first time can give a error
you see something like this
***** example ****
processing option: quartz64-rk3566-buildroot-k4.mk
link kernel to proper kernel-directory
renew kernel to proper kernel-directory
link kernel 4
link Debian to proper Debian-distro
renew Debian to proper Debian-Distro
link debian to bullseye or buster
link kernel 4
switching to board: /home/thc013/corner/Quartz64-release/device/rockchip/rk356x/quartz64-rk3566-buildroot-k4.mk
****** example ****
so now you bsp is set to the right options
You have multiple options but you have to make a uboot,kernel and recovery and a rootfs so the best start is just as a base for the later buiding of distros
# build all (uboot,kernel,recovery,rootfs"buildroot",rockchip image) / AKA BUILDROOT
./build.sh
**Info**
For the 4.19 kernel you get after a few minutes a blue screen where you have to give the right voltage for the io-domains
watch carefull some domains are not asked
the domain info comes from the schematic or the dts file
pmuio1-supply = <&vcc3v3_pmu>; not asked
pmuio2-supply = <&vcc_3v3>;
vccio1-supply = <&vccio_acodec>; 3,3
vccio2-supply = <&vcc_1v8>; not asked
vccio3-supply = <&vccio_sd>; 3,3
vccio4-supply = <&vcca1v8_pmu>;
vccio5-supply = <&vcc_3v3>;
vccio6-supply = <&vcc1v8_dvp>;
vccio7-supply = <&vcc_3v3>;
After that the buildroot will start the rest of the building
Depening on the speed of your pc it takes from a hour to ?
so after some coffee and some heat for the cold weather you get
Now it build a rockhip image DO NOT FLASH TO SD !!!!!!!!
Make buildroot image ok!
..../Quartz64/rockdev/pack/QUARTZ64-RK3566-BUILDROOT-K4-GPT-!DATE!-2137.img
Now it builds a rockhip image DO NOT FLASH TO SD !!!!!!!!
#change to the SD/EMMC IMAGE option
.#for 4.19
./build.sh quartz64-rk3566-raw-k4.mk
#or 5.10
./build.sh quartz64-rk3566-raw-k5.mk
#Build image
./build.sh rawimg
***Info ***
Make raw image ok!
..../Quartz64/rockdev/pack/QUARTZ64-RK3566-RAW-K4-GPT-!DATE!-2137.img
Now you can flash that image RAW to a sd or EMMC with your desired tool Etcher,dd etc
Now you can build a Debian or a Yocto image
**** DEBIAN ******
#for 4.19
#or 5.10
before building you have to install extra packages they differ from ubuntu and debian so you have to install or overwrite them first
sudo apt-get install binfmt-support qemu-user-static
sudo dpkg -i ubuntu-build-service/packages/*
sudo apt-get install -f
# build Debian rootfs
./build.sh debian
.#for 4.19
#or 5.10
#Build image
./build.sh rawimg
***Info ***
Make raw image ok!
Same as rest /Quartz64/rockdev/pack/
**** Ubuntu ******
#for 4.19
#or 5.10
# build Ubuntu rootfs
./build.sh ubuntu
*** This build option ask after a few minutes the keyboard and region settings ****
.#for 4.19
#or 5.10
#Build image
./build.sh rawimg
***Info ***
Make raw image ok!
***** YOCTO *****
!!! Yocto can take a time to build the toolchain has also clang etc included !!!
#for 4.19
#or 5.10
./build.sh yocto
.#for 4.19
#or 5.10
#Build image
./build.sh rawimg
***Info ***
Make raw image ok!
***** BUILD OPTIONS ****
Available options:
*.mk              -switch to specified board config
launch              -list current SDK boards and switch to specified board config
uboot              -build uboot
spl                -build spl
loader            -build loader
kernel            -build kernel"
modules            -build kernel modules
modules2          -build kernel modules to rockdev/pack/modules *added*
toolchain          -build toolchain
extboot            -build extlinux boot.img, boot from EFI partition
rootfs            -build default rootfs, currently build buildroot as default
buildroot          -build buildroot rootfs
ramboot            -build ramboot image
multi-npu_boot    -build boot image for multi-npu board
yocto              -build yocto rootfs
debian            -build debian 9 or 10 rootfs !! set in config !! !! only bullseye included
ubuntu            -build Ubuntu 20.04 rootfs !! set in config !! !! only focal included
pcba              -build pcba not tested
recovery          -build recovery
all                -build uboot, kernel, rootfs, recovery image
cleanall          -clean uboot, kernel, rootfs, recovery
firmware          -pack all the image we need to boot up system
updateimg          -pack update image not tested
rawimg            -pack raw image
otapackage        -pack ab update otapackage image (update_ota.img) not tested
sdpackage          -pack update sdcard package image (update_sdcard.img) not tested
save              -save images, patches, commands used to debug
allsave            -build all & firmware & updateimg & save
check              -check the environment of building
info              -see the current board building information
app/<pkg>          -build packages in the dir of app/*
external/<pkg>    -build packages in the dir of external/*
**** Examples ****
For if you made changes to uboot or the kernel
buildroot is another story
#u-boot
./build.sh uboot
#kernel
./build.sh kernel
#recovery
./build.sh recovery
***** Making modules from the kernel ****
it can be that you want to copy or have some kernel modules to copy to your image
./build.sh modules2
makes in the folder rockdev/pack/modules the kernel-modules
****** TESTS ******
the distros all contain a folder rockchip test with some simple demos and test even a benchmark
cd ~/rockchip_test
# some test options
./rockhip_test.sh
The npu video and gpu are most fun
ddr test :                  1 (memtester & stressapptest)
cpufreq test:              2 (cpufreq stresstest)
????flash stress test:          3
# not working # bluetooth test:      4 (bluetooth on&off test)
# not working # audio test:          5
recovery test:              6 (default wipe all)
suspend_resume test:        7 (suspend & resume)
wifi test:                  8
ethernet test:              9
auto reboot test:          10
ddr freq scaling test       11
#not working # npu test              12
npu2 test                  13 (rk356x or rk3588)
??? camera test                14 (use rkisp_demo)
video test                  15 (use gstreamer-wayland and app_demo)
gpu test                            16 (use glmark2)
# not working# chromium test          17 (chromium with video hardware acceleration)"
nand power lost test:       18
************ Last Info ******
That is almost step for step i hope
it just started with a dts and boardconfig but got a little bigger
if i made any faults or i missed something please let me know
no debug program just plain doing diff,reading(there is a lot),copy paste and some simple adjustments to make it work for me
well it was something diffrent as making a custom limo os for the limo M1 360 from vodafone in 2009 (got first to root cdc_nand) gone glory
the sources and info you can all find them on google and github and gitlab
so no OFFICIAL ROCKCHIP or QUARTZ64 JUST !!CUSTOM!!
I will include download links with the images it compiles
and to make it work for another 3566 or 68 just make a boardconfig.mk in ?/Quartz64/device/rockchip/rk356x/
and make sure the defconfigs and dts are inthe right places
well at least it gets you on the way
SPECIAL THNX TO quartz64 chat , my free time ,a quartz64 too stay still alive ,ryzen 3700x+5700xt to keep me warm,20TB nas for the space,R.I.P sd (2),touchscreen,monitor and OPI4 (well the opi semi dead dont fuss with the fusb32 in uboot )
Expand
Edited by hotnikq
Posted (edited)
how to DUMP from mmcblk1
Device         Start      End  Sectors  Size Type
/dev/mmcblk1p1  8192    16383     8192    4M unknown
/dev/mmcblk1p2 16384    24575     8192    4M unknown
/dev/mmcblk1p3 24576    32767     8192    4M unknown
/dev/mmcblk1p4 32768 61071326 61038559 29.1G EFI System
install the android original image on MMC
and connect the ssd on soldered reader With armbian h96max v0.5
sudo dd if=/dev/mmcblk1 of=~/sd-card-copy.img bs=1M status=progress
Your SD-card need to be 64gb to dump 32gb mmc
Edited by hotnikq
  On 6/7/2023 at 6:26 PM, Kenneth Hidalgo said:
Hello everyone, I already have an image working on my h96max v56, it is Debian-based, the only problem is that the rootfs partition is only 6gb, who can help me to leave it with more space?
Expand
### Partition " / " resized to FULL DISK ###
$ df -h
 sudo resize2fs /dev/mmcblk1p4
$ df -h
Posted (edited)
Linux version 4.19.193
(qmx_srv@qmxsrv-MS-7C09)
(gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05),
GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #24 SMP Thu Mar 2 10:16:53 CST 2023
Machine model: Rockchip RK3566 EVB3 DDR3 V10 Board
can't unpack the image on windows....
can't unpack the image on linux...
sha256......
let's try DD it to an SD card on device
MMC struct
  Quote
root@linaro-alip:/home/linaro# lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0 29.1G  0 disk
├─mmcblk0p1  179:1    0    4M  0 part
├─mmcblk0p2  179:2    0    4M  0 part
├─mmcblk0p3  179:3    0   32M  0 part
├─mmcblk0p4  179:4    0   64M  0 part
├─mmcblk0p5  179:5    0   32M  0 part
├─mmcblk0p6  179:6    0    6G  0 part /
├─mmcblk0p7  179:7    0  128M  0 part /media/linaro/a8682f9f-1928-4693-bd5c-a4f9
└─mmcblk0p8  179:8    0 22.9G  0 part /media/linaro/2c3bc23e-7aba-4a79-8509-244a
mmcblk0boot0 179:32   0    8M  1 disk
mmcblk0boot1 179:64   0    8M  1 disk
Expand
BLKid:
  Quote
/dev/mmcblk0p1: LABEL="armbi_root" UUID="daab97c2-c37f-4766-8eae-441c355546e1" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="48e7f43e-9370-4040-b954-c8a43cffc3a0"
/dev/mmcblk1p15: UUID="d29b6245-7c54-498b-b07c-8686b886009e" BLOCK_SIZE="4096" TYPE="f2fs" PARTLABEL="userdata" PARTUUID="754e0000-0000-4f48-8000-5a1c000009e7"
/dev/mmcblk1p11: UUID="777a36b9-d924-4eb8-94b3-759f24280d06" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="metadata" PARTUUID="da290000-0000-4278-8000-68480000488f"
/dev/mmcblk1p10: UUID="e8a0c1a4-14b4-49da-9e84-230873bf67ef" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="cache" PARTUUID="61460000-0000-4f31-8000-0d0d000060e7"
/dev/zram0: UUID="e39079db-ee82-4d87-9ddc-d1dbe32f1e6d" TYPE="swap"
/dev/zram1: LABEL="log2ram" UUID="5e88c00c-a999-4cfa-9c6c-e6ae4aecd4f5" BLOCK_SIZE="4096" TYPE="ext4"
/dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="cc2e0000-0000-4f45-8000-462600000896"
/dev/mmcblk1p13: PARTLABEL="logo" PARTUUID="a64b0000-0000-4530-8000-140c00000954"
/dev/mmcblk1p1: PARTLABEL="security" PARTUUID="51720000-0000-402f-8000-591a00000d1e"
/dev/mmcblk1p8: PARTLABEL="recovery" PARTUUID="633a0000-0000-4f05-8000-2202000023a1"
/dev/mmcblk1p6: PARTLABEL="vbmeta" PARTUUID="c7070000-0000-4626-8000-12a100001e8b"
/dev/mmcblk1p4: PARTLABEL="misc" PARTUUID="4f1b0000-0000-457e-8000-04ac00007464"
/dev/mmcblk1p14: PARTLABEL="super" PARTUUID="89760000-0000-450e-8000-262700004300"
/dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="ba210000-0000-4b35-8000-5be2000003ec"
/dev/mmcblk1p12: PARTLABEL="baseparameter" PARTUUID="037e0000-0000-4701-8000-70040000769c"
/dev/mmcblk1p9: PARTLABEL="backup" PARTUUID="d2350000-0000-4669-8000-588e0000465a"
/dev/mmcblk1p7: PARTLABEL="boot" PARTUUID="4d7c0000-0000-420b-8000-2aa000004574"
/dev/mmcblk1p5: PARTLABEL="dtbo" PARTUUID="0b4b0000-0000-4527-8000-623d0000459e"
armbian@station-m2:~$
Expand
Let's try dtbview.exe "from Renate Teamblast"
C:\>dtbview dtbo.img > big.txt
Result DTB:
  Quote
000000  Header
000048  / {
000050     version = < 0x0 >;
000060     totalsize = < 0x30a4a00 >;
000070     timestamp = < 0x64182c44 >;
000080     description = "U-Boot FIT source file for arm";
0000ac     images {
0000b8        fdt {
0000c0           data-size = < 0x1e4af >;
0000d0           data-position = < 0x800 >;
0000e0           type = "flat_dt";
0000f4           arch = "arm64";
000108           compression = "none";
00011c           load = < 0xffffff00 >;
00012c           hash {
000138              value = < 0x7d0a9eea 0x7126526a 0x3863e266 0x2c9221d0 0x15a74dc4 0x48441685 0x81a72d42 0x1e7c9f31 >;
000164              algo = "sha256";
000178           }
00017c        }
000180        kernel {
00018c           data-size = < 0x15ba008 >;
00019c           data-position = < 0x1ee00 >;
0001ac           type = "kernel";
0001c0           arch = "arm64";
0001d4           os = "linux";
0001e8           compression = "none";
0001fc           entry = < 0xffffff01 >;
00020c           load = < 0xffffff01 >;
00021c           hash {
000228              value = < 0x12d957b2 0x6e72c7e3 0xab747dc2 0xa52433b0 0xeb4e5a71 0xfeb69df7 0x2db12149 0x8da267bd >;
000254              algo = "sha256";
000268           }
00026c        }
000270        ramdisk {
00027c           data-size = < 0x1aa3a98 >;
00028c           data-position = < 0x15d9000 >;
00029c           type = "ramdisk";
0002b0           arch = "arm64";
0002c4           os = "linux";
0002d8           compression = "none";
0002ec           load = < 0xffffff02 >;
0002fc           hash {
000308              value = < 0x3a626b27 0x8b6d2c15 0x5261fd8a 0x12f1c8a8 0xcda058d1 0x46349a96 0x8e74db97 0x7b3ac061 >;
000334              algo = "sha256";
000348           }
00034c        }
000350        resource {
000360           data-size = < 0x27a00 >;
000370           data-position = < 0x307cc00 >;
000380           type = "multi";
000394           arch = "arm64";
0003a8           compression = "none";
0003bc           hash {
0003c8              value = < 0xc108aa5e 0x41833d11 0xdacb6f54 0x4ed356e9 0x43864117 0x2b22935e 0xdd1b191c 0xed537e79 >;
0003f4              algo = "sha256";
000408           }
00040c        }
000410     }
000414     configurations {
000428        default = "conf";
00043c        conf {
000448           rollback-index = < 0x0 >;
000458           fdt = "fdt";
000468           kernel = "kernel";
00047c           ramdisk = "ramdisk";
000490           multi = "resource";
0004a8           signature {
0004b8              algo = "sha256,rsa2048";
0004d4              padding = "pss";
0004e4              key-name-hint = "dev";
0004f4              sign-images = "fdt\0kernel\0ramdisk\0multi";
00051c           }
000520        }
000524     }
000528  }
00052c  End
000530  Strings
000800  Header
000838  / {
000840     compatible = "rockchip,rk3566-evb3-DDR3-v10\0rockchip,rk3566";
00087c     interrupt-parent = < 0x1 >;
00088c     #address-cells = < 0x2 >;
00089c     #size-cells = < 0x2 >;
0008ac     model = "Rockchip RK3566 EVB3 DDR3 V10 Board";
0008dc     ddr_timing {
0008ec        compatible = "rockchip,ddr-timing";
00090c        ddr2_speed_bin = < 0x0 >;
00091c        ddr3_speed_bin = < 0x15 >;
00092c        ddr4_speed_bin = < 0xc >;
00093c        pd_idle = < 0xd >;
00094c        sr_idle = < 0x5d >;
00095c        sr_mc_gate_idle = < 0x0 >;
00096c        srpd_lite_idle = < 0x0 >;
00097c        standby_idle = < 0x0 >;
00098c        auto_pd_dis_freq = < 0x42a >;
00099c        auto_sr_dis_freq = < 0x320 >;
0009ac        ddr2_dll_dis_freq = < 0x12c >;
0009bc        ddr3_dll_dis_freq = < 0x12c >;
0009cc        ddr4_dll_dis_freq = < 0x271 >;
0009dc        phy_dll_dis_freq = < 0x190 >;
0009ec        ddr2_odt_dis_freq = < 0x64 >;
0009fc        phy_ddr2_odt_dis_freq = < 0x64 >;
000a0c        ddr2_drv = < 0x2 >;
000a1c        ddr2_odt = < 0x40 >;
000a2c        phy_ddr2_ca_drv = < 0x0 >;
000a3c        phy_ddr2_ck_drv = < 0x0 >;
000a4c        phy_ddr2_dq_drv = < 0x0 >;
000a5c        phy_ddr2_odt = < 0x0 >;
000a6c        ddr3_odt_dis_freq = < 0x14d >;
000a7c        phy_ddr3_odt_dis_freq = < 0x14d >;
000a8c        ddr3_drv = < 0x2 >;
000a9c        ddr3_odt = < 0x40 >;
000aac        phy_ddr3_ca_drv = < 0x0 >;
000abc        phy_ddr3_ck_drv = < 0x0 >;
000acc        phy_ddr3_dq_drv = < 0x0 >;
000adc        phy_ddr3_odt = < 0x0 >;
000aec        phy_lpddr2_odt_dis_freq = < 0x14d >;
000afc        lpddr2_drv = < 0x2 >;
000b0c        phy_lpddr2_ca_drv = < 0x0 >;
000b1c        phy_lpddr2_ck_drv = < 0x0 >;
000b2c        phy_lpddr2_dq_drv = < 0x0 >;
000b3c        phy_lpddr2_odt = < 0x0 >;
000b4c        lpddr3_odt_dis_freq = < 0x14d >;
000b5c        phy_lpddr3_odt_dis_freq = < 0x14d >;
000b6c        lpddr3_drv = < 0x1 >;
000b7c        lpddr3_odt = < 0x2 >;
000b8c        phy_lpddr3_ca_drv = < 0x0 >;
000b9c        phy_lpddr3_ck_drv = < 0x0 >;
000bac        phy_lpddr3_dq_drv = < 0x0 >;
000bbc        phy_lpddr3_odt = < 0x0 >;
000bcc        lpddr4_odt_dis_freq = < 0x14d >;
000bdc        phy_lpddr4_odt_dis_freq = < 0x14d >;
000bec        lpddr4_drv = < 0x30 >;
000bfc        lpddr4_dq_odt = < 0x1 >;
000c0c        lpddr4_ca_odt = < 0x0 >;
000c1c        phy_lpddr4_ca_drv = < 0x0 >;
000c2c        phy_lpddr4_ck_cs_drv = < 0x0 >;
000c3c        phy_lpddr4_dq_drv = < 0x0 >;
000c4c        phy_lpddr4_odt = < 0x0 >;
000c5c        ddr4_odt_dis_freq = < 0x271 >;
000c6c        phy_ddr4_odt_dis_freq = < 0x271 >;
000c7c        ddr4_drv = < 0x0 >;
000c8c        ddr4_odt = < 0x200 >;
000c9c        phy_ddr4_ca_drv = < 0x0 >;
000cac        phy_ddr4_ck_drv = < 0x0 >;
000cbc        phy_ddr4_dq_drv = < 0x0 >;
000ccc        phy_ddr4_odt = < 0x0 >;
000cdc        phandle = < 0xa6 >;
000cec     }
000cf0     aliases {
000cfc        csi2dphy0 = "/csi2-dphy0";
000d14        csi2dphy1 = "/csi2-dphy1";
000d2c        csi2dphy2 = "/csi2-dphy2";
000d44        dsi0 = "/dsi@fe060000";
000d60        dsi1 = "/dsi@fe070000";
000d7c        ethernet1 = "/ethernet@fe010000";
000d9c        gpio0 = "/pinctrl/gpio@fdd60000";
000dc0        gpio1 = "/pinctrl/gpio@fe740000";
000de4        gpio2 = "/pinctrl/gpio@fe750000";
000e08        gpio3 = "/pinctrl/gpio@fe760000";
000e2c        gpio4 = "/pinctrl/gpio@fe770000";
000e50        i2c0 = "/i2c@fdd40000";
000e6c        i2c1 = "/i2c@fe5a0000";
000e88        i2c2 = "/i2c@fe5b0000";
000ea4        i2c3 = "/i2c@fe5c0000";
000ec0        i2c4 = "/i2c@fe5d0000";
000edc        i2c5 = "/i2c@fe5e0000";
000ef8        mmc0 = "/sdhci@fe310000";
000f14        mmc1 = "/dwmmc@fe2b0000";
000f30        mmc2 = "/dwmmc@fe2c0000";
000f4c        mmc3 = "/dwmmc@fe000000";
000f68        serial0 = "/serial@fdd50000";
000f88        serial1 = "/serial@fe650000";
000fa8        serial2 = "/serial@fe660000";
000fc8        serial3 = "/serial@fe670000";
000fe8        serial4 = "/serial@fe680000";
001008        serial5 = "/serial@fe690000";
001028        serial6 = "/serial@fe6a0000";
001048        serial7 = "/serial@fe6b0000";
001068        serial8 = "/serial@fe6c0000";
001088        serial9 = "/serial@fe6d0000";
0010a8        spi0 = "/spi@fe610000";
0010c4        spi1 = "/spi@fe620000";
0010e0        spi2 = "/spi@fe630000";
0010fc        spi3 = "/spi@fe640000";
001118     }
00111c     cpus {
001128        #address-cells = < 0x2 >;
001138        #size-cells = < 0x0 >;
001148        cpu@0 {
001154           device_type = "cpu";
001164           compatible = "arm,cortex-a55";
001180           reg = < 0x0 0x0 >;
001194           enable-method = "psci";
0011a8           clocks = < 0x2 0x0 >;
0011bc           operating-points-v2 = < 0x3 >;
0011cc           cpu-idle-states = < 0x4 >;
0011dc           #cooling-cells = < 0x2 >;
0011ec           dynamic-power-coefficient = < 0xbb >;
0011fc           cpu-supply = < 0x5 >;
00120c           phandle = < 0x9 >;
00121c           power-model {
00122c              compatible = "simple-power-model";
00124c              leakage-range = < 0xa 0x28 >;
001260              ls = < 0xffffdc14 0x18d8 0x0 >;
001278              static-coefficient = < 0x186a0 >;
001288              ts = < 0x1476e 0x3263d 0xffffef34 0x47 >;
0012a4              thermal-zone = "soc-thermal";
0012bc           }
0012c0        }
0012c4        cpu@100 {
0012d0           device_type = "cpu";
0012e0           compatible = "arm,cortex-a55";
0012fc           reg = < 0x0 0x100 >;
001310           enable-method = "psci";
001324           clocks = < 0x2 0x0 >;
001338           operating-points-v2 = < 0x3 >;
001348           cpu-idle-states = < 0x4 >;
001358           phandle = < 0xa >;
001368        }
00136c        cpu@200 {
001378           device_type = "cpu";
001388           compatible = "arm,cortex-a55";
0013a4           reg = < 0x0 0x200 >;
0013b8           enable-method = "psci";
0013cc           clocks = < 0x2 0x0 >;
0013e0           operating-points-v2 = < 0x3 >;
0013f0           cpu-idle-states = < 0x4 >;
001400           phandle = < 0xb >;
001410        }
001414        cpu@300 {
001420           device_type = "cpu";
001430           compatible = "arm,cortex-a55";
00144c           reg = < 0x0 0x300 >;
001460           enable-method = "psci";
001474           clocks = < 0x2 0x0 >;
001488           operating-points-v2 = < 0x3 >;
001498           cpu-idle-states = < 0x4 >;
0014a8           phandle = < 0xc >;
0014b8        }
0014bc        idle-states {
0014cc           entry-method = "psci";
0014e0           cpu-sleep {
0014f0              compatible = "arm,idle-state";
00150c              local-timer-stop;
001518              arm,psci-suspend-param = < 0x10000 >;
001528              entry-latency-us = < 0x64 >;
001538              exit-latency-us = < 0x78 >;
001548              min-residency-us = < 0x3e8 >;
001558              phandle = < 0x4 >;
001568           }
00156c        }
001570     }
001574     cpu0-opp-table {
001588        compatible = "operating-points-v2";
0015a8        opp-shared;
0015b4        mbist-vmin = < 0xc96a8 0xdbba0 0xe7ef0 >;
0015cc        nvmem-cells = < 0x6 0x7 0x8 >;
0015e4        nvmem-cell-names = "leakage\0pvtm\0mbist-vmin";
001608        rockchip,pvtm-voltage-sel = < 0x0 0x14050 0x0 0x14051 0x16b48 0x1 0x16b49 0x186a0 0x2 >;
001638        rockchip,pvtm-freq = < 0x639c0 >;
001648        rockchip,pvtm-volt = < 0xdbba0 >;
001658        rockchip,pvtm-ch = < 0x0 0x5 >;
00166c        rockchip,pvtm-sample-time = < 0x3e8 >;
00167c        rockchip,pvtm-number = < 0xa >;
00168c        rockchip,pvtm-error = < 0x3e8 >;
00169c        rockchip,pvtm-ref-temp = < 0x28 >;
0016ac        rockchip,pvtm-temp-prop = < 0x1a 0x1a >;
0016c0        rockchip,thermal-zone = "soc-thermal";
0016d8        rockchip,temp-hysteresis = < 0x1388 >;
0016e8        rockchip,low-temp = < 0x0 >;
0016f8        rockchip,low-temp-adjust-volt = < 0x0 0x648 0x124f8 >;
001710        phandle = < 0x3 >;
001720        opp-408000000 {
001734           opp-hz = < 0x0 0x18519600 >;
001748           opp-microvolt = < 0xc96a8 0xc96a8 0x118c30 >;
001760           clock-latency-ns = < 0x9c40 >;
001770        }
001774        opp-600000000 {
001788           opp-hz = < 0x0 0x23c34600 >;
00179c           opp-microvolt = < 0xc96a8 0xc96a8 0x118c30 >;
0017b4           clock-latency-ns = < 0x9c40 >;
0017c4        }
0017c8        opp-816000000 {
0017dc           opp-hz = < 0x0 0x30a32c00 >;
0017f0           opp-microvolt = < 0xc96a8 0xc96a8 0x118c30 >;
001808           clock-latency-ns = < 0x9c40 >;
001818           opp-suspend;
001824        }
001828        opp-1104000000 {
00183c           opp-hz = < 0x0 0x41cdb400 >;
001850           opp-microvolt = < 0xc96a8 0xc96a8 0x118c30 >;
001868           clock-latency-ns = < 0x9c40 >;
001878        }
00187c        opp-1416000000 {
001890           opp-hz = < 0x0 0x54667200 >;
0018a4           opp-microvolt = < 0xe1d48 0xe1d48 0x118c30 >;
0018bc           clock-latency-ns = < 0x9c40 >;
0018cc        }
0018d0        opp-1608000000 {
0018e4           opp-hz = < 0x0 0x5fd82200 >;
0018f8           opp-microvolt = < 0xf4240 0xf4240 0x118c30 >;
001910           clock-latency-ns = < 0x9c40 >;
001920        }
001924        opp-1800000000 {
001938           opp-hz = < 0x0 0x6b49d200 >;
00194c           opp-microvolt = < 0x100590 0x100590 0x118c30 >;
001964           clock-latency-ns = < 0x9c40 >;
001974        }
001978     }
00197c     arm-pmu {
001988        compatible = "arm,cortex-a55-pmu\0arm,armv8-pmuv3";
0019b8        interrupts = < 0x0 0xe4 0x4 0x0 0xe5 0x4 0x0 0xe6 0x4 0x0 0xe7 0x4 >;
0019f4        interrupt-affinity = < 0x9 0xa 0xb 0xc >;
001a10     }
001a14     cpuinfo {
001a20        compatible = "rockchip,cpuinfo";
001a40        nvmem-cells = < 0xd 0xe 0xf >;
001a58        nvmem-cell-names = "id\0cpu-version\0cpu-code";
001a7c     }
001a80     display-subsystem {
001a98        compatible = "rockchip,display-subsystem";
001ac0        memory-region = < 0x10 0x11 >;
001ad4        memory-region-names = "drm-logo\0drm-cubic-lut";
001af8        ports = < 0x12 >;
001b08        devfreq = < 0x13 >;
001b18        phandle = < 0x132 >;
001b28        route {
001b34           route-dsi0 {
001b44              status = "okay";
001b58              logo,uboot = "logo.bmp";
001b70              logo,kernel = "logo_kernel.bmp";
001b8c              logo,mode = "center";
001ba0              charge_logo,mode = "center";
001bb4              connect = < 0x14 >;
001bc4              phandle = < 0x133 >;
001bd4           }
001bd8           route-dsi1 {
001be8              status = "disabled";
001c00              logo,uboot = "logo.bmp";
001c18              logo,kernel = "logo_kernel.bmp";
001c34              logo,mode = "center";
001c48              charge_logo,mode = "center";
001c5c              connect = < 0x15 >;
001c6c              phandle = < 0x134 >;
001c7c           }
001c80           route-edp {
001c90              status = "disabled";
001ca8              logo,uboot = "logo.bmp";
001cc0              logo,kernel = "logo_kernel.bmp";
001cdc              logo,mode = "center";
001cf0              charge_logo,mode = "center";
001d04              connect = < 0x16 >;
001d14              phandle = < 0x135 >;
001d24           }
001d28           route-hdmi {
001d38              status = "okay";
001d4c              logo,uboot = "logo.bmp";
001d64              logo,kernel = "logo_kernel.bmp";
001d80              logo,mode = "center";
001d94              charge_logo,mode = "center";
001da8              connect = < 0x17 >;
001db8              phandle = < 0x136 >;
001dc8           }
001dcc           route-lvds {
001ddc              status = "disabled";
001df4              logo,uboot = "logo.bmp";
001e0c              logo,kernel = "logo_kernel.bmp";
001e28              logo,mode = "center";
001e3c              charge_logo,mode = "center";
001e50              connect = < 0x18 >;
001e60              phandle = < 0x137 >;
001e70           }
001e74           route-rgb {
001e84              status = "disabled";
001e9c              logo,uboot = "logo.bmp";
001eb4              logo,kernel = "logo_kernel.bmp";
001ed0              logo,mode = "center";
001ee4              charge_logo,mode = "center";
001ef8              connect = < 0x19 >;
001f08              phandle = < 0x138 >;
001f18           }
001f1c        }
001f20     }
001f24     firmware {
001f34        optee {
001f40           compatible = "linaro,optee-tz";
001f5c           method = "smc";
001f6c           phandle = < 0x139 >;
001f7c        }
001f80        scmi {
001f8c           compatible = "arm,scmi-smc";
001fa8           shmem = < 0x1a >;
001fb8           arm,smc-id = < 0x82000010 >;
001fc8           #address-cells = < 0x1 >;
001fd8           #size-cells = < 0x0 >;
001fe8           phandle = < 0x13a >;
001ff8           protocol@14 {
002008              reg = < 0x14 >;
002018              #clock-cells = < 0x1 >;
002028              rockchip,clk-init = "Tfr";
002038              phandle = < 0x2 >;
002048           }
00204c        }
002050        sdei {
00205c           compatible = "arm,sdei-1.0";
002078           method = "smc";
002088           phandle = < 0x13b >;
002098        }
00209c     }
0020a0     mpp-srv {
0020ac        compatible = "rockchip,mpp-service";
0020d0        rockchip,taskqueue-count = < 0x6 >;
0020e0        rockchip,resetgroup-count = < 0x6 >;
0020f0        status = "okay";
002104        phandle = < 0x66 >;
002114     }
002118     psci {
002124        compatible = "arm,psci-1.0";
002140        method = "smc";
002150     }
002154     reserved-memory {
002168        #address-cells = < 0x2 >;
002178        #size-cells = < 0x2 >;
002188        ranges;
002194        phandle = < 0x13c >;
0021a4        drm-logo@00000000 {
0021bc           compatible = "rockchip,drm-logo";
0021dc           reg = < 0x0 0x0 0x0 0x0 >;
0021f8           phandle = < 0x10 >;
002208        }
00220c        drm-cubic-lut@00000000 {
002228           compatible = "rockchip,drm-cubic-lut";
00224c           reg = < 0x0 0x0 0x0 0x0 >;
002268           phandle = < 0x11 >;
002278        }
00227c        ramoops@110000 {
002290           compatible = "ramoops";
0022a4           reg = < 0x0 0x110000 0x0 0xf0000 >;
0022c0           record-size = < 0x20000 >;
0022d0           console-size = < 0x80000 >;
0022e0           ftrace-size = < 0x0 >;
0022f0           pmsg-size = < 0x50000 >;
002300           phandle = < 0x13d >;
002310        }
002314     }
002318     rockchip-suspend {
002330        compatible = "rockchip,pm-rk3568";
002350        status = "okay";
002364        rockchip,sleep-debug-en = < 0x1 >;
002374        rockchip,sleep-mode-config = < 0x5ec >;
002384        rockchip,wakeup-config = < 0x10 >;
002394        phandle = < 0x13e >;
0023a4     }
0023a8     rockchip-system-monitor {
0023c4        compatible = "rockchip,system-monitor";
0023e8        rockchip,thermal-zone = "soc-thermal";
002400        phandle = < 0x13f >;
002410     }
002414     thermal-zones {
002428        phandle = < 0x140 >;
002438        soc-thermal {
002448           polling-delay-passive = < 0x14 >;
002458           polling-delay = < 0x3e8 >;
002468           sustainable-power = < 0x5c3 >;
002478           thermal-sensors = < 0x1b 0x0 >;
00248c           phandle = < 0x141 >;
00249c           trips {
0024a8              trip-point-0 {
0024bc                 temperature = < 0x11170 >;
0024cc                 hysteresis = < 0x7d0 >;
0024dc                 type = "passive";
0024f0                 phandle = < 0x142 >;
002500              }
002504              trip-point-1 {
002518                 temperature = < 0x14c08 >;
002528                 hysteresis = < 0x7d0 >;
002538                 type = "passive";
00254c                 phandle = < 0x1c >;
00255c              }
002560              soc-crit {
002570                 temperature = < 0x1c138 >;
002580                 hysteresis = < 0x7d0 >;
002590                 type = "critical";
0025a8                 phandle = < 0x143 >;
0025b8              }
0025bc           }
0025c0           cooling-maps {
0025d4              map0 {
0025e0                 trip = < 0x1c >;
0025f0                 cooling-device = < 0x9 0xffffffff 0xffffffff >;
002608                 contribution = < 0x400 >;
002618              }
00261c              map1 {
002628                 trip = < 0x1c >;
002638                 cooling-device = < 0x1d 0xffffffff 0xffffffff >;
002650                 contribution = < 0x400 >;
002660              }
002664           }
002668        }
00266c        gpu-thermal {
00267c           polling-delay-passive = < 0x14 >;
00268c           polling-delay = < 0x3e8 >;
00269c           thermal-sensors = < 0x1b 0x1 >;
0026b0           phandle = < 0x144 >;
0026c0        }
0026c4     }
0026c8     timer {
0026d4        compatible = "arm,armv8-timer";
0026f0        interrupts = < 0x1 0xd 0xf04 0x1 0xe 0xf04 0x1 0xb 0xf04 0x1 0xa 0xf04 >;
00272c        arm,no-tick-in-suspend;
002738     }
00273c     external-gmac1-clock {
002758        compatible = "fixed-clock";
002770        clock-frequency = < 0x7735940 >;
002780        clock-output-names = "gmac1_clkin";
002798        #clock-cells = < 0x0 >;
0027a8        phandle = < 0x145 >;
0027b8     }
0027bc     xpcs-gmac1-clock {
0027d4        compatible = "fixed-clock";
0027ec        clock-frequency = < 0x7735940 >;
0027fc        clock-output-names = "clk_gmac1_xpcs_mii";
00281c        #clock-cells = < 0x0 >;
00282c        phandle = < 0x146 >;
00283c     }
002840     i2s1-mclkin-rx {
002854        compatible = "fixed-clock";
00286c        #clock-cells = < 0x0 >;
00287c        clock-frequency = < 0xbb8000 >;
00288c        clock-output-names = "i2s1_mclkin_rx";
0028a8        phandle = < 0x147 >;
0028b8     }
0028bc     i2s1-mclkin-tx {
0028d0        compatible = "fixed-clock";
0028e8        #clock-cells = < 0x0 >;
0028f8        clock-frequency = < 0xbb8000 >;
002908        clock-output-names = "i2s1_mclkin_tx";
002924        phandle = < 0x148 >;
002934     }
002938     i2s2-mclkin {
002948        compatible = "fixed-clock";
002960        #clock-cells = < 0x0 >;
002970        clock-frequency = < 0xbb8000 >;
002980        clock-output-names = "i2s2_mclkin";
002998        phandle = < 0x149 >;
0029a8     }
0029ac     i2s3-mclkin {
0029bc        compatible = "fixed-clock";
0029d4        #clock-cells = < 0x0 >;
0029e4        clock-frequency = < 0xbb8000 >;
0029f4        clock-output-names = "i2s3_mclkin";
002a0c        phandle = < 0x14a >;
002a1c     }
002a20     mpll {
002a2c        compatible = "fixed-clock";
002a44        #clock-cells = < 0x0 >;
002a54        clock-frequency = < 0x2faf0800 >;
002a64        clock-output-names = "mpll";
002a78        phandle = < 0x14b >;
002a88     }
002a8c     xin24m {
002a98        compatible = "fixed-clock";
002ab0        #clock-cells = < 0x0 >;
002ac0        clock-frequency = < 0x16e3600 >;
002ad0        clock-output-names = "xin24m";
002ae4        phandle = < 0x14c >;
002af4     }
002af8     xin32k {
002b04        compatible = "fixed-clock";
002b1c        clock-frequency = < 0x8000 >;
002b2c        clock-output-names = "xin32k";
002b40        #clock-cells = < 0x0 >;
002b50        pinctrl-names = "default";
002b64        pinctrl-0 = < 0x1e >;
002b74        phandle = < 0x14d >;
002b84     }
002b88     scmi-shmem@10f000 {
002ba0        compatible = "arm,scmi-shmem";
002bbc        reg = < 0x0 0x10f000 0x0 0x100 >;
002bd8        phandle = < 0x1a >;
002be8     }
002bec     sata@fc400000 {
002c00        compatible = "snps,dwc-ahci";
002c1c        reg = < 0x0 0xfc400000 0x0 0x1000 >;
002c38        clocks = < 0x1f 0x9b 0x1f 0x9c 0x1f 0x9d >;
002c5c        clock-names = "sata\0pmalive\0rxoob";
002c7c        interrupts = < 0x0 0x5f 0x4 >;
002c94        interrupt-names = "hostc";
002ca8        phys = < 0x20 0x1 >;
002cbc        phy-names = "sata-phy";
002cd4        ports-implemented = < 0x1 >;
002ce4        power-domains = < 0x21 0xf >;
002cf8        status = "disabled";
002d10        phandle = < 0x14e >;
002d20     }
002d24     sata@fc800000 {
002d38        compatible = "snps,dwc-ahci";
002d54        reg = < 0x0 0xfc800000 0x0 0x1000 >;
002d70        clocks = < 0x1f 0xa0 0x1f 0xa1 0x1f 0xa2 >;
002d94        clock-names = "sata\0pmalive\0rxoob";
002db4        interrupts = < 0x0 0x60 0x4 >;
002dcc        interrupt-names = "hostc";
002de0        phys = < 0x22 0x1 >;
002df4        phy-names = "sata-phy";
002e0c        ports-implemented = < 0x1 >;
002e1c        power-domains = < 0x21 0xf >;
002e30        status = "disabled";
002e48        phandle = < 0x14f >;
002e58     }
002e5c     usbdrd {
002e68        compatible = "rockchip,rk3568-dwc3\0rockchip,rk3399-dwc3";
002ea0        clocks = < 0x1f 0xa6 0x1f 0xa7 0x1f 0xa5 0x1f 0x7f >;
002ecc        clock-names = "ref_clk\0suspend_clk\0bus_clk\0pipe_clk";
002f00        #address-cells = < 0x2 >;
002f10        #size-cells = < 0x2 >;
002f20        ranges;
002f2c        status = "okay";
002f40        phandle = < 0x150 >;
002f50        dwc3@fcc00000 {
002f64           compatible = "snps,dwc3";
002f7c           reg = < 0x0 0xfcc00000 0x0 0x400000 >;
002f98           interrupts = < 0x0 0xa9 0x4 >;
002fb0           dr_mode = "host";
002fc4           phys = < 0x23 >;
002fd4           phy-names = "usb2-phy";
002fec           phy_type = "utmi_wide";
003004           power-domains = < 0x21 0xf >;
003018           resets = < 0x1f 0x94 >;
00302c           reset-names = "usb3-otg";
003044           snps,dis_enblslpm_quirk;
003050           snps,dis-u2-freeclk-exists-quirk;
00305c           snps,dis-del-phy-power-chg-quirk;
003068           snps,dis-tx-ipgap-linecheck-quirk;
003074           snps,dis_rxdet_inp3_quirk;
003080           snps,xhci-trb-ent-quirk;
00308c           status = "okay";
0030a0           extcon = < 0x24 >;
0030b0           maximum-speed = "high-speed";
0030c8           snps,dis_u2_susphy_quirk;
0030d4           phandle = < 0x151 >;
0030e4        }
0030e8     }
0030ec     usbhost {
0030f8        compatible = "rockchip,rk3568-dwc3\0rockchip,rk3399-dwc3";
003130        clocks = < 0x1f 0xa9 0x1f 0xaa 0x1f 0xa8 0x1f 0x7f >;
