etona Posted March 14, 2017 Share Posted March 14, 2017 To change the screen resolution, you need to edit the file "amlogics905x_init.sh". To move comments from 1080 to 720 and restart the system.. ---- Firefox sound fixed. Screen resolution , i dont know how. I am try, and i cant. Im finded this file in "boot" folder, and give me 4 option. 2x terminal, do nothing, 1x exit,do exit, and 1x display, this option I can open, but cant edit... Can write # near 1080, and delete near 720, but cant save this. Next time when open is same, again. Some program for setting this, in synaptic not egsist? Link to comment Share on other sites More sharing options...
xXx Posted March 14, 2017 Share Posted March 14, 2017 3 minutes ago, etona said: Screen resolution , i dont know how. sudo nano /boot/thefileinquestion.sh edit the file and remove the "#" in front of 1080 line, put it in from of the 720 line. CTRL+O to save CTRL+X to exit sudo reboot. You are done. Link to comment Share on other sites More sharing options...
etona Posted March 14, 2017 Share Posted March 14, 2017 Problem again. Where to find text to edit? Link to comment Share on other sites More sharing options...
xXx Posted March 14, 2017 Share Posted March 14, 2017 @etona sudo nano /boot/amlogics905x_init.sh the "file in question" is the file amlogics905x_init.sh 1 Link to comment Share on other sites More sharing options...
etona Posted March 14, 2017 Share Posted March 14, 2017 I have nexboxa95x, with s905x 2ghz, and p212 board. Not other two nexbox with aml. s905.. Link to comment Share on other sites More sharing options...
xXx Posted March 14, 2017 Share Posted March 14, 2017 3 minutes ago, etona said: I have nexboxa95x, with s905x 2ghz, and p212 board. Not other two nexbox with aml. s905.. I'm sorry, but i can't help you any further, because i have MiniM8S only. The other boxes i mentioned in an older post, was for donation ( not mine ). Link to comment Share on other sites More sharing options...
etona Posted March 14, 2017 Share Posted March 14, 2017 Tnx. Now cant sawing with airmouse, have no usb keyboard..Sorry i am newbie, with linux.. Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 File /boot/amlogics905x_init.sh common to the entire line of devices s9xxx. Link to comment Share on other sites More sharing options...
etona Posted March 15, 2017 Share Posted March 15, 2017 I am solved firefox, and now audio work perfect, now video dont work... I must learning too much. Now Ill waiting some time, and try making a new sd card... On my armbian i have "vim terminal", and "mate terminal". Maibie i have wrong software? This "odroid", I am never started, dont work by me. Link to comment Share on other sites More sharing options...
etona Posted March 15, 2017 Share Posted March 15, 2017 Tnx for help. Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 Do not use versions of images from Odroid without special manual adjustments, You can turn TV box into a brick. Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 (edited) On 3/14/2017 at 8:01 AM, balbes150 said: Judging by the output, the installation should work. Pay attention to matching the size of the partitions and installed system. That would be enough space to install. i'm not sure what you mean by "matching the size" but i guess that you have to make sure that the size of the data in your "ROOTFS" partition is less than the size of the emmc data size. in my case the xenial server is less than 2GB so i guess it's okay. Anyways i tried the install.sh script from your "5.27 (test 20170314)" xenial server image and it didn't work. the 5.27 image runs fine on my a95x with p201 dtb, haven't tested anything beside first boot and reboot. the install script runs ok, but then the box boots into a loop (display signal and eth link light loop, never reaches the nexbox logo). Is there a way to debug that in some logs somewhere or do i have to solder a serial. i can still boot from the sdcard so i'm currently also testing a restore with the latest xxx dd_backup script. -- edit -- restore from failed emmc install worked fine with xxx script Edited March 15, 2017 by mdel Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 Without UART it is difficult to understand where start the problem. If possible, it is useful to see the output of fw_printenv from running from external media system. Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 @ 30 minutes ago, balbes150 said: Without UART it is difficult to understand where start the problem. If possible, it is useful to see the output of fw_printenv from running from external media system. fw_printenv before install.sh http://termbin.com/mohh fw_printenv after install.sh (running from the external sd) http://termbin.com/gwre i will try to solder serial later today or in the a few days. Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 Try to remove the output of fw_printenv after installation (after running the script install.sh) and system restart without pulling out the SD card. What would the system starts from the external media immediately after installation. Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 here's the serial output : http://termbin.com/1ng2 you'll see a loop ending i believe with "Resetting CPU ..." then i halted by striking a key and added the output of "help" and "printenv" i've started reading it but i can't really find out what's wrong or what's going on with the loading process.. Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 sorry missed your answer : what do you mean by "remove the output of fw_printenv after installation" ? here's what i did exactly : - run install.sh - do a "shutdown -h now" - unplug the power, remove the sd card - plug the power back in, see the boot loop. then i unplug power again, put the sd card back in and plug the power, then the system starts from the sdcard right away. Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 I meant that after installing, restart TV box (with a connected SD card). To run the command fw_printenv. Something to watch, fixed the result of a change in ENV. UPDATE Show more the log output from UART when system starts with external media. UPDATE2 I don't see in the log of boot from UART, that would be before the kernel is running from internal memory load dtb data from the internal memory. You can try hands prescribe the right option to ENV (using the console UART). Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 (edited) here's the fw_printenv after ./install.sh && reboot (with sdcard of course) : http://termbin.com/cdot here's the serial output for the normal sd card boot : http://termbin.com/mpw9 one thing, there's a wireless "air keyboard+mouse" (one single device) plugged in the usb port if you see some usb devices in the logs. and i also always connect the lan cable. yes i know i can call dtb/kernel loading and boot from uboot serial prompt but i don't know too much about that so i'm searching at the moment. -- edit -- i don't quite understand what are the command to boot from emmc, it's quite simple with the fatload commands from external storage. Anyways i'm going to try loading from tftp, as i have a server running and that uboot seems to support tftp and using the emmc "/data" rootfs . -- edit 2 -- okay i can load uInitrd and zImage from my tftp server and then boot using the s905_autoscript booti command so the system is running from the internal emmc and mount shows : /dev/data on / type ext4 (rw,noatime,errors=remount-ro,data=writeback) let me know if you find what's wrong with the boot command, i've tried to look again but i'm not seeing much that i can recognize and uboot documentation is not helping me, many commands are missing. thx Edited March 15, 2017 by mdel Link to comment Share on other sites More sharing options...
