Minimalistic Flat Design
Minimalisti, yet complex, this wallpaper represents a CPU on a silicon wafer with a PCB design.
The design has infinite background color possibilities as shown in the GIF below:
Designed by: AntwanDesign
EDIT: Here is a .zip with 8 color variations in ALL resolutions: DOWNLOAD HERE!
Well Hello Armbians,
( i just joined today, was on BPI before)
Actually the original Wallpaper isnt that bad.
My personal opinion, i dont like the standard linux penguin animal motive. The universe...well, sdcards..no.
i like #29 pretty well. (high-rise buildings with electronics)
reduce text to just-
Armbian
ARM-Linux
I used GIMP and Affinity Designer. I created the vector of the pcbs, which will be provided if needed.
If you do not like the sdcard, I can change to with whatever you want. Just ask.
I hosted the .zip file on dropbox, with all the resolutions needed. Download HERE
HDAnBfq.jpgGood luck to everyone! :D
Hey username,
good stuff. i've been meaning to check out affinity. i've heard a lot of good stuff. how do you like it?
  On 11/29/2016 at 8:10 PM, chzbacon said:
Hey username,
I have used Sketch before. I switched to Affinity designer because it is multiplatform and Sketch was too slow with bigger files. Affinity is much more responsive