00315c        clock-names = "ref_clk\0suspend_clk\0bus_clk\0pipe_clk";
003190        #address-cells = < 0x2 >;
0031a0        #size-cells = < 0x2 >;
0031b0        ranges;
0031bc        status = "okay";
0031d0        phandle = < 0x152 >;
0031e0        dwc3@fd000000 {
0031f4           compatible = "snps,dwc3";
00320c           reg = < 0x0 0xfd000000 0x0 0x400000 >;
003228           interrupts = < 0x0 0xaa 0x4 >;
003240           dr_mode = "host";
003254           phys = < 0x25 0x20 0x4 >;
00326c           phy-names = "usb2-phy\0usb3-phy";
00328c           phy_type = "utmi_wide";
0032a4           power-domains = < 0x21 0xf >;
0032b8           resets = < 0x1f 0x95 >;
0032cc           reset-names = "usb3-host";
0032e4           snps,dis_enblslpm_quirk;
0032f0           snps,dis-u2-freeclk-exists-quirk;
0032fc           snps,dis-del-phy-power-chg-quirk;
003308           snps,dis-tx-ipgap-linecheck-quirk;
003314           snps,dis_rxdet_inp3_quirk;
003320           snps,xhci-trb-ent-quirk;
00332c           status = "okay";
003340           phandle = < 0x153 >;
003350        }
003354     }
003358     interrupt-controller@fd400000 {
00337c        compatible = "arm,gic-v3";
003394        #interrupt-cells = < 0x3 >;
0033a4        #address-cells = < 0x2 >;
0033b4        #size-cells = < 0x2 >;
0033c4        ranges;
0033d0        interrupt-controller;
0033dc        reg = < 0x0 0xfd400000 0x0 0x10000 0x0 0xfd460000 0x0 0xc0000 >;
003408        interrupts = < 0x1 0x9 0x4 >;
003420        phandle = < 0x1 >;
003430        interrupt-controller@fd440000 {
003454           compatible = "arm,gic-v3-its";
003470           msi-controller;
00347c           #msi-cells = < 0x1 >;
00348c           reg = < 0x0 0xfd440000 0x0 0x20000 >;
0034a8           phandle = < 0xa9 >;
0034b8        }
0034bc     }
0034c0     usb@fd800000 {
0034d4        compatible = "generic-ehci";
0034f0        reg = < 0x0 0xfd800000 0x0 0x40000 >;
00350c        interrupts = < 0x0 0x82 0x4 >;
003524        clocks = < 0x1f 0xbd 0x1f 0xbe 0x1f 0xbc 0x26 >;
00354c        clock-names = "usbhost\0arbiter\0pclk\0utmi";
003574        phys = < 0x27 >;
003584        phy-names = "usb2-phy";
00359c        status = "disabled";
0035b4        phandle = < 0x154 >;
0035c4     }
0035c8     usb@fd840000 {
0035dc        compatible = "generic-ohci";
0035f8        reg = < 0x0 0xfd840000 0x0 0x40000 >;
003614        interrupts = < 0x0 0x83 0x4 >;
00362c        clocks = < 0x1f 0xbd 0x1f 0xbe 0x1f 0xbc 0x26 >;
003654        clock-names = "usbhost\0arbiter\0pclk\0utmi";
00367c        phys = < 0x27 >;
00368c        phy-names = "usb2-phy";
0036a4        status = "disabled";
0036bc        phandle = < 0x155 >;
0036cc     }
0036d0     usb@fd880000 {
0036e4        compatible = "generic-ehci";
003700        reg = < 0x0 0xfd880000 0x0 0x40000 >;
00371c        interrupts = < 0x0 0x85 0x4 >;
003734        clocks = < 0x1f 0xbf 0x1f 0xc0 0x1f 0xbc 0x26 >;
00375c        clock-names = "usbhost\0arbiter\0pclk\0utmi";
003784        phys = < 0x28 >;
003794        phy-names = "usb2-phy";
0037ac        status = "disabled";
0037c4        phandle = < 0x156 >;
0037d4     }
0037d8     usb@fd8c0000 {
0037ec        compatible = "generic-ohci";
003808        reg = < 0x0 0xfd8c0000 0x0 0x40000 >;
003824        interrupts = < 0x0 0x86 0x4 >;
00383c        clocks = < 0x1f 0xbf 0x1f 0xc0 0x1f 0xbc 0x26 >;
003864        clock-names = "usbhost\0arbiter\0pclk\0utmi";
00388c        phys = < 0x28 >;
00389c        phy-names = "usb2-phy";
0038b4        status = "disabled";
0038cc        phandle = < 0x157 >;
0038dc     }
0038e0     syscon@fda00000 {
0038f4        compatible = "rockchip,rk3568-xpcs\0syscon";
00391c        reg = < 0x0 0xfda00000 0x0 0x200000 >;
003938        status = "disabled";
003950        phandle = < 0x158 >;
003960     }
003964     syscon@fdc20000 {
003978        compatible = "rockchip,rk3568-pmugrf\0syscon\0simple-mfd";
0039b0        reg = < 0x0 0xfdc20000 0x0 0x10000 >;
0039cc        phandle = < 0x33 >;
0039dc        io-domains {
0039ec           compatible = "rockchip,rk3568-pmu-io-voltage-domain";
003a20           status = "okay";
003a34           pmuio2-supply = < 0x29 >;
003a44           vccio1-supply = < 0x2a >;
003a54           vccio3-supply = < 0x2b >;
003a64           vccio4-supply = < 0x2c >;
003a74           vccio5-supply = < 0x2d >;
003a84           vccio6-supply = < 0x2c >;
003a94           vccio7-supply = < 0x2d >;
003aa4           pmuio1-supply = < 0x29 >;
003ab4           phandle = < 0x159 >;
003ac4        }
003ac8        reboot-mode {
003ad8           compatible = "syscon-reboot-mode";
003af8           offset = < 0x200 >;
003b08           mode-bootloader = < 0x5242c301 >;
003b18           mode-charge = < 0x5242c30b >;
003b28           mode-fastboot = < 0x5242c309 >;
003b38           mode-loader = < 0x5242c301 >;
003b48           mode-normal = < 0x5242c300 >;
003b58           mode-recovery = < 0x5242c303 >;
003b68           mode-ums = < 0x5242c30c >;
003b78           mode-panic = < 0x5242c307 >;
003b88           mode-watchdog = < 0x5242c308 >;
003b98           phandle = < 0x15a >;
003ba8        }
003bac     }
003bb0     syscon@fdc50000 {
003bc4        compatible = "rockchip,rk3568-pipegrf\0syscon";
003bf0        reg = < 0x0 0xfdc50000 0x0 0x1000 >;
003c0c        phandle = < 0x102 >;
003c1c     }
003c20     syscon@fdc60000 {
003c34        compatible = "rockchip,rk3568-grf\0syscon\0simple-mfd";
003c68        reg = < 0x0 0xfdc60000 0x0 0x10000 >;
003c84        phandle = < 0x32 >;
003c94        io-domains {
003ca4           compatible = "rockchip,rk3568-io-voltage-domain";
003cd4           status = "disabled";
003cec           phandle = < 0x15b >;
003cfc        }
003d00        lvds {
003d0c           compatible = "rockchip,rk3568-lvds";
003d30           phys = < 0x2e >;
003d40           phy-names = "phy";
003d50           status = "disabled";
003d68           phandle = < 0x15c >;
003d78           ports {
003d84              #address-cells = < 0x1 >;
003d94              #size-cells = < 0x0 >;
003da4              port@0 {
003db0                 reg = < 0x0 >;
003dc0                 #address-cells = < 0x1 >;
003dd0                 #size-cells = < 0x0 >;
003de0                 endpoint@1 {
003df0                    reg = < 0x1 >;
003e00                    remote-endpoint = < 0x18 >;
003e10                    status = "disabled";
003e28                    phandle = < 0x8a >;
003e38                 }
003e3c                 endpoint@2 {
003e4c                    reg = < 0x2 >;
003e5c                    remote-endpoint = < 0x2f >;
003e6c                    status = "disabled";
003e84                    phandle = < 0x8b >;
003e94                 }
003e98              }
003e9c           }
003ea0        }
003ea4        rgb {
003eac           compatible = "rockchip,rk3568-rgb";
003ecc           pinctrl-names = "default";
003ee0           pinctrl-0 = < 0x30 >;
003ef0           status = "disabled";
003f08           phandle = < 0x15d >;
003f18           ports {
003f24              #address-cells = < 0x1 >;
003f34              #size-cells = < 0x0 >;
003f44              port@0 {
003f50                 reg = < 0x0 >;
003f60                 #address-cells = < 0x1 >;
003f70                 #size-cells = < 0x0 >;
003f80                 endpoint@2 {
003f90                    reg = < 0x2 >;
003fa0                    remote-endpoint = < 0x19 >;
003fb0                    status = "disabled";
003fc8                    phandle = < 0x8c >;
003fd8                 }
003fdc              }
003fe0           }
003fe4        }
003fe8     }
003fec     syscon@fdc70000 {
004000        compatible = "rockchip,pipe-phy-grf\0syscon";
00402c        reg = < 0x0 0xfdc70000 0x0 0x1000 >;
004048        phandle = < 0x15e >;
004058     }
00405c     syscon@fdc80000 {
004070        compatible = "rockchip,pipe-phy-grf\0syscon";
00409c        reg = < 0x0 0xfdc80000 0x0 0x1000 >;
0040b8        phandle = < 0x103 >;
0040c8     }
0040cc     syscon@fdc90000 {
0040e0        compatible = "rockchip,pipe-phy-grf\0syscon";
00410c        reg = < 0x0 0xfdc90000 0x0 0x1000 >;
004128        phandle = < 0x104 >;
004138     }
00413c     syscon@fdca0000 {
004150        compatible = "rockchip,rk3568-usb2phy-grf\0syscon";
004180        reg = < 0x0 0xfdca0000 0x0 0x8000 >;
00419c        phandle = < 0x109 >;
0041ac     }
0041b0     syscon@fdca8000 {
0041c4        compatible = "rockchip,rk3568-usb2phy-grf\0syscon";
0041f4        reg = < 0x0 0xfdca8000 0x0 0x8000 >;
004210        phandle = < 0x10c >;
004220     }
004224     edp-phy@fdcb0000 {
00423c        compatible = "rockchip,rk3568-edp-phy";
004260        reg = < 0x0 0xfdcb0000 0x0 0x8000 >;
00427c        clocks = < 0x31 0x29 0x1f 0x192 >;
004298        clock-names = "refclk\0pclk";
0042b0        resets = < 0x1f 0x1d6 >;
0042c4        reset-names = "apb";
0042d4        #phy-cells = < 0x0 >;
0042e4        status = "okay";
0042f8        phandle = < 0xa2 >;
004308     }
00430c     sram@fdcc0000 {
004320        compatible = "mmio-sram";
004338        reg = < 0x0 0xfdcc0000 0x0 0xb000 >;
004354        #address-cells = < 0x1 >;
004364        #size-cells = < 0x1 >;
004374        ranges = < 0x0 0x0 0xfdcc0000 0xb000 >;
004390        phandle = < 0x15f >;
0043a0        rkvdec-sram@0 {
0043b4           reg = < 0x0 0xb000 >;
0043c8           phandle = < 0x6e >;
0043d8        }
0043dc     }
0043e0     clock-controller@fdd00000 {
004400        compatible = "rockchip,rk3568-pmucru";
004424        reg = < 0x0 0xfdd00000 0x0 0x1000 >;
004440        rockchip,grf = < 0x32 >;
004450        rockchip,pmugrf = < 0x33 >;
004460        #clock-cells = < 0x1 >;
004470        #reset-cells = < 0x1 >;
004480        assigned-clocks = < 0x31 0x32 >;
004494        assigned-clock-parents = < 0x31 0x5 >;
0044a8        phandle = < 0x31 >;
0044b8     }
0044bc     clock-controller@fdd20000 {
0044dc        compatible = "rockchip,rk3568-cru";
0044fc        reg = < 0x0 0xfdd20000 0x0 0x1000 >;
004518        rockchip,grf = < 0x32 >;
004528        #clock-cells = < 0x1 >;
004538        #reset-cells = < 0x1 >;
004548        assigned-clocks = < 0x31 0x5 0x1f 0x106 0x1f 0x10b 0x31 0x1 0x31 0x2b 0x1f 0x3 0x1f 0x19b 0x1f 0x9 0x1f 0x19c 0x1f 0x19d 0x1f 0x1a1 0x1f 0x19e 0x1f 0x19f 0x1f 0x1a0 0x1f 0x4 0x1f 0x10d 0x1f 0x10e 0x1f 0x173 0x1f 0x174 0x1f 0x175 0x1f 0x176 0x1f 0xc9 0x1f 0xca 0x1f 0x6 0x1f 0x7e 0x1f 0x7f 0x1f 0x3d 0x1f 0x41 0x1f 0x45 0x1f 0x49 0x1f 0x4d 0x1f 0x4d 0x1f 0x55 0x1f 0x51 0x1f 0x5d 0x1f 0xdd >;
004674        assigned-clock-rates = < 0x8000 0x11e1a300 0x11e1a300 0xbebc200 0x5f5e100 0x3b9aca00 0x1dcd6500 0x13d92d40 0xee6b280 0x7735940 0x5f5e100 0x3b9aca0 0x2faf080 0x17d7840 0x46cf7100 0x8f0d180 0x5f5e100 0x1dcd6500 0x17d78400 0x8f0d180 0x5f5e100 0x11e1a300 0x8f0d180 0x47868c00 0x17d78400 0x5f5e100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x46cf7100 0x1dcd6500 >;
004710        assigned-clock-parents = < 0x31 0x8 0x1f 0x4 0x1f 0x4 >;
004734        phandle = < 0x1f >;
004744     }
004748     i2c@fdd40000 {
00475c        compatible = "rockchip,rk3399-i2c";
00477c        reg = < 0x0 0xfdd40000 0x0 0x1000 >;
004798        clocks = < 0x31 0x7 0x31 0x2d >;
0047b4        clock-names = "i2c\0pclk";
0047cc        interrupts = < 0x0 0x2e 0x4 >;
0047e4        pinctrl-names = "default";
0047f8        pinctrl-0 = < 0x34 >;
004808        #address-cells = < 0x1 >;
004818        #size-cells = < 0x0 >;
004828        status = "okay";
00483c        phandle = < 0x160 >;
00484c        pmic@20 {
004858           compatible = "rockchip,rk809";
004874           reg = < 0x20 >;
004884           interrupt-parent = < 0x35 >;
004894           interrupts = < 0x3 0x8 >;
0048a8           pinctrl-names = "default\0pmic-sleep\0pmic-power-off\0pmic-reset";
0048e4           pinctrl-0 = < 0x36 >;
0048f4           pinctrl-1 = < 0x37 0x38 >;
004908           pinctrl-2 = < 0x39 0x3a >;
00491c           pinctrl-3 = < 0x39 0x3b >;
004930           rockchip,system-power-controller;
00493c           wakeup-source;
004948           #clock-cells = < 0x1 >;
004958           clock-output-names = "rk808-clkout1\0rk808-clkout2";
004980           pmic-reset-func = < 0x0 >;
004990           not-save-power-en = < 0x1 >;
0049a0           vcc1-supply = < 0x3c >;
0049b0           vcc2-supply = < 0x3c >;
0049c0           vcc3-supply = < 0x3c >;
0049d0           vcc4-supply = < 0x3c >;
0049e0           vcc5-supply = < 0x3c >;
0049f0           vcc6-supply = < 0x3c >;
004a00           vcc7-supply = < 0x3c >;
004a10           vcc8-supply = < 0x3c >;
004a20           vcc9-supply = < 0x3c >;
004a30           phandle = < 0x12a >;
004a40           pwrkey {
004a4c              status = "okay";
004a60           }
004a64           pinctrl_rk8xx {
004a78              gpio-controller;
004a84              #gpio-cells = < 0x2 >;
004a94              phandle = < 0x161 >;
004aa4              rk817_slppin_null {
004abc                 pins = "gpio_slp";
004ad4                 function = "pin_fun0";
004aec                 phandle = < 0x162 >;
004afc              }
004b00              rk817_slppin_slp {
004b18                 pins = "gpio_slp";
004b30                 function = "pin_fun1";
004b48                 phandle = < 0x38 >;
004b58              }
004b5c              rk817_slppin_pwrdn {
004b74                 pins = "gpio_slp";
004b8c                 function = "pin_fun2";
004ba4                 phandle = < 0x3a >;
004bb4              }
004bb8              rk817_slppin_rst {
004bd0                 pins = "gpio_slp";
004be8                 function = "pin_fun3";
004c00                 phandle = < 0x3b >;
004c10              }
004c14           }
004c18           regulators {
004c28              DCDC_REG1 {
004c38                 regulator-always-on;
004c44                 regulator-boot-on;
004c50                 regulator-min-microvolt = < 0x7a120 >;
004c60                 regulator-max-microvolt = < 0x149970 >;
004c70                 regulator-init-microvolt = < 0xdbba0 >;
004c80                 regulator-ramp-delay = < 0x1771 >;
004c90                 regulator-initial-mode = < 0x2 >;
004ca0                 regulator-name = "vdd_logic";
004cb8                 phandle = < 0x61 >;
004cc8                 regulator-state-mem {
004ce0                    regulator-off-in-suspend;
004cec                 }
004cf0              }
004cf4              DCDC_REG2 {
004d04                 regulator-always-on;
004d10                 regulator-boot-on;
004d1c                 regulator-min-microvolt = < 0x7a120 >;
004d2c                 regulator-max-microvolt = < 0x149970 >;
004d3c                 regulator-init-microvolt = < 0xdbba0 >;
004d4c                 regulator-ramp-delay = < 0x1771 >;
004d5c                 regulator-initial-mode = < 0x2 >;
004d6c                 regulator-name = "vdd_gpu";
004d80                 phandle = < 0x63 >;
004d90                 regulator-state-mem {
004da8                    regulator-off-in-suspend;
004db4                 }
004db8              }
004dbc              DCDC_REG3 {
004dcc                 regulator-always-on;
004dd8                 regulator-boot-on;
004de4                 regulator-initial-mode = < 0x2 >;
004df4                 regulator-name = "vcc_ddr";
004e08                 phandle = < 0x163 >;
004e18                 regulator-state-mem {
004e30                    regulator-on-in-suspend;
004e3c                 }
004e40              }
004e44              DCDC_REG4 {
004e54                 regulator-always-on;
004e60                 regulator-boot-on;
004e6c                 regulator-min-microvolt = < 0x7a120 >;
004e7c                 regulator-max-microvolt = < 0x149970 >;
004e8c                 regulator-init-microvolt = < 0xdbba0 >;
004e9c                 regulator-ramp-delay = < 0x1771 >;
004eac                 regulator-initial-mode = < 0x2 >;
004ebc                 regulator-name = "vdd_npu";
004ed0                 phandle = < 0x5e >;
004ee0                 regulator-state-mem {
004ef8                    regulator-off-in-suspend;
004f04                 }
004f08              }
004f0c              LDO_REG1 {
004f1c                 regulator-boot-on;
004f28                 regulator-always-on;
004f34                 regulator-min-microvolt = < 0xdbba0 >;
004f44                 regulator-max-microvolt = < 0xdbba0 >;
004f54                 regulator-name = "vdda0v9_image";
004f70                 phandle = < 0x164 >;
004f80                 regulator-state-mem {
004f98                    regulator-off-in-suspend;
004fa4                 }
004fa8              }
004fac              LDO_REG2 {
004fbc                 regulator-always-on;
004fc8                 regulator-boot-on;
004fd4                 regulator-min-microvolt = < 0xdbba0 >;
004fe4                 regulator-max-microvolt = < 0xdbba0 >;
004ff4                 regulator-name = "vdda_0v9";
00500c                 phandle = < 0x165 >;
00501c                 regulator-state-mem {
005034                    regulator-off-in-suspend;
005040                 }
005044              }
005048              LDO_REG3 {
005058                 regulator-always-on;
005064                 regulator-boot-on;
005070                 regulator-min-microvolt = < 0xdbba0 >;
005080                 regulator-max-microvolt = < 0xdbba0 >;
005090                 regulator-name = "vdda0v9_pmu";
0050a8                 phandle = < 0x166 >;
0050b8                 regulator-state-mem {
0050d0                    regulator-on-in-suspend;
0050dc                    regulator-suspend-microvolt = < 0xdbba0 >;
0050ec                 }
0050f0              }
0050f4              LDO_REG4 {
005104                 regulator-always-on;
005110                 regulator-boot-on;
00511c                 regulator-min-microvolt = < 0x325aa0 >;
00512c                 regulator-max-microvolt = < 0x325aa0 >;
00513c                 regulator-name = "vccio_acodec";
005158                 phandle = < 0x2a >;
005168                 regulator-state-mem {
005180                    regulator-off-in-suspend;
00518c                 }
005190              }
005194              LDO_REG5 {
0051a4                 regulator-always-on;
0051b0                 regulator-boot-on;
0051bc                 regulator-min-microvolt = < 0x1b7740 >;
0051cc                 regulator-max-microvolt = < 0x325aa0 >;
0051dc                 regulator-name = "vccio_sd";
0051f4                 phandle = < 0x2b >;
005204                 regulator-state-mem {
00521c                    regulator-off-in-suspend;
005228                 }
00522c              }
005230              LDO_REG6 {
005240                 regulator-always-on;
00524c                 regulator-boot-on;
005258                 regulator-min-microvolt = < 0x325aa0 >;
005268                 regulator-max-microvolt = < 0x325aa0 >;
005278                 regulator-name = "vcc3v3_pmu";
005290                 phandle = < 0x29 >;
0052a0                 regulator-state-mem {
0052b8                    regulator-on-in-suspend;
0052c4                    regulator-suspend-microvolt = < 0x325aa0 >;
0052d4                 }
0052d8              }
0052dc              LDO_REG7 {
0052ec                 regulator-always-on;
0052f8                 regulator-boot-on;
005304                 regulator-min-microvolt = < 0x1b7740 >;
005314                 regulator-max-microvolt = < 0x1b7740 >;
005324                 regulator-name = "vcca_1v8";
00533c                 phandle = < 0x101 >;
00534c                 regulator-state-mem {
005364                    regulator-off-in-suspend;
005370                 }
005374              }
005378              LDO_REG8 {
005388                 regulator-always-on;
005394                 regulator-boot-on;
0053a0                 regulator-min-microvolt = < 0x1b7740 >;
0053b0                 regulator-max-microvolt = < 0x1b7740 >;
0053c0                 regulator-name = "vcca1v8_pmu";
0053d8                 phandle = < 0x167 >;
0053e8                 regulator-state-mem {
005400                    regulator-on-in-suspend;
00540c                    regulator-suspend-microvolt = < 0x1b7740 >;
00541c                 }
005420              }
005424              LDO_REG9 {
005434                 regulator-always-on;
005440                 regulator-boot-on;
00544c                 regulator-min-microvolt = < 0x1b7740 >;
00545c                 regulator-max-microvolt = < 0x1b7740 >;
00546c                 regulator-name = "vcca1v8_image";
005488                 phandle = < 0x168 >;
005498                 regulator-state-mem {
0054b0                    regulator-off-in-suspend;
0054bc                 }
0054c0              }
0054c4              DCDC_REG5 {
0054d4                 regulator-always-on;
0054e0                 regulator-boot-on;
0054ec                 regulator-min-microvolt = < 0x1b7740 >;
0054fc                 regulator-max-microvolt = < 0x1b7740 >;
00550c                 regulator-name = "vcc_1v8";
005520                 phandle = < 0x2c >;
005530                 regulator-state-mem {
005548                    regulator-off-in-suspend;
005554                 }
005558              }
00555c              SWITCH_REG1 {
00556c                 regulator-always-on;
005578                 regulator-boot-on;
005584                 regulator-name = "vcc_3v3";
005598                 phandle = < 0x2d >;
0055a8                 regulator-state-mem {
0055c0                    regulator-off-in-suspend;
0055cc                 }
0055d0              }
0055d4              SWITCH_REG2 {
0055e4                 regulator-always-on;
0055f0                 regulator-boot-on;
0055fc                 regulator-name = "vcc3v3_sd";
005614                 phandle = < 0xaa >;
005624                 regulator-state-mem {
00563c                    regulator-off-in-suspend;
005648                 }
00564c              }
005650           }
005654           codec {
005660              #sound-dai-cells = < 0x0 >;
005670              compatible = "rockchip,rk809-codec\0rockchip,rk817-codec";
0056a8              clocks = < 0x1f 0x1a4 >;
0056bc              clock-names = "mclk";
0056d0              assigned-clocks = < 0x1f 0x1a4 0x1f 0x1a8 >;
0056ec              assigned-clock-rates = < 0xbb8000 >;
0056fc              assigned-clock-parents = < 0x1f 0x54 0x1f 0x1a4 >;
005718              pinctrl-names = "default";
00572c              hp-volume = < 0x14 >;
00573c              spk-volume = < 0x3 >;
00574c              mic-in-differential;
005758              status = "disabled";
005770              phandle = < 0x122 >;
005780           }
005784        }
005788        tcs4525@1c {
005798           compatible = "tcs,tcs452x";
0057b0           reg = < 0x1c >;
0057c0           vin-supply = < 0x3d >;
0057d0           regulator-compatible = "fan53555-reg";
0057ec           regulator-name = "vdd_cpu";
005800           regulator-min-microvolt = < 0xadf34 >;
005810           regulator-max-microvolt = < 0x1535b0 >;
005820           regulator-init-microvolt = < 0xdbba0 >;
005830           regulator-ramp-delay = < 0x8fc >;
005840           fcs,suspend-voltage-selector = < 0x1 >;
005850           regulator-boot-on;
00585c           regulator-always-on;
005868           phandle = < 0x5 >;
005878           regulator-state-mem {
005890              regulator-off-in-suspend;
00589c           }
0058a0        }
0058a4     }
0058a8     serial@fdd50000 {
0058bc        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
0058f0        reg = < 0x0 0xfdd50000 0x0 0x100 >;
00590c        interrupts = < 0x0 0x74 0x4 >;
005924        clocks = < 0x31 0xb 0x31 0x2c >;
005940        clock-names = "baudclk\0apb_pclk";
005960        reg-shift = < 0x2 >;
005970        reg-io-width = < 0x4 >;
005980        dmas = < 0x3e 0x0 0x3e 0x1 >;
00599c        pinctrl-names = "default";
0059b0        pinctrl-0 = < 0x3f >;
0059c0        status = "disabled";
0059d8        phandle = < 0x169 >;
0059e8     }
0059ec     pwm@fdd70000 {
005a00        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
005a34        reg = < 0x0 0xfdd70000 0x0 0x10 >;
005a50        #pwm-cells = < 0x3 >;
005a60        pinctrl-names = "active";
005a74        pinctrl-0 = < 0x40 >;
005a84        clocks = < 0x31 0xd 0x31 0x30 >;
005aa0        clock-names = "pwm\0pclk";
005ab8        status = "disabled";
005ad0        phandle = < 0x16a >;
005ae0     }
005ae4     pwm@fdd70010 {
005af8        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
005b2c        reg = < 0x0 0xfdd70010 0x0 0x10 >;
005b48        #pwm-cells = < 0x3 >;
005b58        pinctrl-names = "active";
005b6c        pinctrl-0 = < 0x41 >;
005b7c        clocks = < 0x31 0xd 0x31 0x30 >;
005b98        clock-names = "pwm\0pclk";
005bb0        status = "disabled";
005bc8        phandle = < 0x16b >;
005bd8     }
005bdc     pwm@fdd70020 {
005bf0        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
005c24        reg = < 0x0 0xfdd70020 0x0 0x10 >;
005c40        #pwm-cells = < 0x3 >;
005c50        pinctrl-names = "active";
005c64        pinctrl-0 = < 0x42 >;
005c74        clocks = < 0x31 0xd 0x31 0x30 >;
005c90        clock-names = "pwm\0pclk";
005ca8        status = "disabled";
005cc0        phandle = < 0x16c >;
005cd0     }
005cd4     pwm@fdd70030 {
005ce8        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
005d1c        reg = < 0x0 0xfdd70030 0x0 0x10 >;
005d38        interrupts = < 0x0 0x52 0x4 0x0 0x56 0x4 >;
005d5c        #pwm-cells = < 0x3 >;
005d6c        pinctrl-names = "active";
005d80        pinctrl-0 = < 0x43 >;
005d90        clocks = < 0x31 0xd 0x31 0x30 >;
005dac        clock-names = "pwm\0pclk";
005dc4        status = "disabled";
005ddc        phandle = < 0x16d >;
005dec     }
005df0     power-management@fdd90000 {
005e10        compatible = "rockchip,rk3568-pmu\0syscon\0simple-mfd";
005e44        reg = < 0x0 0xfdd90000 0x0 0x1000 >;
005e60        phandle = < 0x16e >;
005e70        power-controller {
005e88           compatible = "rockchip,rk3568-power-controller";
005eb8           #power-domain-cells = < 0x1 >;
005ec8           #address-cells = < 0x1 >;
005ed8           #size-cells = < 0x0 >;
005ee8           status = "okay";
005efc           phandle = < 0x21 >;
005f0c           pd_npu@6 {
005f1c              reg = < 0x6 >;
005f2c              clocks = < 0x1f 0x27 0x1f 0x25 0x1f 0x26 >;
005f50              pm_qos = < 0x44 >;
005f60           }
005f64           pd_gpu@7 {
005f74              reg = < 0x7 >;
005f84              clocks = < 0x1f 0x19 0x1f 0x1a >;
005fa0              pm_qos = < 0x45 >;
005fb0           }
005fb4           pd_vi@8 {
005fc0              reg = < 0x8 >;
005fd0              clocks = < 0x1f 0xcc 0x1f 0xcd >;
005fec              pm_qos = < 0x46 0x47 0x48 >;
006004           }
006008           pd_vo@9 {
006014              reg = < 0x9 >;
006024              clocks = < 0x1f 0xda 0x1f 0xdb 0x1f 0xdc >;
006048              pm_qos = < 0x49 0x4a 0x4b >;
006060           }
006064           pd_rga@10 {
006074              reg = < 0xa >;
006084              clocks = < 0x1f 0xf1 0x1f 0xf2 >;
0060a0              pm_qos = < 0x4c 0x4d 0x4e 0x4f 0x50 0x51 >;
0060c4           }
0060c8           pd_vpu@11 {
0060d8              reg = < 0xb >;
0060e8              clocks = < 0x1f 0xed >;
0060fc              pm_qos = < 0x52 >;
00610c           }
006110           pd_rkvdec@13 {
006124              clocks = < 0x1f 0x107 >;
006138              reg = < 0xd >;
006148              pm_qos = < 0x53 >;
006158           }
00615c           pd_rkvenc@14 {
006170              reg = < 0xe >;
006180              clocks = < 0x1f 0x102 >;
006194              pm_qos = < 0x54 0x55 0x56 >;
0061ac           }
0061b0           pd_pipe@15 {
0061c0              reg = < 0xf >;
0061d0              clocks = < 0x1f 0x7f >;
0061e4              pm_qos = < 0x57 0x58 0x59 0x5a 0x5b >;
006204           }
006208        }
00620c     }
006210     pvtm@fde00000 {
006224        compatible = "rockchip,rk3568-core-pvtm";
00624c        reg = < 0x0 0xfde00000 0x0 0x100 >;
006268        #address-cells = < 0x1 >;
006278        #size-cells = < 0x0 >;
006288        pvtm@0 {
006294           reg = < 0x0 >;
0062a4           clocks = < 0x1f 0x13 0x1f 0x1c2 >;
0062c0           clock-names = "clk\0pclk";
0062d8           resets = < 0x1f 0x1a 0x1f 0x19 >;
0062f4           reset-names = "rts\0rst-p";
00630c           thermal-zone = "soc-thermal";
006324        }
006328     }
00632c     npu@fde40000 {
006340        compatible = "rockchip,rk3568-rknpu\0rockchip,rknpu";
006374        reg = < 0x0 0xfde40000 0x0 0x10000 >;
006390        interrupts = < 0x0 0x97 0x4 >;
0063a8        clocks = < 0x2 0x2 0x1f 0x23 0x1f 0x28 0x1f 0x29 >;
0063d4        clock-names = "scmi_clk\0clk\0aclk\0hclk";
0063f8        assigned-clocks = < 0x1f 0x23 >;
00640c        assigned-clock-rates = < 0x23c34600 >;
00641c        resets = < 0x1f 0x2b 0x1f 0x2c >;
006438        reset-names = "srst_a\0srst_h";
006454        power-domains = < 0x21 0x6 >;
006468        operating-points-v2 = < 0x5c >;
006478        iommus = < 0x5d >;
006488        status = "okay";
00649c        rknpu-supply = < 0x5e >;
0064ac        phandle = < 0x16f >;
0064bc     }
0064c0     npu-opp-table {
0064d4        compatible = "operating-points-v2";
0064f4        mbist-vmin = < 0xc96a8 0xdbba0 0xe7ef0 >;
00650c        nvmem-cells = < 0x5f 0x7 0x8 >;
006524        nvmem-cell-names = "leakage\0pvtm\0mbist-vmin";
006548        rockchip,temp-hysteresis = < 0x1388 >;
006558        rockchip,low-temp = < 0x0 >;
006568        rockchip,low-temp-adjust-volt = < 0x0 0x2bc 0xc350 >;
006580        phandle = < 0x5c >;
006590        opp-200000000 {
0065a4           opp-hz = < 0x0 0xbebc200 >;
0065b8           opp-microvolt = < 0xc96a8 0xc96a8 0xf4240 >;
0065d0        }
0065d4        opp-300000000 {
0065e8           opp-hz = < 0x0 0x11b3dc40 >;
0065fc           opp-microvolt = < 0xc96a8 0xc96a8 0xf4240 >;
006614        }
006618        opp-400000000 {
00662c           opp-hz = < 0x0 0x17d78400 >;
006640           opp-microvolt = < 0xc96a8 0xc96a8 0xf4240 >;
006658        }
00665c        opp-600000000 {
006670           opp-hz = < 0x0 0x23c34600 >;
006684           opp-microvolt = < 0xc96a8 0xc96a8 0xf4240 >;
00669c        }
0066a0        opp-700000000 {
0066b4           opp-hz = < 0x0 0x29b92700 >;
0066c8           opp-microvolt = < 0xcf850 0xcf850 0xf4240 >;
0066e0        }
0066e4        opp-800000000 {
0066f8           opp-hz = < 0x0 0x2faf0800 >;
00670c           opp-microvolt = < 0xd59f8 0xd59f8 0xf4240 >;
006724        }
006728        opp-900000000 {
00673c           opp-hz = < 0x0 0x35a4e900 >;
006750           opp-microvolt = < 0xe1d48 0xe1d48 0xf4240 >;
006768        }
00676c        opp-1000000000 {
006780           opp-hz = < 0x0 0x3b9aca00 >;
006794           opp-microvolt = < 0xf4240 0xf4240 0xf4240 >;
0067ac           status = "disabled";
0067c4        }
0067c8     }
0067cc     bus-npu {
0067d8        compatible = "rockchip,rk3568-bus";
0067f8        rockchip,busfreq-policy = "clkfreq";
00680c        clocks = < 0x2 0x2 >;
006820        clock-names = "bus";
006830        operating-points-v2 = < 0x60 >;
006840        status = "okay";
006854        bus-supply = < 0x61 >;
006864        pvtm-supply = < 0x5 >;
006874        phandle = < 0x170 >;
006884     }
006888     bus-npu-opp-table {
0068a0        compatible = "operating-points-v2";
0068c0        opp-shared;
0068cc        nvmem-cells = < 0x7 >;
0068dc        nvmem-cell-names = "pvtm";
0068f0        rockchip,pvtm-voltage-sel = < 0x0 0x14050 0x0 0x14051 0x16b48 0x1 0x16b49 0x186a0 0x2 >;
006920        rockchip,pvtm-ch = < 0x0 0x5 >;
006934        phandle = < 0x60 >;
006944        opp-1000000000 {
006958           opp-hz = < 0x0 0x3b9aca00 >;
00696c           opp-microvolt = < 0xe7ef0 >;
00697c           opp-microvolt-L0 = < 0xe7ef0 >;
00698c           opp-microvolt-L1 = < 0xe1d48 >;
00699c           opp-microvolt-L2 = < 0x0 >;
0069ac        }
0069b0        opp-900000000 {
0069c4           opp-hz = < 0x0 0x35a4e900 >;
0069d8           opp-microvolt = < 0x0 >;
0069e8        }
0069ec     }
0069f0     iommu@fde4b000 {
006a04        compatible = "rockchip,iommu-v2";
006a24        reg = < 0x0 0xfde4b000 0x0 0x40 >;
006a40        interrupts = < 0x0 0x97 0x4 >;
006a58        interrupt-names = "rknpu_mmu";
006a70        clocks = < 0x1f 0x28 0x1f 0x29 >;
006a8c        clock-names = "aclk\0iface";
006aa4        power-domains = < 0x21 0x6 >;
006ab8        #iommu-cells = < 0x0 >;
006ac8        status = "okay";
006adc        phandle = < 0x5d >;
006aec     }
006af0     gpu@fde60000 {
006b04        compatible = "arm,mali-bifrost";
006b24        reg = < 0x0 0xfde60000 0x0 0x4000 >;
006b40        interrupts = < 0x0 0x27 0x4 0x0 0x29 0x4 0x0 0x28 0x4 >;
006b70        interrupt-names = "GPU\0MMU\0JOB";
006b88        upthreshold = < 0x28 >;
006b98        downdifferential = < 0xa >;
006ba8        clocks = < 0x2 0x1 0x1f 0x1b >;
006bc4        clock-names = "clk_mali\0clk_gpu";
006be4        power-domains = < 0x21 0x7 >;
006bf8        #cooling-cells = < 0x2 >;
006c08        operating-points-v2 = < 0x62 >;
006c18        status = "okay";
006c2c        mali-supply = < 0x63 >;
006c3c        phandle = < 0x1d >;
006c4c        power-model {
006c5c           compatible = "simple-power-model";
006c7c           leakage-range = < 0x5 0xf >;
006c90           ls = < 0xffffa23e 0x5927 0x0 >;
006ca8           static-coefficient = < 0x186a0 >;
006cb8           dynamic-coefficient = < 0x3b9 >;
006cc8           ts = < 0xfffe56a6 0xf87a 0xfffffab5 0x14 >;
006ce4           thermal-zone = "gpu-thermal";
006cfc           phandle = < 0x171 >;
006d0c        }
006d10     }
006d14     opp-table2 {
006d24        compatible = "operating-points-v2";
006d44        mbist-vmin = < 0xc96a8 0xdbba0 0xe7ef0 >;
006d5c        nvmem-cells = < 0x64 0x7 0x8 >;
006d74        nvmem-cell-names = "leakage\0pvtm\0mbist-vmin";
006d98        phandle = < 0x62 >;
006da8        opp-200000000 {
006dbc           opp-hz = < 0x0 0xbebc200 >;
006dd0           opp-microvolt = < 0xc96a8 >;
006de0        }
006de4        opp-300000000 {
006df8           opp-hz = < 0x0 0x11e1a300 >;
006e0c           opp-microvolt = < 0xc96a8 >;
006e1c        }
006e20        opp-400000000 {
006e34           opp-hz = < 0x0 0x17d78400 >;
006e48           opp-microvolt = < 0xc96a8 >;
006e58        }
006e5c        opp-600000000 {
006e70           opp-hz = < 0x0 0x23c34600 >;
006e84           opp-microvolt = < 0xc96a8 >;
006e94        }
006e98        opp-700000000 {
006eac           opp-hz = < 0x0 0x29b92700 >;
006ec0           opp-microvolt = < 0xdbba0 >;
006ed0        }
006ed4        opp-800000000 {
006ee8           opp-hz = < 0x0 0x2faf0800 >;
006efc           opp-microvolt = < 0xe7ef0 >;
006f0c        }
006f10     }
006f14     pvtm@fde80000 {
006f28        compatible = "rockchip,rk3568-gpu-pvtm";
006f50        reg = < 0x0 0xfde80000 0x0 0x100 >;
006f6c        #address-cells = < 0x1 >;
006f7c        #size-cells = < 0x0 >;
006f8c        pvtm@1 {
006f98           reg = < 0x1 >;
006fa8           clocks = < 0x1f 0x1e 0x1f 0x1d >;
006fc4           clock-names = "clk\0pclk";
006fdc           resets = < 0x1f 0x24 0x1f 0x23 >;
006ff8           reset-names = "rts\0rst-p";
007010           thermal-zone = "gpu-thermal";
007028        }
00702c     }
007030     pvtm@fde90000 {
007044        compatible = "rockchip,rk3568-npu-pvtm";
00706c        reg = < 0x0 0xfde90000 0x0 0x100 >;
007088        #address-cells = < 0x1 >;
007098        #size-cells = < 0x0 >;
0070a8        pvtm@2 {
0070b4           reg = < 0x2 >;
0070c4           clocks = < 0x1f 0x2b 0x1f 0x2a 0x1f 0x25 >;
0070e8           clock-names = "clk\0pclk\0hclk";
007104           resets = < 0x1f 0x2e 0x1f 0x2d >;
007120           reset-names = "rts\0rst-p";
007138           thermal-zone = "soc-thermal";
007150        }
007154     }
007158     vdpu@fdea0400 {
00716c        compatible = "rockchip,vpu-decoder-v2";
007190        reg = < 0x0 0xfdea0400 0x0 0x400 >;
0071ac        interrupts = < 0x0 0x8b 0x4 >;
0071c4        interrupt-names = "irq_dec";
0071d8        clocks = < 0x1f 0xee 0x1f 0xef >;
0071f4        clock-names = "aclk_vcodec\0hclk_vcodec";
007218        resets = < 0x1f 0x11a 0x1f 0x11b >;
007234        reset-names = "video_a\0video_h";
