lucascgo Posted October 25, 2022 Posted October 25, 2022 Hello everyone, I'm running the image from NanoPi R2S on a NanoPi R2C Plus (that has 8 GB eMMC). Is well working, but I would like to install the OS on the eMMC. Is it possible? Thanks. 0 Quote
ga6 Posted January 14, 2025 Posted January 14, 2025 It's easy to enable For example, in the r2s options, the “current” option means installing the 6.12 kernel. And according to the content of `config/boards/nanopi-r2s.csc` file, the dts file is `rk3328-nanopi-r2-rev00.dts`. Then go to `patch/kernel/archive/rockchip64-6.12/dt/` and modify the file `rk3328-nanopi-r2-rev00.dts`. // If you want to enable eMMC, find the following &emmc { status = "disabled"; }; // Modified to &emmc { status = "okey"; }; By the way If you want to enable sdio wifi, follow these // find the following &sdmmc_ext { status = "disabled"; }; &sdio_pwrseq { status = "disabled"; }; // Modified to &sdmmc_ext { vmmc-supply = <&vcc_io>; vqmmc-supply = <&vcc_18>; max-frequency = <150000000>; sd-uhs-sdr104; status = "okay"; /delete-node/ bcrmf@1; rtl8822cs@1 { reg = <1>; compatible = "realtek,rtl8822cs"; }; }; &sdmmc0ext_clk { rockchip,pins = <3 RK_PA2 3 &pcfg_pull_none_8ma>; }; &sdmmc0ext_cmd { rockchip,pins = <3 RK_PA0 3 &pcfg_pull_up_8ma>; }; &sdmmc0ext_bus4 { rockchip,pins = <3 RK_PA4 3 &pcfg_pull_up_8ma>, <3 RK_PA5 3 &pcfg_pull_up_8ma>, <3 RK_PA6 3 &pcfg_pull_up_8ma>, <3 RK_PA7 3 &pcfg_pull_up_8ma>; }; &sdio_pwrseq { status = "okay"; }; Finally, just recompile. 0 Quote
Werner Posted January 14, 2025 Posted January 14, 2025 Would you mind sending a PR adding these changes? Might be useful for others. https://docs.armbian.com/Process_Contribute/ 0 Quote