balbes150 Posted March 15, 2017 Author Share Posted March 15, 2017 Perhaps the reason is not the correct file linux.img (which is automatically generated when you build the image, it is possible to rebuild manually and overwrite). I need time to check it out. I think You have the system does not start due to the fact that the team is the u-boot bootloader (bootm) can only run "old" versions of the kernel (processed with mkimage command or mkbootimg), and the eMMC will get the option to use booti command. Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 (edited) unrelated to the internal emmc boot. running your Armbian_5.27_S9xxx_Ubuntu_xenial_3.14.29_server_20170314.img image, (on the internal emmc at the moment) i notice that the cpu temperature reported by armbianmonitor is much higher than on my other identical a95x running your Armbian_5.26_S9xxx_Ubuntu_xenial_3.14.29_server_20170302.img the two boxes are NOT in the same location but still the heatsink is much hotter than usual : root@amlogic-s905x:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 16:24:19: 500MHz 0.38 4% 0% 0% 0% 2% 0% 61.0°C 16:24:25: 1000MHz 0.35 4% 0% 0% 0% 2% 0% 60.0°C 16:24:30: 500MHz 0.32 4% 0% 0% 0% 2% 0% 60.0°C 16:24:35: 250MHz 0.30 4% 0% 0% 0% 2% 0% 59.0°C 16:24:40: 100MHz 0.27 4% 0% 0% 0% 2% 0% 60.0°C 16:24:45: 500MHz 0.25 4% 0% 0% 0% 2% 0% 59.0°C 16:24:50: 250MHz 0.23 4% 0% 0% 0% 2% 0% 60.0°C 16:24:55: 100MHz 0.21 4% 0% 0% 0% 2% 0% 60.0°C 16:25:00: 1000MHz 0.20 4% 0% 0% 0% 2% 0% 60.0°C other box (5.26) : Time CPU load %cpu %sys %usr %nice %io %irq CPU 16:31:43: 1000MHz 1.10 7% 1% 3% 0% 1% 0% 45.0°C 16:31:48: 1296MHz 1.09 7% 1% 3% 0% 1% 0% 45.0°C 16:31:53: 1000MHz 1.00 7% 1% 3% 0% 1% 0% 44.0°C 16:31:58: 1000MHz 1.00 7% 1% 3% 0% 1% 0% 45.0°C 16:32:03: 500MHz 1.16 7% 1% 3% 0% 1% 0% 44.0°C 16:32:08: 1000MHz 1.06 7% 1% 3% 0% 1% 0% 45.0°C i will flash the same 5.26 image and run it on my "hot" box to see what happens. -- edit -- i could not reproduce that behavior when booting from the sd card (same 5.27 image), i'll see what happens when i try to boot from emmc again. Edited March 16, 2017 by mdel Link to comment Share on other sites More sharing options...
mdel Posted March 15, 2017 Share Posted March 15, 2017 (edited) okay i think i understand. the final boot command is "storeboot" if nothing else is found : storeboot=if imgread kernel boot ${loadaddr}; then store dtb read $dtb_mem_addr; bootm ${loadaddr}; fi;run update; which loads your /boot/linux.img file that you have dd to /dev/boot in install.sh. then bootm which fails to run that linux.img.. (for some reason loading that image is okay ?) So as booti works fine, i was wondering if i could do something real ugly, which is : (assuming that there's no fat partition already available on the flash) format /dev/boot to fat32, copy uInitrd and zImage there, then change uboot env to run the fatload/booti sequence ? would that work ? i'm a bit scared to brick my device by formatting /dev/boot directly, a bit stupid since you already dd the same block. The idea is that since android is not present on the device anymore, it doesn't matter if storeboot is never reached or broken.. (which it is at the moment). As long as we keep the bootcmd=run start_autoscript / start_autoscript / start_mmc_autoscript / start_usb_autoscript sequence in uboot env, right ? -- edit -- correct me if i'm wrong but it looks like the emmc is not a regular mmc device so fatload can't be used to read form it ?? -- edit 2 -- i don't see how i can access a fat partition on my device emmc (it's supposed to work on some devices), so i'm back trying to use bootm with your linux kernel. Edited March 16, 2017 by mdel Link to comment Share on other sites More sharing options...