007250        iommus = < 0x65 >;
007260        power-domains = < 0x21 0xb >;
007274        rockchip,srv = < 0x66 >;
007284        rockchip,taskqueue-node = < 0x0 >;
007294        rockchip,resetgroup-node = < 0x0 >;
0072a4        status = "okay";
0072b8        phandle = < 0x172 >;
0072c8     }
0072cc     iommu@fdea0800 {
0072e0        compatible = "rockchip,iommu-v2";
007300        reg = < 0x0 0xfdea0800 0x0 0x40 >;
00731c        interrupts = < 0x0 0x8a 0x4 >;
007334        interrupt-names = "vdpu_mmu";
00734c        clock-names = "aclk\0iface";
007364        clocks = < 0x1f 0xee 0x1f 0xef >;
007380        power-domains = < 0x21 0xb >;
007394        #iommu-cells = < 0x0 >;
0073a4        status = "okay";
0073b8        phandle = < 0x65 >;
0073c8     }
0073cc     rk_rga@fdeb0000 {
0073e0        compatible = "rockchip,rga2";
0073fc        reg = < 0x0 0xfdeb0000 0x0 0x1000 >;
007418        interrupts = < 0x0 0x5a 0x4 >;
007430        clocks = < 0x1f 0xf3 0x1f 0xf4 0x1f 0xf5 >;
007454        clock-names = "aclk_rga\0hclk_rga\0clk_rga";
00747c        power-domains = < 0x21 0xa >;
007490        status = "okay";
0074a4        phandle = < 0x173 >;
0074b4     }
0074b8     ebc@fdec0000 {
0074cc        compatible = "rockchip,rk3568-ebc-tcon";
0074f4        reg = < 0x0 0xfdec0000 0x0 0x5000 >;
007510        interrupts = < 0x0 0x11 0x4 >;
007528        clocks = < 0x1f 0xf9 0x1f 0xfa >;
007544        clock-names = "hclk\0dclk";
00755c        power-domains = < 0x21 0xa >;
007570        rockchip,grf = < 0x32 >;
007580        pinctrl-names = "default";
007594        pinctrl-0 = < 0x67 >;
0075a4        status = "disabled";
0075bc        phandle = < 0x174 >;
0075cc     }
0075d0     jpegd@fded0000 {
0075e4        compatible = "rockchip,rkv-jpeg-decoder-v1";
007610        reg = < 0x0 0xfded0000 0x0 0x400 >;
00762c        interrupts = < 0x0 0x3e 0x4 >;
007644        clocks = < 0x1f 0xfb 0x1f 0xfc >;
007660        clock-names = "aclk_vcodec\0hclk_vcodec";
007684        rockchip,disable-auto-freq;
007690        resets = < 0x1f 0x12c 0x1f 0x12d >;
0076ac        reset-names = "video_a\0video_h";
0076c8        iommus = < 0x68 >;
0076d8        rockchip,srv = < 0x66 >;
0076e8        rockchip,taskqueue-node = < 0x1 >;
0076f8        rockchip,resetgroup-node = < 0x1 >;
007708        power-domains = < 0x21 0xa >;
00771c        status = "okay";
007730        phandle = < 0x175 >;
007740     }
007744     iommu@fded0480 {
007758        compatible = "rockchip,iommu-v2";
007778        reg = < 0x0 0xfded0480 0x0 0x40 >;
007794        interrupts = < 0x0 0x3d 0x4 >;
0077ac        interrupt-names = "jpegd_mmu";
0077c4        clock-names = "aclk\0iface";
0077dc        clocks = < 0x1f 0xfb 0x1f 0xfc >;
0077f8        power-domains = < 0x21 0xa >;
00780c        #iommu-cells = < 0x0 >;
00781c        status = "okay";
007830        phandle = < 0x68 >;
007840     }
007844     vepu@fdee0000 {
007858        compatible = "rockchip,vpu-encoder-v2";
00787c        reg = < 0x0 0xfdee0000 0x0 0x400 >;
007898        interrupts = < 0x0 0x40 0x4 >;
0078b0        clocks = < 0x1f 0xfd 0x1f 0xfe >;
0078cc        clock-names = "aclk_vcodec\0hclk_vcodec";
0078f0        rockchip,disable-auto-freq;
0078fc        resets = < 0x1f 0x12e 0x1f 0x12f >;
007918        reset-names = "video_a\0video_h";
007934        iommus = < 0x69 >;
007944        rockchip,srv = < 0x66 >;
007954        rockchip,taskqueue-node = < 0x2 >;
007964        rockchip,resetgroup-node = < 0x2 >;
007974        power-domains = < 0x21 0xa >;
007988        status = "okay";
00799c        phandle = < 0x176 >;
0079ac     }
0079b0     iommu@fdee0800 {
0079c4        compatible = "rockchip,iommu-v2";
0079e4        reg = < 0x0 0xfdee0800 0x0 0x40 >;
007a00        interrupts = < 0x0 0x3f 0x4 >;
007a18        interrupt-names = "vepu_mmu";
007a30        clock-names = "aclk\0iface";
007a48        clocks = < 0x1f 0xfd 0x1f 0xfe >;
007a64        power-domains = < 0x21 0xa >;
007a78        #iommu-cells = < 0x0 >;
007a88        status = "okay";
007a9c        phandle = < 0x69 >;
007aac     }
007ab0     iep@fdef0000 {
007ac4        compatible = "rockchip,iep-v2";
007ae0        reg = < 0x0 0xfdef0000 0x0 0x500 >;
007afc        interrupts = < 0x0 0x38 0x4 >;
007b14        clocks = < 0x1f 0xf6 0x1f 0xf7 0x1f 0xf8 >;
007b38        clock-names = "aclk\0hclk\0sclk";
007b54        resets = < 0x1f 0x127 0x1f 0x128 0x1f 0x129 >;
007b78        reset-names = "rst_a\0rst_h\0rst_s";
007b98        power-domains = < 0x21 0xa >;
007bac        rockchip,srv = < 0x66 >;
007bbc        rockchip,taskqueue-node = < 0x5 >;
007bcc        rockchip,resetgroup-node = < 0x5 >;
007bdc        iommus = < 0x6a >;
007bec        status = "okay";
007c00        phandle = < 0x177 >;
007c10     }
007c14     iommu@fdef0800 {
007c28        compatible = "rockchip,iommu-v2";
007c48        reg = < 0x0 0xfdef0800 0x0 0x100 >;
007c64        interrupts = < 0x0 0x38 0x4 >;
007c7c        interrupt-names = "iep_mmu";
007c90        clocks = < 0x1f 0xf6 0x1f 0xf7 >;
007cac        clock-names = "aclk\0iface";
007cc4        #iommu-cells = < 0x0 >;
007cd4        power-domains = < 0x21 0xa >;
007ce8        status = "okay";
007cfc        phandle = < 0x6a >;
007d0c     }
007d10     eink@fdf00000 {
007d24        compatible = "rockchip,rk3568-eink-tcon";
007d4c        reg = < 0x0 0xfdf00000 0x0 0x74 >;
007d68        interrupts = < 0x0 0xb2 0x4 >;
007d80        clocks = < 0x1f 0xff 0x1f 0x100 >;
007d9c        clock-names = "pclk\0hclk";
007db4        status = "disabled";
007dcc        phandle = < 0x178 >;
007ddc     }
007de0     rkvenc@fdf40000 {
007df4        compatible = "rockchip,rkv-encoder-v1";
007e18        reg = < 0x0 0xfdf40000 0x0 0x400 >;
007e34        interrupts = < 0x0 0x8c 0x4 >;
007e4c        interrupt-names = "irq_enc";
007e60        clocks = < 0x1f 0x103 0x1f 0x104 0x1f 0x105 >;
007e84        clock-names = "aclk_vcodec\0hclk_vcodec\0clk_core";
007eb4        rockchip,normal-rates = < 0x11b3dc40 0x0 0x11b3dc40 >;
007ecc        resets = < 0x1f 0x133 0x1f 0x134 0x1f 0x135 >;
007ef0        reset-names = "video_a\0video_h\0video_core";
007f18        assigned-clocks = < 0x1f 0x103 0x1f 0x105 >;
007f34        assigned-clock-rates = < 0x11b3dc40 0x11b3dc40 >;
007f48        iommus = < 0x6b >;
007f58        node-name = "rkvenc";
007f6c        rockchip,srv = < 0x66 >;
007f7c        rockchip,taskqueue-node = < 0x3 >;
007f8c        rockchip,resetgroup-node = < 0x3 >;
007f9c        power-domains = < 0x21 0xe >;
007fb0        operating-points-v2 = < 0x6c >;
007fc0        status = "okay";
007fd4        venc-supply = < 0x61 >;
007fe4        phandle = < 0x179 >;
007ff4     }
007ff8     rkvenc-opp-table {
008010        compatible = "operating-points-v2";
008030        nvmem-cells = < 0x7 >;
008040        nvmem-cell-names = "pvtm";
008054        rockchip,pvtm-voltage-sel = < 0x0 0x14050 0x0 0x14051 0x16b48 0x1 0x16b49 0x186a0 0x2 >;
008084        rockchip,pvtm-ch = < 0x0 0x5 >;
008098        phandle = < 0x6c >;
0080a8        opp-297000000 {
0080bc           opp-hz = < 0x0 0x11b3dc40 >;
0080d0           opp-microvolt = < 0x0 >;
0080e0        }
0080e4        opp-400000000 {
0080f8           opp-hz = < 0x0 0x17d78400 >;
00810c           opp-microvolt = < 0xe7ef0 >;
00811c           opp-microvolt-L0 = < 0xe7ef0 >;
00812c           opp-microvolt-L1 = < 0xe1d48 >;
00813c           opp-microvolt-L2 = < 0x0 >;
00814c        }
008150     }
008154     iommu@fdf40f00 {
008168        compatible = "rockchip,iommu-v2";
008188        reg = < 0x0 0xfdf40f00 0x0 0x40 0x0 0xfdf40f40 0x0 0x40 >;
0081b4        interrupts = < 0x0 0x8d 0x4 0x0 0x8e 0x4 >;
0081d8        interrupt-names = "rkvenc_mmu0\0rkvenc_mmu1";
0081fc        clocks = < 0x1f 0x103 0x1f 0x104 >;
008218        clock-names = "aclk\0iface";
008230        rockchip,disable-mmu-reset;
00823c        rockchip,enable-cmd-retry;
008248        #iommu-cells = < 0x0 >;
008258        power-domains = < 0x21 0xe >;
00826c        status = "okay";
008280        phandle = < 0x6b >;
008290     }
008294     rkvdec@fdf80200 {
0082a8        compatible = "rockchip,rkv-decoder-rk3568\0rockchip,rkv-decoder-v2";
0082e8        reg = < 0x0 0xfdf80200 0x0 0x400 >;
008304        interrupts = < 0x0 0x5b 0x4 >;
00831c        interrupt-names = "irq_dec";
008330        clocks = < 0x1f 0x108 0x1f 0x109 0x1f 0x10a 0x1f 0x10b 0x1f 0x10c >;
008364        clock-names = "aclk_vcodec\0hclk_vcodec\0clk_cabac\0clk_core\0clk_hevc_cabac";
0083ac        rockchip,normal-rates = < 0x11b3dc40 0x0 0x11b3dc40 0x11b3dc40 0x23c34600 >;
0083cc        rockchip,advanced-rates = < 0x179a7b00 0x0 0x179a7b00 0x179a7b00 0x23c34600 >;
0083ec        rockchip,default-max-load = < 0x1fe000 >;
0083fc        resets = < 0x1f 0x142 0x1f 0x143 0x1f 0x144 0x1f 0x145 0x1f 0x146 >;
008430        assigned-clocks = < 0x1f 0x108 0x1f 0x10a 0x1f 0x10b 0x1f 0x10c >;
00845c        assigned-clock-rates = < 0x11b3dc40 0x11b3dc40 0x11b3dc40 0x11b3dc40 >;
008478        reset-names = "video_a\0video_h\0video_cabac\0video_core\0video_hevc_cabac";
0084bc        power-domains = < 0x21 0xd >;
0084d0        iommus = < 0x6d >;
0084e0        rockchip,srv = < 0x66 >;
0084f0        rockchip,taskqueue-node = < 0x4 >;
008500        rockchip,resetgroup-node = < 0x4 >;
008510        rockchip,sram = < 0x6e >;
008520        rockchip,rcb-iova = < 0x10000000 0x10000 >;
008534        rockchip,rcb-min-width = < 0x200 >;
008544        status = "okay";
008558        phandle = < 0x17a >;
008568     }
00856c     iommu@fdf80800 {
008580        compatible = "rockchip,iommu-v2";
0085a0        reg = < 0x0 0xfdf80800 0x0 0x40 0x0 0xfdf80840 0x0 0x40 >;
0085cc        interrupts = < 0x0 0x5c 0x4 >;
0085e4        interrupt-names = "rkvdec_mmu";
0085fc        clocks = < 0x1f 0x108 0x1f 0x109 >;
008618        clock-names = "aclk\0iface";
008630        power-domains = < 0x21 0xd >;
008644        #iommu-cells = < 0x0 >;
008654        status = "okay";
008668        phandle = < 0x6d >;
008678     }
00867c     mipi-csi2@fdfb0000 {
008694        compatible = "rockchip,rk3568-mipi-csi2";
0086bc        reg = < 0x0 0xfdfb0000 0x0 0x10000 >;
0086d8        reg-names = "csihost_regs";
0086f4        interrupts = < 0x0 0x8 0x4 0x0 0x9 0x4 >;
008718        interrupt-names = "csi-intr1\0csi-intr2";
008738        clocks = < 0x1f 0xd5 >;
00874c        clock-names = "pclk_csi2host";
008768        resets = < 0x1f 0xff >;
00877c        reset-names = "srst_csihost_p";
008798        status = "disabled";
0087b0        phandle = < 0x17b >;
0087c0     }
0087c4     rkcif@fdfe0000 {
0087d8        compatible = "rockchip,rk3568-cif";
0087f8        reg = < 0x0 0xfdfe0000 0x0 0x8000 >;
008814        reg-names = "cif_regs";
00882c        interrupts = < 0x0 0x92 0x4 >;
008844        interrupt-names = "cif-intr";
00885c        clocks = < 0x1f 0xce 0x1f 0xcf 0x1f 0xd0 0x1f 0xd1 >;
008888        clock-names = "aclk_cif\0hclk_cif\0dclk_cif\0iclk_cif_g";
0088bc        resets = < 0x1f 0xf7 0x1f 0xf8 0x1f 0xf9 0x1f 0xfb 0x1f 0xfa >;
0088f0        reset-names = "rst_cif_a\0rst_cif_h\0rst_cif_d\0rst_cif_p\0rst_cif_i";
008930        assigned-clocks = < 0x1f 0xd0 >;
008944        assigned-clock-rates = < 0x11e1a300 >;
008954        power-domains = < 0x21 0x8 >;
008968        rockchip,grf = < 0x32 >;
008978        iommus = < 0x6f >;
008988        status = "okay";
00899c        phandle = < 0x70 >;
0089ac     }
0089b0     iommu@fdfe0800 {
0089c4        compatible = "rockchip,iommu-v2";
0089e4        reg = < 0x0 0xfdfe0800 0x0 0x100 >;
008a00        interrupts = < 0x0 0x92 0x4 >;
008a18        interrupt-names = "cif_mmu";
008a2c        clocks = < 0x1f 0xce 0x1f 0xcf >;
008a48        clock-names = "aclk\0iface";
008a60        power-domains = < 0x21 0x8 >;
008a74        rockchip,disable-mmu-reset;
008a80        #iommu-cells = < 0x0 >;
008a90        status = "disabled";
008aa8        phandle = < 0x6f >;
008ab8     }
008abc     rkcif_dvp {
008acc        compatible = "rockchip,rkcif-dvp";
008aec        rockchip,hw = < 0x70 >;
008afc        status = "okay";
008b10        phandle = < 0x72 >;
008b20        port {
008b2c           endpoint {
008b3c              remote-endpoint = < 0x71 >;
008b4c              bus-width = < 0x8 >;
008b5c              vsync-active = < 0x0 >;
008b6c              hsync-active = < 0x1 >;
008b7c              phandle = < 0xd1 >;
008b8c           }
008b90        }
008b94     }
008b98     rkcif_dvp_sditf {
008bac        compatible = "rockchip,rkcif-sditf";
008bd0        rockchip,cif = < 0x72 >;
008be0        status = "disabled";
008bf8        phandle = < 0x17c >;
008c08     }
008c0c     rkcif_mipi_lvds {
008c20        compatible = "rockchip,rkcif-mipi-lvds";
008c48        rockchip,hw = < 0x70 >;
008c58        status = "disabled";
008c70        phandle = < 0x73 >;
008c80     }
008c84     rkcif_mipi_lvds_sditf {
008ca0        compatible = "rockchip,rkcif-sditf";
008cc4        rockchip,cif = < 0x73 >;
008cd4        status = "disabled";
008cec        phandle = < 0x17d >;
008cfc     }
008d00     rkisp@fdff0000 {
008d14        compatible = "rockchip,rk3568-rkisp";
008d38        reg = < 0x0 0xfdff0000 0x0 0x10000 >;
008d54        interrupts = < 0x0 0x39 0x4 0x0 0x3a 0x4 0x0 0x3c 0x4 >;
008d84        interrupt-names = "mipi_irq\0mi_irq\0isp_irq";
008da8        clocks = < 0x1f 0xd2 0x1f 0xd3 0x1f 0xd4 >;
008dcc        clock-names = "aclk_isp\0hclk_isp\0clk_isp";
008df4        resets = < 0x1f 0xfd 0x1f 0xfc >;
008e10        reset-names = "isp\0isp-h";
008e28        rockchip,grf = < 0x32 >;
008e38        power-domains = < 0x21 0x8 >;
008e4c        iommus = < 0x74 >;
008e5c        rockchip,iq-feature = < 0x3fb 0xf7fe67ff >;
008e70        status = "okay";
008e84        phandle = < 0x75 >;
008e94     }
008e98     iommu@fdff1a00 {
008eac        compatible = "rockchip,iommu-v2";
008ecc        reg = < 0x0 0xfdff1a00 0x0 0x100 >;
008ee8        interrupts = < 0x0 0x3b 0x4 >;
008f00        interrupt-names = "isp_mmu";
008f14        clocks = < 0x1f 0xd2 0x1f 0xd3 >;
008f30        clock-names = "aclk\0iface";
008f48        power-domains = < 0x21 0x8 >;
008f5c        #iommu-cells = < 0x0 >;
008f6c        rockchip,disable-mmu-reset;
008f78        status = "okay";
008f8c        phandle = < 0x74 >;
008f9c     }
008fa0     rkisp-vir0 {
008fb0        compatible = "rockchip,rkisp-vir";
008fd0        rockchip,hw = < 0x75 >;
008fe0        status = "okay";
008ff4        phandle = < 0x17e >;
009004        port {
009010           #address-cells = < 0x1 >;
009020           #size-cells = < 0x0 >;
009030           endpoint@0 {
009040              reg = < 0x0 >;
009050              remote-endpoint = < 0x76 >;
009060              phandle = < 0x108 >;
009070           }
009074        }
009078     }
00907c     rkisp-vir1 {
00908c        compatible = "rockchip,rkisp-vir";
0090ac        rockchip,hw = < 0x75 >;
0090bc        status = "disabled";
0090d4        phandle = < 0x17f >;
0090e4     }
0090e8     ethernet@fe010000 {
009100        compatible = "rockchip,rk3568-gmac\0snps,dwmac-4.20a";
009134        reg = < 0x0 0xfe010000 0x0 0x10000 >;
009150        interrupts = < 0x0 0x20 0x4 0x0 0x1d 0x4 >;
009174        interrupt-names = "macirq\0eth_wake_irq";
009194        rockchip,grf = < 0x32 >;
0091a4        clocks = < 0x1f 0x186 0x1f 0x189 0x1f 0x189 0x1f 0xc7 0x1f 0xc3 0x1f 0xc4 0x1f 0x189 0x1f 0xc8 0x1f 0xac >;
0091f8        clock-names = "stmmaceth\0mac_clk_rx\0mac_clk_tx\0clk_mac_refout\0aclk_mac\0pclk_mac\0clk_mac_speed\0ptp_ref\0pclk_xpcs";
009268        resets = < 0x1f 0xec >;
00927c        reset-names = "stmmaceth";
009294        snps,mixed-burst;
0092a0        snps,tso;
0092ac        snps,axi-config = < 0x77 >;
0092bc        snps,mtl-rx-config = < 0x78 >;
0092cc        snps,mtl-tx-config = < 0x79 >;
0092dc        status = "okay";
0092f0        phy-mode = "rgmii";
009304        clock_in_out = "output";
009318        snps,reset-gpio = < 0x7a 0x1 0x1 >;
009330        snps,reset-active-low;
00933c        snps,reset-delays-us = < 0x0 0x4e20 0x186a0 >;
009354        assigned-clocks = < 0x1f 0x189 0x1f 0x186 >;
009370        assigned-clock-parents = < 0x1f 0x187 0x1f 0xc5 >;
00938c        assigned-clock-rates = < 0x0 0x7735940 >;
0093a0        pinctrl-names = "default";
0093b4        pinctrl-0 = < 0x7b 0x7c 0x7d 0x7e 0x7f >;
0093d4        tx_delay = < 0x41 >;
0093e4        rx_delay = < 0x2e >;
0093f4        phy-handle = < 0x80 >;
009404        phandle = < 0x180 >;
009414        mdio {
009420           compatible = "snps,dwmac-mdio";
00943c           #address-cells = < 0x1 >;
00944c           #size-cells = < 0x0 >;
00945c           phandle = < 0x181 >;
00946c           phy@0 {
009478              compatible = "ethernet-phy-ieee802.3-c22";
0094a0              reg = < 0x0 >;
0094b0              phandle = < 0x80 >;
0094c0           }
0094c4        }
0094c8        stmmac-axi-config {
0094e0           snps,wr_osr_lmt = < 0x4 >;
0094f0           snps,rd_osr_lmt = < 0x8 >;
009500           snps,blen = < 0x0 0x0 0x0 0x0 0x10 0x8 0x4 >;
009528           phandle = < 0x77 >;
009538        }
00953c        rx-queues-config {
009554           snps,rx-queues-to-use = < 0x1 >;
009564           phandle = < 0x78 >;
009574           queue0 {
009580           }
009584        }
009588        tx-queues-config {
0095a0           snps,tx-queues-to-use = < 0x1 >;
0095b0           phandle = < 0x79 >;
0095c0           queue0 {
0095cc           }
0095d0        }
0095d4     }
0095d8     vop@fe040000 {
0095ec        compatible = "rockchip,rk3568-vop";
00960c        reg = < 0x0 0xfe040000 0x0 0x3000 0x0 0xfe044000 0x0 0x1000 >;
009638        reg-names = "regs\0gamma_lut";
009654        rockchip,grf = < 0x32 >;
009664        interrupts = < 0x0 0x94 0x4 >;
00967c        clocks = < 0x1f 0xdd 0x1f 0xde 0x1f 0xdf 0x1f 0xe0 0x1f 0xe1 >;
0096b0        clock-names = "aclk_vop\0hclk_vop\0dclk_vp0\0dclk_vp1\0dclk_vp2";
0096ec        iommus = < 0x81 >;
0096fc        power-domains = < 0x21 0x9 >;
009710        status = "okay";
009724        assigned-clocks = < 0x1f 0xdf 0x1f 0xe0 >;
009740        assigned-clock-parents = < 0x31 0x2 0x1f 0x5 >;
00975c        phandle = < 0x182 >;
00976c        ports {
009778           #address-cells = < 0x1 >;
009788           #size-cells = < 0x0 >;
009798           phandle = < 0x12 >;
0097a8           port@0 {
0097b4              #address-cells = < 0x1 >;
0097c4              #size-cells = < 0x0 >;
0097d4              reg = < 0x0 >;
0097e4              phandle = < 0x183 >;
0097f4              endpoint@0 {
009804                 reg = < 0x0 >;
009814                 remote-endpoint = < 0x82 >;
009824                 phandle = < 0x8d >;
009834              }
009838              endpoint@1 {
009848                 reg = < 0x1 >;
009858                 remote-endpoint = < 0x83 >;
009868                 phandle = < 0x15 >;
009878              }
00987c              endpoint@2 {
00988c                 reg = < 0x2 >;
00989c                 remote-endpoint = < 0x84 >;
0098ac                 phandle = < 0x16 >;
0098bc              }
0098c0              endpoint@3 {
0098d0                 reg = < 0x3 >;
0098e0                 remote-endpoint = < 0x85 >;
0098f0                 phandle = < 0x17 >;
009900              }
009904           }
009908           port@1 {
009914              #address-cells = < 0x1 >;
009924              #size-cells = < 0x0 >;
009934              reg = < 0x1 >;
009944              phandle = < 0x184 >;
009954              endpoint@0 {
009964                 reg = < 0x0 >;
009974                 remote-endpoint = < 0x86 >;
009984                 phandle = < 0x14 >;
009994              }
009998              endpoint@1 {
0099a8                 reg = < 0x1 >;
0099b8                 remote-endpoint = < 0x87 >;
0099c8                 phandle = < 0x96 >;
0099d8              }
0099dc              endpoint@2 {
0099ec                 reg = < 0x2 >;
0099fc                 remote-endpoint = < 0x88 >;
009a0c                 phandle = < 0xa3 >;
009a1c              }
009a20              endpoint@3 {
009a30                 reg = < 0x3 >;
009a40                 remote-endpoint = < 0x89 >;
009a50                 phandle = < 0xa1 >;
009a60              }
009a64              endpoint@4 {
009a74                 reg = < 0x4 >;
009a84                 remote-endpoint = < 0x8a >;
009a94                 phandle = < 0x18 >;
009aa4              }
009aa8           }
009aac           port@2 {
009ab8              #address-cells = < 0x1 >;
009ac8              #size-cells = < 0x0 >;
009ad8              reg = < 0x2 >;
009ae8              phandle = < 0x185 >;
009af8              endpoint@0 {
009b08                 reg = < 0x0 >;
009b18                 remote-endpoint = < 0x8b >;
009b28                 phandle = < 0x2f >;
009b38              }
009b3c              endpoint@1 {
009b4c                 reg = < 0x1 >;
009b5c                 remote-endpoint = < 0x8c >;
009b6c                 phandle = < 0x19 >;
009b7c              }
009b80           }
009b84        }
009b88     }
009b8c     iommu@fe043e00 {
009ba0        compatible = "rockchip,iommu-v2";
009bc0        reg = < 0x0 0xfe043e00 0x0 0x100 0x0 0xfe043f00 0x0 0x100 >;
009bec        interrupts = < 0x0 0x94 0x4 >;
009c04        interrupt-names = "vop_mmu";
009c18        clocks = < 0x1f 0xdd 0x1f 0xde >;
009c34        clock-names = "aclk\0iface";
009c4c        #iommu-cells = < 0x0 >;
009c5c        status = "okay";
009c70        phandle = < 0x81 >;
009c80     }
009c84     dsi@fe060000 {
009c98        compatible = "rockchip,rk3568-mipi-dsi";
009cc0        reg = < 0x0 0xfe060000 0x0 0x10000 >;
009cdc        interrupts = < 0x0 0x44 0x4 >;
009cf4        clocks = < 0x1f 0xe8 0x1f 0xda 0x2e >;
009d14        clock-names = "pclk\0hclk\0hs_clk";
009d34        resets = < 0x1f 0x110 >;
009d48        reset-names = "apb";
009d58        phys = < 0x2e >;
009d68        phy-names = "mipi_dphy";
009d80        power-domains = < 0x21 0x9 >;
009d94        rockchip,grf = < 0x32 >;
009da4        #address-cells = < 0x1 >;
009db4        #size-cells = < 0x0 >;
009dc4        status = "disabled";
009ddc        phandle = < 0x186 >;
009dec        ports {
009df8           #address-cells = < 0x1 >;
009e08           #size-cells = < 0x0 >;
009e18           port@0 {
009e24              reg = < 0x0 >;
009e34              #address-cells = < 0x1 >;
009e44              #size-cells = < 0x0 >;
009e54              phandle = < 0x187 >;
009e64              endpoint@0 {
009e74                 reg = < 0x0 >;
009e84                 remote-endpoint = < 0x8d >;
009e94                 status = "disabled";
009eac                 phandle = < 0x82 >;
009ebc              }
009ec0              endpoint@1 {
009ed0                 reg = < 0x1 >;
009ee0                 remote-endpoint = < 0x14 >;
009ef0                 status = "okay";
009f04                 phandle = < 0x86 >;
009f14              }
009f18           }
009f1c           port@1 {
009f28              reg = < 0x1 >;
009f38              endpoint {
009f48                 remote-endpoint = < 0x8e >;
009f58                 phandle = < 0x94 >;
009f68              }
009f6c           }
009f70        }
009f74        panel@0 {
009f80           status = "okay";
009f94           compatible = "simple-panel-dsi";
009fb4           reg = < 0x0 >;
009fc4           backlight = < 0x8f >;
009fd4           reset-delay-ms = < 0x3c >;
009fe4           enable-delay-ms = < 0x3c >;
009ff4           prepare-delay-ms = < 0x3c >;
00a004           unprepare-delay-ms = < 0x3c >;
00a014           disable-delay-ms = < 0x3c >;
00a024           dsi,flags = < 0xa03 >;
00a034           dsi,format = < 0x0 >;
00a044           dsi,lanes = < 0x4 >;
00a054           panel-init-sequence = < 0x230002fe 0x21230002 0x4002300 0x2006423 0x22a00 0x23000226 0x64230002 0x54002300 0x2506423 0x27b00 0x23000277 0x64230002 0xa2002300 0x29d6423 0x2c900 0x230002c5 0x64230002 0x1712300 0x2277123 0x25171 0x23000278 0x71230002 0x9e712300 0x2c67123 0x20289 0x23000228 0x89230002 0x52892300 0x2798923 0x29f89 0x230002c7 0x89230002 0x39e2300 0x2299e23 0x2539e 0x2300027a 0x9e230002 0xa09e2300 0x2c89e23 0x20900 0x23000205 0xb0230002 0x31002300 0x22bb023 0x25a00 0x23000255 0xb0230002 0x80002300 0x27cb023 0x2a700 0x230002a3 0xb0230002 0xce002300 0x2cab023 0x206c0 0x2300022d 0xc0230002 0x56c02300 0x27dc023 0x2a4c0 0x230002cb 0xc0230002 0x7cf2300 0x22fcf23 0x258cf 0x2300027e 0xcf230002 0xa5cf2300 0x2cccf23 0x208dd 0x23000230 0xdd230002 0x59dd2300 0x27fdd23 0x2a6dd 0x230002cd 0xdd230002 0xe152300 0x20ae923 0x23615 0x23000232 0xe9230002 0x5f152300 0x25be923 0x28515 0x23000281 0xe9230002 0xad152300 0x2a9e923 0x2d315 0x230002cf 0xe9230002 0xb142300 0x2331423 0x25c14 0x23000282 0x14230002 0xaa142300 0x2d01423 0x20c36 0x23000234 0x36230002 0x5d362300 0x2833623 0x2ab36 0x230002d1 0x36230002 0xd6b2300 0x2356b23 0x25e6b 0x23000284 0x6b230002 0xac6b2300 0x2d26b23 0x2135a 0x2300020f 0x94230002 0x3b5a2300 0x2379423 0x2645a 0x23000260 0x94230002 0x8a5a2300 0x2869423 0x2b25a 0x230002ae 0x94230002 0xd85a2300 0x2d49423 0x210d1 0x23000238 0xd1230002 0x61d12300 0x287d123 0x2afd1 0x230002d5 0xd1230002 0x11042300 0x2390423 0x26204 0x23000288 0x4230002 0xb0042300 0x2d60423 0x21205 0x2300023a 0x5230002 0x63052300 0x2890523 0x2b105 0x230002d7 0x5230002 0x18aa2300 0x2143623 0x242aa 0x2300023d 0x36230002 0x69aa2300 0x2653623 0x28faa 0x2300028b 0x36230002 0xb7aa2300 0x2b33623 0x2ddaa 0x230002d9 0x36230002 0x15742300 0x23f7423 0x26674 0x2300028c 0x74230002 0xb4742300 0x2da7423 0x2169f 0x23000240 0x9f230002 0x679f2300 0x28d9f23 0x2b59f 0x230002db 0x9f230002 0x17dc2300 0x241dc23 0x268dc 0x2300028e 0xdc230002 0xb6dc2300 0x2dcdc23 0x21dff 0x23000219 0x3230002 0x47ff2300 0x2430323 0x26eff 0x2300026a 0x3230002 0x94ff2300 0x2900323 0x2bcff 0x230002b8 0x3230002 0xe2ff2300 0x2de0323 0x21a35 0x23000244 0x35230002 0x6b352300 0x2913523 0x2b935 0x230002df 0x35230002 0x1b452300 0x2454523 0x26c45 0x23000292 0x45230002 0xba452300 0x2e04523 0x21c55 0x23000246 0x55230002 0x6d552300 0x2935523 0x2bb55 0x230002e1 0x55230002 0x22ff2300 0x21e6823 0x24cff 0x23000248 0x68230002 0x73ff2300 0x26f6823 0x299ff 0x23000295 0x68230002 0xc1ff2300 0x2bd6823 0x2e7ff 0x230002e3 0x68230002 0x1f7e2300 0x2497e23 0x2707e 0x23000296 0x7e230002 0xbe7e2300 0x2e47e23 0x22097 0x2300024a 0x97230002 0x71972300 0x2979723 0x2bf97 0x230002e5 0x97230002 0x21b52300 0x24bb523 0x272b5 0x23000298 0xb5230002 0xc0b52300 0x2e6b523 0x225f0 0x23000223 0xe8230002 0x4ff02300 0x24de823 0x276f0 0x23000274 0xe8230002 0x9cf02300 0x29ae823 0x2c4f0 0x230002c2 0xe8230002 0xeaf02300 0x2e8e823 0x224ff 0x2300024e 0xff230002 0x75ff2300 0x29bff23 0x2c3ff 0x230002e9 0xff230002 0xfe3d2300 0x2000423 0x2fe23 0x23000208 0x82230002 0xa002300 0x20b0023 0x20c01 0x23000216 0x230002 0x18022300 0x21b0423 0x21904 0x2300021c 0x81230002 0x1f002300 0x2200323 0x22304 0x23000221 0x1230002 0x54632300 0x2555423 0x26e45 0x2300026d 0x36230002 0xfe3d2300 0x2557823 0x2fe20 0x23000226 0x30230002 0xfe3d2300 0x2207123 0x2508f 0x23000251 0x8f230002 0xfe002300 0x2350005 0x78011105 0x1e012900 >;
00a578           panel-exit-sequence = < 0x5000128 0x5000110 >;
00a58c           power-supply = < 0x90 >;
00a59c           reset-gpios = < 0x91 0x5 0x1 >;
00a5b4           pinctrl-names = "default";
00a5c8           pinctrl-0 = < 0x92 >;
00a5d8           phandle = < 0x188 >;
00a5e8           display-timings {
00a5fc              native-mode = < 0x93 >;
00a60c              phandle = < 0x189 >;
00a61c              timing0 {
00a628                 clock-frequency = < 0x7de2900 >;
00a638                 hactive = < 0x438 >;
00a648                 vactive = < 0x780 >;
00a658                 hfront-porch = < 0xf >;
00a668                 hsync-len = < 0x2 >;
00a678                 hback-porch = < 0x1e >;
00a688                 vfront-porch = < 0xf >;
00a698                 vsync-len = < 0x2 >;
00a6a8                 vback-porch = < 0xf >;
00a6b8                 hsync-active = < 0x0 >;
00a6c8                 vsync-active = < 0x0 >;
00a6d8                 de-active = < 0x0 >;
00a6e8                 pixelclk-active = < 0x1 >;
00a6f8                 phandle = < 0x93 >;
00a708              }
00a70c           }
00a710           ports {
00a71c              #address-cells = < 0x1 >;
00a72c              #size-cells = < 0x0 >;
00a73c              port@0 {
00a748                 reg = < 0x0 >;
00a758                 endpoint {
00a768                    remote-endpoint = < 0x94 >;
00a778                    phandle = < 0x8e >;
00a788                 }
00a78c              }
00a790           }
00a794        }
00a798     }
00a79c     dsi@fe070000 {
00a7b0        compatible = "rockchip,rk3568-mipi-dsi";
00a7d8        reg = < 0x0 0xfe070000 0x0 0x10000 >;
00a7f4        interrupts = < 0x0 0x45 0x4 >;
00a80c        clocks = < 0x1f 0xe9 0x1f 0xda 0x95 >;
00a82c        clock-names = "pclk\0hclk\0hs_clk";
00a84c        resets = < 0x1f 0x111 >;
00a860        reset-names = "apb";
00a870        phys = < 0x95 >;
00a880        phy-names = "mipi_dphy";
00a898        power-domains = < 0x21 0x9 >;
00a8ac        rockchip,grf = < 0x32 >;
00a8bc        #address-cells = < 0x1 >;
00a8cc        #size-cells = < 0x0 >;
00a8dc        status = "disabled";
00a8f4        phandle = < 0x18a >;
00a904        ports {
00a910           #address-cells = < 0x1 >;
00a920           #size-cells = < 0x0 >;
00a930           port@0 {
00a93c              reg = < 0x0 >;
00a94c              #address-cells = < 0x1 >;
00a95c              #size-cells = < 0x0 >;
00a96c              phandle = < 0x18b >;
00a97c              endpoint@0 {
00a98c                 reg = < 0x0 >;
00a99c                 remote-endpoint = < 0x15 >;
00a9ac                 status = "disabled";
00a9c4                 phandle = < 0x83 >;
00a9d4              }
00a9d8              endpoint@1 {
00a9e8                 reg = < 0x1 >;
00a9f8                 remote-endpoint = < 0x96 >;
00aa08                 status = "disabled";
00aa20                 phandle = < 0x87 >;
00aa30              }
00aa34           }
00aa38           port@1 {
00aa44              reg = < 0x1 >;
00aa54              endpoint {
00aa64                 remote-endpoint = < 0x97 >;
00aa74                 phandle = < 0x9d >;
00aa84              }
00aa88           }
00aa8c        }
00aa90        panel@0 {
00aa9c           status = "okay";
00aab0           compatible = "simple-panel-dsi";
00aad0           reg = < 0x0 >;
00aae0           backlight = < 0x98 >;
00aaf0           reset-delay-ms = < 0x3c >;
00ab00           enable-delay-ms = < 0x3c >;
00ab10           prepare-delay-ms = < 0x3c >;
00ab20           unprepare-delay-ms = < 0x3c >;
00ab30           disable-delay-ms = < 0x3c >;
00ab40           dsi,flags = < 0xa03 >;
00ab50           dsi,format = < 0x0 >;
00ab60           dsi,lanes = < 0x4 >;
00ab70           panel-init-sequence = < 0x230002fe 0x21230002 0x4002300 0x2006423 0x22a00 0x23000226 0x64230002 0x54002300 0x2506423 0x27b00 0x23000277 0x64230002 0xa2002300 0x29d6423 0x2c900 0x230002c5 0x64230002 0x1712300 0x2277123 0x25171 0x23000278 0x71230002 0x9e712300 0x2c67123 0x20289 0x23000228 0x89230002 0x52892300 0x2798923 0x29f89 0x230002c7 0x89230002 0x39e2300 0x2299e23 0x2539e 0x2300027a 0x9e230002 0xa09e2300 0x2c89e23 0x20900 0x23000205 0xb0230002 0x31002300 0x22bb023 0x25a00 0x23000255 0xb0230002 0x80002300 0x27cb023 0x2a700 0x230002a3 0xb0230002 0xce002300 0x2cab023 0x206c0 0x2300022d 0xc0230002 0x56c02300 0x27dc023 0x2a4c0 0x230002cb 0xc0230002 0x7cf2300 0x22fcf23 0x258cf 0x2300027e 0xcf230002 0xa5cf2300 0x2cccf23 0x208dd 0x23000230 0xdd230002 0x59dd2300 0x27fdd23 0x2a6dd 0x230002cd 0xdd230002 0xe152300 0x20ae923 0x23615 0x23000232 0xe9230002 0x5f152300 0x25be923 0x28515 0x23000281 0xe9230002 0xad152300 0x2a9e923 0x2d315 0x230002cf 0xe9230002 0xb142300 0x2331423 0x25c14 0x23000282 0x14230002 0xaa142300 0x2d01423 0x20c36 0x23000234 0x36230002 0x5d362300 0x2833623 0x2ab36 0x230002d1 0x36230002 0xd6b2300 0x2356b23 0x25e6b 0x23000284 0x6b230002 0xac6b2300 0x2d26b23 0x2135a 0x2300020f 0x94230002 0x3b5a2300 0x2379423 0x2645a 0x23000260 0x94230002 0x8a5a2300 0x2869423 0x2b25a 0x230002ae 0x94230002 0xd85a2300 0x2d49423 0x210d1 0x23000238 0xd1230002 0x61d12300 0x287d123 0x2afd1 0x230002d5 0xd1230002 0x11042300 0x2390423 0x26204 0x23000288 0x4230002 0xb0042300 0x2d60423 0x21205 0x2300023a 0x5230002 0x63052300 0x2890523 0x2b105 0x230002d7 0x5230002 0x18aa2300 0x2143623 0x242aa 0x2300023d 0x36230002 0x69aa2300 0x2653623 0x28faa 0x2300028b 0x36230002 0xb7aa2300 0x2b33623 0x2ddaa 0x230002d9 0x36230002 0x15742300 0x23f7423 0x26674 0x2300028c 0x74230002 0xb4742300 0x2da7423 0x2169f 0x23000240 0x9f230002 0x679f2300 0x28d9f23 0x2b59f 0x230002db 0x9f230002 0x17dc2300 0x241dc23 0x268dc 0x2300028e 0xdc230002 0xb6dc2300 0x2dcdc23 0x21dff 0x23000219 0x3230002 0x47ff2300 0x2430323 0x26eff 0x2300026a 0x3230002 0x94ff2300 0x2900323 0x2bcff 0x230002b8 0x3230002 0xe2ff2300 0x2de0323 0x21a35 0x23000244 0x35230002 0x6b352300 0x2913523 0x2b935 0x230002df 0x35230002 0x1b452300 0x2454523 0x26c45 0x23000292 0x45230002 0xba452300 0x2e04523 0x21c55 0x23000246 0x55230002 0x6d552300 0x2935523 0x2bb55 0x230002e1 0x55230002 0x22ff2300 0x21e6823 0x24cff 0x23000248 0x68230002 0x73ff2300 0x26f6823 0x299ff 0x23000295 0x68230002 0xc1ff2300 0x2bd6823 0x2e7ff 0x230002e3 0x68230002 0x1f7e2300 0x2497e23 0x2707e 0x23000296 0x7e230002 0xbe7e2300 0x2e47e23 0x22097 0x2300024a 0x97230002 0x71972300 0x2979723 0x2bf97 0x230002e5 0x97230002 0x21b52300 0x24bb523 0x272b5 0x23000298 0xb5230002 0xc0b52300 0x2e6b523 0x225f0 0x23000223 0xe8230002 0x4ff02300 0x24de823 0x276f0 0x23000274 0xe8230002 0x9cf02300 0x29ae823 0x2c4f0 0x230002c2 0xe8230002 0xeaf02300 0x2e8e823 0x224ff 0x2300024e 0xff230002 0x75ff2300 0x29bff23 0x2c3ff 0x230002e9 0xff230002 0xfe3d2300 0x2000423 0x2fe23 0x23000208 0x82230002 0xa002300 0x20b0023 0x20c01 0x23000216 0x230002 0x18022300 0x21b0423 0x21904 0x2300021c 0x81230002 0x1f002300 0x2200323 0x22304 0x23000221 0x1230002 0x54632300 0x2555423 0x26e45 0x2300026d 0x36230002 0xfe3d2300 0x2557823 0x2fe20 0x23000226 0x30230002 0xfe3d2300 0x2207123 0x2508f 0x23000251 0x8f230002 0xfe002300 0x2350005 0x78011105 0x1e012900 >;
00b094           panel-exit-sequence = < 0x5000128 0x5000110 >;
00b0a8           power-supply = < 0x99 >;
00b0b8           reset-gpios = < 0x9a 0x16 0x1 >;
00b0d0           pinctrl-names = "default";
00b0e4           pinctrl-0 = < 0x9b >;
00b0f4           phandle = < 0x18c >;
00b104           display-timings {
00b118              native-mode = < 0x9c >;
00b128              phandle = < 0x18d >;
00b138              timing0 {
00b144                 clock-frequency = < 0x7de2900 >;
00b154                 hactive = < 0x438 >;
00b164                 vactive = < 0x780 >;
00b174                 hfront-porch = < 0xf >;
00b184                 hsync-len = < 0x2 >;
00b194                 hback-porch = < 0x1e >;
00b1a4                 vfront-porch = < 0xf >;
00b1b4                 vsync-len = < 0x2 >;
00b1c4                 vback-porch = < 0xf >;
00b1d4                 hsync-active = < 0x0 >;
00b1e4                 vsync-active = < 0x0 >;
00b1f4                 de-active = < 0x0 >;
00b204                 pixelclk-active = < 0x1 >;
00b214                 phandle = < 0x9c >;
00b224              }
00b228           }
00b22c           ports {
00b238              #address-cells = < 0x1 >;
00b248              #size-cells = < 0x0 >;
00b258              port@0 {
00b264                 reg = < 0x0 >;
00b274                 endpoint {
00b284                    remote-endpoint = < 0x9d >;
00b294                    phandle = < 0x97 >;
00b2a4                 }
00b2a8              }
00b2ac           }
00b2b0        }
00b2b4     }
00b2b8     hdmi@fe0a0000 {
00b2cc        compatible = "rockchip,rk3568-dw-hdmi";
00b2f0        reg = < 0x0 0xfe0a0000 0x0 0x20000 >;
00b30c        interrupts = < 0x0 0x2d 0x4 >;
00b324        clocks = < 0x1f 0xe6 0x1f 0xe7 0x1f 0x193 0x31 0x2 0x1f 0xde >;
00b358        clock-names = "iahb\0isfr\0cec\0ref\0hclk";
00b37c        power-domains = < 0x21 0x9 >;
00b390        reg-io-width = < 0x4 >;
00b3a0        rockchip,grf = < 0x32 >;
00b3b0        #sound-dai-cells = < 0x0 >;
00b3c0        pinctrl-names = "default";
00b3d4        pinctrl-0 = < 0x9e 0x9f 0xa0 >;
00b3ec        status = "okay";
