Hi! Does anybody have armbian 5.34 build img for xiaomi mi box? I needed it to dump my firmware and unbrick another box. https://forum.xda-developers.com/android-stick--console-computers/amlogic/xiaomi-mi-box-s-uart-boot-log-uboot-env-t3884685/amp/
I've uploaded it to megashares: https://mega.nz/#!N3AUWYQa!_IFkdHuTdh7Ynp9sLzaVyVj3BwDKJJRD7YFOlSEF6H0
Size on disk is 813558412 bytes and has an md5sum of 9d8a0b0868f51a6fcf33ca2bcbad6097.
I'm loaded armbian on mi box, but where is no emmc flash device in hw, how can I  make a copy img of emmc.
GXL:BL1:9ac50e:bb16dc;FEAT:BDFD71BC:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;0.0;CHK:0;
TE: 86831
BL2 Built : 18:52:48, Feb 20 2019. gxl gbd7fccf - jiangong.you@droid06-bj
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 5
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 912MHz
bist_test rank: 0 18 00 30 2a 13 42 17 00 2f 32 1a 4a 18 00 30 2b 13 43 17 00 2e        31 19 49 693  rank: 1 15 00 2a 2b 13 43 15 00 2a 32 1a 4a 15 01 29 2a 13 42 15        00 2a 31 19 49 693   - PASS
Rank0: 1024MB(auto)-2T-13
Rank1: 1024MB(auto)-2T-13
AddrBus test pass!
-s
emmc switch 3 ok
Authentication key not yet programmed
emmc_rpmb_key_is_programmed: error 0x00000007
emmc switch 0 ok
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
aml log : R1024 check pass!
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x01700000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x01700000, size: 0x0002c600
Load bl32 from eMMC, src: 0x00050200, des: 0x01700000, size: 0x00033e00
Load bl33 from eMMC, src: 0x00084200, des: 0x01700000, size: 0x00054e00
NOTICE:  BL3-1: v1.0(release):b60a036
NOTICE:  BL3-1: Built : 17:03:54, Apr 10 2018
[BL31]: GXL CPU setup!
NOTICE:  BL3-1: GXL secure boot!
NOTICE:  BL3-1: BL33 decompress pass
mpu_config_enable:ok
[Image: gxl_v1.1.3255-1a77b01 2017-09-15 16:58:02 xiaobo.gu@droid12]
OPS=0x84
fb 2 4d 33 37 c5 9e 40 a4 5e b2 4c [1.404346 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-2: ATOS-V2.4-69-gc1e2fb5 #1 Wed Jan 31 06:57:06 UTC 2018 arm
INFO:    BL3-2: Chip: GXL Rev: D (21:D - 80:2)
INFO:    BL3-2: crypto engine DMA
INFO:    BL3-2: secure time TEE
INFO:    BL3-2: CONFIG_DEVICE_SECURE 0xb200000e
U-Boot 2015.01-g9a75fc5-dirty (Jul 11 2019 - 19:46:21), Build: jenkins-oneday-69        9
DRAM:  2 GiB
Relocation Offset is: 76ed3000
gpio: pin gpiodv_24 (gpio 43) value is 1
gpio: pin gpioh_3 (gpio 52) value is 1
register usb cfg[0][1] = 0000000077f5db98
[CANVAS]canvas init
MMC:   aml_priv->desc_buf = 0x0000000073ed3b40
aml_priv->desc_buf = 0x0000000073ed5e60
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x3ff2800
emmc/sd response timeout, cmd55, status=0x3ff2800
init_part() 293: PART_TYPE_AML
[mmc_init] mmc init success
      Amlogic multi-dtb tool
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 2 dtbs.
        aml_dt soc: gxl platform: oneday variant: dcdc
        dtb 0 soc: gxl   plat: oneday   vari: dcdc
        dtb 1 soc: gxl   plat: oneday   vari: pmic
      Find match dtb: 0
start dts,buffer=0000000073ed8690,dt_addr=0000000073ed8e90
get_partition_from_dts() 103: ret 0
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
parts: 14
00:      logo   0000000000800000 1
01:  recovery   0000000001800000 1
02:      misc   0000000000800000 1
03:       dto   0000000000800000 1
04:  cri_data   0000000000800000 2
05:     param   0000000001000000 2
06:      boot   0000000001000000 1
07:       rsv   0000000001000000 1
08:       tee   0000000002000000 1
09:    vendor   0000000006400000 1
10:       oem   0000000012c00000 1
11:    system   0000000046000000 1
12:     cache   0000000010000000 2
13:      data   ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
check pattern success
mmc env offset: 0x17400000
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-2610: calc 30df8ef, store 30df8ef
dtb_read()-2827: total valid 2
update_old_dtb()-2808: do nothing
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpu: vpu_clk_gate_init_off finish
vpp: vpp_init
hpd_state=0
cvbs performance type = 6, table = 0
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
[KM]Error:f[keymanage_dts_get_key_device]L85:carrier key name is not exist
[KM]Error:f[_get_km_ops_by_name]L231:key carrier not know device 4
[KM]Error:f[key_manage_query_exist]L546:There isn't dts cfg for key[carrier]
[KM]Error:f[key_manage_query_size]L503:Fail in query key exist
Start read misc partition datas!
info->magic =
info->version_major = 1
info->version_minor = 0
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[0].successful_boot = 0
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->slots[1].successful_boot = 0
info->crc32 = -1075449479
active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=0
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x7f800000
[CANVAS]addr=0x7f800000 width=5760, height=2160
pull down bt_reset
pull up bt_reset
set hci reset
set scan parameters
set scan enable
pull down bt_enable
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... init_part() 278: PART_TYPE_DOS
1 Storage Device(s) found
reading s905_autoscript
1545 bytes read in 32 ms (46.9 KiB/s)
## Executing script at 01020000
reading uInitrd
4334456 bytes read in 276 ms (15 MiB/s)
reading zImage
17986048 bytes read in 1021 ms (16.8 MiB/s)
reading dtb.img
** Unable to read file dtb.img **
dtb_read_shortcut()-2668: short cut in...