mdel Posted March 16, 2017 Share Posted March 16, 2017 @balbes150 can you tell me how your /boot/linux.img (bootm image) is build and what's in it ? here's the "help bootm" from my device : Spoiler gxb_p201_v1#help bootm bootm - boot application image from memory Usage: bootm [addr [arg ...]] - boot application image stored in memory passing arguments 'arg ...'; when booting a Linux kernel, 'arg' can be the address of an initrd image When booting a Linux kernel which requires a flat device-tree a third argument is required which is the address of the device-tree blob. To boot that kernel without an initrd image, use a '-' for the second argument. If you do not pass a third a bd_info struct will be passed instead For the new multi component uImage format (FIT) addresses must be extened to include component or configuration unit name: addr:<subimg_uname> - direct component image specification addr#<conf_uname> - configuration specification Use iminfo command to get the list of existing component images and configurations. Sub-commands to do part of the bootm sequence. The sub-commands must be issued in the order below (it's ok to not issue all sub-commands): start [addr [arg ...]] loados - load OS image ramdisk - relocate initrd, set env initrd_start/initrd_end fdt - relocate flat device tree cmdline - OS specific command line processing/setup bdt - OS specific bd_t processing prep - OS specific prep before relocation or go go - start OS seeing how different that uboot is from the general documentation, i imagine it could be necessary to tweak the bootm command for my specific device. Link to comment Share on other sites More sharing options...
balbes150 Posted March 16, 2017 Author Share Posted March 16, 2017 Wait not a lot, I found the cause, now working on a solution. Link to comment Share on other sites More sharing options...
balbes150 Posted March 16, 2017 Author Share Posted March 16, 2017 To repair installation errors in the internal memory, replace the first partition (/boot) file "linux.img" on it. https://yadi.sk/d/i8mKgFEi3BW24i Link to comment Share on other sites More sharing options...
mdel Posted March 16, 2017 Share Posted March 16, 2017 nice, works fine now. can you tell me what was wrong ? Link to comment Share on other sites More sharing options...
balbes150 Posted March 16, 2017 Author Share Posted March 16, 2017 (edited) I made a mistake in the build script (lost the third element dtb). Therefore, the kernel file (linux.img) had minimal data dtb and the kernel fell as erroneous. Updated the images on the website (test 20170316). This hotfix installation functions to the internal memory eMMC. Edited March 16, 2017 by balbes150 Link to comment Share on other sites More sharing options...
jozicka Posted March 16, 2017 Share Posted March 16, 2017 Hi, I have A95X box with s905x with last Armbian_5.26... image. It is used as replacement for NAS pi server. All is working nicely, only Samba speed is 11 MB/s (both upload and download). It is still much better then Pi speed (2,5 MB upload), However I expected more... (just more and more, that is what they want..)First I thought it is because of ntfs format of drivers, so I moved files of one drive out, formated to ext4, and moved files back. However the speed did not get any better. And also I have noticed the transfer speed from one USB NTFS drive to second NTFS drive is 22 MB/s (with cpu ussage 42%), so it looks the CPU is not the bottleneck. Please do you have any tips, what can be set, to get the network speed UP? 1 Link to comment Share on other sites More sharing options...
mdel Posted March 16, 2017 Share Posted March 16, 2017 11 hours ago, balbes150 said: Updated the images on the website (test 20170316). This hotfix installation functions to the internal memory eMMC. thx i'll test it again and please don't forget about adding my a95x dts Link to comment Share on other sites More sharing options...
mdel Posted March 16, 2017 Share Posted March 16, 2017 (edited) 34 minutes ago, jozicka said: Please do you have any tips, what can be set, to get the network speed UP? 11 MB/s looks a lot like a max 100Mbps LAN speed. check your box specs but if it doesn't have Gigabit ethernet (Gbe, sometime called 1000M) you won't get faster network speeds. I don't remember if the s905x has better Gbe capabilities (MAC or PHY) than s905 but if it's not the case then those boxes will more likely have 10/100 and not Gbe LAN which will be available on some boxe and probably more on high end ones.. then you have too choices, get a Gbe box or board, or use an usb3.0 Gbe ethernet adapter (around 10e), but you won't get Gbe speeds with those adapters, usually 200-300Mbps and USB2.0 is limited to 480Mpbs (theorical) anyways. Edited March 16, 2017 by mdel Link to comment Share on other sites More sharing options...