00b400        rockchip,phy-table = < 0x58834d4 0x8009 0x0 0x270 0x9d5b340 0x800b 0x0 0x26d 0xb1069a8 0x800b 0x0 0x1ed 0x11b3dc40 0x800b 0x0 0x1ad 0x2367b880 0x8029 0x0 0x88 0x0 0x0 0x0 0x0 >;
00b46c        phandle = < 0x11f >;
00b47c        ports {
00b488           #address-cells = < 0x1 >;
00b498           #size-cells = < 0x0 >;
00b4a8           port {
00b4b4              reg = < 0x0 >;
00b4c4              #address-cells = < 0x1 >;
00b4d4              #size-cells = < 0x0 >;
00b4e4              phandle = < 0x18e >;
00b4f4              endpoint@0 {
00b504                 reg = < 0x0 >;
00b514                 remote-endpoint = < 0x17 >;
00b524                 status = "okay";
00b538                 phandle = < 0x85 >;
00b548              }
00b54c              endpoint@1 {
00b55c                 reg = < 0x1 >;
00b56c                 remote-endpoint = < 0xa1 >;
00b57c                 status = "disabled";
00b594                 phandle = < 0x89 >;
00b5a4              }
00b5a8           }
00b5ac        }
00b5b0     }
00b5b4     edp@fe0c0000 {
00b5c8        compatible = "rockchip,rk3568-edp";
00b5e8        reg = < 0x0 0xfe0c0000 0x0 0x10000 >;
00b604        interrupts = < 0x0 0x12 0x4 >;
00b61c        clocks = < 0x31 0x29 0x1f 0xea 0x1f 0xeb 0x1f 0xda >;
00b648        clock-names = "dp\0pclk\0spdif\0hclk";
00b668        resets = < 0x1f 0x113 0x1f 0x112 >;
00b684        reset-names = "dp\0apb";
00b698        phys = < 0xa2 >;
00b6a8        phy-names = "dp";
00b6b8        power-domains = < 0x21 0x9 >;
00b6cc        status = "okay";
00b6e0        hpd-gpios = < 0x91 0x7 0x0 >;
00b6f8        phandle = < 0x18f >;
00b708        ports {
00b714           #address-cells = < 0x1 >;
00b724           #size-cells = < 0x0 >;
00b734           port@0 {
00b740              reg = < 0x0 >;
00b750              #address-cells = < 0x1 >;
00b760              #size-cells = < 0x0 >;
00b770              phandle = < 0x190 >;
00b780              endpoint@0 {
00b790                 reg = < 0x0 >;
00b7a0                 remote-endpoint = < 0x16 >;
00b7b0                 status = "okay";
00b7c4                 phandle = < 0x84 >;
00b7d4              }
00b7d8              endpoint@1 {
00b7e8                 reg = < 0x1 >;
00b7f8                 remote-endpoint = < 0xa3 >;
00b808                 status = "disabled";
00b820                 phandle = < 0x88 >;
00b830              }
00b834           }
00b838        }
00b83c     }
00b840     qos@fe128000 {
00b854        compatible = "syscon";
00b868        reg = < 0x0 0xfe128000 0x0 0x20 >;
00b884        phandle = < 0x45 >;
00b894     }
00b898     qos@fe138080 {
00b8ac        compatible = "syscon";
00b8c0        reg = < 0x0 0xfe138080 0x0 0x20 >;
00b8dc        phandle = < 0x54 >;
00b8ec     }
00b8f0     qos@fe138100 {
00b904        compatible = "syscon";
00b918        reg = < 0x0 0xfe138100 0x0 0x20 >;
00b934        phandle = < 0x55 >;
00b944     }
00b948     qos@fe138180 {
00b95c        compatible = "syscon";
00b970        reg = < 0x0 0xfe138180 0x0 0x20 >;
00b98c        phandle = < 0x56 >;
00b99c     }
00b9a0     qos@fe148000 {
00b9b4        compatible = "syscon";
00b9c8        reg = < 0x0 0xfe148000 0x0 0x20 >;
00b9e4        phandle = < 0x46 >;
00b9f4     }
00b9f8     qos@fe148080 {
00ba0c        compatible = "syscon";
00ba20        reg = < 0x0 0xfe148080 0x0 0x20 >;
00ba3c        phandle = < 0x47 >;
00ba4c     }
00ba50     qos@fe148100 {
00ba64        compatible = "syscon";
00ba78        reg = < 0x0 0xfe148100 0x0 0x20 >;
00ba94        phandle = < 0x48 >;
00baa4     }
00baa8     qos@fe150000 {
00babc        compatible = "syscon";
00bad0        reg = < 0x0 0xfe150000 0x0 0x20 >;
00baec        phandle = < 0x52 >;
00bafc     }
00bb00     qos@fe158000 {
00bb14        compatible = "syscon";
00bb28        reg = < 0x0 0xfe158000 0x0 0x20 >;
00bb44        phandle = < 0x4c >;
00bb54     }
00bb58     qos@fe158100 {
00bb6c        compatible = "syscon";
00bb80        reg = < 0x0 0xfe158100 0x0 0x20 >;
00bb9c        phandle = < 0x4d >;
00bbac     }
00bbb0     qos@fe158180 {
00bbc4        compatible = "syscon";
00bbd8        reg = < 0x0 0xfe158180 0x0 0x20 >;
00bbf4        phandle = < 0x4e >;
00bc04     }
00bc08     qos@fe158200 {
00bc1c        compatible = "syscon";
00bc30        reg = < 0x0 0xfe158200 0x0 0x20 >;
00bc4c        phandle = < 0x4f >;
00bc5c     }
00bc60     qos@fe158280 {
00bc74        compatible = "syscon";
00bc88        reg = < 0x0 0xfe158280 0x0 0x20 >;
00bca4        phandle = < 0x50 >;
00bcb4     }
00bcb8     qos@fe158300 {
00bccc        compatible = "syscon";
00bce0        reg = < 0x0 0xfe158300 0x0 0x20 >;
00bcfc        phandle = < 0x51 >;
00bd0c     }
00bd10     qos@fe180000 {
00bd24        compatible = "syscon";
00bd38        reg = < 0x0 0xfe180000 0x0 0x20 >;
00bd54        phandle = < 0x44 >;
00bd64     }
00bd68     qos@fe190000 {
00bd7c        compatible = "syscon";
00bd90        reg = < 0x0 0xfe190000 0x0 0x20 >;
00bdac        phandle = < 0x57 >;
00bdbc     }
00bdc0     qos@fe190280 {
00bdd4        compatible = "syscon";
00bde8        reg = < 0x0 0xfe190280 0x0 0x20 >;
00be04        phandle = < 0x58 >;
00be14     }
00be18     qos@fe190300 {
00be2c        compatible = "syscon";
00be40        reg = < 0x0 0xfe190300 0x0 0x20 >;
00be5c        phandle = < 0x59 >;
00be6c     }
00be70     qos@fe190380 {
00be84        compatible = "syscon";
00be98        reg = < 0x0 0xfe190380 0x0 0x20 >;
00beb4        phandle = < 0x5a >;
00bec4     }
00bec8     qos@fe190400 {
00bedc        compatible = "syscon";
00bef0        reg = < 0x0 0xfe190400 0x0 0x20 >;
00bf0c        phandle = < 0x5b >;
00bf1c     }
00bf20     qos@fe198000 {
00bf34        compatible = "syscon";
00bf48        reg = < 0x0 0xfe198000 0x0 0x20 >;
00bf64        phandle = < 0x53 >;
00bf74     }
00bf78     qos@fe1a8000 {
00bf8c        compatible = "syscon";
00bfa0        reg = < 0x0 0xfe1a8000 0x0 0x20 >;
00bfbc        phandle = < 0x49 >;
00bfcc     }
00bfd0     qos@fe1a8080 {
00bfe4        compatible = "syscon";
00bff8        reg = < 0x0 0xfe1a8080 0x0 0x20 >;
00c014        phandle = < 0x4a >;
00c024     }
00c028     qos@fe1a8100 {
00c03c        compatible = "syscon";
00c050        reg = < 0x0 0xfe1a8100 0x0 0x20 >;
00c06c        phandle = < 0x4b >;
00c07c     }
00c080     dwmmc@fe000000 {
00c094        compatible = "rockchip,rk3568-dw-mshc\0rockchip,rk3288-dw-mshc";
00c0d0        reg = < 0x0 0xfe000000 0x0 0x4000 >;
00c0ec        interrupts = < 0x0 0x64 0x4 >;
00c104        max-frequency = < 0x8f0d180 >;
00c114        clocks = < 0x1f 0xc1 0x1f 0xc2 0x1f 0x18e 0x1f 0x18f >;
00c140        clock-names = "biu\0ciu\0ciu-drive\0ciu-sample";
00c16c        fifo-depth = < 0x100 >;
00c17c        resets = < 0x1f 0xeb >;
00c190        reset-names = "reset";
00c1a4        status = "disabled";
00c1bc        phandle = < 0x191 >;
00c1cc     }
00c1d0     dfi@fe230000 {
00c1e4        reg = < 0x0 0xfe230000 0x0 0x400 >;
00c200        compatible = "rockchip,rk3568-dfi";
00c220        rockchip,pmugrf = < 0x33 >;
00c230        status = "okay";
00c244        phandle = < 0xa4 >;
00c254     }
00c258     dmc {
00c260        compatible = "rockchip,rk3568-dmc";
00c280        interrupts = < 0x0 0xa 0x4 >;
00c298        interrupt-names = "complete";
00c2b0        devfreq-events = < 0xa4 >;
00c2c0        clocks = < 0x2 0x3 >;
00c2d4        clock-names = "dmc_clk";
00c2e8        operating-points-v2 = < 0xa5 >;
00c2f8        ddr_timing = < 0xa6 >;
00c308        vop-bw-dmc-freq = < 0x0 0x1f9 0x4f1a0 0x1fa 0x1869f 0x80e80 >;
00c32c        upthreshold = < 0x28 >;
00c33c        downdifferential = < 0x14 >;
00c34c        system-status-level = < 0x1 0x4 0x8 0x8 0x2 0x1 0x10 0x4 0x10000 0x4 0x1000 0x8 0x4000 0x8 0x2000 0x8 0xc00 0x8 >;
00c3a0        auto-min-freq = < 0x4f1a0 >;
00c3b0        auto-freq-en = < 0x1 >;
00c3c0        #cooling-cells = < 0x2 >;
00c3d0        status = "disabled";
00c3e8        center-supply = < 0x61 >;
00c3f8        phandle = < 0x13 >;
00c408     }
00c40c     dmc-opp-table {
00c420        compatible = "operating-points-v2";
00c440        mbist-vmin = < 0xc96a8 0xdbba0 0xe7ef0 >;
00c458        nvmem-cells = < 0xa7 0x7 0x8 >;
00c470        nvmem-cell-names = "leakage\0pvtm\0mbist-vmin";
00c494        rockchip,temp-hysteresis = < 0x1388 >;
00c4a4        rockchip,low-temp = < 0x0 >;
00c4b4        rockchip,low-temp-adjust-volt = < 0x0 0x618 0x61a8 >;
00c4cc        rockchip,leakage-voltage-sel = < 0x1 0x50 0x0 0x51 0xfe 0x1 >;
00c4f0        phandle = < 0xa5 >;
00c500        opp-1560000000 {
00c514           opp-hz = < 0x0 0x5cfbb600 >;
00c528           opp-microvolt = < 0xdbba0 >;
00c538           opp-microvolt-L0 = < 0xdbba0 >;
00c548           opp-microvolt-L1 = < 0xcf850 >;
00c558        }
00c55c     }
00c560     pcie@fe260000 {
00c574        compatible = "rockchip,rk3568-pcie\0snps,dw-pcie";
00c5a4        #address-cells = < 0x3 >;
00c5b4        #size-cells = < 0x2 >;
00c5c4        bus-range = < 0x0 0xf >;
00c5d8        clocks = < 0x1f 0x81 0x1f 0x82 0x1f 0x83 0x1f 0x84 0x1f 0x85 >;
00c60c        clock-names = "aclk_mst\0aclk_slv\0aclk_dbi\0pclk\0aux";
00c63c        device_type = "pci";
00c64c        interrupts = < 0x0 0x4b 0x4 0x0 0x4a 0x4 0x0 0x49 0x4 0x0 0x48 0x4 0x0 0x47 0x4 >;
00c694        interrupt-names = "sys\0pmc\0msg\0legacy\0err";
00c6b8        #interrupt-cells = < 0x1 >;
00c6c8        interrupt-map-mask = < 0x0 0x0 0x0 0x7 >;
00c6e4        interrupt-map = < 0x0 0x0 0x0 0x1 0xa8 0x0 0x0 0x0 0x0 0x2 0xa8 0x1 0x0 0x0 0x0 0x3 0xa8 0x2 0x0 0x0 0x0 0x4 0xa8 0x3 >;
00c750        linux,pci-domain = < 0x0 >;
00c760        num-ib-windows = < 0x6 >;
00c770        num-ob-windows = < 0x2 >;
00c780        max-link-speed = < 0x2 >;
00c790        msi-map = < 0x0 0xa9 0x0 0x1000 >;
00c7ac        num-lanes = < 0x1 >;
00c7bc        phys = < 0x22 0x2 >;
00c7d0        phy-names = "pcie-phy";
00c7e8        power-domains = < 0x21 0xf >;
00c7fc        ranges = < 0x800 0x0 0x0 0x3 0x0 0x0 0x800000 0x81000000 0x0 0x800000 0x3 0x800000 0x0 0x100000 0x83000000 0x0 0x900000 0x3 0x900000 0x0 0x3f700000 >;
00c85c        reg = < 0x3 0xc0000000 0x0 0x400000 0x0 0xfe260000 0x0 0x10000 >;
00c888        reg-names = "pcie-dbi\0pcie-apb";
00c8a8        resets = < 0x1f 0xa1 >;
00c8bc        reset-names = "pipe";
00c8d0        status = "disabled";
00c8e8        phandle = < 0x192 >;
00c8f8        legacy-interrupt-controller {
00c918           interrupt-controller;
00c924           #address-cells = < 0x0 >;
00c934           #interrupt-cells = < 0x1 >;
00c944           interrupt-parent = < 0x1 >;
00c954           interrupts = < 0x0 0x48 0x1 >;
00c96c           phandle = < 0xa8 >;
00c97c        }
00c980     }
00c984     dwmmc@fe2b0000 {
00c998        compatible = "rockchip,rk3568-dw-mshc\0rockchip,rk3288-dw-mshc";
00c9d4        reg = < 0x0 0xfe2b0000 0x0 0x4000 >;
00c9f0        interrupts = < 0x0 0x62 0x4 >;
00ca08        max-frequency = < 0x8f0d180 >;
00ca18        clocks = < 0x1f 0xb0 0x1f 0xb1 0x1f 0x18a 0x1f 0x18b >;
00ca44        clock-names = "biu\0ciu\0ciu-drive\0ciu-sample";
00ca70        fifo-depth = < 0x100 >;
00ca80        resets = < 0x1f 0xd4 >;
00ca94        reset-names = "reset";
00caa8        status = "okay";
00cabc        supports-sd;
00cac8        bus-width = < 0x4 >;
00cad8        cap-mmc-highspeed;
00cae4        cap-sd-highspeed;
00caf0        disable-wp;
00cafc        sd-uhs-sdr104;
00cb08        vmmc-supply = < 0xaa >;
00cb18        vqmmc-supply = < 0x2b >;
00cb28        pinctrl-names = "default";
00cb3c        pinctrl-0 = < 0xab 0xac 0xad 0xae >;
00cb58        phandle = < 0x193 >;
00cb68     }
00cb6c     dwmmc@fe2c0000 {
00cb80        compatible = "rockchip,rk3568-dw-mshc\0rockchip,rk3288-dw-mshc";
00cbbc        reg = < 0x0 0xfe2c0000 0x0 0x4000 >;
00cbd8        interrupts = < 0x0 0x63 0x4 >;
00cbf0        max-frequency = < 0x8f0d180 >;
00cc00        clocks = < 0x1f 0xb2 0x1f 0xb3 0x1f 0x18c 0x1f 0x18d >;
00cc2c        clock-names = "biu\0ciu\0ciu-drive\0ciu-sample";
00cc58        fifo-depth = < 0x100 >;
00cc68        resets = < 0x1f 0xd6 >;
00cc7c        reset-names = "reset";
00cc90        status = "okay";
00cca4        supports-sdio;
00ccb0        bus-width = < 0x4 >;
00ccc0        disable-wp;
00cccc        cap-sd-highspeed;
00ccd8        cap-sdio-irq;
00cce4        keep-power-in-suspend;
00ccf0        mmc-pwrseq = < 0xaf >;
00cd00        non-removable;
00cd0c        pinctrl-names = "default";
00cd20        pinctrl-0 = < 0xb0 0xb1 0xb2 >;
00cd38        sd-uhs-sdr104;
00cd44        phandle = < 0x194 >;
00cd54     }
00cd58     sfc@fe300000 {
00cd6c        compatible = "rockchip,sfc";
00cd88        reg = < 0x0 0xfe300000 0x0 0x4000 >;
00cda4        interrupts = < 0x0 0x65 0x4 >;
00cdbc        clocks = < 0x1f 0x78 0x1f 0x76 >;
00cdd8        clock-names = "clk_sfc\0hclk_sfc";
00cdf8        assigned-clocks = < 0x1f 0x78 >;
00ce0c        assigned-clock-rates = < 0x5f5e100 >;
00ce1c        status = "okay";
00ce30        phandle = < 0x195 >;
00ce40     }
00ce44     sdhci@fe310000 {
00ce58        compatible = "rockchip,dwcmshc-sdhci\0snps,dwcmshc-sdhci";
00ce90        reg = < 0x0 0xfe310000 0x0 0x10000 >;
00ceac        interrupts = < 0x0 0x13 0x4 >;
00cec4        assigned-clocks = < 0x1f 0x7b 0x1f 0x7d >;
00cee0        assigned-clock-rates = < 0xbebc200 0x16e3600 >;
00cef4        clocks = < 0x1f 0x7c 0x1f 0x7a 0x1f 0x79 0x1f 0x7b 0x1f 0x7d >;
00cf28        clock-names = "core\0bus\0axi\0block\0timer";
00cf50        status = "okay";
00cf64        bus-width = < 0x8 >;
00cf74        supports-emmc;
00cf80        non-removable;
00cf8c        max-frequency = < 0xbebc200 >;
00cf9c        phandle = < 0x196 >;
00cfac     }
00cfb0     nandc@fe330000 {
00cfc4        compatible = "rockchip,rk-nandc-v9";
00cfe8        reg = < 0x0 0xfe330000 0x0 0x4000 >;
00d004        interrupts = < 0x0 0x46 0x4 >;
00d01c        nandc_id = < 0x0 >;
00d02c        clocks = < 0x1f 0x75 0x1f 0x74 >;
00d048        clock-names = "clk_nandc\0hclk_nandc";
00d06c        status = "okay";
00d080        #address-cells = < 0x1 >;
00d090        #size-cells = < 0x0 >;
00d0a0        phandle = < 0x197 >;
00d0b0        nand@0 {
00d0bc           reg = < 0x0 >;
00d0cc           nand-bus-width = < 0x8 >;
00d0dc           nand-ecc-mode = "hw";
00d0ec           nand-ecc-strength = < 0x10 >;
00d0fc           nand-ecc-step-size = < 0x400 >;
00d10c        }
00d110     }
00d114     crypto@fe380000 {
00d128        compatible = "rockchip,rk3568-crypto";
00d14c        reg = < 0x0 0xfe380000 0x0 0x4000 >;
00d168        interrupts = < 0x0 0x4 0x4 >;
00d180        clocks = < 0x1f 0x6a 0x1f 0x6b 0x1f 0x6c 0x1f 0x6d >;
00d1ac        clock-names = "aclk\0hclk\0sclk\0apb_pclk";
00d1d0        assigned-clocks = < 0x1f 0x6c >;
00d1e4        assigned-clock-rates = < 0xbebc200 >;
00d1f4        resets = < 0x1f 0x69 >;
00d208        reset-names = "crypto-rst";
00d220        status = "disabled";
00d238        phandle = < 0x198 >;
00d248     }
00d24c     rng@fe388000 {
00d260        compatible = "rockchip,cryptov2-rng";
00d284        reg = < 0x0 0xfe388000 0x0 0x2000 >;
00d2a0        clocks = < 0x1f 0x70 0x1f 0x6f >;
00d2bc        clock-names = "clk_trng\0hclk_trng";
00d2dc        resets = < 0x1f 0x6d >;
00d2f0        reset-names = "reset";
00d304        status = "okay";
00d318        phandle = < 0x199 >;
00d328     }
00d32c     otp@fe38c000 {
00d340        compatible = "rockchip,rk3568-otp";
00d360        reg = < 0x0 0xfe38c000 0x0 0x4000 >;
00d37c        #address-cells = < 0x1 >;
00d38c        #size-cells = < 0x1 >;
00d39c        clocks = < 0x1f 0x73 0x1f 0x72 0x1f 0x71 0x1f 0x181 >;
00d3c8        clock-names = "usr\0sbpi\0apb\0phy";
00d3e8        resets = < 0x1f 0x1cf >;
00d3fc        reset-names = "otp_phy";
00d410        phandle = < 0x19a >;
00d420        cpu-code@2 {
00d430           reg = < 0x2 0x2 >;
00d444           phandle = < 0xf >;
00d454        }
00d458        cpu-version@8 {
00d46c           reg = < 0x8 0x1 >;
00d480           bits = < 0x3 0x3 >;
00d494           phandle = < 0xe >;
00d4a4        }
00d4a8        mbist-vmin@9 {
00d4bc           reg = < 0x9 0x1 >;
00d4d0           bits = < 0x0 0x4 >;
00d4e4           phandle = < 0x8 >;
00d4f4        }
00d4f8        id@a {
00d504           reg = < 0xa 0x10 >;
00d518           phandle = < 0xd >;
00d528        }
00d52c        cpu-leakage@1a {
00d540           reg = < 0x1a 0x1 >;
00d554           phandle = < 0x6 >;
00d564        }
00d568        log-leakage@1b {
00d57c           reg = < 0x1b 0x1 >;
00d590           phandle = < 0xa7 >;
00d5a0        }
00d5a4        npu-leakage@1c {
00d5b8           reg = < 0x1c 0x1 >;
00d5cc           phandle = < 0x5f >;
00d5dc        }
00d5e0        gpu-leakage@1d {
00d5f4           reg = < 0x1d 0x1 >;
00d608           phandle = < 0x64 >;
00d618        }
00d61c        core-pvtm@2a {
00d630           reg = < 0x2a 0x2 >;
00d644           phandle = < 0x7 >;
00d654        }
00d658     }
00d65c     i2s@fe400000 {
00d670        compatible = "rockchip,rk3568-i2s-tdm";
00d694        reg = < 0x0 0xfe400000 0x0 0x1000 >;
00d6b0        interrupts = < 0x0 0x34 0x4 >;
00d6c8        clocks = < 0x1f 0x3f 0x1f 0x43 0x1f 0x39 >;
00d6ec        clock-names = "mclk_tx\0mclk_rx\0hclk";
00d710        dmas = < 0xb3 0x0 >;
00d724        dma-names = "tx";
00d734        resets = < 0x1f 0x50 0x1f 0x51 >;
00d750        reset-names = "tx-m\0rx-m";
00d768        rockchip,cru = < 0x1f >;
00d778        rockchip,grf = < 0x32 >;
00d788        rockchip,playback-only;
00d794        #sound-dai-cells = < 0x0 >;
00d7a4        status = "okay";
00d7b8        phandle = < 0x11e >;
00d7c8     }
00d7cc     i2s@fe410000 {
00d7e0        compatible = "rockchip,rk3568-i2s-tdm";
00d804        reg = < 0x0 0xfe410000 0x0 0x1000 >;
00d820        interrupts = < 0x0 0x35 0x4 >;
00d838        clocks = < 0x1f 0x47 0x1f 0x4b 0x1f 0x3a >;
00d85c        clock-names = "mclk_tx\0mclk_rx\0hclk";
00d880        dmas = < 0xb3 0x2 0xb3 0x3 >;
00d89c        dma-names = "tx\0rx";
00d8b0        resets = < 0x1f 0x52 0x1f 0x53 >;
00d8cc        reset-names = "tx-m\0rx-m";
00d8e4        rockchip,cru = < 0x1f >;
00d8f4        rockchip,grf = < 0x32 >;
00d904        #sound-dai-cells = < 0x0 >;
00d914        pinctrl-names = "default";
00d928        pinctrl-0 = < 0xb4 0xb5 0xb6 0xb7 >;
00d944        status = "disabled";
00d95c        rockchip,clk-trcm = < 0x1 >;
00d96c        phandle = < 0xc4 >;
00d97c     }
00d980     i2s@fe420000 {
00d994        compatible = "rockchip,rk3568-i2s-tdm";
00d9b8        reg = < 0x0 0xfe420000 0x0 0x1000 >;
00d9d4        interrupts = < 0x0 0x36 0x4 >;
00d9ec        clocks = < 0x1f 0x4f 0x1f 0x4f 0x1f 0x3b >;
00da10        clock-names = "mclk_tx\0mclk_rx\0hclk";
00da34        dmas = < 0xb3 0x4 0xb3 0x5 >;
00da50        dma-names = "tx\0rx";
00da64        rockchip,cru = < 0x1f >;
00da74        rockchip,grf = < 0x32 >;
00da84        rockchip,clk-trcm = < 0x1 >;
00da94        #sound-dai-cells = < 0x0 >;
00daa4        pinctrl-names = "default";
00dab8        pinctrl-0 = < 0xb8 0xb9 0xba 0xbb >;
00dad4        status = "disabled";
00daec        phandle = < 0x19b >;
00dafc     }
00db00     i2s@fe430000 {
00db14        compatible = "rockchip,rk3568-i2s-tdm";
00db38        reg = < 0x0 0xfe430000 0x0 0x1000 >;
00db54        interrupts = < 0x0 0x37 0x4 >;
00db6c        clocks = < 0x1f 0x53 0x1f 0x57 0x1f 0x3c >;
00db90        clock-names = "mclk_tx\0mclk_rx\0hclk";
00dbb4        dmas = < 0xb3 0x6 0xb3 0x7 >;
00dbd0        dma-names = "tx\0rx";
00dbe4        resets = < 0x1f 0x55 0x1f 0x56 >;
00dc00        reset-names = "tx-m\0rx-m";
00dc18        rockchip,cru = < 0x1f >;
00dc28        rockchip,grf = < 0x32 >;
00dc38        rockchip,clk-trcm = < 0x1 >;
00dc48        #sound-dai-cells = < 0x0 >;
00dc58        pinctrl-names = "default";
00dc6c        pinctrl-0 = < 0xbc 0xbd 0xbe 0xbf >;
00dc88        status = "okay";
00dc9c        phandle = < 0x11a >;
00dcac     }
00dcb0     pdm@fe440000 {
00dcc4        compatible = "rockchip,rk3568-pdm\0rockchip,pdm";
00dcf4        reg = < 0x0 0xfe440000 0x0 0x1000 >;
00dd10        clocks = < 0x1f 0x5a 0x1f 0x59 >;
00dd2c        clock-names = "pdm_clk\0pdm_hclk";
00dd4c        dmas = < 0xb3 0x9 >;
00dd60        dma-names = "rx";
00dd70        pinctrl-names = "default";
00dd84        pinctrl-0 = < 0xc0 0xc1 0xc2 0xc3 >;
00dda0        #sound-dai-cells = < 0x0 >;
00ddb0        status = "disabled";
00ddc8        phandle = < 0x120 >;
00ddd8     }
00dddc     vad@fe450000 {
00ddf0        compatible = "rockchip,rk3568-vad";
00de10        reg = < 0x0 0xfe450000 0x0 0x10000 >;
00de2c        reg-names = "vad";
00de3c        clocks = < 0x1f 0x5b >;
00de50        clock-names = "hclk";
00de64        interrupts = < 0x0 0x89 0x4 >;
00de7c        rockchip,audio-src = < 0xc4 >;
00de8c        rockchip,det-channel = < 0x0 >;
00de9c        rockchip,mode = < 0x0 >;
00deac        #sound-dai-cells = < 0x0 >;
00debc        status = "disabled";
00ded4        rockchip,buffer-time-ms = < 0x80 >;
00dee4        phandle = < 0x125 >;
00def4     }
00def8     spdif@fe460000 {
00df0c        compatible = "rockchip,rk3568-spdif";
00df30        reg = < 0x0 0xfe460000 0x0 0x1000 >;
00df4c        interrupts = < 0x0 0x66 0x4 >;
00df64        dmas = < 0xb3 0x1 >;
00df78        dma-names = "tx";
00df88        clock-names = "mclk\0hclk";
00dfa0        clocks = < 0x1f 0x5f 0x1f 0x5c >;
00dfbc        #sound-dai-cells = < 0x0 >;
00dfcc        pinctrl-names = "default";
00dfe0        pinctrl-0 = < 0xc5 >;
00dff0        status = "disabled";
00e008        phandle = < 0x123 >;
00e018     }
00e01c     audpwm@fe470000 {
00e030        compatible = "rockchip,rk3568-audio-pwm\0rockchip,audio-pwm-v1";
00e06c        reg = < 0x0 0xfe470000 0x0 0x1000 >;
00e088        clocks = < 0x1f 0x63 0x1f 0x60 >;
00e0a4        clock-names = "clk\0hclk";
00e0bc        dmas = < 0xb3 0x8 >;
00e0d0        dma-names = "tx";
00e0e0        #sound-dai-cells = < 0x0 >;
00e0f0        rockchip,sample-width-bits = < 0xb >;
00e100        rockchip,interpolat-points = < 0x1 >;
00e110        status = "disabled";
00e128        phandle = < 0x19c >;
00e138     }
00e13c     codec-digital@fe478000 {
00e158        compatible = "rockchip,rk3568-codec-digital\0rockchip,codec-digital-v1";
00e19c        reg = < 0x0 0xfe478000 0x0 0x1000 >;
00e1b8        clocks = < 0x1f 0x67 0x1f 0x66 0x1f 0x65 0x1f 0x64 >;
00e1e4        clock-names = "adc\0dac\0i2c\0pclk";
00e204        pinctrl-names = "default";
00e218        pinctrl-0 = < 0xc6 >;
00e228        resets = < 0x1f 0x5f >;
00e23c        reset-names = "reset";
00e250        rockchip,grf = < 0x32 >;
00e260        #sound-dai-cells = < 0x0 >;
00e270        status = "disabled";
00e288        phandle = < 0x11b >;
00e298     }
00e29c     dmac@fe530000 {
00e2b0        compatible = "arm,pl330\0arm,primecell";
00e2d4        reg = < 0x0 0xfe530000 0x0 0x4000 >;
00e2f0        interrupts = < 0x0 0xe 0x4 0x0 0xd 0x4 >;
00e314        clocks = < 0x1f 0x10d >;
00e328        clock-names = "apb_pclk";
00e340        #dma-cells = < 0x1 >;
00e350        arm,pl330-periph-burst;
00e35c        phandle = < 0x3e >;
00e36c     }
00e370     dmac@fe550000 {
00e384        compatible = "arm,pl330\0arm,primecell";
00e3a8        reg = < 0x0 0xfe550000 0x0 0x4000 >;
00e3c4        interrupts = < 0x0 0x10 0x4 0x0 0xf 0x4 >;
00e3e8        clocks = < 0x1f 0x10d >;
00e3fc        clock-names = "apb_pclk";
00e414        #dma-cells = < 0x1 >;
00e424        arm,pl330-periph-burst;
00e430        phandle = < 0xb3 >;
00e440     }
00e444     rkscr@fe560000 {
00e458        compatible = "rockchip-scr";
00e474        reg = < 0x0 0xfe560000 0x0 0x10000 >;
00e490        interrupts = < 0x0 0x61 0x4 >;
00e4a8        pinctrl-names = "default";
00e4bc        pinctrl-0 = < 0xc7 >;
00e4cc        clocks = < 0x1f 0x114 >;
00e4e0        clock-names = "g_pclk_sim_card";
00e4fc        status = "disabled";
00e514        phandle = < 0x19d >;
00e524     }
00e528     can@fe570000 {
00e53c        compatible = "rockchip,canfd-1.0";
00e55c        reg = < 0x0 0xfe570000 0x0 0x1000 >;
00e578        interrupts = < 0x0 0x1 0x4 >;
00e590        clocks = < 0x1f 0x141 0x1f 0x140 >;
00e5ac        clock-names = "baudclk\0apb_pclk";
00e5cc        resets = < 0x1f 0x155 0x1f 0x154 >;
00e5e8        reset-names = "can\0can-apb";
00e600        tx-fifo-depth = < 0x1 >;
00e610        rx-fifo-depth = < 0x6 >;
00e620        status = "disabled";
00e638        assigned-clocks = < 0x1f 0x141 >;
00e64c        assigned-clock-rates = < 0x8f0d180 >;
00e65c        pinctrl-names = "default";
00e670        pinctrl-0 = < 0xc8 >;
00e680        phandle = < 0x19e >;
00e690     }
00e694     can@fe580000 {
00e6a8        compatible = "rockchip,canfd-1.0";
00e6c8        reg = < 0x0 0xfe580000 0x0 0x1000 >;
00e6e4        interrupts = < 0x0 0x2 0x4 >;
00e6fc        clocks = < 0x1f 0x143 0x1f 0x142 >;
00e718        clock-names = "baudclk\0apb_pclk";
00e738        resets = < 0x1f 0x157 0x1f 0x156 >;
00e754        reset-names = "can\0can-apb";
00e76c        tx-fifo-depth = < 0x1 >;
00e77c        rx-fifo-depth = < 0x6 >;
00e78c        status = "disabled";
00e7a4        assigned-clocks = < 0x1f 0x143 >;
00e7b8        assigned-clock-rates = < 0x8f0d180 >;
00e7c8        pinctrl-names = "default";
00e7dc        pinctrl-0 = < 0xc9 >;
00e7ec        phandle = < 0x19f >;
00e7fc     }
00e800     can@fe590000 {
00e814        compatible = "rockchip,canfd-1.0";
00e834        reg = < 0x0 0xfe590000 0x0 0x1000 >;
00e850        interrupts = < 0x0 0x3 0x4 >;
00e868        clocks = < 0x1f 0x145 0x1f 0x144 >;
00e884        clock-names = "baudclk\0apb_pclk";
00e8a4        resets = < 0x1f 0x159 0x1f 0x158 >;
00e8c0        reset-names = "can\0can-apb";
00e8d8        tx-fifo-depth = < 0x1 >;
00e8e8        rx-fifo-depth = < 0x6 >;
00e8f8        status = "disabled";
00e910        assigned-clocks = < 0x1f 0x145 >;
00e924        assigned-clock-rates = < 0x8f0d180 >;
00e934        pinctrl-names = "default";
00e948        pinctrl-0 = < 0xca >;
00e958        phandle = < 0x1a0 >;
00e968     }
00e96c     i2c@fe5a0000 {
00e980        compatible = "rockchip,rk3399-i2c";
00e9a0        reg = < 0x0 0xfe5a0000 0x0 0x1000 >;
00e9bc        clocks = < 0x1f 0x148 0x1f 0x147 >;
00e9d8        clock-names = "i2c\0pclk";
00e9f0        interrupts = < 0x0 0x2f 0x4 >;
00ea08        pinctrl-names = "default";
00ea1c        pinctrl-0 = < 0xcb >;
00ea2c        #address-cells = < 0x1 >;
00ea3c        #size-cells = < 0x0 >;
00ea4c        status = "okay";
00ea60        clock-frequency = < 0x186a0 >;
00ea70        phandle = < 0x1a1 >;
00ea80        gt1x@14 {
00ea8c           compatible = "goodix,gt1x";
00eaa4           reg = < 0x14 >;
00eab4           pinctrl-names = "default";
00eac8           pinctrl-0 = < 0xcc >;
00ead8           goodix,rst-gpio = < 0x35 0xe 0x0 >;
00eaf0           goodix,irq-gpio = < 0x35 0xd 0x8 >;
00eb08           power-supply = < 0x90 >;
00eb18           status = "disabled";
00eb30           phandle = < 0x1a2 >;
00eb40        }
00eb44     }
00eb48     i2c@fe5b0000 {
00eb5c        compatible = "rockchip,rk3399-i2c";
00eb7c        reg = < 0x0 0xfe5b0000 0x0 0x1000 >;
00eb98        clocks = < 0x1f 0x14a 0x1f 0x149 >;
00ebb4        clock-names = "i2c\0pclk";
00ebcc        interrupts = < 0x0 0x30 0x4 >;
00ebe4        pinctrl-names = "default";
00ebf8        pinctrl-0 = < 0xcd >;
00ec08        #address-cells = < 0x1 >;
00ec18        #size-cells = < 0x0 >;
00ec28        status = "okay";
00ec3c        phandle = < 0x1a3 >;
00ec4c        gc2145@3c {
00ec5c           status = "okay";
00ec70           compatible = "galaxycore,gc2145";
00ec90           reg = < 0x3c >;
00eca0           clocks = < 0x1f 0xd6 >;
00ecb4           clock-names = "xvclk";
00ecc8           power-domains = < 0x21 0x8 >;
00ecdc           pinctrl-names = "default";
00ecf0           pinctrl-0 = < 0xce 0xcf 0xd0 >;
00ed08           power-gpios = < 0x7a 0x1c 0x0 >;
00ed20           pwdn-gpios = < 0x7a 0x1a 0x0 >;
00ed38           rockchip,camera-module-index = < 0x1 >;
00ed48           rockchip,camera-module-facing = "front";
00ed5c           rockchip,camera-module-name = "CameraKing";
00ed74           rockchip,camera-module-lens-name = "Largan";
00ed88           phandle = < 0x1a4 >;
00ed98           port {
00eda4              endpoint {
00edb4                 remote-endpoint = < 0xd1 >;
00edc4                 phandle = < 0x71 >;
00edd4              }
00edd8           }
00eddc        }
00ede0        ov5695@36 {
00edf0           status = "okay";
00ee04           compatible = "ovti,ov5695";
00ee1c           reg = < 0x36 >;
00ee2c           clocks = < 0x1f 0xd7 >;
00ee40           clock-names = "xvclk";
00ee54           power-domains = < 0x21 0x8 >;
00ee68           pinctrl-names = "default";
00ee7c           pinctrl-0 = < 0xd2 >;
00ee8c           reset-gpios = < 0x7a 0x18 0x0 >;
00eea4           pwdn-gpios = < 0x7a 0x16 0x0 >;
00eebc           rockchip,camera-module-index = < 0x0 >;
00eecc           rockchip,camera-module-facing = "back";
00eee0           rockchip,camera-module-name = "TongJu";
00eef4           rockchip,camera-module-lens-name = "CHT842-MD";
00ef0c           phandle = < 0x1a5 >;
00ef1c           port {
00ef28              endpoint {
00ef38                 remote-endpoint = < 0xd3 >;
00ef48                 data-lanes = < 0x1 0x2 >;
00ef5c                 phandle = < 0x106 >;
00ef6c              }
00ef70           }
00ef74        }
00ef78        gc8034@37 {
00ef88           compatible = "galaxycore,gc8034";
00efa8           status = "okay";
00efbc           reg = < 0x37 >;
00efcc           clocks = < 0x1f 0xd7 >;
00efe0           clock-names = "xvclk";
00eff4           power-domains = < 0x21 0x8 >;
00f008           pinctrl-names = "default";
00f01c           pinctrl-0 = < 0xd2 >;
00f02c           reset-gpios = < 0x7a 0x18 0x1 >;
00f044           pwdn-gpios = < 0x7a 0x16 0x1 >;
00f05c           rockchip,camera-module-index = < 0x0 >;
00f06c           rockchip,camera-module-facing = "back";
00f080           rockchip,camera-module-name = "RK-CMK-8M-2-v1";
00f09c           rockchip,camera-module-lens-name = "CK8401";
00f0b0           phandle = < 0x1a6 >;
00f0c0           port {
00f0cc              endpoint {
00f0dc                 remote-endpoint = < 0xd4 >;
00f0ec                 data-lanes = < 0x1 0x2 0x3 0x4 >;
00f108                 phandle = < 0x107 >;
00f118              }
00f11c           }
00f120        }
00f124     }
00f128     i2c@fe5c0000 {
00f13c        compatible = "rockchip,rk3399-i2c";
00f15c        reg = < 0x0 0xfe5c0000 0x0 0x1000 >;
00f178        clocks = < 0x1f 0x14c 0x1f 0x14b >;
00f194        clock-names = "i2c\0pclk";
00f1ac        interrupts = < 0x0 0x31 0x4 >;
00f1c4        pinctrl-names = "default";
00f1d8        pinctrl-0 = < 0xd5 >;
00f1e8        #address-cells = < 0x1 >;
00f1f8        #size-cells = < 0x0 >;
00f208        status = "disabled";
00f220        phandle = < 0x1a7 >;
00f230     }
00f234     i2c@fe5d0000 {
00f248        compatible = "rockchip,rk3399-i2c";
00f268        reg = < 0x0 0xfe5d0000 0x0 0x1000 >;
00f284        clocks = < 0x1f 0x14e 0x1f 0x14d >;
00f2a0        clock-names = "i2c\0pclk";
00f2b8        interrupts = < 0x0 0x32 0x4 >;
00f2d0        pinctrl-names = "default";
00f2e4        pinctrl-0 = < 0xd6 >;
00f2f4        #address-cells = < 0x1 >;
00f304        #size-cells = < 0x0 >;
00f314        status = "disabled";
00f32c        phandle = < 0x1a8 >;
00f33c     }
00f340     i2c@fe5e0000 {
00f354        compatible = "rockchip,rk3399-i2c";
00f374        reg = < 0x0 0xfe5e0000 0x0 0x1000 >;
00f390        clocks = < 0x1f 0x150 0x1f 0x14f >;
00f3ac        clock-names = "i2c\0pclk";
00f3c4        interrupts = < 0x0 0x33 0x4 >;
00f3dc        pinctrl-names = "default";
00f3f0        pinctrl-0 = < 0xd7 >;
00f400        #address-cells = < 0x1 >;
00f410        #size-cells = < 0x0 >;
00f420        status = "okay";
00f434        phandle = < 0x1a9 >;
00f444        mxc6655xa@15 {
00f458           status = "okay";
00f46c           compatible = "gs_mxc6655xa";
00f488           pinctrl-names = "default";
00f49c           pinctrl-0 = < 0xd8 >;
00f4ac           reg = < 0x15 >;
00f4bc           irq-gpio = < 0x7a 0x11 0x8 >;
00f4d4           irq_enable = < 0x0 >;
00f4e4           poll_delay_ms = < 0x1e >;
00f4f4           type = < 0x2 >;
00f504           power-off-in-suspend = < 0x1 >;
00f514           layout = < 0x1 >;
00f524           phandle = < 0x1aa >;
00f534        }
00f538     }
00f53c     timer@fe5f0000 {
00f550        compatible = "rockchip,rk3568-timer\0rockchip,rk3288-timer";
00f588        reg = < 0x0 0xfe5f0000 0x0 0x1000 >;
00f5a4        interrupts = < 0x0 0x6d 0x4 >;
00f5bc        clocks = < 0x1f 0x16c 0x1f 0x16d >;
00f5d8        clock-names = "pclk\0timer";
00f5f0        phandle = < 0x1ab >;
00f600     }
00f604     watchdog@fe600000 {
00f61c        compatible = "snps,dw-wdt";
00f634        reg = < 0x0 0xfe600000 0x0 0x100 >;
00f650        clocks = < 0x1f 0x116 0x1f 0x115 >;
00f66c        clock-names = "tclk\0pclk";
00f684        interrupts = < 0x0 0x95 0x4 >;
00f69c        status = "okay";
00f6b0        phandle = < 0x1ac >;
00f6c0     }
00f6c4     spi@fe610000 {
00f6d8        compatible = "rockchip,rk3066-spi";
00f6f8        reg = < 0x0 0xfe610000 0x0 0x1000 >;
00f714        interrupts = < 0x0 0x67 0x4 >;
00f72c        #address-cells = < 0x1 >;
00f73c        #size-cells = < 0x0 >;
00f74c        clocks = < 0x1f 0x152 0x1f 0x151 >;
00f768        clock-names = "spiclk\0apb_pclk";
00f784        dmas = < 0x3e 0x14 0x3e 0x15 >;
00f7a0        dma-names = "tx\0rx";
00f7b4        pinctrl-names = "default\0high_speed";
00f7d4        pinctrl-0 = < 0xd9 0xda 0xdb >;
00f7ec        pinctrl-1 = < 0xd9 0xda 0xdc >;
00f804        status = "disabled";
00f81c        phandle = < 0x1ad >;
00f82c     }
00f830     spi@fe620000 {
00f844        compatible = "rockchip,rk3066-spi";
00f864        reg = < 0x0 0xfe620000 0x0 0x1000 >;
00f880        interrupts = < 0x0 0x68 0x4 >;
00f898        #address-cells = < 0x1 >;
00f8a8        #size-cells = < 0x0 >;
00f8b8        clocks = < 0x1f 0x154 0x1f 0x153 >;
00f8d4        clock-names = "spiclk\0apb_pclk";
00f8f0        dmas = < 0x3e 0x16 0x3e 0x17 >;
00f90c        dma-names = "tx\0rx";
00f920        pinctrl-names = "default\0high_speed";
00f940        pinctrl-0 = < 0xdd 0xde 0xdf >;
00f958        pinctrl-1 = < 0xdd 0xde 0xe0 >;
00f970        status = "disabled";
00f988        phandle = < 0x1ae >;
00f998     }
00f99c     spi@fe630000 {
00f9b0        compatible = "rockchip,rk3066-spi";
00f9d0        reg = < 0x0 0xfe630000 0x0 0x1000 >;
00f9ec        interrupts = < 0x0 0x69 0x4 >;
00fa04        #address-cells = < 0x1 >;
00fa14        #size-cells = < 0x0 >;
00fa24        clocks = < 0x1f 0x156 0x1f 0x155 >;
00fa40        clock-names = "spiclk\0apb_pclk";
00fa5c        dmas = < 0x3e 0x18 0x3e 0x19 >;
00fa78        dma-names = "tx\0rx";
00fa8c        pinctrl-names = "default\0high_speed";
00faac        pinctrl-0 = < 0xe1 0xe2 0xe3 >;
00fac4        pinctrl-1 = < 0xe1 0xe2 0xe4 >;
00fadc        status = "disabled";
00faf4        phandle = < 0x1af >;
00fb04     }
00fb08     spi@fe640000 {
00fb1c        compatible = "rockchip,rk3066-spi";
00fb3c        reg = < 0x0 0xfe640000 0x0 0x1000 >;
00fb58        interrupts = < 0x0 0x6a 0x4 >;
00fb70        #address-cells = < 0x1 >;
00fb80        #size-cells = < 0x0 >;
00fb90        clocks = < 0x1f 0x158 0x1f 0x157 >;
00fbac        clock-names = "spiclk\0apb_pclk";
00fbc8        dmas = < 0x3e 0x1a 0x3e 0x1b >;
00fbe4        dma-names = "tx\0rx";
00fbf8        pinctrl-names = "default\0high_speed";
00fc18        pinctrl-0 = < 0xe5 0xe6 0xe7 >;
00fc30        pinctrl-1 = < 0xe5 0xe6 0xe8 >;
00fc48        status = "okay";
00fc5c        max-freq = < 0x2faf080 >;
00fc6c        phandle = < 0x1b0 >;
00fc7c        spi_testdev@00 {
00fc90           compatible = "rockchip,spidev";
00fcac           reg = < 0x0 >;
00fcbc           spi-max-frequency = < 0x4c4b40 >;
00fccc        }
00fcd0     }
00fcd4     serial@fe650000 {
00fce8        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
00fd1c        reg = < 0x0 0xfe650000 0x0 0x100 >;
00fd38        interrupts = < 0x0 0x75 0x4 >;
00fd50        clocks = < 0x1f 0x11f 0x1f 0x11c >;
00fd6c        clock-names = "baudclk\0apb_pclk";
00fd8c        reg-shift = < 0x2 >;
00fd9c        reg-io-width = < 0x4 >;
00fdac        dmas = < 0x3e 0x2 0x3e 0x3 >;
00fdc8        pinctrl-names = "default";
00fddc        pinctrl-0 = < 0xe9 0xea >;
00fdf0        status = "okay";
00fe04        phandle = < 0x1b1 >;
00fe14     }
00fe18     serial@fe660000 {
00fe2c        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
00fe60        reg = < 0x0 0xfe660000 0x0 0x100 >;
00fe7c        interrupts = < 0x0 0x76 0x4 >;
00fe94        clocks = < 0x1f 0x123 0x1f 0x120 >;
00feb0        clock-names = "baudclk\0apb_pclk";
00fed0        reg-shift = < 0x2 >;
00fee0        reg-io-width = < 0x4 >;
00fef0        dmas = < 0x3e 0x4 0x3e 0x5 >;
00ff0c        pinctrl-names = "default";
00ff20        pinctrl-0 = < 0xeb >;
00ff30        status = "disabled";
00ff48        phandle = < 0x1b2 >;
00ff58     }
00ff5c     serial@fe670000 {
00ff70        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
00ffa4        reg = < 0x0 0xfe670000 0x0 0x100 >;
00ffc0        interrupts = < 0x0 0x77 0x4 >;
00ffd8        clocks = < 0x1f 0x127 0x1f 0x124 >;
00fff4        clock-names = "baudclk\0apb_pclk";
010014        reg-shift = < 0x2 >;
010024        reg-io-width = < 0x4 >;
010034        dmas = < 0x3e 0x6 0x3e 0x7 >;
010050        pinctrl-names = "default";
010064        pinctrl-0 = < 0xec >;
010074        status = "disabled";
01008c        phandle = < 0x1b3 >;
01009c     }
0100a0     serial@fe680000 {
0100b4        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
0100e8        reg = < 0x0 0xfe680000 0x0 0x100 >;
010104        interrupts = < 0x0 0x78 0x4 >;
01011c        clocks = < 0x1f 0x12b 0x1f 0x128 >;
010138        clock-names = "baudclk\0apb_pclk";
010158        reg-shift = < 0x2 >;
010168        reg-io-width = < 0x4 >;
010178        dmas = < 0x3e 0x8 0x3e 0x9 >;
010194        pinctrl-names = "default";
0101a8        pinctrl-0 = < 0xed >;
0101b8        status = "disabled";
0101d0        phandle = < 0x1b4 >;
0101e0     }
0101e4     serial@fe690000 {
0101f8        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
01022c        reg = < 0x0 0xfe690000 0x0 0x100 >;
010248        interrupts = < 0x0 0x79 0x4 >;
010260        clocks = < 0x1f 0x12f 0x1f 0x12c >;
01027c        clock-names = "baudclk\0apb_pclk";
01029c        reg-shift = < 0x2 >;
0102ac        reg-io-width = < 0x4 >;
0102bc        dmas = < 0x3e 0xa 0x3e 0xb >;
0102d8        pinctrl-names = "default";
0102ec        pinctrl-0 = < 0xee >;
0102fc        status = "disabled";
010314        phandle = < 0x1b5 >;
010324     }
010328     serial@fe6a0000 {
01033c        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
010370        reg = < 0x0 0xfe6a0000 0x0 0x100 >;
01038c        interrupts = < 0x0 0x7a 0x4 >;
0103a4        clocks = < 0x1f 0x133 0x1f 0x130 >;
0103c0        clock-names = "baudclk\0apb_pclk";
0103e0        reg-shift = < 0x2 >;
0103f0        reg-io-width = < 0x4 >;
010400        dmas = < 0x3e 0xc 0x3e 0xd >;
01041c        pinctrl-names = "default";
010430        pinctrl-0 = < 0xef >;
010440        status = "disabled";
010458        phandle = < 0x1b6 >;
010468     }
01046c     serial@fe6b0000 {
010480        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
0104b4        reg = < 0x0 0xfe6b0000 0x0 0x100 >;
0104d0        interrupts = < 0x0 0x7b 0x4 >;
0104e8        clocks = < 0x1f 0x137 0x1f 0x134 >;
010504        clock-names = "baudclk\0apb_pclk";
010524        reg-shift = < 0x2 >;
010534        reg-io-width = < 0x4 >;
010544        dmas = < 0x3e 0xe 0x3e 0xf >;
010560        pinctrl-names = "default";
010574        pinctrl-0 = < 0xf0 >;
010584        status = "okay";
010598        phandle = < 0x1b7 >;
0105a8     }
0105ac     serial@fe6c0000 {
0105c0        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
0105f4        reg = < 0x0 0xfe6c0000 0x0 0x100 >;
010610        interrupts = < 0x0 0x7c 0x4 >;
010628        clocks = < 0x1f 0x13b 0x1f 0x138 >;
010644        clock-names = "baudclk\0apb_pclk";
010664        reg-shift = < 0x2 >;
010674        reg-io-width = < 0x4 >;
010684        dmas = < 0x3e 0x10 0x3e 0x11 >;
0106a0        pinctrl-names = "default";
0106b4        pinctrl-0 = < 0xf1 >;
0106c4        status = "disabled";
0106dc        phandle = < 0x1b8 >;
0106ec     }
0106f0     serial@fe6d0000 {
010704        compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
010738        reg = < 0x0 0xfe6d0000 0x0 0x100 >;
010754        interrupts = < 0x0 0x7d 0x4 >;
01076c        clocks = < 0x1f 0x13f 0x1f 0x13c >;
010788        clock-names = "baudclk\0apb_pclk";
0107a8        reg-shift = < 0x2 >;
0107b8        reg-io-width = < 0x4 >;
0107c8        dmas = < 0x3e 0x12 0x3e 0x13 >;
0107e4        pinctrl-names = "default";
0107f8        pinctrl-0 = < 0xf2 >;
010808        status = "disabled";
010820        phandle = < 0x1b9 >;
010830     }
010834     pwm@fe6e0000 {
010848        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
01087c        reg = < 0x0 0xfe6e0000 0x0 0x10 >;
010898        #pwm-cells = < 0x3 >;
0108a8        pinctrl-names = "active";
0108bc        pinctrl-0 = < 0xf3 >;
0108cc        clocks = < 0x1f 0x15a 0x1f 0x159 >;
0108e8        clock-names = "pwm\0pclk";
010900        status = "okay";
010914        phandle = < 0x11c >;
010924     }
010928     pwm@fe6e0010 {
01093c        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
010970        reg = < 0x0 0xfe6e0010 0x0 0x10 >;
01098c        #pwm-cells = < 0x3 >;
01099c        pinctrl-names = "active";
0109b0        pinctrl-0 = < 0xf4 >;
0109c0        clocks = < 0x1f 0x15a 0x1f 0x159 >;
0109dc        clock-names = "pwm\0pclk";
0109f4        status = "okay";
010a08        phandle = < 0x11d >;
010a18     }
010a1c     pwm@fe6e0020 {
010a30        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
010a64        reg = < 0x0 0xfe6e0020 0x0 0x10 >;
010a80        #pwm-cells = < 0x3 >;
010a90        pinctrl-names = "active";
010aa4        pinctrl-0 = < 0xf5 >;
010ab4        clocks = < 0x1f 0x15a 0x1f 0x159 >;
010ad0        clock-names = "pwm\0pclk";
010ae8        status = "disabled";
010b00        phandle = < 0x1ba >;
010b10     }
010b14     pwm@fe6e0030 {
010b28        compatible = "rockchip,remotectl-pwm";
010b4c        reg = < 0x0 0xfe6e0030 0x0 0x10 >;
010b68        interrupts = < 0x0 0x53 0x4 0x0 0x57 0x4 >;
010b8c        #pwm-cells = < 0x3 >;
010b9c        pinctrl-names = "default";
010bb0        pinctrl-0 = < 0xf6 >;
010bc0        clocks = < 0x1f 0x15a 0x1f 0x159 >;
010bdc        clock-names = "pwm\0pclk";
010bf4        status = "disabled";
010c0c        remote_pwm_id = < 0x3 >;
010c1c        handle_cpu_id = < 0x1 >;
010c2c        remote_support_psci = < 0x0 >;
010c3c        phandle = < 0x1bb >;
010c4c        ir_key1 {
010c58           rockchip,usercode = < 0x4040 >;
010c68           rockchip,key_table = < 0xf2 0xe8 0xba 0x9e 0xf4 0x67 0xf1 0x6c 0xef 0x69 0xee 0x6a 0xbd 0x66 0xea 0x73 0xe3 0x72 0xe2 0xd9 0xb2 0x74 0xbc 0x71 0xec 0x8b 0xbf 0x190 0xe0 0x191 0xe1 0x192 0xe9 0xb7 0xe6 0xf8 0xe8 0xb9 0xe7 0xba 0xf0 0x184 0xbe 0x175 >;
010d24        }
010d28        ir_key2 {
010d34           rockchip,usercode = < 0xff00 >;
010d44           rockchip,key_table = < 0xf9 0x66 0xbf 0x9e 0xfb 0x8b 0xaa 0xe8 0xb9 0x67 0xe9 0x6c 0xb8 0x69 0xea 0x6a 0xeb 0x72 0xef 0x73 0xf7 0x71 0xe7 0x74 0xfc 0x74 0xa9 0x72 0xa8 0x72 0xe0 0x72 0xa5 0x72 0xab 0xb7 0xb7 0x184 0xe8 0x184 0xf8 0xb8 0xaf 0xb9 0xed 0x72 0xee 0xba 0xb3 0x72 0xf1 0x72 0xf2 0x72 0xf3 0xd9 0xb4 0x72 0xbe 0xd9 >;
010e40        }
010e44        ir_key3 {
010e50           rockchip,usercode = < 0x1dcc >;
010e60           rockchip,key_table = < 0xee 0xe8 0xf0 0x9e 0xf8 0x67 0xbb 0x6c 0xef 0x69 0xed 0x6a 0xfc 0x66 0xf1 0x73 0xfd 0x72 0xb7 0xd9 0xff 0x74 0xf3 0x71 0xbf 0x8b 0xf9 0x191 0xf5 0x192 0xb3 0x184 0xbe 0x2 0xba 0x3 0xb2 0x4 0xbd 0x5 0xf9 0x6 0xb1 0x7 0xfc 0x8 0xf8 0x9 0xb0 0xa 0xb6 0xb 0xb5 0xe >;
010f44        }
010f48     }
010f4c     pwm@fe6f0000 {
010f60        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
010f94        reg = < 0x0 0xfe6f0000 0x0 0x10 >;
010fb0        #pwm-cells = < 0x3 >;
010fc0        pinctrl-names = "active";
010fd4        pinctrl-0 = < 0xf7 >;
010fe4        clocks = < 0x1f 0x15d 0x1f 0x15c >;
011000        clock-names = "pwm\0pclk";
011018        status = "disabled";
011030        phandle = < 0x1bc >;
011040     }
011044     pwm@fe6f0010 {
011058        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
01108c        reg = < 0x0 0xfe6f0010 0x0 0x10 >;
0110a8        #pwm-cells = < 0x3 >;
0110b8        pinctrl-names = "active";
0110cc        pinctrl-0 = < 0xf8 >;
0110dc        clocks = < 0x1f 0x15d 0x1f 0x15c >;
0110f8        clock-names = "pwm\0pclk";
011110        status = "disabled";
011128        phandle = < 0x1bd >;
011138     }
01113c     pwm@fe6f0020 {
011150        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
011184        reg = < 0x0 0xfe6f0020 0x0 0x10 >;
0111a0        #pwm-cells = < 0x3 >;
0111b0        pinctrl-names = "active";
0111c4        pinctrl-0 = < 0xf9 >;
0111d4        clocks = < 0x1f 0x15d 0x1f 0x15c >;
0111f0        clock-names = "pwm\0pclk";
011208        status = "disabled";
011220        phandle = < 0x1be >;
011230     }
011234     pwm@fe6f0030 {
011248        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
01127c        reg = < 0x0 0xfe6f0030 0x0 0x10 >;
011298        interrupts = < 0x0 0x54 0x4 0x0 0x58 0x4 >;
0112bc        #pwm-cells = < 0x3 >;
0112cc        pinctrl-names = "active";
0112e0        pinctrl-0 = < 0xfa >;
0112f0        clocks = < 0x1f 0x15d 0x1f 0x15c >;
01130c        clock-names = "pwm\0pclk";
011324        status = "disabled";
01133c        phandle = < 0x1bf >;
01134c     }
011350     pwm@fe700000 {
011364        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
011398        reg = < 0x0 0xfe700000 0x0 0x10 >;
0113b4        #pwm-cells = < 0x3 >;
0113c4        pinctrl-names = "active";
0113d8        pinctrl-0 = < 0xfb >;
0113e8        clocks = < 0x1f 0x160 0x1f 0x15f >;
011404        clock-names = "pwm\0pclk";
01141c        status = "disabled";
011434        phandle = < 0x1c0 >;
011444     }
011448     pwm@fe700010 {
01145c        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
011490        reg = < 0x0 0xfe700010 0x0 0x10 >;
0114ac        #pwm-cells = < 0x3 >;
0114bc        pinctrl-names = "active";
0114d0        pinctrl-0 = < 0xfc >;
0114e0        clocks = < 0x1f 0x160 0x1f 0x15f >;
0114fc        clock-names = "pwm\0pclk";
011514        status = "disabled";
01152c        phandle = < 0x1c1 >;
01153c     }
011540     pwm@fe700020 {
011554        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
011588        reg = < 0x0 0xfe700020 0x0 0x10 >;
0115a4        #pwm-cells = < 0x3 >;
0115b4        pinctrl-names = "active";
0115c8        pinctrl-0 = < 0xfd >;
0115d8        clocks = < 0x1f 0x160 0x1f 0x15f >;
0115f4        clock-names = "pwm\0pclk";
01160c        status = "disabled";
011624        phandle = < 0x1c2 >;
011634     }
011638     pwm@fe700030 {
01164c        compatible = "rockchip,rk3568-pwm\0rockchip,rk3328-pwm";
011680        reg = < 0x0 0xfe700030 0x0 0x10 >;
01169c        interrupts = < 0x0 0x55 0x4 0x0 0x59 0x4 >;
0116c0        #pwm-cells = < 0x3 >;
0116d0        pinctrl-names = "active";
0116e4        pinctrl-0 = < 0xfe >;
0116f4        clocks = < 0x1f 0x160 0x1f 0x15f >;
011710        clock-names = "pwm\0pclk";
011728        status = "disabled";
011740        phandle = < 0x1c3 >;
011750     }
011754     tsadc@fe710000 {
011768        compatible = "rockchip,rk3568-tsadc";
01178c        reg = < 0x0 0xfe710000 0x0 0x100 >;
0117a8        interrupts = < 0x0 0x73 0x4 >;
0117c0        rockchip,grf = < 0x32 >;
0117d0        clocks = < 0x1f 0x111 0x1f 0x10f >;
0117ec        clock-names = "tsadc\0apb_pclk";
011808        assigned-clocks = < 0x1f 0x110 0x1f 0x111 >;
011824        assigned-clock-rates = < 0x1036640 0xaae60 >;
011838        resets = < 0x1f 0x182 0x1f 0x181 0x1f 0x1d7 >;
01185c        reset-names = "tsadc\0tsadc-apb\0tsadc-phy";
011884        #thermal-sensor-cells = < 0x1 >;
011894        rockchip,hw-tshut-temp = < 0x1d4c0 >;
0118a4        rockchip,hw-tshut-mode = < 0x0 >;
0118b4        rockchip,hw-tshut-polarity = < 0x0 >;
0118c4        pinctrl-names = "gpio\0otpout";
0118dc        pinctrl-0 = < 0xff >;
0118ec        pinctrl-1 = < 0x100 >;
0118fc        status = "okay";
011910        phandle = < 0x1b >;
011920     }
011924     saradc@fe720000 {
011938        compatible = "rockchip,rk3568-saradc\0rockchip,rk3399-saradc";
011974        reg = < 0x0 0xfe720000 0x0 0x100 >;
011990        interrupts = < 0x0 0x5d 0x4 >;
0119a8        #io-channel-cells = < 0x1 >;
0119b8        clocks = < 0x1f 0x113 0x1f 0x112 >;
0119d4        clock-names = "saradc\0apb_pclk";
0119f0        resets = < 0x1f 0x180 >;
011a04        reset-names = "saradc-apb";
011a1c        status = "okay";
011a30        vref-supply = < 0x101 >;
011a40        phandle = < 0x118 >;
011a50     }
011a54     mailbox@fe780000 {
011a6c        compatible = "rockchip,rk3568-mailbox\0rockchip,rk3368-mailbox";
011aa8        reg = < 0x0 0xfe780000 0x0 0x1000 >;
011ac4        interrupts = < 0x0 0xb7 0x4 0x0 0xb8 0x4 0x0 0xb9 0x4 0x0 0xba 0x4 >;
011b00        clocks = < 0x1f 0x11b >;
011b14        clock-names = "pclk_mailbox";
011b30        #mbox-cells = < 0x1 >;
011b40        status = "disabled";
011b58        phandle = < 0x1c4 >;
011b68     }
011b6c     phy@fe830000 {
011b80        compatible = "rockchip,rk3568-naneng-combphy";
011bac        reg = < 0x0 0xfe830000 0x0 0x100 >;
011bc8        #phy-cells = < 0x1 >;
011bd8        clocks = < 0x31 0x22 0x1f 0x17d 0x1f 0x7f >;
011bfc        clock-names = "refclk\0apbclk\0pipe_clk";
011c20        assigned-clocks = < 0x31 0x22 >;
011c34        assigned-clock-rates = < 0x5f5e100 >;
011c44        resets = < 0x1f 0x1c6 0x1f 0x1c7 >;
011c60        reset-names = "combphy-apb\0combphy";
011c80        rockchip,pipe-grf = < 0x102 >;
011c90        rockchip,pipe-phy-grf = < 0x103 >;
011ca0        status = "okay";
011cb4        phandle = < 0x20 >;
011cc4     }
011cc8     phy@fe840000 {
011cdc        compatible = "rockchip,rk3568-naneng-combphy";
011d08        reg = < 0x0 0xfe840000 0x0 0x100 >;
011d24        #phy-cells = < 0x1 >;
011d34        clocks = < 0x31 0x25 0x1f 0x17e 0x1f 0x7f >;
011d58        clock-names = "refclk\0apbclk\0pipe_clk";
011d7c        assigned-clocks = < 0x31 0x25 >;
011d90        assigned-clock-rates = < 0x5f5e100 >;
011da0        resets = < 0x1f 0x1c8 0x1f 0x1c9 >;
011dbc        reset-names = "combphy-apb\0combphy";
011ddc        rockchip,pipe-grf = < 0x102 >;
011dec        rockchip,pipe-phy-grf = < 0x104 >;
011dfc        status = "disabled";
011e14        phandle = < 0x22 >;
011e24     }
011e28     video-phy@fe850000 {
011e40        compatible = "rockchip,rk3568-video-phy";
011e68        reg = < 0x0 0xfe850000 0x0 0x10000 0x0 0xfe060000 0x0 0x10000 >;
011e94        clocks = < 0x31 0x17 0x1f 0x17a 0x1f 0xe8 >;
011eb8        clock-names = "ref\0pclk_phy\0pclk_host";
011edc        #clock-cells = < 0x0 >;
011eec        resets = < 0x1f 0x1bb >;
011f00        reset-names = "rst";
011f10        power-domains = < 0x21 0x9 >;
011f24        #phy-cells = < 0x0 >;
011f34        status = "okay";
011f48        phandle = < 0x2e >;
011f58     }
011f5c     video-phy@fe860000 {
011f74        compatible = "rockchip,rk3568-video-phy";
011f9c        reg = < 0x0 0xfe860000 0x0 0x10000 0x0 0xfe070000 0x0 0x10000 >;
011fc8        clocks = < 0x31 0x19 0x1f 0x17b 0x1f 0xe9 >;
011fec        clock-names = "ref\0pclk_phy\0pclk_host";
012010        #clock-cells = < 0x0 >;
012020        resets = < 0x1f 0x1bc >;
012034        reset-names = "rst";
012044        power-domains = < 0x21 0x9 >;
012058        #phy-cells = < 0x0 >;
012068        status = "disabled";
012080        phandle = < 0x95 >;
012090     }
012094     csi2-dphy-hw@fe870000 {
0120b0        compatible = "rockchip,rk3568-csi2-dphy-hw";
0120dc        reg = < 0x0 0xfe870000 0x0 0x1000 >;
0120f8        clocks = < 0x1f 0x179 >;
01210c        clock-names = "pclk";
012120        rockchip,grf = < 0x32 >;
012130        status = "okay";
012144        phandle = < 0x105 >;
012154     }
012158     csi2-dphy0 {
012168        compatible = "rockchip,rk3568-csi2-dphy";
012190        rockchip,hw = < 0x105 >;
0121a0        status = "okay";
0121b4        phandle = < 0x1c5 >;
0121c4        ports {
0121d0           #address-cells = < 0x1 >;
0121e0           #size-cells = < 0x0 >;
0121f0           port@0 {
0121fc              reg = < 0x0 >;
01220c              #address-cells = < 0x1 >;
01221c              #size-cells = < 0x0 >;
01222c              endpoint@1 {
01223c                 reg = < 0x1 >;
01224c                 remote-endpoint = < 0x106 >;
01225c                 data-lanes = < 0x1 0x2 >;
012270                 phandle = < 0xd3 >;
012280              }
012284              endpoint@2 {
012294                 reg = < 0x2 >;
0122a4                 remote-endpoint = < 0x107 >;
0122b4                 data-lanes = < 0x1 0x2 0x3 0x4 >;
0122d0                 phandle = < 0xd4 >;
0122e0              }
0122e4           }
0122e8           port@1 {
0122f4              reg = < 0x1 >;
012304              #address-cells = < 0x1 >;
012314              #size-cells = < 0x0 >;
012324              endpoint@0 {
012334                 reg = < 0x0 >;
012344                 remote-endpoint = < 0x108 >;
012354                 phandle = < 0x76 >;
012364              }
012368           }
01236c        }
012370     }
012374     csi2-dphy1 {
012384        compatible = "rockchip,rk3568-csi2-dphy";
0123ac        rockchip,hw = < 0x105 >;
0123bc        status = "disabled";
0123d4        phandle = < 0x1c6 >;
0123e4     }
0123e8     csi2-dphy2 {
0123f8        compatible = "rockchip,rk3568-csi2-dphy";
012420        rockchip,hw = < 0x105 >;
012430        status = "disabled";
012448        phandle = < 0x1c7 >;
012458     }
01245c     usb2-phy@fe8a0000 {
012474        compatible = "rockchip,rk3568-usb2phy";
012498        reg = < 0x0 0xfe8a0000 0x0 0x10000 >;
0124b4        interrupts = < 0x0 0x87 0x4 >;
0124cc        clocks = < 0x31 0x13 >;
0124e0        clock-names = "phyclk";
0124f4        #clock-cells = < 0x0 >;
012504        assigned-clocks = < 0x1f 0xb >;
012518        assigned-clock-parents = < 0x24 >;
012528        clock-output-names = "usb480m_phy";
012540        rockchip,usbgrf = < 0x109 >;
012550        status = "okay";
012564        phandle = < 0x24 >;
012574        host-port {
012584           #phy-cells = < 0x0 >;
012594           status = "okay";
0125a8           phy-supply = < 0x10a >;
0125b8           phandle = < 0x25 >;
0125c8        }
0125cc        otg-port {
0125dc           #phy-cells = < 0x0 >;
0125ec           status = "okay";
012600           vbus-supply = < 0x10b >;
012610           phandle = < 0x23 >;
012620        }
012624     }
012628     usb2-phy@fe8b0000 {
012640        compatible = "rockchip,rk3568-usb2phy";
012664        reg = < 0x0 0xfe8b0000 0x0 0x10000 >;
012680        interrupts = < 0x0 0x88 0x4 >;
012698        clocks = < 0x31 0x15 >;
0126ac        clock-names = "phyclk";
0126c0        #clock-cells = < 0x0 >;
0126d0        rockchip,usbgrf = < 0x10c >;
0126e0        status = "okay";
0126f4        phandle = < 0x26 >;
012704        host-port {
012714           #phy-cells = < 0x0 >;
012724           status = "okay";
012738           phy-supply = < 0x10a >;
012748           phandle = < 0x28 >;
012758        }
01275c        otg-port {
01276c           #phy-cells = < 0x0 >;
01277c           status = "okay";
012790           phy-supply = < 0x10a >;
0127a0           phandle = < 0x27 >;
0127b0        }
0127b4     }
0127b8     pinctrl {
0127c4        compatible = "rockchip,rk3568-pinctrl";
0127e8        rockchip,grf = < 0x32 >;
0127f8        rockchip,pmu = < 0x33 >;
012808        #address-cells = < 0x2 >;
012818        #size-cells = < 0x2 >;
012828        ranges;
012834        phandle = < 0x10d >;
012844        gpio@fdd60000 {
012858           compatible = "rockchip,gpio-bank";
012878           reg = < 0x0 0xfdd60000 0x0 0x100 >;
012894           interrupts = < 0x0 0x21 0x4 >;
0128ac           clocks = < 0x31 0x2e 0x31 0xc >;
0128c8           gpio-controller;
0128d4           #gpio-cells = < 0x2 >;
0128e4           gpio-ranges = < 0x10d 0x0 0x0 0x20 >;
012900           interrupt-controller;
01290c           #interrupt-cells = < 0x2 >;
01291c           phandle = < 0x35 >;
01292c        }
012930        gpio@fe740000 {
012944           compatible = "rockchip,gpio-bank";
012964           reg = < 0x0 0xfe740000 0x0 0x100 >;
012980           interrupts = < 0x0 0x22 0x4 >;
012998           clocks = < 0x1f 0x163 0x1f 0x164 >;
0129b4           gpio-controller;
0129c0           #gpio-cells = < 0x2 >;
0129d0           gpio-ranges = < 0x10d 0x0 0x20 0x20 >;
0129ec           interrupt-controller;
0129f8           #interrupt-cells = < 0x2 >;
012a08           phandle = < 0x91 >;
012a18        }
012a1c        gpio@fe750000 {
012a30           compatible = "rockchip,gpio-bank";
012a50           reg = < 0x0 0xfe750000 0x0 0x100 >;
012a6c           interrupts = < 0x0 0x23 0x4 >;
012a84           clocks = < 0x1f 0x165 0x1f 0x166 >;
012aa0           gpio-controller;
012aac           #gpio-cells = < 0x2 >;
012abc           gpio-ranges = < 0x10d 0x0 0x40 0x20 >;
012ad8           interrupt-controller;
012ae4           #interrupt-cells = < 0x2 >;
012af4           phandle = < 0x12c >;
012b04        }
012b08        gpio@fe760000 {
012b1c           compatible = "rockchip,gpio-bank";
012b3c           reg = < 0x0 0xfe760000 0x0 0x100 >;
012b58           interrupts = < 0x0 0x24 0x4 >;
012b70           clocks = < 0x1f 0x167 0x1f 0x168 >;
012b8c           gpio-controller;
012b98           #gpio-cells = < 0x2 >;
012ba8           gpio-ranges = < 0x10d 0x0 0x60 0x20 >;
012bc4           interrupt-controller;
012bd0           #interrupt-cells = < 0x2 >;
012be0           phandle = < 0x7a >;
012bf0        }
012bf4        gpio@fe770000 {
012c08           compatible = "rockchip,gpio-bank";
012c28           reg = < 0x0 0xfe770000 0x0 0x100 >;
012c44           interrupts = < 0x0 0x25 0x4 >;
012c5c           clocks = < 0x1f 0x169 0x1f 0x16a >;
012c78           gpio-controller;
012c84           #gpio-cells = < 0x2 >;
012c94           gpio-ranges = < 0x10d 0x0 0x80 0x20 >;
012cb0           interrupt-controller;
012cbc           #interrupt-cells = < 0x2 >;
012ccc           phandle = < 0x9a >;
012cdc        }
012ce0        pcfg-pull-up {
012cf4           bias-pull-up;
012d00           phandle = < 0x110 >;
012d10        }
012d14        pcfg-pull-down {
012d28           bias-pull-down;
012d34           phandle = < 0x117 >;
012d44        }
012d48        pcfg-pull-none {
012d5c           bias-disable;
012d68           phandle = < 0x10e >;
012d78        }
012d7c        pcfg-pull-none-drv-level-1 {
012d9c           bias-disable;
012da8           drive-strength = < 0x1 >;
012db8           phandle = < 0x112 >;
012dc8        }
012dcc        pcfg-pull-none-drv-level-2 {
012dec           bias-disable;
012df8           drive-strength = < 0x2 >;
012e08           phandle = < 0x111 >;
012e18        }
012e1c        pcfg-pull-none-drv-level-3 {
012e3c           bias-disable;
012e48           drive-strength = < 0x3 >;
012e58           phandle = < 0x116 >;
012e68        }
012e6c        pcfg-pull-up-drv-level-1 {
012e8c           bias-pull-up;
012e98           drive-strength = < 0x1 >;
012ea8           phandle = < 0x115 >;
012eb8        }
012ebc        pcfg-pull-up-drv-level-2 {
012edc           bias-pull-up;
012ee8           drive-strength = < 0x2 >;
012ef8           phandle = < 0x10f >;
012f08        }
012f0c        pcfg-pull-none-smt {
012f24           bias-disable;
012f30           input-schmitt-enable;
012f3c           phandle = < 0x113 >;
012f4c        }
012f50        pcfg-output-low-pull-down {
012f70           output-low;
012f7c           bias-pull-down;
012f88           phandle = < 0x114 >;
012f98        }
012f9c        acodec {
012fa8           acodec-pins {
012fb8              rockchip,pins = < 0x1 0x9 0x5 0x10e 0x1 0x1 0x5 0x10e 0x1 0x0 0x5 0x10e 0x1 0x7 0x5 0x10e 0x1 0x8 0x5 0x10e 0x1 0x3 0x5 0x10e 0x1 0x5 0x5 0x10e >;
013034              phandle = < 0xc6 >;
013044           }
013048        }
01304c        cam {
013054           cam-clkout0 {
013064              rockchip,pins = < 0x4 0x7 0x1 0x10e >;
013080              phandle = < 0xd2 >;
013090           }
013094           camera-pwr {
0130a4              rockchip,pins = < 0x0 0x11 0x0 0x10e >;
0130c0              phandle = < 0x131 >;
0130d0           }
0130d4        }
0130d8        can0 {
0130e4           can0m1-pins {
0130f4              rockchip,pins = < 0x2 0x2 0x4 0x10e 0x2 0x1 0x4 0x10e >;
013120              phandle = < 0xc8 >;
013130           }
013134        }
013138        can1 {
013144           can1m1-pins {
013154              rockchip,pins = < 0x4 0x12 0x3 0x10e 0x4 0x13 0x3 0x10e >;
013180              phandle = < 0xc9 >;
013190           }
013194        }
013198        can2 {
0131a4           can2m1-pins {
0131b4              rockchip,pins = < 0x2 0x9 0x4 0x10e 0x2 0xa 0x4 0x10e >;
0131e0              phandle = < 0xca >;
0131f0           }
0131f4        }
0131f8        cif {
013200           cif-clk {
01320c              rockchip,pins = < 0x4 0x10 0x1 0x10e >;
013228              phandle = < 0xce >;
013238           }
01323c           cif-dvp-clk {
01324c              rockchip,pins = < 0x4 0x11 0x1 0x10e 0x4 0xe 0x1 0x10e 0x4 0xf 0x1 0x10e >;
013288              phandle = < 0xcf >;
013298           }
01329c           cif-dvp-bus16 {
0132b0              rockchip,pins = < 0x3 0x1e 0x1 0x10e 0x3 0x1f 0x1 0x10e 0x4 0x0 0x1 0x10e 0x4 0x1 0x1 0x10e 0x4 0x2 0x1 0x10e 0x4 0x3 0x1 0x10e 0x4 0x4 0x1 0x10e 0x4 0x5 0x1 0x10e >;
01333c              phandle = < 0xd0 >;
01334c           }
013350        }
013354        clk32k {
013360           clk32k-out0 {
013370              rockchip,pins = < 0x0 0x8 0x2 0x10e >;
01338c              phandle = < 0x1e >;
01339c           }
0133a0        }
0133a4        ebc {
0133ac           ebc-pins {
0133bc              rockchip,pins = < 0x4 0x10 0x2 0x10e 0x4 0xb 0x2 0x10e 0x4 0xc 0x2 0x10e 0x4 0x6 0x2 0x10e 0x4 0x11 0x2 0x10e 0x3 0x16 0x2 0x10e 0x3 0x17 0x2 0x10e 0x3 0x18 0x2 0x10e 0x3 0x19 0x2 0x10e 0x3 0x1a 0x2 0x10e 0x3 0x1b 0x2 0x10e 0x3 0x1c 0x2 0x10e 0x3 0x1d 0x2 0x10e 0x3 0x1e 0x2 0x10e 0x3 0x1f 0x2 0x10e 0x4 0x0 0x2 0x10e 0x4 0x1 0x2 0x10e 0x4 0x2 0x2 0x10e 0x4 0x3 0x2 0x10e 0x4 0x4 0x2 0x10e 0x4 0x5 0x2 0x10e 0x4 0xe 0x2 0x10e 0x4 0xf 0x2 0x10e >;
013538              phandle = < 0x67 >;
013548           }
01354c        }
013550        gmac1 {
01355c           gmac1m0-miim {
013570              rockchip,pins = < 0x3 0x14 0x3 0x10e 0x3 0x15 0x3 0x10e >;
01359c              phandle = < 0x7b >;
0135ac           }
0135b0           gmac1m0-rx-bus2 {
0135c4              rockchip,pins = < 0x3 0x9 0x3 0x10e 0x3 0xa 0x3 0x10e 0x3 0xb 0x3 0x10e >;
013600              phandle = < 0x7d >;
013610           }
013614        }
013618        hdmitx {
013624           hdmitxm0-cec {
013638              rockchip,pins = < 0x4 0x19 0x1 0x10e >;
013654              phandle = < 0xa0 >;
013664           }
013668           hdmitx-scl {
013678              rockchip,pins = < 0x4 0x17 0x1 0x10e >;
013694              phandle = < 0x9e >;
0136a4           }
0136a8           hdmitx-sda {
0136b8              rockchip,pins = < 0x4 0x18 0x1 0x10e >;
0136d4              phandle = < 0x9f >;
0136e4           }
0136e8        }
0136ec        i2c0 {
0136f8           i2c0-xfer {
013708              rockchip,pins = < 0x0 0x9 0x1 0x113 0x0 0xa 0x1 0x113 >;
013734              phandle = < 0x34 >;
013744           }
013748        }
01374c        i2c1 {
013758           i2c1-xfer {
013768              rockchip,pins = < 0x0 0xb 0x1 0x113 0x0 0xc 0x1 0x113 >;
013794              phandle = < 0xcb >;
0137a4           }
0137a8        }
0137ac        i2c2 {
0137b8           i2c2m1-xfer {
0137c8              rockchip,pins = < 0x4 0xd 0x1 0x113 0x4 0xc 0x1 0x113 >;
0137f4              phandle = < 0xcd >;
013804           }
013808        }
01380c        i2c3 {
013818           i2c3m0-xfer {
013828              rockchip,pins = < 0x1 0x1 0x1 0x113 0x1 0x0 0x1 0x113 >;
013854              phandle = < 0xd5 >;
013864           }
013868        }
01386c        i2c4 {
013878           i2c4m0-xfer {
013888              rockchip,pins = < 0x4 0xb 0x1 0x113 0x4 0xa 0x1 0x113 >;
0138b4              phandle = < 0xd6 >;
0138c4           }
0138c8        }
0138cc        i2c5 {
0138d8           i2c5m0-xfer {
0138e8              rockchip,pins = < 0x3 0xb 0x4 0x113 0x3 0xc 0x4 0x113 >;
013914              phandle = < 0xd7 >;
013924           }
013928        }
01392c        i2s1 {
013938           i2s1m0-lrcktx {
01394c              rockchip,pins = < 0x1 0x5 0x1 0x10e >;
013968              phandle = < 0xb5 >;
013978           }
01397c           i2s1m0-sclktx {
013990              rockchip,pins = < 0x1 0x3 0x1 0x10e >;
0139ac              phandle = < 0xb4 >;
0139bc           }
0139c0           i2s1m0-sdi0 {
0139d0              rockchip,pins = < 0x1 0xb 0x1 0x10e >;
0139ec              phandle = < 0xb6 >;
0139fc           }
013a00           i2s1m0-sdo0 {
013a10              rockchip,pins = < 0x1 0x7 0x1 0x10e >;
013a2c              phandle = < 0xb7 >;
013a3c           }
013a40        }
013a44        i2s2 {
013a50           i2s2m0-lrcktx {
013a64              rockchip,pins = < 0x2 0x13 0x1 0x10e >;
013a80              phandle = < 0xb9 >;
013a90           }
013a94           i2s2m0-sclktx {
013aa8              rockchip,pins = < 0x2 0x12 0x1 0x10e >;
013ac4              phandle = < 0xb8 >;
013ad4           }
013ad8           i2s2m0-sdi {
013ae8              rockchip,pins = < 0x2 0x15 0x1 0x10e >;
013b04              phandle = < 0xba >;
013b14           }
013b18           i2s2m0-sdo {
013b28              rockchip,pins = < 0x2 0x14 0x1 0x10e >;
013b44              phandle = < 0xbb >;
013b54           }
013b58        }
013b5c        i2s3 {
013b68           i2s3m1-lrck {
013b78              rockchip,pins = < 0x4 0x14 0x5 0x10e >;
013b94              phandle = < 0xbd >;
013ba4           }
013ba8           i2s3m1-sclk {
013bb8              rockchip,pins = < 0x4 0x13 0x5 0x10e >;
013bd4              phandle = < 0xbc >;
013be4           }
013be8           i2s3m1-sdi {
013bf8              rockchip,pins = < 0x4 0x16 0x5 0x10e >;
013c14              phandle = < 0xbe >;
013c24           }
013c28           i2s3m1-sdo {
013c38              rockchip,pins = < 0x4 0x15 0x5 0x10e >;
013c54              phandle = < 0xbf >;
013c64           }
013c68        }
013c6c        lcdc {
013c78           lcdc-ctl {
013c88              rockchip,pins = < 0x3 0x0 0x1 0x10e 0x2 0x18 0x1 0x10e 0x2 0x19 0x1 0x10e 0x2 0x1a 0x1 0x10e 0x2 0x1b 0x1 0x10e 0x2 0x1c 0x1 0x10e 0x2 0x1d 0x1 0x10e 0x2 0x1e 0x1 0x10e 0x2 0x1f 0x1 0x10e 0x3 0x1 0x1 0x10e 0x3 0x2 0x1 0x10e 0x3 0x3 0x1 0x10e 0x3 0x4 0x1 0x10e 0x3 0x5 0x1 0x10e 0x3 0x6 0x1 0x10e 0x3 0x7 0x1 0x10e 0x3 0x8 0x1 0x10e 0x3 0x9 0x1 0x10e 0x3 0xa 0x1 0x10e 0x3 0xb 0x1 0x10e 0x3 0xc 0x1 0x10e 0x3 0xd 0x1 0x10e 0x3 0xe 0x1 0x10e 0x3 0xf 0x1 0x10e 0x3 0x10 0x1 0x10e 0x3 0x13 0x1 0x10e 0x3 0x11 0x1 0x10e 0x3 0x12 0x1 0x10e >;
013e54              phandle = < 0x30 >;
013e64           }
013e68        }
013e6c        pdm {
013e74           pdmm1-clk1 {
013e84              rockchip,pins = < 0x4 0x0 0x4 0x10e >;
013ea0              phandle = < 0xc0 >;
013eb0           }
013eb4           pdmm1-sdi1 {
013ec4              rockchip,pins = < 0x4 0x1 0x4 0x10e >;
013ee0              phandle = < 0xc1 >;
013ef0           }
013ef4           pdmm1-sdi2 {
013f04              rockchip,pins = < 0x4 0x2 0x5 0x10e >;
013f20              phandle = < 0xc2 >;
013f30           }
013f34           pdmm1-sdi3 {
013f44              rockchip,pins = < 0x4 0x3 0x5 0x10e >;
013f60              phandle = < 0xc3 >;
013f70           }
013f74        }
013f78        pmic {
013f84           pmic_int {
013f94              rockchip,pins = < 0x0 0x3 0x0 0x110 >;
013fb0              phandle = < 0x36 >;
013fc0           }
013fc4           soc_slppin_gpio {
013fd8              rockchip,pins = < 0x0 0x2 0x0 0x114 >;
013ff4              phandle = < 0x39 >;
014004           }
014008           soc_slppin_slp {
01401c              rockchip,pins = < 0x0 0x2 0x1 0x110 >;
014038              phandle = < 0x37 >;
014048           }
01404c           soc_slppin_rst {
014060              rockchip,pins = < 0x0 0x2 0x2 0x10e >;
01407c              phandle = < 0x1c8 >;
01408c           }
014090        }
014094        pwm0 {
0140a0           pwm0m0-pins {
0140b0              rockchip,pins = < 0x0 0xf 0x1 0x10e >;
0140cc              phandle = < 0x40 >;
0140dc           }
0140e0        }
0140e4        pwm1 {
0140f0           pwm1m0-pins {
014100              rockchip,pins = < 0x0 0x10 0x1 0x10e >;
01411c              phandle = < 0x41 >;
01412c           }
014130        }
014134        pwm2 {
014140           pwm2m0-pins {
014150              rockchip,pins = < 0x0 0x11 0x1 0x10e >;
01416c              phandle = < 0x42 >;
01417c           }
014180        }
014184        pwm3 {
014190           pwm3-pins {
0141a0              rockchip,pins = < 0x0 0x12 0x1 0x10e >;
0141bc              phandle = < 0x43 >;
0141cc           }
0141d0        }
0141d4        pwm4 {
0141e0           pwm4-pins {
0141f0              rockchip,pins = < 0x0 0x13 0x1 0x10e >;
01420c              phandle = < 0xf3 >;
01421c           }
014220        }
014224        pwm5 {
014230           pwm5-pins {
014240              rockchip,pins = < 0x0 0x14 0x1 0x10e >;
01425c              phandle = < 0xf4 >;
01426c           }
014270        }
014274        pwm6 {
014280           pwm6-pins {
014290              rockchip,pins = < 0x0 0x15 0x1 0x10e >;
0142ac              phandle = < 0xf5 >;
0142bc           }
0142c0        }
0142c4        pwm7 {
0142d0           pwm7-pins {
0142e0              rockchip,pins = < 0x0 0x16 0x1 0x10e >;
0142fc              phandle = < 0xf6 >;
01430c           }
014310        }
014314        pwm8 {
014320           pwm8m0-pins {
014330              rockchip,pins = < 0x3 0x9 0x5 0x10e >;
01434c              phandle = < 0xf7 >;
01435c           }
014360        }
014364        pwm9 {
014370           pwm9m0-pins {
014380              rockchip,pins = < 0x3 0xa 0x5 0x10e >;
01439c              phandle = < 0xf8 >;
0143ac           }
0143b0        }
0143b4        pwm10 {
0143c0           pwm10m0-pins {
0143d4              rockchip,pins = < 0x3 0xd 0x5 0x10e >;
0143f0              phandle = < 0xf9 >;
014400           }
014404        }
014408        pwm11 {
014414           pwm11m0-pins {
014428              rockchip,pins = < 0x3 0xe 0x5 0x10e >;
014444              phandle = < 0xfa >;
014454           }
014458        }
01445c        pwm12 {
014468           pwm12m0-pins {
01447c              rockchip,pins = < 0x3 0xf 0x2 0x10e >;
014498              phandle = < 0xfb >;
0144a8           }
0144ac        }
0144b0        pwm13 {
0144bc           pwm13m0-pins {
0144d0              rockchip,pins = < 0x3 0x10 0x2 0x10e >;
0144ec              phandle = < 0xfc >;
0144fc           }
014500        }
014504        pwm14 {
014510           pwm14m0-pins {
014524              rockchip,pins = < 0x3 0x14 0x1 0x10e >;
014540              phandle = < 0xfd >;
014550           }
014554        }
014558        pwm15 {
014564           pwm15m0-pins {
014578              rockchip,pins = < 0x3 0x15 0x1 0x10e >;
014594              phandle = < 0xfe >;
0145a4           }
0145a8        }
0145ac        scr {
0145b4           scr-pins {
0145c4              rockchip,pins = < 0x1 0x2 0x3 0x10e 0x1 0x7 0x3 0x110 0x1 0x3 0x3 0x110 0x1 0x5 0x3 0x10e >;
014610              phandle = < 0xc7 >;
014620           }
014624        }
014628        sdmmc0 {
014634           sdmmc0-bus4 {
014644              rockchip,pins = < 0x1 0x1d 0x1 0x10f 0x1 0x1e 0x1 0x10f 0x1 0x1f 0x1 0x10f 0x2 0x0 0x1 0x10f >;
014690              phandle = < 0xab >;
0146a0           }
0146a4           sdmmc0-clk {
0146b4              rockchip,pins = < 0x2 0x2 0x1 0x10f >;
0146d0              phandle = < 0xac >;
0146e0           }
0146e4           sdmmc0-cmd {
0146f4              rockchip,pins = < 0x2 0x1 0x1 0x10f >;
014710              phandle = < 0xad >;
014720           }
014724           sdmmc0-det {
014734              rockchip,pins = < 0x0 0x4 0x1 0x110 >;
014750              phandle = < 0xae >;
014760           }
014764        }
014768        sdmmc1 {
014774           sdmmc1-bus4 {
014784              rockchip,pins = < 0x2 0x3 0x1 0x10f 0x2 0x4 0x1 0x10f 0x2 0x5 0x1 0x10f 0x2 0x6 0x1 0x10f >;
0147d0              phandle = < 0xb0 >;
0147e0           }
0147e4           sdmmc1-clk {
0147f4              rockchip,pins = < 0x2 0x8 0x1 0x10f >;
014810              phandle = < 0xb2 >;
014820           }
014824           sdmmc1-cmd {
014834              rockchip,pins = < 0x2 0x7 0x1 0x10f >;
014850              phandle = < 0xb1 >;
014860           }
014864        }
014868        spdif {
014874           spdifm0-tx {
014884              rockchip,pins = < 0x1 0x4 0x4 0x10e >;
0148a0              phandle = < 0xc5 >;
0148b0           }
0148b4        }
0148b8        spi0 {
0148c4           spi0m0-pins {
0148d4              rockchip,pins = < 0x0 0xd 0x2 0x10e 0x0 0x15 0x2 0x10e 0x0 0xe 0x2 0x10e >;
014910              phandle = < 0xdb >;
014920           }
014924           spi0m0-cs0 {
014934              rockchip,pins = < 0x0 0x16 0x2 0x10e >;
014950              phandle = < 0xd9 >;
014960           }
014964           spi0m0-cs1 {
014974              rockchip,pins = < 0x0 0x14 0x2 0x10e >;
014990              phandle = < 0xda >;
0149a0           }
0149a4        }
0149a8        spi1 {
0149b4           spi1m0-pins {
0149c4              rockchip,pins = < 0x2 0xd 0x3 0x10e 0x2 0xe 0x3 0x10e 0x2 0xf 0x4 0x10e >;
014a00              phandle = < 0xdf >;
014a10           }
014a14           spi1m0-cs0 {
014a24              rockchip,pins = < 0x2 0x10 0x4 0x10e >;
014a40              phandle = < 0xdd >;
014a50           }
014a54           spi1m0-cs1 {
014a64              rockchip,pins = < 0x2 0x16 0x3 0x10e >;
014a80              phandle = < 0xde >;
014a90           }
014a94        }
014a98        spi2 {
014aa4           spi2m0-pins {
014ab4              rockchip,pins = < 0x2 0x11 0x4 0x10e 0x2 0x12 0x4 0x10e 0x2 0x13 0x4 0x10e >;
014af0              phandle = < 0xe3 >;
014b00           }
014b04           spi2m0-cs0 {
014b14              rockchip,pins = < 0x2 0x14 0x4 0x10e >;
014b30              phandle = < 0xe1 >;
014b40           }
014b44           spi2m0-cs1 {
014b54              rockchip,pins = < 0x2 0x15 0x4 0x10e >;
014b70              phandle = < 0xe2 >;
014b80           }
014b84        }
014b88        spi3 {
014b94           spi3m0-pins {
014ba4              rockchip,pins = < 0x4 0xb 0x4 0x10e 0x4 0x8 0x4 0x10e 0x4 0xa 0x4 0x10e >;
014be0              phandle = < 0xe7 >;
014bf0           }
014bf4           spi3m0-cs0 {
014c04              rockchip,pins = < 0x4 0x6 0x4 0x10e >;
014c20              phandle = < 0xe5 >;
014c30           }
014c34           spi3m0-cs1 {
014c44              rockchip,pins = < 0x4 0x7 0x4 0x10e >;
014c60              phandle = < 0xe6 >;
014c70           }
014c74        }
014c78        tsadc {
014c84           tsadc-shutorg {
014c98              rockchip,pins = < 0x0 0x1 0x2 0x10e >;
014cb4              phandle = < 0x100 >;
014cc4           }
014cc8        }
014ccc        uart0 {
014cd8           uart0-xfer {
014ce8              rockchip,pins = < 0x0 0x10 0x3 0x110 0x0 0x11 0x3 0x110 >;
014d14              phandle = < 0x3f >;
014d24           }
014d28        }
014d2c        uart1 {
014d38           uart1m0-xfer {
014d4c              rockchip,pins = < 0x2 0xb 0x2 0x110 0x2 0xc 0x2 0x110 >;
014d78              phandle = < 0xe9 >;
014d88           }
014d8c           uart1m0-ctsn {
014da0              rockchip,pins = < 0x2 0xe 0x2 0x10e >;
014dbc              phandle = < 0xea >;
014dcc           }
014dd0           uart1m0-rtsn {
014de4              rockchip,pins = < 0x2 0xd 0x2 0x10e >;
014e00              phandle = < 0x12e >;
014e10           }
014e14        }
014e18        uart2 {
014e24           uart2m0-xfer {
014e38              rockchip,pins = < 0x0 0x18 0x1 0x110 0x0 0x19 0x1 0x110 >;
014e64              phandle = < 0xeb >;
014e74           }
014e78        }
014e7c        uart3 {
014e88           uart3m0-xfer {
014e9c              rockchip,pins = < 0x1 0x0 0x2 0x110 0x1 0x1 0x2 0x110 >;
014ec8              phandle = < 0xec >;
014ed8           }
014edc        }
014ee0        uart4 {
014eec           uart4m0-xfer {
014f00              rockchip,pins = < 0x1 0x4 0x2 0x110 0x1 0x6 0x2 0x110 >;
014f2c              phandle = < 0xed >;
014f3c           }
014f40        }
014f44        uart5 {
014f50           uart5m0-xfer {
014f64              rockchip,pins = < 0x2 0x1 0x3 0x110 0x2 0x2 0x3 0x110 >;
014f90              phandle = < 0xee >;
014fa0           }
014fa4        }
014fa8        uart6 {
014fb4           uart6m0-xfer {
014fc8              rockchip,pins = < 0x2 0x3 0x3 0x110 0x2 0x4 0x3 0x110 >;
014ff4              phandle = < 0xef >;
015004           }
015008        }
01500c        uart7 {
015018           uart7m2-xfer {
01502c              rockchip,pins = < 0x4 0x3 0x4 0x110 0x4 0x2 0x4 0x110 >;
015058              phandle = < 0xf0 >;
015068           }
01506c        }
015070        uart8 {
01507c           uart8m0-xfer {
015090              rockchip,pins = < 0x2 0x16 0x2 0x110 0x2 0x15 0x3 0x110 >;
0150bc              phandle = < 0xf1 >;
0150cc           }
0150d0        }
0150d4        uart9 {
0150e0           uart9m0-xfer {
0150f4              rockchip,pins = < 0x2 0x7 0x3 0x110 0x2 0x8 0x3 0x110 >;
015120              phandle = < 0xf2 >;
015130           }
015134        }
015138        spi0-hs {
015144           spi0m0-pins {
015154              rockchip,pins = < 0x0 0xd 0x2 0x115 0x0 0x15 0x2 0x115 0x0 0xe 0x2 0x115 >;
015190              phandle = < 0xdc >;
0151a0           }
0151a4        }
0151a8        spi1-hs {
0151b4           spi1m0-pins {
0151c4              rockchip,pins = < 0x2 0xd 0x3 0x115 0x2 0xe 0x3 0x115 0x2 0xf 0x4 0x115 >;
015200              phandle = < 0xe0 >;
015210           }
015214        }
015218        spi2-hs {
015224           spi2m0-pins {
015234              rockchip,pins = < 0x2 0x11 0x4 0x115 0x2 0x12 0x4 0x115 0x2 0x13 0x4 0x115 >;
015270              phandle = < 0xe4 >;
015280           }
015284        }
015288        spi3-hs {
015294           spi3m0-pins {
0152a4              rockchip,pins = < 0x4 0xb 0x4 0x115 0x4 0x8 0x4 0x115 0x4 0xa 0x4 0x115 >;
0152e0              phandle = < 0xe8 >;
0152f0           }
0152f4        }
0152f8        gmac-txd-level3 {
01530c           gmac1m0-tx-bus2-level3 {
015328              rockchip,pins = < 0x3 0xd 0x3 0x116 0x3 0xe 0x3 0x116 0x3 0xf 0x3 0x10e >;
015364              phandle = < 0x7c >;
015374           }
015378           gmac1m0-rgmii-bus-level3 {
015398              rockchip,pins = < 0x3 0x4 0x3 0x10e 0x3 0x5 0x3 0x10e 0x3 0x2 0x3 0x116 0x3 0x3 0x3 0x116 >;
0153e4              phandle = < 0x7f >;
0153f4           }
0153f8        }
0153fc        gmac-txc-level2 {
015410           gmac1m0-rgmii-clk-level2 {
015430              rockchip,pins = < 0x3 0x7 0x3 0x10e 0x3 0x6 0x3 0x111 >;
01545c              phandle = < 0x7e >;
01546c           }
015470        }
015474        gpio-func {
015484           tsadc-gpio-func {
015498              rockchip,pins = < 0x0 0x1 0x0 0x10e >;
0154b4              phandle = < 0xff >;
0154c4           }
0154c8        }
0154cc        mxc6655xa {
0154dc           mxc6655xa_irq_gpio {
0154f4              rockchip,pins = < 0x3 0x11 0x0 0x10e >;
015510              phandle = < 0xd8 >;
015520           }
015524        }
015528        touch {
015534           touch-gpio {
015544              rockchip,pins = < 0x0 0xd 0x0 0x110 0x0 0xe 0x0 0x10e >;
015570              phandle = < 0xcc >;
015580           }
015584        }
015588        sdio-pwrseq {
015598           wifi-enable-h {
0155ac              rockchip,pins = < 0x2 0x9 0x0 0x10e >;
0155c8              phandle = < 0x12b >;
0155d8           }
0155dc        }
0155e0        usb {
0155e8           vcc5v0-host-en {
0155fc              rockchip,pins = < 0x0 0x6 0x0 0x10e >;
015618              phandle = < 0x128 >;
015628           }
01562c           vcc5v0-otg-en {
015640              rockchip,pins = < 0x0 0x5 0x0 0x10e >;
01565c              phandle = < 0x129 >;
01566c           }
015670        }
015674        wireless-bluetooth {
01568c           uart8-gpios {
01569c              rockchip,pins = < 0x2 0x9 0x0 0x10e >;
0156b8              phandle = < 0x1c9 >;
0156c8           }
0156cc           uart1-gpios {
0156dc              rockchip,pins = < 0x2 0xd 0x0 0x10e >;
0156f8              phandle = < 0x12f >;
015708           }
01570c        }
015710        headphone {
015720           hp-det {
01572c              rockchip,pins = < 0x4 0xb 0x0 0x117 >;
015748              phandle = < 0x130 >;
015758           }
01575c        }
015760        lcd0 {
01576c           lcd-rst-gpio {
015780              rockchip,pins = < 0x1 0x5 0x0 0x10e >;
01579c              phandle = < 0x92 >;
0157ac           }
0157b0        }
0157b4        lcd1 {
0157c0           lcd1-rst-gpio {
0157d4              rockchip,pins = < 0x4 0x16 0x0 0x10e >;
0157f0              phandle = < 0x9b >;
015800           }
015804        }
015808        wireless-wlan {
01581c           wifi-host-wake-irq {
015834              rockchip,pins = < 0x2 0xa 0x0 0x117 >;
015850              phandle = < 0x12d >;
015860           }
015864        }
015868     }
01586c     adc-keys {
01587c        compatible = "adc-keys";
015894        io-channels = < 0x118 0x0 >;
0158a8        io-channel-names = "buttons";
0158bc        keyup-threshold-microvolt = < 0x1b7740 >;
0158cc        poll-interval = < 0x64 >;
0158dc        phandle = < 0x1ca >;
0158ec        vol-up-key {
0158fc           label = "volume up";
015914           linux,code = < 0x73 >;
015924           press-threshold-microvolt = < 0x6d6 >;
015934        }
015938        vol-down-key {
01594c           label = "volume down";
015964           linux,code = < 0x72 >;
015974           press-threshold-microvolt = < 0x48a1c >;
015984        }
015988        menu-key {
015998           label = "menu";
0159ac           linux,code = < 0x8b >;
0159bc           press-threshold-microvolt = < 0xef420 >;
0159cc        }
0159d0        back-key {
0159e0           label = "back";
0159f4           linux,code = < 0x9e >;
015a04           press-threshold-microvolt = < 0x13eb9c >;
015a14        }
015a18     }
015a1c     audiopwmout-diff {
015a34        status = "disabled";
015a4c        compatible = "simple-audio-card";
015a6c        simple-audio-card,format = "i2s";
015a7c        simple-audio-card,name = "rockchip,audiopwmout-diff";
015aa4        simple-audio-card,mclk-fs = < 0x100 >;
015ab4        simple-audio-card,bitclock-master = < 0x119 >;
015ac4        simple-audio-card,frame-master = < 0x119 >;
015ad4        phandle = < 0x1cb >;
015ae4        simple-audio-card,cpu {
015b00           sound-dai = < 0x11a >;
015b10        }
015b14        simple-audio-card,codec {
015b30           sound-dai = < 0x11b >;
015b40           phandle = < 0x119 >;
015b50        }
015b54     }
015b58     backlight {
015b68        compatible = "pwm-backlight";
015b84        pwms = < 0x11c 0x0 0x61a8 0x0 >;
015ba0        brightness-levels = < 0x0 0x14 0x14 0x15 0x15 0x16 0x16 0x17 0x17 0x18 0x18 0x19 0x19 0x1a 0x1a 0x1b 0x1b 0x1c 0x1c 0x1d 0x1d 0x1e 0x1e 0x1f 0x1f 0x20 0x20 0x21 0x21 0x22 0x22 0x23 0x23 0x24 0x24 0x25 0x25 0x26 0x26 0x27 0x28 0x29 0x2a 0x2b 0x2c 0x2d 0x2e 0x2f 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x3a 0x3b 0x3c 0x3d 0x3e 0x3f 0x40 0x41 0x42 0x43 0x44 0x45 0x46 0x47 0x48 0x49 0x4a 0x4b 0x4c 0x4d 0x4e 0x4f 0x50 0x51 0x52 0x53 0x54 0x55 0x56 0x57 0x58 0x59 0x5a 0x5b 0x5c 0x5d 0x5e 0x5f 0x60 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a 0x7b 0x7c 0x7d 0x7e 0x7f 0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 0x90 0x91 0x92 0x93 0x94 0x95 0x96 0x97 0x98 0x99 0x9a 0x9b 0x9c 0x9d 0x9e 0x9f 0xa0 0xa1 0xa2 0xa3 0xa4 0xa5 0xa6 0xa7 0xa8 0xa9 0xaa 0xab 0xac 0xad 0xae 0xaf 0xb0 0xb1 0xb2 0xb3 0xb4 0xb5 0xb6 0xb7 0xb8 0xb9 0xba 0xbb 0xbc 0xbd 0xbe 0xbf 0xc0 0xc1 0xc2 0xc3 0xc4 0xc5 0xc6 0xc7 0xc8 0xc9 0xca 0xcb 0xcc 0xcd 0xce 0xcf 0xd0 0xd1 0xd2 0xd3 0xd4 0xd5 0xd6 0xd7 0xd8 0xd9 0xda 0xdb 0xdc 0xdd 0xde 0xdf 0xe0 0xe1 0xe2 0xe3 0xe4 0xe5 0xe6 0xe7 0xe8 0xe9 0xea 0xeb 0xec 0xed 0xee 0xef 0xf0 0xf1 0xf2 0xf3 0xf4 0xf5 0xf6 0xf7 0xf8 0xf9 0xfa 0xfb 0xfc 0xfd 0xfe 0xff >;
015fac        default-brightness-level = < 0xc8 >;
015fbc        phandle = < 0x8f >;
015fcc     }
015fd0     backlight1 {
015fe0        compatible = "pwm-backlight";
015ffc        pwms = < 0x11d 0x0 0x61a8 0x0 >;
016018        brightness-levels = < 0x0 0x14 0x14 0x15 0x15 0x16 0x16 0x17 0x17 0x18 0x18 0x19 0x19 0x1a 0x1a 0x1b 0x1b 0x1c 0x1c 0x1d 0x1d 0x1e 0x1e 0x1f 0x1f 0x20 0x20 0x21 0x21 0x22 0x22 0x23 0x23 0x24 0x24 0x25 0x25 0x26 0x26 0x27 0x28 0x29 0x2a 0x2b 0x2c 0x2d 0x2e 0x2f 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x3a 0x3b 0x3c 0x3d 0x3e 0x3f 0x40 0x41 0x42 0x43 0x44 0x45 0x46 0x47 0x48 0x49 0x4a 0x4b 0x4c 0x4d 0x4e 0x4f 0x50 0x51 0x52 0x53 0x54 0x55 0x56 0x57 0x58 0x59 0x5a 0x5b 0x5c 0x5d 0x5e 0x5f 0x60 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a 0x7b 0x7c 0x7d 0x7e 0x7f 0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 0x90 0x91 0x92 0x93 0x94 0x95 0x96 0x97 0x98 0x99 0x9a 0x9b 0x9c 0x9d 0x9e 0x9f 0xa0 0xa1 0xa2 0xa3 0xa4 0xa5 0xa6 0xa7 0xa8 0xa9 0xaa 0xab 0xac 0xad 0xae 0xaf 0xb0 0xb1 0xb2 0xb3 0xb4 0xb5 0xb6 0xb7 0xb8 0xb9 0xba 0xbb 0xbc 0xbd 0xbe 0xbf 0xc0 0xc1 0xc2 0xc3 0xc4 0xc5 0xc6 0xc7 0xc8 0xc9 0xca 0xcb 0xcc 0xcd 0xce 0xcf 0xd0 0xd1 0xd2 0xd3 0xd4 0xd5 0xd6 0xd7 0xd8 0xd9 0xda 0xdb 0xdc 0xdd 0xde 0xdf 0xe0 0xe1 0xe2 0xe3 0xe4 0xe5 0xe6 0xe7 0xe8 0xe9 0xea 0xeb 0xec 0xed 0xee 0xef 0xf0 0xf1 0xf2 0xf3 0xf4 0xf5 0xf6 0xf7 0xf8 0xf9 0xfa 0xfb 0xfc 0xfd 0xfe 0xff >;
016424        default-brightness-level = < 0xc8 >;
016434        phandle = < 0x98 >;
016444     }
016448     dc-12v {
016454        compatible = "regulator-fixed";
016470        regulator-name = "dc_12v";
016484        regulator-always-on;
016490        regulator-boot-on;
01649c        regulator-min-microvolt = < 0xb71b00 >;
0164ac        regulator-max-microvolt = < 0xb71b00 >;
0164bc        phandle = < 0x126 >;
0164cc     }
0164d0     hdmi-sound {
0164e0        compatible = "simple-audio-card";
016500        simple-audio-card,format = "i2s";
016510        simple-audio-card,mclk-fs = < 0x80 >;
016520        simple-audio-card,name = "rockchip,hdmi";
01653c        status = "okay";
016550        phandle = < 0x1cc >;
016560        simple-audio-card,cpu {
01657c           sound-dai = < 0x11e >;
01658c        }
016590        simple-audio-card,codec {
0165ac           sound-dai = < 0x11f >;
0165bc        }
0165c0     }
0165c4     leds {
0165d0        compatible = "gpio-leds";
0165e8        phandle = < 0x1cd >;
0165f8        work {
016604           gpios = < 0x35 0x1b 0x0 >;
01661c           linux,default-trigger = "heartbeat";
016634           status = "disabled";
01664c           phandle = < 0x1ce >;
01665c        }
016660        led-status {
016670           gpios = < 0x35 0x1b 0x0 >;
016688           linux,default-trigger = "timer";
01669c           default-state = "on";
0166ac        }
0166b0        led-system {
0166c0           gpios = < 0x35 0x1c 0x0 >;
0166d8           linux,default-trigger = "none";
0166ec           default-state = "on";
0166fc        }
016700        led-wifi {
016710           gpios = < 0x35 0x1d 0x0 >;
016728           linux,default-trigger = "none";
01673c           default-state = "on";
01674c        }
016750        led-eth {
01675c           gpios = < 0x35 0x1e 0x0 >;
016774           linux,default-trigger = "none";
016788           default-state = "on";
016798        }
01679c        led-board {
0167ac           gpios = < 0x9a 0x17 0x0 >;
0167c4           linux,default-trigger = "none";
0167d8           default-state = "on";
0167e8        }
0167ec     }
0167f0     dummy-codec {
016800        status = "disabled";
016818        compatible = "rockchip,dummy-codec";
01683c        #sound-dai-cells = < 0x0 >;
01684c        phandle = < 0x121 >;
01685c     }
016860     pdm-mic-array {
016874        status = "disabled";
01688c        compatible = "simple-audio-card";
0168ac        simple-audio-card,name = "rockchip,pdm-mic-array";
0168d0        phandle = < 0x1cf >;
0168e0        simple-audio-card,cpu {
0168fc           sound-dai = < 0x120 >;
01690c        }
016910        simple-audio-card,codec {
01692c           sound-dai = < 0x121 >;
01693c        }
016940     }
016944     rk809-sound {
016954        status = "disabled";
01696c        compatible = "simple-audio-card";
01698c        simple-audio-card,format = "i2s";
01699c        simple-audio-card,name = "rockchip,rk809-codec";
0169c0        simple-audio-card,mclk-fs = < 0x100 >;
0169d0        phandle = < 0x1d0 >;
0169e0        simple-audio-card,cpu {
0169fc           sound-dai = < 0x11a >;
016a0c        }
016a10        simple-audio-card,codec {
016a2c           sound-dai = < 0x122 >;
016a3c        }
016a40     }
016a44     spdif-sound {
016a54        status = "okay";
016a68        compatible = "simple-audio-card";
016a88        simple-audio-card,name = "ROCKCHIP,SPDIF";
016aa4        simple-audio-card,cpu {
016ac0           sound-dai = < 0x123 >;
016ad0        }
016ad4        simple-audio-card,codec {
016af0           sound-dai = < 0x124 >;
016b00        }
016b04     }
016b08     spdif-out {
016b18        status = "okay";
016b2c        compatible = "linux,spdif-dit";
016b48        #sound-dai-cells = < 0x0 >;
016b58        phandle = < 0x124 >;
016b68     }
016b6c     vad-sound {
016b7c        status = "disabled";
016b94        compatible = "rockchip,multicodecs-card";
016bbc        rockchip,card-name = "rockchip,rk3568-vad";
016bdc        rockchip,cpu = < 0xc4 >;
016bec        rockchip,codec = < 0x122 0x125 >;
016c00        phandle = < 0x1d1 >;
016c10     }
016c14     vcc3v3-sys {
016c24        compatible = "regulator-fixed";
016c40        regulator-name = "vcc3v3_sys";
016c58        regulator-always-on;
016c64        regulator-boot-on;
016c70        regulator-min-microvolt = < 0x325aa0 >;
016c80        regulator-max-microvolt = < 0x325aa0 >;
016c90        vin-supply = < 0x126 >;
016ca0        phandle = < 0x3c >;
016cb0     }
016cb4     vcc5v0-sys {
016cc4        compatible = "regulator-fixed";
016ce0        regulator-name = "vcc5v0_sys";
016cf8        regulator-always-on;
016d04        regulator-boot-on;
016d10        regulator-min-microvolt = < 0x4c4b40 >;
016d20        regulator-max-microvolt = < 0x4c4b40 >;
016d30        vin-supply = < 0x126 >;
016d40        phandle = < 0x3d >;
016d50     }
016d54     vcc5v0-usb {
016d64        compatible = "regulator-fixed";
016d80        regulator-name = "vcc5v0_usb";
016d98        regulator-always-on;
016da4        regulator-boot-on;
016db0        regulator-min-microvolt = < 0x4c4b40 >;
016dc0        regulator-max-microvolt = < 0x4c4b40 >;
016dd0        vin-supply = < 0x126 >;
016de0        phandle = < 0x127 >;
016df0     }
016df4     vcc5v0-host-regulator {
016e10        compatible = "regulator-fixed";
016e2c        regulator-name = "vcc5v0_host";
016e44        regulator-boot-on;
016e50        regulator-always-on;
016e5c        regulator-min-microvolt = < 0x4c4b40 >;
016e6c        regulator-max-microvolt = < 0x4c4b40 >;
016e7c        enable-active-high;
016e88        gpio = < 0x35 0x6 0x0 >;
016ea0        vin-supply = < 0x127 >;
016eb0        pinctrl-names = "default";
016ec4        pinctrl-0 = < 0x128 >;
016ed4        phandle = < 0x10a >;
016ee4     }
016ee8     vcc5v0-otg-regulator {
016f04        compatible = "regulator-fixed";
016f20        regulator-name = "vcc5v0_otg";
016f38        regulator-min-microvolt = < 0x4c4b40 >;
016f48        regulator-max-microvolt = < 0x4c4b40 >;
016f58        enable-active-high;
016f64        gpio = < 0x35 0x5 0x0 >;
016f7c        vin-supply = < 0x127 >;
016f8c        pinctrl-names = "default";
016fa0        pinctrl-0 = < 0x129 >;
016fb0        phandle = < 0x10b >;
016fc0     }
016fc4     vcc3v3-lcd0-n {
016fd8        compatible = "regulator-fixed";
016ff4        regulator-name = "vcc3v3_lcd0_n";
017010        regulator-boot-on;
01701c        regulator-min-microvolt = < 0x325aa0 >;
01702c        regulator-max-microvolt = < 0x325aa0 >;
01703c        enable-active-high;
017048        gpio = < 0x35 0x10 0x0 >;
017060        vin-supply = < 0x3c >;
017070        phandle = < 0x90 >;
017080        regulator-state-mem {
017098           regulator-off-in-suspend;
0170a4        }
0170a8     }
0170ac     vcc3v3-lcd1-n {
0170c0        compatible = "regulator-fixed";
0170dc        regulator-name = "vcc3v3_lcd1_n";
0170f8        regulator-boot-on;
017104        regulator-min-microvolt = < 0x325aa0 >;
017114        regulator-max-microvolt = < 0x325aa0 >;
017124        enable-active-high;
017130        gpio = < 0x35 0x15 0x0 >;
017148        vin-supply = < 0x3c >;
017158        phandle = < 0x99 >;
017168        regulator-state-mem {
017180           regulator-off-in-suspend;
01718c        }
017190     }
017194     sdio-pwrseq {
0171a4        compatible = "mmc-pwrseq-simple";
0171c4        clocks = < 0x12a 0x1 >;
0171d8        clock-names = "ext_clock";
0171f0        pinctrl-names = "default";
017204        pinctrl-0 = < 0x12b >;
017214        post-power-on-delay-ms = < 0xc8 >;
017224        reset-gpios = < 0x12c 0x9 0x1 >;
01723c        phandle = < 0xaf >;
01724c     }
017250     wireless-wlan {
017264        compatible = "wlan-platdata";
017280        rockchip,grf = < 0x32 >;
017290        wifi_chip_type = "ap6398s";
0172a4        status = "okay";
0172b8        pinctrl-names = "default";
0172cc        pinctrl-0 = < 0x12d >;
0172dc        WIFI,host_wake_irq = < 0x12c 0xa 0x0 >;
0172f4        phandle = < 0x1d2 >;
017304     }
017308     wireless-bluetooth {
017320        compatible = "bluetooth-platdata";
017340        clocks = < 0x12a 0x1 >;
017354        clock-names = "ext_clock";
01736c        uart_rts_gpios = < 0x12c 0xd 0x1 >;
017384        pinctrl-names = "default\0rts_gpio";
0173a4        pinctrl-0 = < 0x12e >;
0173b4        pinctrl-1 = < 0x12f >;
0173c4        BT,reset_gpio = < 0x12c 0xf 0x0 >;
0173dc        BT,wake_gpio = < 0x12c 0x11 0x0 >;
0173f4        BT,wake_host_irq = < 0x12c 0x10 0x0 >;
01740c        status = "okay";
017420        phandle = < 0x1d3 >;
017430     }
017434     test-power {
017444        status = "okay";
017458     }
01745c     rk-headset {
01746c        compatible = "rockchip_headset";
01748c        headset_gpio = < 0x9a 0xb 0x1 >;
0174a4        pinctrl-names = "default";
0174b8        pinctrl-0 = < 0x130 >;
0174c8        phandle = < 0x1d4 >;
0174d8     }
0174dc     vcc3v3-vga {
0174ec        compatible = "regulator-fixed";
017508        regulator-name = "vcc3v3_vga";
017520        regulator-always-on;
01752c        regulator-boot-on;
017538        gpio = < 0x9a 0xa 0x0 >;
017550        enable-active-high;
01755c        vin-supply = < 0x3c >;
01756c        status = "disabled";
017584        phandle = < 0x1d5 >;
017594     }
017598     vcc-camera-regulator {
0175b4        compatible = "regulator-fixed";
0175d0        gpio = < 0x35 0x11 0x0 >;
0175e8        pinctrl-names = "default";
0175fc        pinctrl-0 = < 0x131 >;
01760c        regulator-name = "vcc_camera";
017624        enable-active-high;
017630        regulator-always-on;
01763c        regulator-boot-on;
017648        phandle = < 0x1d6 >;
017658     }
01765c     chosen {
017668        bootargs = "earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rw rootwait";
0176d0        phandle = < 0x1d7 >;
0176e0     }
0176e4     fiq-debugger {
0176f8        compatible = "rockchip,fiq-debugger";
01771c        rockchip,serial-id = < 0x2 >;
01772c        rockchip,wake-irq = < 0x0 >;
01773c        rockchip,irq-mode-enable = < 0x1 >;
01774c        rockchip,baudrate = < 0x16e360 >;
01775c        interrupts = < 0x0 0xfc 0x8 >;
017774        pinctrl-names = "default";
017788        pinctrl-0 = < 0xeb >;
017798        status = "okay";
0177ac        phandle = < 0x1d8 >;
0177bc     }
0177c0     debug@fd904000 {
0177d4        compatible = "rockchip,debug";
0177f0        reg = < 0x0 0xfd904000 0x0 0x1000 0x0 0xfd905000 0x0 0x1000 0x0 0xfd906000 0x0 0x1000 0x0 0xfd907000 0x0 0x1000 >;
01783c        phandle = < 0x1d9 >;
01784c     }
017850     cspmu@fd90c000 {
017864        compatible = "rockchip,cspmu";
017880        reg = < 0x0 0xfd90c000 0x0 0x1000 0x0 0xfd90d000 0x0 0x1000 0x0 0xfd90e000 0x0 0x1000 0x0 0xfd90f000 0x0 0x1000 >;
0178cc        phandle = < 0x1da >;
0178dc     }
0178e0     __symbols__ {
0178f0        ddr_timing = "/ddr_timing";
017908        cpu0 = "/cpus/cpu@0";
017920        cpu1 = "/cpus/cpu@100";
01793c        cpu2 = "/cpus/cpu@200";
017958        cpu3 = "/cpus/cpu@300";
017974        CPU_SLEEP = "/cpus/idle-states/cpu-sleep";
01799c        cpu0_opp_table = "/cpu0-opp-table";
0179b8        display_subsystem = "/display-subsystem";
0179d8        route_dsi0 = "/display-subsystem/route/route-dsi0";
017a08        route_dsi1 = "/display-subsystem/route/route-dsi1";
017a38        route_edp = "/display-subsystem/route/route-edp";
017a68        route_hdmi = "/display-subsystem/route/route-hdmi";
017a98        route_lvds = "/display-subsystem/route/route-lvds";
017ac8        route_rgb = "/display-subsystem/route/route-rgb";
017af8        optee = "/firmware/optee";
017b14        scmi = "/firmware/scmi";
017b30        scmi_clk = "/firmware/scmi/protocol@14";
017b58        sdei = "/firmware/sdei";
017b74        mpp_srv = "/mpp-srv";
017b8c        reserved_memory = "/reserved-memory";
017bac        drm_logo = "/reserved-memory/drm-logo@00000000";
017bdc        drm_cubic_lut = "/reserved-memory/drm-cubic-lut@00000000";
017c10        ramoops = "/reserved-memory/ramoops@110000";
017c3c        rockchip_suspend = "/rockchip-suspend";
017c5c        rockchip_system_monitor = "/rockchip-system-monitor";
017c84        thermal_zones = "/thermal-zones";
017ca0        soc_thermal = "/thermal-zones/soc-thermal";
017cc8        threshold = "/thermal-zones/soc-thermal/trips/trip-point-0";
017d04        target = "/thermal-zones/soc-thermal/trips/trip-point-1";
017d40        soc_crit = "/thermal-zones/soc-thermal/trips/soc-crit";
017d78        gpu_thermal = "/thermal-zones/gpu-thermal";
017da0        gmac1_clkin = "/external-gmac1-clock";
017dc4        gmac1_xpcsclk = "/xpcs-gmac1-clock";
017de4        i2s1_mclkin_rx = "/i2s1-mclkin-rx";
017e00        i2s1_mclkin_tx = "/i2s1-mclkin-tx";
017e1c        i2s2_mclkin = "/i2s2-mclkin";
017e38        i2s3_mclkin = "/i2s3-mclkin";
017e54        mpll = "/mpll";
017e68        xin24m = "/xin24m";
017e7c        xin32k = "/xin32k";
017e90        scmi_shmem = "/scmi-shmem@10f000";
017eb0        sata1 = "/sata@fc400000";
017ecc        sata2 = "/sata@fc800000";
017ee8        usbdrd30 = "/usbdrd";
017efc        usbdrd_dwc3 = "/usbdrd/dwc3@fcc00000";
017f20        usbhost30 = "/usbhost";
017f38        usbhost_dwc3 = "/usbhost/dwc3@fd000000";
017f5c        gic = "/interrupt-controller@fd400000";
017f88        its = "/interrupt-controller@fd400000/interrupt-controller@fd440000";
017fd4        usb_host0_ehci = "/usb@fd800000";
017ff0        usb_host0_ohci = "/usb@fd840000";
01800c        usb_host1_ehci = "/usb@fd880000";
018028        usb_host1_ohci = "/usb@fd8c0000";
018044        xpcs = "/syscon@fda00000";
018064        pmugrf = "/syscon@fdc20000";
018084        pmu_io_domains = "/syscon@fdc20000/io-domains";
0180ac        reboot_mode = "/syscon@fdc20000/reboot-mode";
0180d8        pipegrf = "/syscon@fdc50000";
0180f8        grf = "/syscon@fdc60000";
018118        io_domains = "/syscon@fdc60000/io-domains";
018140        lvds = "/syscon@fdc60000/lvds";
018164        lvds_in_vp1 = "/syscon@fdc60000/lvds/ports/port@0/endpoint@1";
0181a0        lvds_in_vp2 = "/syscon@fdc60000/lvds/ports/port@0/endpoint@2";
0181dc        rgb = "/syscon@fdc60000/rgb";
018200        rgb_in_vp2 = "/syscon@fdc60000/rgb/ports/port@0/endpoint@2";
01823c        pipe_phy_grf0 = "/syscon@fdc70000";
01825c        pipe_phy_grf1 = "/syscon@fdc80000";
01827c        pipe_phy_grf2 = "/syscon@fdc90000";
01829c        usb2phy0_grf = "/syscon@fdca0000";
0182bc        usb2phy1_grf = "/syscon@fdca8000";
0182dc        edp_phy = "/edp-phy@fdcb0000";
0182fc        sram = "/sram@fdcc0000";
018318        rkvdec_sram = "/sram@fdcc0000/rkvdec-sram@0";
018344        pmucru = "/clock-controller@fdd00000";
01836c        cru = "/clock-controller@fdd20000";
018394        i2c0 = "/i2c@fdd40000";
0183b0        rk809 = "/i2c@fdd40000/pmic@20";
0183d4        pinctrl_rk8xx = "/i2c@fdd40000/pmic@20/pinctrl_rk8xx";
018404        rk817_slppin_null = "/i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_null";
018448        rk817_slppin_slp = "/i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_slp";
01848c        rk817_slppin_pwrdn = "/i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_pwrdn";
0184d0        rk817_slppin_rst = "/i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_rst";
018514        vdd_logic = "/i2c@fdd40000/pmic@20/regulators/DCDC_REG1";
01854c        vdd_gpu = "/i2c@fdd40000/pmic@20/regulators/DCDC_REG2";
018584        vcc_ddr = "/i2c@fdd40000/pmic@20/regulators/DCDC_REG3";
0185bc        vdd_npu = "/i2c@fdd40000/pmic@20/regulators/DCDC_REG4";
0185f4        vdda0v9_image = "/i2c@fdd40000/pmic@20/regulators/LDO_REG1";
01862c        vdda_0v9 = "/i2c@fdd40000/pmic@20/regulators/LDO_REG2";
018664        vdda0v9_pmu = "/i2c@fdd40000/pmic@20/regulators/LDO_REG3";
01869c        vccio_acodec = "/i2c@fdd40000/pmic@20/regulators/LDO_REG4";
0186d4        vccio_sd = "/i2c@fdd40000/pmic@20/regulators/LDO_REG5";
01870c        vcc3v3_pmu = "/i2c@fdd40000/pmic@20/regulators/LDO_REG6";
018744        vcca_1v8 = "/i2c@fdd40000/pmic@20/regulators/LDO_REG7";
01877c        vcca1v8_pmu = "/i2c@fdd40000/pmic@20/regulators/LDO_REG8";
0187b4        vcca1v8_image = "/i2c@fdd40000/pmic@20/regulators/LDO_REG9";
0187ec        vcc_1v8 = "/i2c@fdd40000/pmic@20/regulators/DCDC_REG5";
018824        vcc_3v3 = "/i2c@fdd40000/pmic@20/regulators/SWITCH_REG1";
018860        vcc3v3_sd = "/i2c@fdd40000/pmic@20/regulators/SWITCH_REG2";
01889c        rk809_codec = "/i2c@fdd40000/pmic@20/codec";
0188c4        vdd_cpu = "/i2c@fdd40000/tcs4525@1c";
0188ec        uart0 = "/serial@fdd50000";
01890c        pwm0 = "/pwm@fdd70000";
018928        pwm1 = "/pwm@fdd70010";
018944        pwm2 = "/pwm@fdd70020";
018960        pwm3 = "/pwm@fdd70030";
01897c        pmu = "/power-management@fdd90000";
0189a4        power = "/power-management@fdd90000/power-controller";
0189dc        rknpu = "/npu@fde40000";
0189f8        npu_opp_table = "/npu-opp-table";
018a14        bus_npu = "/bus-npu";
018a2c        bus_npu_opp_table = "/bus-npu-opp-table";
018a4c        rknpu_mmu = "/iommu@fde4b000";
018a68        gpu = "/gpu@fde60000";
018a84        gpu_power_model = "/gpu@fde60000/power-model";
018aac        gpu_opp_table = "/opp-table2";
018ac4        vdpu = "/vdpu@fdea0400";
018ae0        vdpu_mmu = "/iommu@fdea0800";
018afc        rk_rga = "/rk_rga@fdeb0000";
018b1c        ebc = "/ebc@fdec0000";
018b38        jpegd = "/jpegd@fded0000";
018b54        jpegd_mmu = "/iommu@fded0480";
018b70        vepu = "/vepu@fdee0000";
018b8c        vepu_mmu = "/iommu@fdee0800";
018ba8        iep = "/iep@fdef0000";
018bc4        iep_mmu = "/iommu@fdef0800";
018be0        eink = "/eink@fdf00000";
018bfc        rkvenc = "/rkvenc@fdf40000";
018c1c        rkvenc_opp_table = "/rkvenc-opp-table";
018c3c        rkvenc_mmu = "/iommu@fdf40f00";
018c58        rkvdec = "/rkvdec@fdf80200";
018c78        rkvdec_mmu = "/iommu@fdf80800";
018c94        mipi_csi2 = "/mipi-csi2@fdfb0000";
018cb4        rkcif = "/rkcif@fdfe0000";
018cd0        rkcif_mmu = "/iommu@fdfe0800";
018cec        rkcif_dvp = "/rkcif_dvp";
018d04        dvp_in_bcam = "/rkcif_dvp/port/endpoint";
018d2c        rkcif_dvp_sditf = "/rkcif_dvp_sditf";
018d4c        rkcif_mipi_lvds = "/rkcif_mipi_lvds";
018d6c        rkcif_mipi_lvds_sditf = "/rkcif_mipi_lvds_sditf";
018d90        rkisp = "/rkisp@fdff0000";
018dac        rkisp_mmu = "/iommu@fdff1a00";
018dc8        rkisp_vir0 = "/rkisp-vir0";
018de0        isp0_in = "/rkisp-vir0/port/endpoint@0";
018e08        rkisp_vir1 = "/rkisp-vir1";
018e20        gmac1 = "/ethernet@fe010000";
018e40        mdio1 = "/ethernet@fe010000/mdio";
018e64        rgmii_phy1 = "/ethernet@fe010000/mdio/phy@0";
018e90        gmac1_stmmac_axi_setup = "/ethernet@fe010000/stmmac-axi-config";
018ec4        gmac1_mtl_rx_setup = "/ethernet@fe010000/rx-queues-config";
018ef4        gmac1_mtl_tx_setup = "/ethernet@fe010000/tx-queues-config";
018f24        vop = "/vop@fe040000";
018f40        vop_out = "/vop@fe040000/ports";
018f60        vp0 = "/vop@fe040000/ports/port@0";
018f88        vp0_out_dsi0 = "/vop@fe040000/ports/port@0/endpoint@0";
018fbc        vp0_out_dsi1 = "/vop@fe040000/ports/port@0/endpoint@1";
018ff0        vp0_out_edp = "/vop@fe040000/ports/port@0/endpoint@2";
019024        vp0_out_hdmi = "/vop@fe040000/ports/port@0/endpoint@3";
019058        vp1 = "/vop@fe040000/ports/port@1";
019080        vp1_out_dsi0 = "/vop@fe040000/ports/port@1/endpoint@0";
0190b4        vp1_out_dsi1 = "/vop@fe040000/ports/port@1/endpoint@1";
0190e8        vp1_out_edp = "/vop@fe040000/ports/port@1/endpoint@2";
01911c        vp1_out_hdmi = "/vop@fe040000/ports/port@1/endpoint@3";
019150        vp1_out_lvds = "/vop@fe040000/ports/port@1/endpoint@4";
019184        vp2 = "/vop@fe040000/ports/port@2";
0191ac        vp2_out_lvds = "/vop@fe040000/ports/port@2/endpoint@0";
0191e0        vp2_out_rgb = "/vop@fe040000/ports/port@2/endpoint@1";
019214        vop_mmu = "/iommu@fe043e00";
019230        dsi0 = "/dsi@fe060000";
01924c        dsi0_in = "/dsi@fe060000/ports/port@0";
019274        dsi0_in_vp0 = "/dsi@fe060000/ports/port@0/endpoint@0";
0192a8        dsi0_in_vp1 = "/dsi@fe060000/ports/port@0/endpoint@1";
0192dc        dsi_out_panel = "/dsi@fe060000/ports/port@1/endpoint";
01930c        dsi0_panel = "/dsi@fe060000/panel@0";
019330        disp_timings0 = "/dsi@fe060000/panel@0/display-timings";
019364        dsi0_timing0 = "/dsi@fe060000/panel@0/display-timings/timing0";
0193a0        panel_in_dsi = "/dsi@fe060000/panel@0/ports/port@0/endpoint";
0193d8        dsi1 = "/dsi@fe070000";
0193f4        dsi1_in = "/dsi@fe070000/ports/port@0";
01941c        dsi1_in_vp0 = "/dsi@fe070000/ports/port@0/endpoint@0";
019450        dsi1_in_vp1 = "/dsi@fe070000/ports/port@0/endpoint@1";
019484        dsi1_out_panel = "/dsi@fe070000/ports/port@1/endpoint";
0194b4        dsi1_panel = "/dsi@fe070000/panel@0";
0194d8        disp_timings1 = "/dsi@fe070000/panel@0/display-timings";
01950c        dsi1_timing0 = "/dsi@fe070000/panel@0/display-timings/timing0";
019548        panel_in_dsi1 = "/dsi@fe070000/panel@0/ports/port@0/endpoint";
019580        hdmi = "/hdmi@fe0a0000";
01959c        hdmi_in = "/hdmi@fe0a0000/ports/port";
0195c4        hdmi_in_vp0 = "/hdmi@fe0a0000/ports/port/endpoint@0";
0195f8        hdmi_in_vp1 = "/hdmi@fe0a0000/ports/port/endpoint@1";
01962c        edp = "/edp@fe0c0000";
019648        edp_in = "/edp@fe0c0000/ports/port@0";
019670        edp_in_vp0 = "/edp@fe0c0000/ports/port@0/endpoint@0";
0196a4        edp_in_vp1 = "/edp@fe0c0000/ports/port@0/endpoint@1";
0196d8        qos_gpu = "/qos@fe128000";
0196f4        qos_rkvenc_rd_m0 = "/qos@fe138080";
019710        qos_rkvenc_rd_m1 = "/qos@fe138100";
01972c        qos_rkvenc_wr_m0 = "/qos@fe138180";
019748        qos_isp = "/qos@fe148000";
019764        qos_vicap0 = "/qos@fe148080";
019780        qos_vicap1 = "/qos@fe148100";
01979c        qos_vpu = "/qos@fe150000";
0197b8        qos_ebc = "/qos@fe158000";
0197d4        qos_iep = "/qos@fe158100";
0197f0        qos_jpeg_dec = "/qos@fe158180";
01980c        qos_jpeg_enc = "/qos@fe158200";
019828        qos_rga_rd = "/qos@fe158280";
019844        qos_rga_wr = "/qos@fe158300";
019860        qos_npu = "/qos@fe180000";
01987c        qos_pcie2x1 = "/qos@fe190000";
019898        qos_sata1 = "/qos@fe190280";
0198b4        qos_sata2 = "/qos@fe190300";
0198d0        qos_usb3_0 = "/qos@fe190380";
0198ec        qos_usb3_1 = "/qos@fe190400";
019908        qos_rkvdec = "/qos@fe198000";
019924        qos_hdcp = "/qos@fe1a8000";
019940        qos_vop_m0 = "/qos@fe1a8080";
01995c        qos_vop_m1 = "/qos@fe1a8100";
019978        sdmmc2 = "/dwmmc@fe000000";
019994        dfi = "/dfi@fe230000";
0199b0        dmc = "/dmc";
0199c4        dmc_opp_table = "/dmc-opp-table";
0199e0        pcie2x1 = "/pcie@fe260000";
0199fc        pcie2x1_intc = "/pcie@fe260000/legacy-interrupt-controller";
019a34        sdmmc0 = "/dwmmc@fe2b0000";
019a50        sdmmc1 = "/dwmmc@fe2c0000";
019a6c        sfc = "/sfc@fe300000";
019a88        sdhci = "/sdhci@fe310000";
019aa4        nandc0 = "/nandc@fe330000";
019ac0        crypto = "/crypto@fe380000";
019ae0        rng = "/rng@fe388000";
019afc        otp = "/otp@fe38c000";
019b18        cpu_code = "/otp@fe38c000/cpu-code@2";
019b40        otp_cpu_version = "/otp@fe38c000/cpu-version@8";
019b68        mbist_vmin = "/otp@fe38c000/mbist-vmin@9";
019b90        otp_id = "/otp@fe38c000/id@a";
019bb0        cpu_leakage = "/otp@fe38c000/cpu-leakage@1a";
019bdc        log_leakage = "/otp@fe38c000/log-leakage@1b";
019c08        npu_leakage = "/otp@fe38c000/npu-leakage@1c";
019c34        gpu_leakage = "/otp@fe38c000/gpu-leakage@1d";
019c60        core_pvtm = "/otp@fe38c000/core-pvtm@2a";
019c88        i2s0_8ch = "/i2s@fe400000";
019ca4        i2s1_8ch = "/i2s@fe410000";
019cc0        i2s2_2ch = "/i2s@fe420000";
019cdc        i2s3_2ch = "/i2s@fe430000";
019cf8        pdm = "/pdm@fe440000";
019d14        vad = "/vad@fe450000";
019d30        spdif_8ch = "/spdif@fe460000";
019d4c        audpwm = "/audpwm@fe470000";
019d6c        dig_acodec = "/codec-digital@fe478000";
019d90        dmac0 = "/dmac@fe530000";
019dac        dmac1 = "/dmac@fe550000";
019dc8        scr = "/rkscr@fe560000";
019de4        can0 = "/can@fe570000";
019e00        can1 = "/can@fe580000";
019e1c        can2 = "/can@fe590000";
019e38        i2c1 = "/i2c@fe5a0000";
019e54        gt1x = "/i2c@fe5a0000/gt1x@14";
019e78        i2c2 = "/i2c@fe5b0000";
019e94        gc2145 = "/i2c@fe5b0000/gc2145@3c";
019eb8        gc2145_out = "/i2c@fe5b0000/gc2145@3c/port/endpoint";
019eec        ov5695 = "/i2c@fe5b0000/ov5695@36";
019f10        ov5695_out = "/i2c@fe5b0000/ov5695@36/port/endpoint";
019f44        gc8034 = "/i2c@fe5b0000/gc8034@37";
019f68        gc8034_out = "/i2c@fe5b0000/gc8034@37/port/endpoint";
019f9c        i2c3 = "/i2c@fe5c0000";
019fb8        i2c4 = "/i2c@fe5d0000";
019fd4        i2c5 = "/i2c@fe5e0000";
019ff0        mxc6655xa = "/i2c@fe5e0000/mxc6655xa@15";
01a018        rktimer = "/timer@fe5f0000";
01a034        wdt = "/watchdog@fe600000";
01a054        spi0 = "/spi@fe610000";
01a070        spi1 = "/spi@fe620000";
01a08c        spi2 = "/spi@fe630000";
01a0a8        spi3 = "/spi@fe640000";
01a0c4        uart1 = "/serial@fe650000";
01a0e4        uart2 = "/serial@fe660000";
01a104        uart3 = "/serial@fe670000";
01a124        uart4 = "/serial@fe680000";
01a144        uart5 = "/serial@fe690000";
01a164        uart6 = "/serial@fe6a0000";
01a184        uart7 = "/serial@fe6b0000";
01a1a4        uart8 = "/serial@fe6c0000";
01a1c4        uart9 = "/serial@fe6d0000";
01a1e4        pwm4 = "/pwm@fe6e0000";
01a200        pwm5 = "/pwm@fe6e0010";
01a21c        pwm6 = "/pwm@fe6e0020";
01a238        pwm7 = "/pwm@fe6e0030";
01a254        pwm8 = "/pwm@fe6f0000";
01a270        pwm9 = "/pwm@fe6f0010";
01a28c        pwm10 = "/pwm@fe6f0020";
01a2a8        pwm11 = "/pwm@fe6f0030";
01a2c4        pwm12 = "/pwm@fe700000";
01a2e0        pwm13 = "/pwm@fe700010";
01a2fc        pwm14 = "/pwm@fe700020";
01a318        pwm15 = "/pwm@fe700030";
01a334        tsadc = "/tsadc@fe710000";
01a350        saradc = "/saradc@fe720000";
01a370        mailbox = "/mailbox@fe780000";
01a390        combphy1_usq = "/phy@fe830000";
01a3ac        combphy2_psq = "/phy@fe840000";
01a3c8        video_phy0 = "/video-phy@fe850000";
01a3e8        video_phy1 = "/video-phy@fe860000";
01a408        csi2_dphy_hw = "/csi2-dphy-hw@fe870000";
01a42c        csi2_dphy0 = "/csi2-dphy0";
01a444        mipi_in_ucam0 = "/csi2-dphy0/ports/port@0/endpoint@1";
01a474        mipi_in_ucam1 = "/csi2-dphy0/ports/port@0/endpoint@2";
01a4a4        csidphy_out = "/csi2-dphy0/ports/port@1/endpoint@0";
01a4d4        csi2_dphy1 = "/csi2-dphy1";
01a4ec        csi2_dphy2 = "/csi2-dphy2";
01a504        usb2phy0 = "/usb2-phy@fe8a0000";
01a524        u2phy0_host = "/usb2-phy@fe8a0000/host-port";
01a550        u2phy0_otg = "/usb2-phy@fe8a0000/otg-port";
01a578        usb2phy1 = "/usb2-phy@fe8b0000";
01a598        u2phy1_host = "/usb2-phy@fe8b0000/host-port";
01a5c4        u2phy1_otg = "/usb2-phy@fe8b0000/otg-port";
01a5ec        pinctrl = "/pinctrl";
01a604        gpio0 = "/pinctrl/gpio@fdd60000";
01a628        gpio1 = "/pinctrl/gpio@fe740000";
01a64c        gpio2 = "/pinctrl/gpio@fe750000";
01a670        gpio3 = "/pinctrl/gpio@fe760000";
01a694        gpio4 = "/pinctrl/gpio@fe770000";
01a6b8        pcfg_pull_up = "/pinctrl/pcfg-pull-up";
01a6dc        pcfg_pull_down = "/pinctrl/pcfg-pull-down";
01a700        pcfg_pull_none = "/pinctrl/pcfg-pull-none";
01a724        pcfg_pull_none_drv_level_1 = "/pinctrl/pcfg-pull-none-drv-level-1";
01a754        pcfg_pull_none_drv_level_2 = "/pinctrl/pcfg-pull-none-drv-level-2";
01a784        pcfg_pull_none_drv_level_3 = "/pinctrl/pcfg-pull-none-drv-level-3";
01a7b4        pcfg_pull_up_drv_level_1 = "/pinctrl/pcfg-pull-up-drv-level-1";
01a7e4        pcfg_pull_up_drv_level_2 = "/pinctrl/pcfg-pull-up-drv-level-2";
01a814        pcfg_pull_none_smt = "/pinctrl/pcfg-pull-none-smt";
01a83c        pcfg_output_low_pull_down = "/pinctrl/pcfg-output-low-pull-down";
01a86c        acodec_pins = "/pinctrl/acodec/acodec-pins";
01a894        cam_clkout0 = "/pinctrl/cam/cam-clkout0";
01a8bc        camera_pwr = "/pinctrl/cam/camera-pwr";
01a8e0        can0m1_pins = "/pinctrl/can0/can0m1-pins";
01a908        can1m1_pins = "/pinctrl/can1/can1m1-pins";
01a930        can2m1_pins = "/pinctrl/can2/can2m1-pins";
01a958        cif_clk = "/pinctrl/cif/cif-clk";
01a97c        cif_dvp_clk = "/pinctrl/cif/cif-dvp-clk";
01a9a4        cif_dvp_bus16 = "/pinctrl/cif/cif-dvp-bus16";
01a9cc        clk32k_out0 = "/pinctrl/clk32k/clk32k-out0";
01a9f4        ebc_pins = "/pinctrl/ebc/ebc-pins";
01aa18        gmac1m0_miim = "/pinctrl/gmac1/gmac1m0-miim";
01aa40        gmac1m0_rx_bus2 = "/pinctrl/gmac1/gmac1m0-rx-bus2";
01aa6c        hdmitxm0_cec = "/pinctrl/hdmitx/hdmitxm0-cec";
01aa98        hdmitx_scl = "/pinctrl/hdmitx/hdmitx-scl";
01aac0        hdmitx_sda = "/pinctrl/hdmitx/hdmitx-sda";
01aae8        i2c0_xfer = "/pinctrl/i2c0/i2c0-xfer";
01ab0c        i2c1_xfer = "/pinctrl/i2c1/i2c1-xfer";
01ab30        i2c2m1_xfer = "/pinctrl/i2c2/i2c2m1-xfer";
01ab58        i2c3m0_xfer = "/pinctrl/i2c3/i2c3m0-xfer";
01ab80        i2c4m0_xfer = "/pinctrl/i2c4/i2c4m0-xfer";
01aba8        i2c5m0_xfer = "/pinctrl/i2c5/i2c5m0-xfer";
01abd0        i2s1m0_lrcktx = "/pinctrl/i2s1/i2s1m0-lrcktx";
01abf8        i2s1m0_sclktx = "/pinctrl/i2s1/i2s1m0-sclktx";
01ac20        i2s1m0_sdi0 = "/pinctrl/i2s1/i2s1m0-sdi0";
01ac48        i2s1m0_sdo0 = "/pinctrl/i2s1/i2s1m0-sdo0";
01ac70        i2s2m0_lrcktx = "/pinctrl/i2s2/i2s2m0-lrcktx";
01ac98        i2s2m0_sclktx = "/pinctrl/i2s2/i2s2m0-sclktx";
01acc0        i2s2m0_sdi = "/pinctrl/i2s2/i2s2m0-sdi";
01ace8        i2s2m0_sdo = "/pinctrl/i2s2/i2s2m0-sdo";
01ad10        i2s3m1_lrck = "/pinctrl/i2s3/i2s3m1-lrck";
01ad38        i2s3m1_sclk = "/pinctrl/i2s3/i2s3m1-sclk";
01ad60        i2s3m1_sdi = "/pinctrl/i2s3/i2s3m1-sdi";
01ad88        i2s3m1_sdo = "/pinctrl/i2s3/i2s3m1-sdo";
01adb0        lcdc_ctl = "/pinctrl/lcdc/lcdc-ctl";
01add4        pdmm1_clk1 = "/pinctrl/pdm/pdmm1-clk1";
01adf8        pdmm1_sdi1 = "/pinctrl/pdm/pdmm1-sdi1";
01ae1c        pdmm1_sdi2 = "/pinctrl/pdm/pdmm1-sdi2";
01ae40        pdmm1_sdi3 = "/pinctrl/pdm/pdmm1-sdi3";
01ae64        pmic_int = "/pinctrl/pmic/pmic_int";
01ae88        soc_slppin_gpio = "/pinctrl/pmic/soc_slppin_gpio";
01aeb4        soc_slppin_slp = "/pinctrl/pmic/soc_slppin_slp";
01aee0        soc_slppin_rst = "/pinctrl/pmic/soc_slppin_rst";
01af0c        pwm0m0_pins = "/pinctrl/pwm0/pwm0m0-pins";
01af34        pwm1m0_pins = "/pinctrl/pwm1/pwm1m0-pins";
01af5c        pwm2m0_pins = "/pinctrl/pwm2/pwm2m0-pins";
01af84        pwm3_pins = "/pinctrl/pwm3/pwm3-pins";
01afa8        pwm4_pins = "/pinctrl/pwm4/pwm4-pins";
01afcc        pwm5_pins = "/pinctrl/pwm5/pwm5-pins";
01aff0        pwm6_pins = "/pinctrl/pwm6/pwm6-pins";
01b014        pwm7_pins = "/pinctrl/pwm7/pwm7-pins";
01b038        pwm8m0_pins = "/pinctrl/pwm8/pwm8m0-pins";
01b060        pwm9m0_pins = "/pinctrl/pwm9/pwm9m0-pins";
01b088        pwm10m0_pins = "/pinctrl/pwm10/pwm10m0-pins";
01b0b0        pwm11m0_pins = "/pinctrl/pwm11/pwm11m0-pins";
01b0d8        pwm12m0_pins = "/pinctrl/pwm12/pwm12m0-pins";
01b100        pwm13m0_pins = "/pinctrl/pwm13/pwm13m0-pins";
01b128        pwm14m0_pins = "/pinctrl/pwm14/pwm14m0-pins";
01b150        pwm15m0_pins = "/pinctrl/pwm15/pwm15m0-pins";
01b178        scr_pins = "/pinctrl/scr/scr-pins";
01b19c        sdmmc0_bus4 = "/pinctrl/sdmmc0/sdmmc0-bus4";
01b1c4        sdmmc0_clk = "/pinctrl/sdmmc0/sdmmc0-clk";
01b1ec        sdmmc0_cmd = "/pinctrl/sdmmc0/sdmmc0-cmd";
01b214        sdmmc0_det = "/pinctrl/sdmmc0/sdmmc0-det";
01b23c        sdmmc1_bus4 = "/pinctrl/sdmmc1/sdmmc1-bus4";
01b264        sdmmc1_clk = "/pinctrl/sdmmc1/sdmmc1-clk";
01b28c        sdmmc1_cmd = "/pinctrl/sdmmc1/sdmmc1-cmd";
01b2b4        spdifm0_tx = "/pinctrl/spdif/spdifm0-tx";
01b2dc        spi0m0_pins = "/pinctrl/spi0/spi0m0-pins";
01b304        spi0m0_cs0 = "/pinctrl/spi0/spi0m0-cs0";
01b32c        spi0m0_cs1 = "/pinctrl/spi0/spi0m0-cs1";
01b354        spi1m0_pins = "/pinctrl/spi1/spi1m0-pins";
01b37c        spi1m0_cs0 = "/pinctrl/spi1/spi1m0-cs0";
01b3a4        spi1m0_cs1 = "/pinctrl/spi1/spi1m0-cs1";
01b3cc        spi2m0_pins = "/pinctrl/spi2/spi2m0-pins";
01b3f4        spi2m0_cs0 = "/pinctrl/spi2/spi2m0-cs0";
01b41c        spi2m0_cs1 = "/pinctrl/spi2/spi2m0-cs1";
01b444        spi3m0_pins = "/pinctrl/spi3/spi3m0-pins";
01b46c        spi3m0_cs0 = "/pinctrl/spi3/spi3m0-cs0";
01b494        spi3m0_cs1 = "/pinctrl/spi3/spi3m0-cs1";
01b4bc        tsadc_shutorg = "/pinctrl/tsadc/tsadc-shutorg";
01b4e8        uart0_xfer = "/pinctrl/uart0/uart0-xfer";
01b510        uart1m0_xfer = "/pinctrl/uart1/uart1m0-xfer";
01b538        uart1m0_ctsn = "/pinctrl/uart1/uart1m0-ctsn";
01b560        uart1m0_rtsn = "/pinctrl/uart1/uart1m0-rtsn";
01b588        uart2m0_xfer = "/pinctrl/uart2/uart2m0-xfer";
01b5b0        uart3m0_xfer = "/pinctrl/uart3/uart3m0-xfer";
01b5d8        uart4m0_xfer = "/pinctrl/uart4/uart4m0-xfer";
01b600        uart5m0_xfer = "/pinctrl/uart5/uart5m0-xfer";
01b628        uart6m0_xfer = "/pinctrl/uart6/uart6m0-xfer";
01b650        uart7m2_xfer = "/pinctrl/uart7/uart7m2-xfer";
01b678        uart8m0_xfer = "/pinctrl/uart8/uart8m0-xfer";
01b6a0        uart9m0_xfer = "/pinctrl/uart9/uart9m0-xfer";
01b6c8        spi0m0_pins_hs = "/pinctrl/spi0-hs/spi0m0-pins";
01b6f4        spi1m0_pins_hs = "/pinctrl/spi1-hs/spi1m0-pins";
01b720        spi2m0_pins_hs = "/pinctrl/spi2-hs/spi2m0-pins";
01b74c        spi3m0_pins_hs = "/pinctrl/spi3-hs/spi3m0-pins";
01b778        gmac1m0_tx_bus2_level3 = "/pinctrl/gmac-txd-level3/gmac1m0-tx-bus2-level3";
01b7b4        gmac1m0_rgmii_bus_level3 = "/pinctrl/gmac-txd-level3/gmac1m0-rgmii-bus-level3";
01b7f4        gmac1m0_rgmii_clk_level2 = "/pinctrl/gmac-txc-level2/gmac1m0-rgmii-clk-level2";
01b834        tsadc_gpio_func = "/pinctrl/gpio-func/tsadc-gpio-func";
01b864        mxc6655xa_irq_gpio = "/pinctrl/mxc6655xa/mxc6655xa_irq_gpio";
01b898        touch_gpio = "/pinctrl/touch/touch-gpio";
01b8c0        wifi_enable_h = "/pinctrl/sdio-pwrseq/wifi-enable-h";
01b8f0        vcc5v0_host_en = "/pinctrl/usb/vcc5v0-host-en";
01b918        vcc5v0_otg_en = "/pinctrl/usb/vcc5v0-otg-en";
01b940        uart8_gpios = "/pinctrl/wireless-bluetooth/uart8-gpios";
01b974        uart1_gpios = "/pinctrl/wireless-bluetooth/uart1-gpios";
01b9a8        hp_det = "/pinctrl/headphone/hp-det";
01b9d0        lcd0_rst_gpio = "/pinctrl/lcd0/lcd-rst-gpio";
01b9f8        lcd1_rst_gpio = "/pinctrl/lcd1/lcd1-rst-gpio";
01ba20        wifi_host_wake_irq = "/pinctrl/wireless-wlan/wifi-host-wake-irq";
01ba58        adc_keys = "/adc-keys";
01ba70        audiopwmout_diff = "/audiopwmout-diff";
01ba90        master = "/audiopwmout-diff/simple-audio-card,codec";
01bac8        backlight = "/backlight";
01bae0        backlight1 = "/backlight1";
01baf8        dc_12v = "/dc-12v";
01bb0c        hdmi_sound = "/hdmi-sound";
01bb24        leds = "/leds";
01bb38        work_led = "/leds/work";
01bb50        pdmics = "/dummy-codec";
01bb6c        pdm_mic_array = "/pdm-mic-array";
01bb88        rk809_sound = "/rk809-sound";
01bba4        spdif_out = "/spdif-out";
01bbbc        vad_sound = "/vad-sound";
01bbd4        vcc3v3_sys = "/vcc3v3-sys";
01bbec        vcc5v0_sys = "/vcc5v0-sys";
01bc04        vcc5v0_usb = "/vcc5v0-usb";
01bc1c        vcc5v0_host = "/vcc5v0-host-regulator";
01bc40        vcc5v0_otg = "/vcc5v0-otg-regulator";
01bc64        vcc3v3_lcd0_n = "/vcc3v3-lcd0-n";
01bc80        vcc3v3_lcd1_n = "/vcc3v3-lcd1-n";
01bc9c        sdio_pwrseq = "/sdio-pwrseq";
01bcb8        wireless_wlan = "/wireless-wlan";
01bcd4        wireless_bluetooth = "/wireless-bluetooth";
01bcf4        rk_headset = "/rk-headset";
01bd0c        vcc3v3_vga = "/vcc3v3-vga";
01bd24        vcc_camera = "/vcc-camera-regulator";
01bd48        chosen = "/chosen";
01bd5c        fiq_debugger = "/fiq-debugger";
01bd78        debug = "/debug@fd904000";
01bd94        cspmu = "/cspmu@fd90c000";
01bdb0     }
01bdb4  }
01bdb8  End
01bdbc  Strings
01ecaf
Expand
Boot TTL LOG
  Quote
DDR Version V1.11 20211103
ln
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: -48ps, dqs1: -168ps, dqs2: -120ps, dqs3: -217ps,
tdqss: cs1 dqs0: -48ps, dqs1: -168ps, dqs2: -96ps, dqs3: -217ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x65
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1056MHz(final freq)
PHY drv:clk:36,ca:36,DQ:29,odt:60
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x43
cs 0:
the read training result:
DQS0:0x40, DQS1:0x36, DQS2:0x3f, DQS3:0x3e,
min  :0x11 0x11 0x13  0xe  0x2  0x3  0x5  0x8 , 0x2  0x3  0x1  0x1  0x5  0x7  0xa  0x7 ,
       0xf  0xe  0xd  0xb  0x1  0x1  0x2  0x5 , 0xb  0x7  0x6  0x1  0xe  0xd  0xf  0xd ,
mid  :0x2f 0x2f 0x30 0x2d 0x21 0x20 0x24 0x26 ,0x20 0x20 0x20 0x1f 0x23 0x26 0x28 0x24 ,
      0x2e 0x2d 0x2c 0x2b 0x20 0x21 0x22 0x24 ,0x2b 0x27 0x25 0x21 0x2e 0x2c 0x2e 0x2c ,
max  :0x4d 0x4e 0x4d 0x4d 0x40 0x3d 0x44 0x45 ,0x3e 0x3e 0x40 0x3d 0x42 0x45 0x47 0x42 ,
      0x4d 0x4d 0x4b 0x4b 0x40 0x42 0x42 0x44 ,0x4b 0x47 0x45 0x41 0x4e 0x4b 0x4e 0x4b ,
range:0x3c 0x3d 0x3a 0x3f 0x3e 0x3a 0x3f 0x3d ,0x3c 0x3b 0x3f 0x3c 0x3d 0x3e 0x3d 0x3b ,
      0x3e 0x3f 0x3e 0x40 0x3f 0x41 0x40 0x3f ,0x40 0x40 0x3f 0x40 0x40 0x3e 0x3f 0x3e ,
the write training result:
DQS0:0x3d, DQS1:0x2d, DQS2:0x33, DQS3:0x26,
min  :0x5f 0x64 0x63 0x62 0x53 0x53 0x58 0x5c 0x5c ,0x4d 0x4e 0x4d 0x4c 0x51 0x53 0x55 0x55 0x4f ,
      0x57 0x57 0x54 0x55 0x4b 0x4c 0x4c 0x52 0x50 ,0x49 0x47 0x44 0x3f 0x4c 0x4b 0x4c 0x4c 0x49 ,
mid  :0x7c 0x80 0x80 0x7e 0x70 0x71 0x75 0x78 0x78 ,0x6a 0x6a 0x68 0x67 0x6e 0x6e 0x70 0x70 0x6b ,
      0x74 0x73 0x70 0x71 0x67 0x67 0x67 0x6d 0x6c ,0x65 0x63 0x5f 0x5b 0x68 0x67 0x66 0x68 0x64 ,
max  :0x99 0x9d 0x9d 0x9b 0x8e 0x8f 0x92 0x94 0x94 ,0x88 0x87 0x84 0x83 0x8b 0x8a 0x8b 0x8b 0x88 ,
      0x91 0x90 0x8c 0x8e 0x83 0x82 0x83 0x88 0x88 ,0x82 0x80 0x7b 0x78 0x84 0x83 0x81 0x84 0x80 ,
range:0x3a 0x39 0x3a 0x39 0x3b 0x3c 0x3a 0x38 0x38 ,0x3b 0x39 0x37 0x37 0x3a 0x37 0x36 0x36 0x39 ,
      0x3a 0x39 0x38 0x39 0x38 0x36 0x37 0x36 0x38 ,0x39 0x39 0x37 0x39 0x38 0x38 0x35 0x38 0x37 ,
cs 1:
DQS0:0x41, DQS1:0x39, DQS2:0x3f, DQS3:0x3e,
min  :0x11 0x11 0x13  0xf  0x1  0x3  0x7  0x9 , 0x3  0x4  0x1  0x1  0x7  0x9  0xb  0x8 ,
      0x10  0xf  0xe  0xb  0x2  0x1  0x3  0x6 , 0xc  0x8  0x6  0x1  0xd  0xd  0xf  0xd ,
mid  :0x2f 0x31 0x31 0x2e 0x21 0x21 0x26 0x27 ,0x22 0x23 0x21 0x21 0x26 0x29 0x2a 0x27 ,
      0x2e 0x2e 0x2c 0x2a 0x21 0x21 0x23 0x24 ,0x2c 0x27 0x25 0x21 0x2d 0x2c 0x2e 0x2b ,
max  :0x4d 0x51 0x4f 0x4e 0x41 0x40 0x46 0x46 ,0x42 0x43 0x42 0x41 0x46 0x49 0x4a 0x46 ,
      0x4d 0x4d 0x4a 0x4a 0x41 0x42 0x43 0x43 ,0x4c 0x47 0x45 0x41 0x4d 0x4c 0x4e 0x4a ,
range:0x3c 0x40 0x3c 0x3f 0x40 0x3d 0x3f 0x3d ,0x3f 0x3f 0x41 0x40 0x3f 0x40 0x3f 0x3e ,
      0x3d 0x3e 0x3c 0x3f 0x3f 0x41 0x40 0x3d ,0x40 0x3f 0x3f 0x40 0x40 0x3f 0x3f 0x3d ,
min  :0x5f 0x63 0x63 0x62 0x53 0x53 0x57 0x5c 0x5c ,0x4e 0x4d 0x4c 0x4c 0x50 0x52 0x56 0x55 0x4f ,
      0x5a 0x5a 0x57 0x58 0x4e 0x4f 0x50 0x55 0x53 ,0x49 0x46 0x43 0x3d 0x4d 0x4a 0x4c 0x4c 0x49 ,
mid  :0x7c 0x7f 0x7f 0x7d 0x70 0x70 0x74 0x78 0x77 ,0x6b 0x6a 0x68 0x67 0x6d 0x6e 0x70 0x6f 0x6b ,
      0x78 0x77 0x74 0x75 0x6b 0x6a 0x6c 0x70 0x6e ,0x65 0x61 0x5f 0x5a 0x68 0x67 0x67 0x68 0x65 ,
max  :0x99 0x9c 0x9c 0x99 0x8d 0x8e 0x92 0x94 0x92 ,0x88 0x87 0x84 0x83 0x8b 0x8a 0x8a 0x89 0x88 ,
      0x96 0x94 0x91 0x92 0x89 0x86 0x88 0x8c 0x8a ,0x81 0x7d 0x7b 0x78 0x84 0x84 0x82 0x84 0x82 ,
range:0x3a 0x39 0x39 0x37 0x3a 0x3b 0x3b 0x38 0x36 ,0x3a 0x3a 0x38 0x37 0x3b 0x38 0x34 0x34 0x39 ,
      0x3c 0x3a 0x3a 0x3a 0x3b 0x37 0x38 0x37 0x37 ,0x38 0x37 0x38 0x3b 0x37 0x3a 0x36 0x38 0x39 ,
CA Training result:
cs:0 min  :0x54 0x4a 0x4e 0x40 0x4d 0x3f 0x4b ,0x4e 0x41 0x4a 0x3c 0x4c 0x39 0x4e ,
cs:0 mid  :0x8c 0x8e 0x86 0x85 0x85 0x84 0x77 ,0x87 0x86 0x82 0x82 0x83 0x7f 0x78 ,
cs:0 max  :0xc4 0xd3 0xbe 0xcb 0xbe 0xc9 0xa3 ,0xc0 0xcb 0xba 0xc8 0xba 0xc5 0xa3 ,
cs:0 range:0x70 0x89 0x70 0x8b 0x71 0x8a 0x58 ,0x72 0x8a 0x70 0x8c 0x6e 0x8c 0x55 ,
cs:1 min  :0x50 0x4a 0x49 0x45 0x49 0x42 0x4a ,0x4a 0x45 0x46 0x3f 0x48 0x3c 0x4a ,
cs:1 mid  :0x8c 0x8c 0x86 0x86 0x84 0x84 0x76 ,0x86 0x85 0x81 0x81 0x82 0x7d 0x76 ,
cs:1 max  :0xc8 0xcf 0xc3 0xc8 0xbf 0xc6 0xa3 ,0xc3 0xc5 0xbd 0xc3 0xbd 0xbe 0xa3 ,
cs:1 range:0x78 0x85 0x7a 0x83 0x76 0x84 0x59 ,0x79 0x80 0x77 0x84 0x75 0x82 0x59 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 10
spl: mmc init failed with error: -95
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256+ OK
## Checking uboot 0x00a00000 ... sha256+ OK
## Checking fdt 0x00b3bb50 ... sha256+ OK
## Checking atf-2 0xfdcc9000 ... sha256+ OK
## Checking atf-3 0xfdcd0000 ... sha256+ OK
## Checking optee 0x08400000 ... sha256+ OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 217.566 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-152-g4e725b15f:cl
NOTICE:  BL31: Built : 10:51:13, Jul 15 2021
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May  7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 #qmx_srv (Mar 20 2023 - 17:46:24 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM:  4 GiB
Sysmem: init
Relocation Offset: ed23d000
Relocation fdt: eb9f8820 - eb9fecd0
CR: M/C/I
Using default environment
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
boot mode: normal
FIT: no signed, no conf required
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 100000Hz
PMIC:  RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
vsel-gpios- not found! Error: -2
vdd_cpu init 900000 uV
io-domain: OK
dmc_fsp failed, ret=-19
Warn: can't find connect driver
Warn: can't get connect driver
Could not find baseparameter partition
Model: Rockchip RK3566 EVB3 DDR3 V10 Board
Rockchip UBOOT DRM driver version: v1.0.1
VOP have 2 active VP
vp0 have layer nr:3[0 2 4 ], primary plane: 4
vp1 have layer nr:3[1 3 5 ], primary plane: 5
vp2 have layer nr:0[], primary plane: 0
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:3840x2160
hdmi@fe0a0000:  detailed mode clock 297000 kHz, flags[5]
    H: 3840 4016 4104 4400
    V: 2160 2168 2178 2250
bus_format: 2025
VOP update mode to: 3840x2160p30, type: HDMI0 for VP0
VP0 set crtc_clock to 297000KHz
VOP VP0 enable Smart0[654x270->654x270@1593x945] fmt[2] addr[0xedf04000]
CEA mode used vic=95
final pixclk = 297000000 tmdsclk = 297000000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=297.000MHz N=5120 cts=247500
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 1416000 KHz
  dpll 528000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 1200000 KHz
  vpll 24000 KHz
  hpll 297000 KHz
  ppll 200000 KHz
  armclk 1416000 KHz
  aclk_bus 150000 KHz
  pclk_bus 100000 KHz
  aclk_top_high 500000 KHz
  aclk_top_low 400000 KHz
  hclk_top 150000 KHz
  pclk_top 100000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Net:   eth1: ethernet@fe010000
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Waring: Could not find security partition
Not AVB images, AVB skip
No valid android hdr
Android image load failed
Android boot failed, error -1.
## Booting FIT Image at 0xea21e800 with size 0x015d9000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at ea21e800 ...
   Using 'conf' configuration
## Verified-boot: 0
   Trying 'kernel' kernel subimage
     Description:  unavailable
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0xea23d600
     Data Size:    22781960 Bytes = 21.7 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00280000
     Entry Point:  0x00280000
     Hash algo:    sha256
     Hash value:   12d957b26e72c7e3ab747dc2a52433b0eb4e5a71feb69df72db121498da267bd
   Verifying Hash Integrity ... sha256+ OK
## Loading fdt from FIT Image at ea21e800 ...
   Trying 'fdt' fdt subimage
     Type:         Flat Device Tree
     Data Start:   0xea21f000
     Data Size:    124079 Bytes = 121.2 KiB
     Load Address: 0x08300000
     Hash algo:    sha256
     Hash value:   7d0a9eea7126526a3863e2662c9221d015a74dc44844168581a72d421e7c9f31
   Loading fdt from 0x08300000 to 0x08300000
   Booting using the fdt blob at 0x08300000
   Loading Kernel Image from 0xea23d600 to 0x00280000 ... OK
   kernel loaded at 0x00280000, end = 0x0183a008
  'reserved-memory' ramoops@110000: addr=110000 size=f0000
   Using Device Tree in place at 0000000008300000, end 00000000083214ae
vp0, plane_mask:0x15, primary-id:4, curser-id:-1
vp1, plane_mask:0x2a, primary-id:5, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000)
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 898.753 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 4.19.193 (qmx_srv@qmxsrv-MS-7C09) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #24 SMP Thu Mar 2 10:16:53 CST 2023
[    0.000000] Machine model: Rockchip RK3566 EVB3 DDR3 V10 Board
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] cma: Reserved 16 MiB at 0x00000000eec00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 23 pages/cpu s54312 r8192 d31704 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1027656
[    0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  androidboot.verifiedbootstate=orange rw rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTUUID=614e0000-0000
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB)
[    0.000000] Memory: 3978812K/4175872K available (13694K kernel code, 2024K rwdata, 4860K rodata, 1600K init, 1810K bss, 180676K reserved, 16384K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 50172 entries in 196 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] ITS [mem 0xfd440000-0xfd45ffff]
[    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @210000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x0000000000230000
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] CPU0: using LPI pending table @0x0000000000240000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001672] Console: colour dummy device 80x25
[    0.002113] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.003056] pid_max: default: 32768 minimum: 301
[    0.003583] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004208] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006028] ASID allocator initialised with 32768 entries
[    0.006624] rcu: Hierarchical SRCU implementation.
[    0.008989] Platform MSI: interrupt-controller@fd440000 domain created
[    0.009922] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    0.011266] smp: Bringing up secondary CPUs ...
[    0.012251] Detected VIPT I-cache on CPU1
[    0.012282] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.012321] CPU1: using LPI pending table @0x0000000000250000
[    0.012366] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.012932] Detected VIPT I-cache on CPU2
[    0.012955] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.012989] CPU2: using LPI pending table @0x0000000000260000
[    0.013022] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.013554] Detected VIPT I-cache on CPU3
[    0.013575] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.013608] CPU3: using LPI pending table @0x0000000000270000
[    0.013639] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.013721] smp: Brought up 1 node, 4 CPUs
[    0.020514] SMP: Total of 4 processors activated.
[    0.020947] CPU features: detected: GIC system register CPU interface
[    0.021535] CPU features: detected: Privileged Access Never
[    0.022047] CPU features: detected: LSE atomic instructions
[    0.022568] CPU features: detected: User Access Override
[    0.023058] CPU features: detected: 32-bit EL0 Support
[    0.023529] CPU features: detected: RAS Extension Support
[    0.024145] CPU: All CPU(s) started at EL2
[    0.024537] alternatives: patching kernel code
[    0.029694] devtmpfs: initialized
[    0.045348] Registered cp15_barrier emulation handler
[    0.045863] Registered setend emulation handler
[    0.046505] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.047410] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.048463] pinctrl core: initialized pinctrl subsystem
[    0.049719] NET: Registered protocol family 16
[    0.052861] cpuidle: using governor menu
[    0.053251] Registered FIQ tty driver
[    0.053946] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.055359] DMA: preallocated 256 KiB pool for atomic allocations
[    0.059571] console [pstore-1] enabled
[    0.059921] pstore: Registered ramoops as persistent store backend
[    0.060492] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.082726] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[    0.083791] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[    0.084788] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[    0.085787] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[    0.086787] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[    0.087451] rockchip-pinctrl pinctrl: probed pinctrl
[    0.096753] cryptd: max_cpu_qlen set to 1000
[[    0.098466] console [ttyFIQ0] enabled
[    0.099157] bootconsole [    0.099157] bootconsole [uart8250] disabled
[uart8250] disabled
[    0.100076] Registered fiq debugger ttyFIQ0
[    0.100873] vcc3v3_sys: supplied by dc_12v
[    0.101155] vcc5v0_sys: supplied by dc_12v
[    0.101434] vcc5v0_usb: supplied by dc_12v
[    0.101835] vcc5v0_host: supplied by vcc5v0_usb
[    0.102177] vcc5v0_otg: supplied by vcc5v0_usb
[    0.102479] vcc3v3_lcd0_n: supplied by vcc3v3_sys
[    0.102817] vcc3v3_lcd1_n: supplied by vcc3v3_sys
[    0.103922] rk_iommu fde4b000.iommu: version = 2
[    0.104366] rk_iommu fdea0800.iommu: version = 2
[    0.104767] rk_iommu fded0480.iommu: version = 2
[    0.105116] rk_iommu fdee0800.iommu: version = 2
[    0.105411] rk_iommu fdef0800.iommu: version = 2
[    0.105692] rk_iommu fdf40f00.iommu: version = 2
[    0.106076] rk_iommu fdf80800.iommu: version = 2
[    0.106383] rk_iommu fdff1a00.iommu: version = 2
[    0.106587] rk_iommu fe043e00.iommu: version = 2
[    0.107274] SCSI subsystem initialized
[    0.107492] usbcore: registered new interface driver usbfs
[    0.107547] usbcore: registered new interface driver hub
[    0.107594] usbcore: registered new device driver usb
[    0.107674] media: Linux media interface: v0.10
[    0.107719] videodev: Linux video capture interface: v2.00
[    0.107789] pps_core: LinuxPPS API ver. 1 registered
[    0.107804] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.107829] PTP clock support registered
[    0.108091] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.109977] Advanced Linux Sound Architecture Driver Initialized.
[    0.110383] Bluetooth: Core ver 2.22
[    0.110429] NET: Registered protocol family 31
[    0.110444] Bluetooth: HCI device and connection manager initialized
[    0.110462] Bluetooth: HCI socket layer initialized
[    0.110478] Bluetooth: L2CAP socket layer initialized
[    0.110513] Bluetooth: SCO socket layer initialized
[    0.110907] rockchip-cpuinfo cpuinfo: SoC            : 35662000
[    0.110925] rockchip-cpuinfo cpuinfo: Serial         : baedc7b8eb5ab5fa
[    0.111680] clocksource: Switched to clocksource arch_sys_counter
[    0.173276] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.173578] NET: Registered protocol family 2
[    0.174071] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes)
[    0.174154] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.174345] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.175162] TCP: Hash tables configured (established 32768 bind 32768)
[    0.175291] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.175468] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.175767] NET: Registered protocol family 1
[    0.176214] RPC: Registered named UNIX socket transport module.
[    0.176231] RPC: Registered udp transport module.
[    0.176244] RPC: Registered tcp transport module.
[    0.176255] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.178189] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.179837] Initialise system trusted keyrings
[    0.180007] workingset: timestamp_bits=61 max_order=20 bucket_order=0
[    0.185042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.185696] NFS: Registering the id_resolver key type
[    0.185734] Key type id_resolver registered
[    0.185748] Key type id_legacy registered
[    0.185782] ntfs: driver 2.1.32 [Flags: R/O].
[    0.186011] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.186190] fuse init (API version 7.27)
[    0.186496] SGI XFS with security attributes, no debug enabled
[    0.188517] NET: Registered protocol family 38
[    0.188551] Key type asymmetric registered
[    0.188565] Asymmetric key parser 'x509' registered
[    0.188610] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.188626] io scheduler noop registered
[    0.188639] io scheduler deadline registered
[    0.188738] io scheduler cfq registered (default)
[    0.188756] io scheduler mq-deadline registered
[    0.188769] io scheduler kyber registered
[    0.189632] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[    0.189776] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[    0.191399] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.5
[    0.191636] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.6
[    0.192830] extcon extcon1: failed to create extcon usb2-phy link
[    0.192947] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.5
[    0.193081] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.5
[    0.193187] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[    0.199669] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.199761] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.199952] pwm-backlight backlight1: backlight1 supply power not found, using dummy regulator
[    0.200015] pwm-backlight backlight1: Linked as a consumer to regulator.0
[    0.200217] mpp_service mpp-srv: eccf16e83556 author: Finley Xiao 2021-07-05 soc: rockchip: opp_select: Export rockchip_nvmem_cell_read_u8/u16()
[    0.200228] mpp_service mpp-srv: probe start
[    0.201006] iommu: Adding device fdf40000.rkvenc to group 5
[    0.201044] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[    0.201230] mpp_rkvenc fdf40000.rkvenc: probing start
[    0.201654] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[    0.201700] rkvenc_init:1196: failed to add venc devfreq
[    0.202866] iommu: Adding device fdea0400.vdpu to group 1
[    0.202902] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[    0.203055] mpp_vdpu2 fdea0400.vdpu: probe device
[    0.203559] mpp_vdpu2 fdea0400.vdpu: probing finish
[    0.204017] iommu: Adding device fdee0000.vepu to group 3
[    0.204051] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[    0.204221] mpp_vepu2 fdee0000.vepu: probe device
[    0.204678] mpp_vepu2 fdee0000.vepu: probing finish
[    0.205167] iommu: Adding device fdef0000.iep to group 4
[    0.205208] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[    0.205334] mpp-iep2 fdef0000.iep: probe device
[    0.205738] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[    0.205897] mpp-iep2 fdef0000.iep: probing finish
[    0.206385] iommu: Adding device fded0000.jpegd to group 2
[    0.206418] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[    0.206544] mpp_jpgdec fded0000.jpegd: probe device
[    0.206990] mpp_jpgdec fded0000.jpegd: probing finish
[    0.207463] iommu: Adding device fdf80200.rkvdec to group 6
[    0.207495] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[    0.207703] mpp_rkvdec2 fdf80200.rkvdec: probing start
[    0.208102] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[    0.208120] rkvdec2_init:875: No niu aclk reset resource define
[    0.208136] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[    0.208148] rkvdec2_init:878: No niu hclk reset resource define
[    0.208449] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[    0.208468] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[    0.208477] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[    0.208484] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[    0.208495] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[    0.208520] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[    0.208830] mpp_service mpp-srv: probe success
[    0.214524] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[    0.214554] dma-pl330 fe530000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.216392] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[    0.216408] dma-pl330 fe550000.dmac:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    0.217955] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    0.218931] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.219714] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 55, base_baud = 1500000) is a 16550A
[    0.220171] fe6b0000.serial: ttyS7 at MMIO 0xfe6b0000 (irq = 56, base_baud = 1500000) is a 16550A
[    0.222447] random: fast init done
[    0.222738] random: crng init done
[    0.223080] iommu: Adding device fe040000.vop to group 8
[    0.223119] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[    0.227301] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[    0.227819] rockchip-drm display-subsystem: Linked as a consumer to fe0c0000.edp
[    0.228261] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[    0.229726] rockchip-drm display-subsystem: dmc is disabled
[    0.229988] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x15, primary plane phy id: 4
[    0.230013] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x2a, primary plane phy id: 5
[    0.230033] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[    0.230233] [drm] unsupported AFBC format[3432564e]
[    0.230286] [drm] failed to init overlay plane Cluster0-win1
[    0.230340] [drm] failed to init overlay plane Cluster1-win1
[    0.230471] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008ebf7d8)
[    0.231346] rockchip-drm display-subsystem: bound fe0c0000.edp (ops 0xffffff8008ec2888)
[    0.231542] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    0.232024] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    0.232626] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008ec32e0)
[    0.232656] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.232670] [drm] No driver support for vblank timestamp query.
[    0.232854] get_framebuffer_by_node: failed to get logo,offset
[    0.711283] rockchip-drm display-subsystem: fb0:  frame buffer device
[    0.712168] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[    0.717372] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[    0.717479] mali fde60000.gpu: Power management initialization failed error = -517
[    0.717507] mali fde60000.gpu: Device initialization Deferred
[    0.717879] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.718525] brd: module loaded
[    0.724223] loop: module loaded
[    0.724584] zram: Added device: zram0
[    0.724699] lkdtm: No crash points registered, enable through debugfs
[    0.728401] libphy: Fixed MDIO Bus: probed
[    0.728453] tun: Universal TUN/TAP device driver, 1.6
[    0.729931] rk_gmac-dwmac fe010000.ethernet: no regulator found
[    0.729955] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[    0.729966] rk_gmac-dwmac fe010000.ethernet: TX delay(0x41).
[    0.729975] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2e).
[    0.729988] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    0.735037] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    0.735272] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    0.735289] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    0.735305] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    0.735316] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    0.735328] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    0.735340] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    0.735378] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    0.735392] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    0.735407] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    0.868366] libphy: stmmac: probed
[    0.870545] usbcore: registered new interface driver rndis_wlan
[    0.870612] usbcore: registered new interface driver rtl8150
[    0.870659] usbcore: registered new interface driver r8152
[    0.870709] usbcore: registered new interface driver asix
[    0.870760] usbcore: registered new interface driver ax88179_178a
[    0.870806] usbcore: registered new interface driver cdc_ether
[    0.870853] usbcore: registered new interface driver rndis_host
[    0.870910] usbcore: registered new interface driver cdc_ncm
[    0.870958] usbcore: registered new interface driver cdc_mbim
[    0.872142] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2
[    0.875405] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2
[    0.879484] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.879514] ehci-pci: EHCI PCI platform driver
[    0.879584] ehci-platform: EHCI generic platform driver
[    0.879940] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.879965] ohci-platform: OHCI generic platform driver
[    0.880919] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    0.881089] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[    0.881412] xhci-hcd xhci-hcd.5.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000001002010010
[    0.881477] xhci-hcd xhci-hcd.5.auto: irq 69, io mem 0xfcc00000
[    0.881801] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.881819] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.881832] usb usb1: Product: xHCI Host Controller
[    0.881844] usb usb1: Manufacturer: Linux 4.19.193 xhci-hcd
[    0.881856] usb usb1: SerialNumber: xhci-hcd.5.auto
[    0.882269] hub 1-0:1.0: USB hub found
[    0.882315] hub 1-0:1.0: 1 port detected
[    0.882649] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[    0.882806] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[    0.882832] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[    0.882903] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.883019] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.883037] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.883050] usb usb2: Product: xHCI Host Controller
[    0.883063] usb usb2: Manufacturer: Linux 4.19.193 xhci-hcd
[    0.883074] usb usb2: SerialNumber: xhci-hcd.5.auto
[    0.883438] hub 2-0:1.0: USB hub found
[    0.883481] hub 2-0:1.0: 1 port detected
[    0.883943] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    0.884095] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
[    0.884407] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[    0.884466] xhci-hcd xhci-hcd.6.auto: irq 70, io mem 0xfd000000
[    0.884729] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.884748] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.884762] usb usb3: Product: xHCI Host Controller
[    0.884774] usb usb3: Manufacturer: Linux 4.19.193 xhci-hcd
[    0.884785] usb usb3: SerialNumber: xhci-hcd.6.auto
[    0.885195] hub 3-0:1.0: USB hub found
[    0.885239] hub 3-0:1.0: 1 port detected
[    0.885532] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[    0.885679] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
[    0.885704] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[    0.885779] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.885889] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    0.885907] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.885921] usb usb4: Product: xHCI Host Controller
[    0.885933] usb usb4: Manufacturer: Linux 4.19.193 xhci-hcd
[    0.885945] usb usb4: SerialNumber: xhci-hcd.6.auto
[    0.886303] hub 4-0:1.0: USB hub found
[    0.886349] hub 4-0:1.0: 1 port detected
[    0.886760] usbcore: registered new interface driver cdc_acm
[    0.886776] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    0.886838] usbcore: registered new interface driver cdc_wdm
[    0.887073] usbcore: registered new interface driver uas
[    0.887191] usbcore: registered new interface driver usb-storage
[    0.887294] usbcore: registered new interface driver usbserial_generic
[    0.887329] usbserial: USB Serial support registered for generic
[    0.887380] usbcore: registered new interface driver cp210x
[    0.887411] usbserial: USB Serial support registered for cp210x
[    0.887483] usbcore: registered new interface driver ftdi_sio
[    0.887516] usbserial: USB Serial support registered for FTDI USB Serial Device
[    0.887664] usbcore: registered new interface driver keyspan
[    0.887697] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    0.887727] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    0.887750] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    0.887780] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    0.887832] usbcore: registered new interface driver option
[    0.887865] usbserial: USB Serial support registered for GSM modem (1-port)
[    0.888061] usbcore: registered new interface driver oti6858
[    0.888099] usbserial: USB Serial support registered for oti6858
[    0.888148] usbcore: registered new interface driver pl2303
[    0.888183] usbserial: USB Serial support registered for pl2303
[    0.888238] usbcore: registered new interface driver qcserial
[    0.888269] usbserial: USB Serial support registered for Qualcomm USB modem
[    0.888359] usbcore: registered new interface driver sierra
[    0.888395] usbserial: USB Serial support registered for Sierra USB modem
[    0.889890] usbcore: registered new interface driver usbtouchscreen
[    0.889956] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[    0.889975] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[    0.890692] i2c /dev entries driver
[    0.892843] rk808 0-0020: chip id: 0x8090
[    0.892898] rk808 0-0020: No cache defaults, reading back from HW
[    0.916612] rk808 0-0020: source: on=0x40, off=0x00
[    0.916638] rk808 0-0020: support dcdc3 fb mode:-22, 63
[    0.916655] rk808 0-0020: support pmic reset mode:0,0
[    0.921327] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.921360] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.921616] vdd_logic: supplied by vcc3v3_sys
[    0.921949] vdd_gpu: supplied by vcc3v3_sys
[    0.922208] vcc_ddr: supplied by vcc3v3_sys
[    0.922482] vdd_npu: supplied by vcc3v3_sys
[    0.922750] vcc_1v8: supplied by vcc3v3_sys
[    0.923003] vdda0v9_image: supplied by vcc3v3_sys
[    0.923254] vdda_0v9: supplied by vcc3v3_sys
[    0.923501] vdda0v9_pmu: supplied by vcc3v3_sys
[    0.923737] vccio_acodec: supplied by vcc3v3_sys
[    0.923984] vccio_sd: supplied by vcc3v3_sys
[    0.924239] vcc3v3_pmu: supplied by vcc3v3_sys
[    0.924494] vcca_1v8: supplied by vcc3v3_sys
[    0.924758] vcca1v8_pmu: supplied by vcc3v3_sys
[    0.925054] vcca1v8_image: supplied by vcc3v3_sys
[    0.925316] vcc_3v3: supplied by vcc3v3_sys
[    0.925547] vcc3v3_sd: supplied by vcc3v3_sys
[    0.925818] rk817-battery rk817-battery: Failed to find matching dt id
[    0.926042] rk817-charger rk817-charger: Failed to find matching dt id
[    0.929117] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    0.935187] rk808-rtc rk808-rtc: registered as rtc0
[    0.936901] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:01:05 UTC (1501837265)
[    0.938505] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    0.941811] vdd_cpu: supplied by vcc5v0_sys
[    0.944114] rockchip-pinctrl pinctrl: pin gpio3-11 already requested by fe010000.ethernet; cannot claim for fe5e0000.i2c
[    0.944140] rockchip-pinctrl pinctrl: pin-107 (fe5e0000.i2c) status -22
[    0.944151] rockchip-pinctrl pinctrl: could not request pin 107 (gpio3-11) from group i2c5m0-xfer  on device rockchip-pinctrl
[    0.944159] rk3x-i2c fe5e0000.i2c: Error applying setting, reverse things back
[    0.944180] rk3x-i2c: probe of fe5e0000.i2c failed with error -22
[    0.945946] iommu: Adding device fdff0000.rkisp to group 7
[    0.945987] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[    0.946171] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[    0.946190] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[    0.946220] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[    0.946959] rkisp rkisp-vir0: rkisp driver version: v01.06.01
[    0.947044] rkisp rkisp-vir0: No memory-region-thunderboot specified
[    0.947239] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[    0.947265] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[    0.948906] usbcore: registered new interface driver uvcvideo
[    0.948926] USB Video Class driver (1.1.1)
[    0.949231] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20
[    0.949262] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[    0.949372] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[    0.949456] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.18
[    0.949490] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[    0.949598] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.19
[    0.949632] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[    0.949723] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.14
[    0.949749] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[    0.949829] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24
[    0.949863] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[    0.949945] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[    0.950050] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[    0.953336] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[    0.954386] Bluetooth: HCI UART driver ver 2.3
[    0.954402] Bluetooth: HCI UART protocol H4 registered
[    0.954416] Bluetooth: HCI UART protocol ATH3K registered
[    0.954493] usbcore: registered new interface driver bfusb
[    0.954559] usbcore: registered new interface driver btusb
[    0.954871] cpu cpu0: leakage=30
[    0.954918] cpu cpu0: pvtm = 89970, from nvmem
[    0.954940] cpu cpu0: pvtm-volt-sel=1
[    0.955807] cpu cpu0: Linked as a consumer to regulator.26
[    0.955867] cpu cpu0: Dropping the link to regulator.26
[    0.956477] cpu cpu0: Linked as a consumer to regulator.26
[    0.957094] cpu cpu0: avs=0
[    0.957155] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[    0.957337] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    0.962200] sdhci: Secure Digital Host Controller Interface driver
[    0.962224] sdhci: Copyright(c) Pierre Ossman
[    0.962236] Synopsys Designware Multimedia Card Interface Driver
[    0.963134] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[    0.963305] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[    0.963321] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[    0.963383] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 39,32 bit host data width,256 deep fifo
[    0.963524] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25
[    0.963594] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.19
[    0.975445] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    0.988711] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode.
[    0.988820] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller.
[    0.988841] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a
[    0.988896] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[    0.989038] dwmmc_rockchip fe2c0000.dwmmc: allocated mmc-pwrseq
[    0.989050] mmc_host mmc2: card is non-removable.
[    1.208780] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    1.222206] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.224348] mmc0: Unknown controller version (5). You may experience problems.
[    1.255077] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[    1.257057] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.257157] hidraw: raw HID events driver (C) Jiri Kosina
[    1.257531] usbcore: registered new interface driver usbhid
[    1.257546] usbhid: USB HID core driver
[    1.257929] rockchip,bus bus-npu: Linked as a consumer to regulator.10
[    1.257957] rockchip,bus bus-npu: Failed to get leakage
[    1.258021] rockchip,bus bus-npu: pvtm = 89970, from nvmem
[    1.258042] rockchip,bus bus-npu: pvtm-volt-sel=1
[    1.258255] rockchip,bus bus-npu: avs=0
[    1.260877] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.21
[    1.260975] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.261538] optee: probing for conduit method from DT.
[    1.261575] optee: revision 3.6 (0b06ae94)
[    1.261979] optee: initialized driver
[    1.261995] rksfc_base v1.1 2016-01-08
[    1.262580] rksfc fe300000.sfc: rksfc_probe clk rate = 99000000
[    1.262692] rkflash_dev_init enter
[    1.262717] sfc nor id: 0 0 0
[    1.262729] rkflash[1] is invalid
[    1.262731] rkflash_dev_init enter
[    1.262756] sfc_nand id: 0 0 0
[    1.262762] rkflash[2] is invalid
[    1.262978] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.263558] usbcore: registered new interface driver snd-usb-audio
[    1.265642] rk817-codec rk817-codec: DMA mask not set
[    1.272227] Initializing XFRM netlink socket
[    1.272644] NET: Registered protocol family 10
[    1.273452] Segment Routing with IPv6
[    1.273554] NET: Registered protocol family 17
[    1.273582] NET: Registered protocol family 15
[    1.273708] Bluetooth: RFCOMM socket layer initialized
[    1.273747] Bluetooth: RFCOMM ver 1.11
[    1.273762] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.273797] Bluetooth: HIDP socket layer initialized
[    1.273844] [BT_RFKILL]: Enter rfkill_rk_init
[    1.273858] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.274408] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    1.274466] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6398s
[    1.274481] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    1.274494] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    1.274532] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 74, flags = 0.
[    1.274550] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    1.274562] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    1.274574] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[    1.274586] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    1.275256] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77.
[    1.275293] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 79.
[    1.275315] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 81.
[    1.275336] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 80.
[    1.275408] [BT_RFKILL]: Request irq for bt wakeup host
[    1.275503] [BT_RFKILL]: ** disable irq
[    1.275657] [BT_RFKILL]: bt_default device registered.
[    1.275836] Key type dns_resolver registered
[    1.275854] openvswitch: Open vSwitch switching datapath
[    1.276091] mpls_gso: MPLS GSO support
[    1.276416] flash vendor_init_thread!
[    1.276435] flash vendor storage:20170308 ret = -1
[    1.276681] rockchip-pinctrl pinctrl: pin gpio4-7 already requested by fe640000.spi; cannot claim for 2-0036
[    1.276708] rockchip-pinctrl pinctrl: pin-135 (2-0036) status -22
[    1.276718] rockchip-pinctrl pinctrl: could not request pin 135 (gpio4-7) from group cam-clkout0  on device rockchip-pinctrl
[    1.276729] ov5695 2-0036: Error applying setting, reverse things back
[    1.276765] ov5695: probe of 2-0036 failed with error -22
[    1.277038] rockchip-pinctrl pinctrl: pin gpio4-7 already requested by fe640000.spi; cannot claim for 2-0037
[    1.277058] rockchip-pinctrl pinctrl: pin-135 (2-0037) status -22
[    1.277075] rockchip-pinctrl pinctrl: could not request pin 135 (gpio4-7) from group cam-clkout0  on device rockchip-pinctrl
[    1.277088] gc8034 2-0037: Error applying setting, reverse things back
[    1.277111] gc8034: probe of 2-0037 failed with error -22
[    1.278124] Loading compiled-in X.509 certificates
[    1.278862] pstore: Using compression: deflate
[    1.279922] rga2: Driver loaded successfully ver:3.2.63318
[    1.280424] rga2: Module initialized.
[    1.286583] mmc0: new HS200 MMC card at address 0001
[    1.287639] mmcblk0: mmc0:0001 032G00 29.1 GiB
[    1.288385] mmcblk0boot0: mmc0:0001 032G00 partition 1 8.00 MiB
[    1.289082] mmcblk0boot1: mmc0:0001 032G00 partition 2 8.00 MiB
[    1.289369] mmcblk0rpmb: mmc0:0001 032G00 partition 3 4.00 MiB, chardev (238:0)
[    1.292414]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[    1.309441] mpp_rkvenc fdf40000.rkvenc: probing start
[    1.310080] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to regulator.10
[    1.310117] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[    1.310189] mpp_rkvenc fdf40000.rkvenc: pvtm = 89970, from nvmem
[    1.310211] mpp_rkvenc fdf40000.rkvenc: pvtm-volt-sel=1
[    1.310399] mpp_rkvenc fdf40000.rkvenc: avs=0
[    1.310779] mpp_rkvenc fdf40000.rkvenc: failed to find power_model node
[    1.310801] mpp_rkvenc fdf40000.rkvenc: failed to initialize power model
[    1.310829] mpp_rkvenc fdf40000.rkvenc: failed to get dynamic-coefficient
[    1.311195] mpp_rkvenc fdf40000.rkvenc: probing finish
[    1.311898] mali fde60000.gpu: Kernel DDK version g2p0-01eac0
[    1.312066] mali fde60000.gpu: Linked as a consumer to regulator.11
[    1.312212] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[    1.312301] mali fde60000.gpu: leakage=8
[    1.312343] mali fde60000.gpu: pvtm = 89970, from nvmem
[    1.312754] mali fde60000.gpu: avs=0
[    1.312775] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    1.313085] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[    1.313179] mali fde60000.gpu: No memory group manager is configured
[    1.313551] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[    1.314142] mali fde60000.gpu: Probed as mali0
[    1.314614] input: adc-keys as /devices/platform/adc-keys/input/input1
[    1.315718] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok
[    1.319118] rockchip-pinctrl pinctrl: pin gpio4-11 already requested by fe640000.spi; cannot claim for rk-headset
[    1.319144] rockchip-pinctrl pinctrl: pin-139 (rk-headset) status -22
[    1.319157] rockchip-pinctrl pinctrl: could not request pin 139 (gpio4-11) from group hp-det  on device rockchip-pinctrl
[    1.319168] rockchip_headset rk-headset: Error applying setting, reverse things back
[    1.319193] rockchip_headset: probe of rk-headset failed with error -22
[    1.319460] iommu: Adding device fde40000.npu to group 0
[    1.319494] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[    1.319979] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[    1.320105] RKNPU fde40000.npu: Linked as a consumer to regulator.13
[    1.320125] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[    1.320535] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[    1.320601] RKNPU fde40000.npu: leakage=4
[    1.320641] RKNPU fde40000.npu: pvtm = 89970, from nvmem
[    1.321103] RKNPU fde40000.npu: avs=0
[    1.321706] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[    1.322319] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.324213] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.325207] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.325823] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '10:15:48', on 'Mar  2 2023'.
[    1.326202] Mali:
[    1.326204] Mali device driver loaded
[    1.326226] rkisp rkisp-vir0: clear unready subdev num: 2
[    1.326239] rockchip-csi2-dphy0: No link between dphy and sensor
[    1.326605] rockchip-csi2-dphy0: No link between dphy and sensor
[    1.326621] rkisp-vir0: update sensor failed
[    1.326777] ALSA device list:
[    1.326788]   #0: rockchip,hdmi
[    1.327076] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.327092] cfg80211: failed to load regulatory.db
[    1.328820] mmc_host mmc2: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    1.332770] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    1.332832] VFS: Mounted root (ext4 filesystem) on device 179:6.
[    1.334643] devtmpfs: mounted
[    1.336509] Freeing unused kernel memory: 1600K
[    1.351749] Run /sbin/init as init process
[    1.400326] vendor storage:20190527 ret = 0
[    1.415963] devfreq fde60000.gpu: Couldn't update frequency transition information.
[    1.557578] systemd[1]: System time before build time, advancing clock.
[    1.561403] systemd[1]: Failed to lookup module alias 'autofs4': Function not implemented
Welcome to Debian GNU/Linux 10 (buster)!
[    1.655139] dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 186
[    1.658153] mmc2: new ultra high speed SDR104 SDIO card at address 0001
File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Created slice system-getty.slice.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote Encrypted Volumes.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Journal Socket.
         Starting Nameserver information manager...
         Starting Remount Root and Kernel File Systems...
         Starting Wait Until Kernel Time Synchronized...
         Starting udev Coldplug all Devices...
         Mounting Kernel Debug File System...
         Starting Journal Service...
         Starting Load Kernel Modules...
         Starting Set the console keyboard layout...
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Nameserver information manager.
         Starting Load/Save Random Seed...
         Starting Create System Users...
[  OK  ] Started Load Kernel Modules.
         Mounting FUSE Control File System...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[    3.139148] systemd-journald[133]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started Create Static Device Nodes in /dev.
         Starting udev Kernel Device Manager...
[  OK  ] Started udev Kernel Device Manager.
         Starting Network Service...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Set the console keyboard layout.
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems.
         Starting Set console font and keymap...
         Starting Enable support fo…l executable binary formats...
         Starting Create Volatile Files and Directories...
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Started Set console font and keymap.
[  OK  ] Started Enable support for…nal executable binary formats.
[  OK  ] Started Helper to synchronize boot up for ifupdown.
         Starting Raise network interfaces...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on triggerhappy.socket.
[  OK  ] Listening on OpenBSD Secure Shell server socket.
[  OK  ] Listening on ACPID Listen Socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started ACPI Events Check.
[  OK  ] Reached target Paths.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting adbd for Debian...
         Starting enable ASYNC for Debian Display...
         Starting Initialize hardware monitoring sensors...
         Starting Daemon for power management...
         Starting rkisp 3A engine...
         Starting System Logging Service...
         Starting triggerhappy global hotkey daemon...
         Starting Disk Manager...
[  OK  ] Started ACPI event daemon.
         Starting LSB: Load kernel …d to enable cpufreq scaling...
[  OK  ] Started D-Bus System Message Bus.
         Starting WPA supplicant...
         Starting Network Manager...
         Starting Login Service...
[  OK  ] Started triggerhappy global hotkey daemon.
[  OK  ] Started System Logging Service.
[  OK  ] Started rkisp 3A engine.
[  OK  ] Started Initialize hardware monitoring sensors.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen …ess of backlight:backlight1...
         Starting Load/Save Screen …ness of backlight:backlight...
[  OK  ] Started Setup rockchip platform environment.
[  OK  ] Started enable ASYNC for Debian Display.
[    4.174478] file system registered
[  OK  ] Started Load/Save Screen B…tness of backlight:backlight1.
[  OK  ] Started Load/Save Screen B…htness of backlight:backlight.
[    4.310430] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    4.505324] Mass Storage Function, version: 2009/09/11
[    4.506865] LUN: removable file: (no medium)
[    4.825111] read descriptors
[    4.825185] read strings
[  OK  ] Started Network Name Resolution.
[  OK  ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
[  OK  ] Found device /dev/ttyFIQ0.
[  OK  ] Started Raise network interfaces.
[  OK  ] Started Daemon for power management.
         Starting Hostname Service...
         Starting Authorization Manager...
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Created slice system-zram\x2dsetup.slice.
         Starting Setup zram based device zram0...
[  OK  ] Started Manage Sound Card State (restore and store).
         Starting Save/Restore Sound Card State...
         Starting LSB: set CPUFreq kernel parameters...
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Network Manager.
[  OK  ] Started WPA supplicant.
[  OK  ] Started Login Service.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Reached target Sound Card.
[  OK  ] Reached target Network.
         Starting vsftpd FTP server...
         Starting /etc/rc.local Compatibility...
         Starting Permit User Sessions...
         Starting Advanced IEEE 802…/WPA/WPA2/EAP Authenticator...
         Starting Network Time Service...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Started Setup zram based device zram0.
[  OK  ] Started vsftpd FTP server.
[  OK  ] Started Permit User Sessions.
[FAILED] Failed to start Advanced I…1X/WPA/WPA2/EAP Authenticator.
See 'systemctl status hostapd.service' for details.
[  OK  ] Started Authorization Manager.
[  OK  ] Started Hostname Service.
         Starting Network Manager Script Dispatcher Service...
[FAILED] Failed to start Network Time Service.
See 'systemctl status ntp.service' for details.
[  OK  ] Started Network Manager Script Dispatcher Service.
[  OK  ] Started LSB: set CPUFreq kernel parameters.
[    5.720133] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.722252] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[    5.744406] dwmac4: Master AXI performs any burst length
[    5.744459] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[    5.744485] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[    5.744823] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[    5.749304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[  OK  ] Started adbd for Debian.
         Starting Light Display Manager...
[  OK  ] Started Disk Manager.
[  OK  ] Started Light Display Manager.
[  OK  ] Stopped Advanced IEEE 802.…1X/WPA/WPA2/EAP Authenticator.
[    7.725000] broken atomic modeset userspace detected, disabling atomic
[    8.807367] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property hdmi_color_depth_capacity
[    8.807452] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property hdmi_output_mode_capacity
[    8.940695] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property output_type_capacity
[    9.364987] rc.local[486]: Creating SSH2 RSA key; this may take some time ...
[    9.391112] rc.local[486]: 2048 SHA256:nH8BHNmo6G8iNCRyS4KOfmF6WB3gQ3V6MOCGFgSyYoc root@linaro-alip (RSA)
[    9.462038] rc.local[486]: Creating SSH2 ECDSA key; this may take some time ...
[    9.487735] rc.local[486]: 256 SHA256:TZSSrr0kHCzn0kcwG3i80HdpalMSMEj5Md+Zbv2iwQk root@linaro-alip (ECDSA)
[    9.534690] rc.local[486]: Creating SSH2 ED25519 key; this may take some time ...
[    9.561101] rc.local[486]: 256 SHA256:kzAVvxSmhqsRiS2lEfYyQWmFqeVopv3eD2kaw0VKih0 root@linaro-alip (ED25519)
[   10.074131] Freeing drm_logo memory: 732K
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Started User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of user linaro.
[   12.536928] rc.local[486]: rescue-ssh.target is a disabled or a static unit, not starting it.
[   12.865935] rc.local[486]: insserv: warning: script 'rkisp_3A.sh' missing LSB tags
[   12.867694] rc.local[486]: insserv: Default-Start undefined, assuming empty start runlevel(s) for script `rkisp_3A.sh'
[   12.868899] rc.local[486]: insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `rkisp_3A.sh'
[   12.870511] rc.local[486]: insserv: warning: script 'S10atomic_commit.sh' missing LSB tags
[   12.871688] rc.local[486]: insserv: Default-Start undefined, assuming empty start runlevel(s) for script `S10atomic_commit.sh'
[   12.873211] rc.local[486]: insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `S10atomic_commit.sh'
[   12.877399] rc.local[486]: insserv: warning: script 'S99_usbhost_en.sh' missing LSB tags
[   12.878170] rc.local[486]: insserv: Default-Start undefined, assuming empty start runlevel(s) for script `S99_usbhost_en.sh'
[   12.879424] rc.local[486]: insserv: Default-Stop  undefined, assuming empty stop  runlevel(s) for script `S99_usbhost_en.sh'
         Starting OpenBSD Secure Shell server...
         Starting Bluetooth service...
[FAILED] Failed to start OpenBSD Secure Shell server.
See 'systemctl status ssh.service' for details.
[   15.961433] rc.local[486]: Job for ssh.service failed because the control process exited with error code.
[   15.962762] rc.local[486]: See "systemctl status ssh.service" and "journalctl -xe" for details.
[   15.987173] rc.local[486]: invoke-rc.d: initscript ssh, action "restart" failed.
[  OK  ] Started Bluetooth service.
[   16.112070] rc.local[486]: ● ssh.service - OpenBSD Secure Shell server
[   16.113777] rc.local[486]:    Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
[   16.116968] rc.local[486]:    Active: failed (Result: exit-code) since Thu 2019-02-14 10:12:12 UTC; 152ms ago
[   16.118841] rc.local[486]:      Docs: man:sshd(8)
[   16.119780] rc.local[486]:            man:sshd_config(5)
[   16.121407] rc.local[486]:   Process: 1030 ExecStartPre=/usr/sbin/sshd -t (code=exited, status=0/SUCCESS)
[   16.124597] rc.local[486]:   Process: 1046 ExecStart=/usr/sbin/sshd -D $SSHD_OPTS (code=exited, status=255/EXCEPTION)
[   16.127920] rc.local[486]:  Main PID: 1046 (code=exited, status=255/EXCEPTION)
[   16.135190] rc.local[486]: Feb 14 10:12:12 linaro-alip sshd[1046]: error: Bind to port 22 on 0.0.0.0 failed: Address already in use.
[   16.136404] rc.local[486]: Feb 14 10:12:12 linaro-alip sshd[1046]: error: Bind to port 22 on :: failed: Address already in use.
[   16.137824] rc.local[486]: Feb 14 10:12:12 linaro-alip sshd[1046]: fatal: Cannot bind any address.
[   16.139002] rc.local[486]: Feb 14 10:12:12 linaro-alip systemd[1]: ssh.service: Failed with result 'exit-code'.
[   16.140175] rc.local[486]: Feb 14 10:12:12 linaro-alip systemd[1]: Failed to start OpenBSD Secure Shell server.
[FAILED] Failed to start /etc/rc.local Compatibility.
See 'systemctl status rc-local.service' for details.
[  OK  ] Started Serial Getty on ttyFIQ0.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[   17.582538] EXT4-fs (mmcblk0p8): mounting ext2 file system using the ext4 subsystem
[   17.592393] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[   17.609003] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[  OK  ] Created slice system-clean\x2dmount\x2dpoint.slice.
[  OK  ] Started Clean the /media/l…8509-244aa3b1d889 mount point.
[   18.040824] EXT4-fs (mmcblk0p7): mounting ext2 file system using the ext4 subsystem
[   18.047023] EXT4-fs (mmcblk0p7): mounted filesystem without journal. Opts: (null)
[  OK  ] Started Clean the /media/l…bd5c-a4f94bfa3bd9 mount point.
[   21.266363] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
Debian GNU/Linux 10 linaro-alip ttyFIQ0
linaro-alip login: root (automatic login)
Linux linaro-alip 4.19.193 #24 SMP Thu Mar 2 10:16:53 CST 2023 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@linaro-alip:~# [   29.512470] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[   29.512503] ======== dhd_wlan_init_plat_data ========
[   29.512511] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[   29.512590] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=97, oob_irq_flags=0x414
[   29.512604] dhd_wlan_init_gpio: WL_REG_ON=-1
[   29.512611] dhd_wifi_platform_load: Enter
[   29.512618] Power-up adapter 'DHD generic adapter'
[   29.515913] wifi_platform_set_power = 1
[   29.515943] ======== PULL WL_REG_ON(-1) HIGH! ========
[   29.515952] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   29.515963] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[   29.515971] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[   29.821752] wifi_platform_bus_enumerate device present 1
[   29.821796] ======== Card detection to detect SDIO card! ========
[   29.821811] mmc2:mmc host rescan start!
[   29.838143] bcmsdh_register: register client driver
[   29.838615] bcmsdh_sdmmc_probe: Enter num=1
[   29.841874] bcmsdh_sdmmc_probe: Enter num=2
[   29.841924] bus num (host idx)=2, slot num (rca)=1
[   29.841939] found adapter info 'DHD generic adapter'
[   29.842011] sdioh_attach: set sd_f2_blocksize 256
[   29.842078] sdioh_attach: sd clock rate = 0
[   29.842318] dhdsdio_probe : no mutex held. set lock
[   29.842460] F1 signature read @0x18000000=0x16024335
[   29.850907] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x0
[   29.852046] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   29.852158] [dhd] dhd_conf_set_chiprev : chip=0x4339, chiprev=1
[   29.852313] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[   29.852860] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[   29.857405] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[   29.865058] dhd_attach(): thread:dhd_watchdog_thread:586 started
[   29.865201] dhd_attach(): thread:dhd_dpc:587 started
[   29.865295] dhd_attach(): thread:dhd_rxf:588 started
[   29.865313] dhd_deferred_work_init: work queue initialized
[   29.865325] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[   29.865528] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[   29.870715] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[   29.878523] Register interface [wlan0]  MAC: f0:25:b7:4c:b3:57
[   29.878523]
[   29.878732] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0
[   29.878774] dhd_wl_ioctl: returning as busstate=0
[   29.878788] dhd_dbg_detach_pkt_monitor, 2204
[   29.878799] dhd_bus_devreset: == Power OFF ==
[   29.888419] bcmsdh_oob_intr_unregister: Enter
[   29.888455] bcmsdh_oob_intr_unregister: irq is not registered
[   29.888473] dhd_txglom_enable: enable 0
[   29.888481] dhd_bus_devreset:  WLAN OFF DONE
[   29.888810] wifi_platform_set_power = 0
[   29.888829] ======== PULL WL_REG_ON(-1) LOW! ========
[   29.888836] [WLAN_RFKILL]: rockchip_wifi_power: 0
[   29.888858] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[   29.888865] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[   29.888874] dhdsdio_probe : the lock is released.
[   29.889086] dhd_module_init: Exit err=0
[   30.043275] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   30.043525] dhd_open: Enter 00000000f2571afd
[   30.043538] dhd_open : no mutex held. set lock
[   30.043549]
[   30.043549] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[   30.043565] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[   30.043572] wifi_platform_set_power = 1
[   30.043578] ======== PULL WL_REG_ON(-1) HIGH! ========
[   30.043585] [WLAN_RFKILL]: rockchip_wifi_power: 1
[   30.043592] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[   30.043598] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[   30.228175] broken atomic modeset userspace detected, disabling atomic
[   30.348449] sdio_reset_comm():
[   30.568442] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[   30.583444] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2)
[   30.601170] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[   30.613381] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[   30.616563] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[   30.618333] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[   30.682009] mmc_host mmc2: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[   31.025117] dwmmc_rockchip fe2c0000.dwmmc: Successfully tuned phase to 186
[   31.025208] sdioh_start: set sd_f2_blocksize 256
[   31.025512]
[   31.025512]
[   31.025512] dhd_bus_devreset: == WLAN ON ==
[   31.025621] F1 signature read @0x18000000=0x16024335
[   31.029308] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x0
[   31.029893] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   31.033881] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[   31.033917] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm4339a0_ag.bin
[   31.033924] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_AP6335.txt
[   31.033930] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm4339a0_ag.blob
[   31.033935] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[   31.034816] dhd_os_open_image: /vendor/etc/firmware/fw_bcm4339a0_ag.bin (569309 bytes) open success
[   31.111428] dhd_os_open_image: /vendor/etc/firmware/nvram_AP6335.txt (2366 bytes) open success
[   31.112398] NVRAM version: AP6335_NVRAM_V1.7_04102014
[   31.113521] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   31.316931] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   31.317174] bcmsdh_oob_intr_register: HW_OOB irq=97 flags=0x4
[   31.317369] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist
[   31.317385] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[   31.319685] Disable tdls_auto_op failed. -1
[   31.319730] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 1
[   31.320364] dhd_apply_default_clm: Ignore clm file /vendor/etc/firmware/clm_bcm4339a0_ag.blob
[   31.330409] Firmware up: op_mode=0x0005, MAC=f0:25:b7:4c:b3:57
[   31.348539]   Driver: 1.579.77.41.22 (r-20191105-2)(20191120-1)
[   31.348539]   Firmware: wl0: Jun 20 2018 18:44:59 version 6.37.45.15 (9b93cd5@shgit)  (r)
[   31.348539]   CLM: 6.8.1
[   31.348796] dhd_txglom_enable: enable 1
[   31.348815] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[   31.348826] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[   31.348835] [dhd] dhd_conf_set_txglom_params : txinrx_thres=128, dhd_txminmax=-1
[   31.348844] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[   31.348856] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[   31.349620] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[   31.350768] dhd_pno_init: Support Android Location Service
[   31.394568] dhd_wlfc_enable: ret=0
[   31.394617] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.394710] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.394838] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.394989] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[   31.395056] dhd_rtt_init : FTM is not supported
[   31.395079] dhd_preinit_ioctls: SensorHub diabled 0
[   31.395627] dhd_preinit_ioctls failed to set ShubHub disable
[   31.397150] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[   31.397176] failed to get wnm_bsstrans_resp
[   31.397613] failed to set WNM capabilities
[   31.397940] dhd_wlfc_enable: ret=0
[   31.397945] [dhd] dhd_conf_set_country : set country CN, revision 38
[   31.397995] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.398090] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.398166] [dhd] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[   31.400930] [dhd] dhd_conf_set_country : Country code: CN (CN/38)
[   31.404043] [dhd-wlan0] wl_android_wifi_on : Success
[   31.448884] dhd_wlfc_enable: ret=0
[   31.465613] dhd_open : the lock is released.
[   31.465648] dhd_open: Exit ret=0
[   31.553852] P2P interface registered
[   31.553893] wl_cfgp2p_add_p2p_disc_if: wdev: 000000006314df58, wdev->net:           (null)
[   31.617247] WLC_E_IF: NO_IF set, event Ignored
[   31.618075] P2P interface started
[   31.639233] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   31.643522] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
[   31.674022] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property hdmi_color_depth_capacity
[   31.674086] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property hdmi_output_mode_capacity
[   31.807332] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property output_type_capacity
[   32.056388] vcc3v3_lcd0_n: disabling
[   32.056435] vcc3v3_lcd1_n: disabling
[   35.013822] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 1, bssidx: 0
[   43.524951] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[   43.581939] [BT_RFKILL]: ENABLE UART_RTS
[   43.688552] [BT_RFKILL]: DISABLE UART_RTS
[   43.688684] [BT_RFKILL]: bt turn on power
[   43.688754] [BT_RFKILL]: Request irq for bt wakeup host
[   43.688845] [BT_RFKILL]: ** disable irq
Expand
big.txtFetching info...
Edited by hotnikq
Posted (edited)
  On 6/8/2023 at 12:47 AM, hotnikq said:
Linux version 4.19.193 like the image v0.3 on this topic...
Expand
this image probably from Rockchip
it's encrypted with sha256
and use an old kernel
can be good to work nativelly
baremetal with RKnpu and GPU
but i'm looking for something more docker side of things
kernel 6.2 is runing amazing, i'm searching for a way to make an image for flash mmc
i can create an image with  Linux_Pack_Firmware
  Quote
/Downloads/Linux_Pack_Firmware/rockdev$ ./mkupdate.sh
start to make update.img...
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x1ce,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x729c0,userspace=0xe6
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x74000,size=0x1aa,userspace=0x1
Add file: ./Image/dtbo.img
Add file: ./Image/dtbo.img done,offset=0x74800,size=0x26f,userspace=0x1
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x75000,size=0x400000,userspace=0x800
Add file: ./Image/parameter.txt done,offset=0x475000,size=0x19e,userspace=0x1
Add file: ./Image/rootfs.img
Add file: ./Image/rootfs.img done,offset=0x475800,size=0x11f213e00,userspace=0x23e428
Add CRC...
Make firmware OK!
------ OK ------
********RKImageMaker ver 1.66********
Generating new image, please wait...
Writing head info...
Writing boot file...
Writing firmware...
Generating MD5 data...
MD5 data generated successfully!
New image generated successfully!
Making ./Image/update.img OK.
Expand
My image looks like this:
/dev/mmcblk1p3: PARTLABEL="trust" PARTUUID="xxx"
/dev/mmcblk1p1: PARTLABEL="security" PARTUUID="xxx"
/dev/mmcblk1p4: PARTLABEL="baseparameter" PARTUUID="xxx"
/dev/mmcblk1p2: PARTLABEL="uboot" PARTUUID="xxx"
/dev/mmcblk1p5: PTUUID="xxxx" PTTYPE="gpt" PARTLABEL="root" PARTUUID="xxx"
and its reporting on ttl:
Scanning mmc 0:4...
Failed to iterate over directory extlinux
Failed to iterate over directory boot.scr.uimg
## Error: "mtd_boot" not defined
But i need to change it to something like this to boot from MMC:
/dev/mmcblk1p4: UUID="xxx" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="xxx"
and it need to do something like this:
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
320 bytes read in 21 ms (14.6 KiB/s)
1:      Armbian
Retrieving file: /boot/uInitrd
33353896 bytes read in 2805 ms (11.3 MiB/s)
Retrieving file: /boot/Image
27853312 bytes read in 2340 ms (11.4 MiB/s)
if i boot from SD card and change it
i'ts working, booting from MMC but i'm trying to make a image to share here and use as backup/repair
Edited by Hqnicolas
Posted (edited)
dear friends that buy cheap  42U$ tv boxes on chinese scam sites!
rk3566 h96MAX ARMBIAN23 kernel6 MMC image it's done.
🏆 help to add other boards in armbian standart, you don't need to be a programmer to help the community,
just need a copy of the ARM BOARD and a x86 computer to compile new versions.
This is an internal mmc trick 2-step image!
You no longer need to solder an SD-card Reader like the creepy Release Version v0.5 BETA that i made.
check before if your device has the regulator: fan53555
check before if your device has: tcs4525
check before if your device has: RK809-5
works with 4gb and 8gb devices
How to use it:
- install RKDevTool Drivers Rockchip
- Use RkDevTool v2.86
- Drop Config.cfg  the RkDevTool config file on folder
Righ click on white background from RKDevTool
click on Load Config
Select the Config.cfg
Step 1:
Extract this file.xz with 7zip
Extract this file.tar with 7zip
Connect Your device:
How? press the back button with a toothpick and connect male to male USB to you computer.
Flash the Update Image on entire device as an Upgrade Firmware
After Complete ! ! Disconect your device ! !
and because I'm lazy and I don't want to work on that damn FIT image anymore. You will need to do a second step:
Step 2:
Reconnect Your device:
Flash the armbian extracted GPT image inside the MMC gpt partition
how:
on RkDevTool v2.86
double click the number on table
set Address on 0x00000000
set Name on gpt
select the root file to flash on the "..." the dot right side of the table........
mark, Write by address
after flash, it's done, use HDMI and USB to create user and password, regular armbian install...
The Gpt file
The Server 4gb Update image
The Server 8gb Update image
Yes, you can Skip Root flash.
But you can drop the v0.7 Root.img file.
Please Reflash GPT.img after new Root.img
Two Root v0.7 Files:
Debian 12 BookWorm Server Minimal ROOT
Debian 12 BookWorm Desktop Gnome ROOT
Armbian_23.11.0-trunk_Station-m2_jammy_edge_6.2.16_Server_Minimal.img ✔️
Boot from internal MMC ✔️
Runs kernel 6.2 Server ✔️
display video HDMi ✔️
detect internal MMC ✔️
Detect SD-CARD ✔️
Detect USB 2.0 port ✖️ (no USB2.0 on Server Images)
Detect USB 3.0 port ✔️ (use a cheap usb hub 3.0)
##################################### END ##############################################
############################### HOT TO CREATE IMAGES ######################################
if you wanna do all that creepy again with other devices and images, (please do it on other devices) and topic
this is all you need to create this image,
first step:
Compile armbian on linux desktop
dont forgot to do it with modified DTS file:
in this case DTB + DTS Files for you to edit because you want to help the community
any resemblance to this topic is mere adaptation
Mount that image virtual device like /media/armbian_boot
fdisk -l your-armbian-image-for-sd-card.img
mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot
if you can't "like WSL2"
sudo apt-get install kpartx
sudo kpartx -av your-armbian-image-for-sd-card.img
sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot
Second Step:  prepare an sd card or usb flash dummy , can be anithing with 6gb
fdisk /dev/mmcblk1
N
default
default (lower this value to match the size of your root image)
T
1
W
third step: format that flash drive for ext4
mkfs.ext4 /dev/mmcblk1p1
fourth step: mount that clear partition and copy the entire virtual drive to the flash device
mount /dev/mmcblk1p1 /mnt
rsync -avx --timeout=10 /media/armbian_boot/ /mnt/
fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1"
blkid
nano -w /mnt/boot/extlinux/extlinux.conf
sync
umount /mnt
sixth step: make an hardware RAW.img from hardware flash drive with these parameters
sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress
PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1
now you have an ROOT IMAGE MADE BY YOURSELF!
Update.img
CREATE the Update Image on linux with the rockchip software.
Linux Pack Rockchip Firmware
  Quote
Add CRC...
Make firmware OK!
------ OK ------
Writing firmware...
Expand
./mkupdate.sh
Uboot Legacy, Parameter.txt to create the Rockchip image
this process generate two files:
File1: Linux_Pack_Firmware/rockdev/Image/update.img
File2: Linux_Pack_Firmware/rockdev/update.img
I generally use the File2 to flash my device on upgrade Firmware RKDevTool
Edited by Hqnicolas