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
[rsvmem] get fdtaddr NULL!
rsvmem - reserve memory
Usage:
rsvmem check                   - check reserved memory
rsvmem dump                    - dump reserved memory
rsvmem check failed
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    4334392 Bytes = 4.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
load dtb from 0x1000000 ......
      Single dtb detected
## Flattened Device Tree blob at 01000000
   Booting using the fdt blob at 0x1000000
   Loading Ramdisk to 73a9e000, end 73ec0338 ... OK
   Loading Device Tree to 000000001fff1000, end 000000001ffff091 ... OK
Starting kernel ...
uboot time: 7376968 us
domain-0 init dvfs: 4
efuse_pw_en: 0x7
WARNING! efuse bits is disabled
Enable A53 JTAG to AO
[    0.000000@0] Booting Linux on physical CPU 0x0
[    0.000000@0] Linux version 4.9.40-amlogics905x (root@user-VirtualBox) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #5 SMP PREEMPT Sun Nov 12 18:10:58 MSK 2017
[    0.000000@0] Boot CPU: AArch64 Processor [410fd034]
[    0.000000@0] efi: Getting EFI parameters from FDT:
[    0.000000@0] efi: UEFI not found.
[    0.000000@0] Reserved memory: created CMA memory pool at 0x0000000005000000, size 36 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,secmon, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created CMA memory pool at 0x000000007f800000, size 8 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,meson-fb, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created CMA memory pool at 0x000000007d800000, size 32 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,di_cma, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created CMA memory pool at 0x0000000075c00000, size 124 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,ion-dev, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created CMA memory pool at 0x0000000074c00000, size 16 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,vdin1_cma, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created DMA memory pool at 0x0000000074c00000, size 0 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,ppmgr, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: created CMA memory pool at 0x0000000060400000, size 308 MiB
[    0.000000@0] OF: reserved mem: initialized node linux,codec_mm_cma, compatible id shared-dma-pool
[    0.000000@0] Reserved memory: unable to setup CMA region
[    0.000000@0] OF: reserved mem: initialized node linux,codec_mm_reserved, compatible id amlogic, codec-mm-reserved
[    0.000000@0] cma: Reserved 16 MiB at 0x000000005f400000
[    0.000000@0] psci: probing for conduit method from DT.
[    0.000000@0] psci: PSCIv0.2 detected in firmware.
[    0.000000@0] psci: Using standard PSCI v0.2 function IDs
[    0.000000@0] psci: Trusted OS migration not required
[    0.000000@0] percpu: Embedded 23 pages/cpu @ffffffc074b55000 s53400 r8192 d32616 u94208
[    0.000000@0] Detected VIPT I-cache on CPU0
[    0.000000@0] CPU features: enabling workaround for ARM erratum 845719
[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 515844
[    0.000000@0] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.repair=yes net.ifnames=0 mac=
[    0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000@0] Memory: 1482360K/2096128K available (11708K kernel code, 1500K rwdata, 3284K rodata, 1024K init, 1360K bss, 60808K reserved, 552960K cma-reserved)
[    0.000000@0] Virtual kernel memory layout:
[    0.000000@0]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000@0]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000@0]       .text : 0xffffff8009080000 - 0xffffff8009bf0000   ( 11712 KB)
[    0.000000@0]     .rodata : 0xffffff8009bf0000 - 0xffffff8009f30000   (  3328 KB)
[    0.000000@0]       .init : 0xffffff8009f30000 - 0xffffff800a030000   (  1024 KB)
[    0.000000@0]       .data : 0xffffff800a030000 - 0xffffff800a1a7200   (  1501 KB)
[    0.000000@0]        .bss : 0xffffff800a1a7200 - 0xffffff800a2fb4dc   (  1361 KB)
[    0.000000@0]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000@0]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000@0]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000@0]               0xffffffbf00004000 - 0xffffffbf02000000   (    31 MB actual)
[    0.000000@0]     memory  : 0xffffffc000100000 - 0xffffffc080000000   (  2047 MB)
[    0.000000@0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000@0] Preemptible hierarchical RCU implementation.
[    0.000000@0]        Build-time adjustment of leaf fanout to 64.
[    0.000000@0]        RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000@0] NR_IRQS:64 nr_irqs:64 0
[    0.000000@0] amlogic_init_sdemmc: register amlogic sdemmc clk
[    0.000000@0] success set parent gpu_p1_composite rate to 400000000
[    0.000000@0] amlogic_init_gpu: register meson gpu clk
[    0.000000@0] amlogic_init_media: register meson media clk
[    0.000000@0] amlogic_init_misc: register meson misc clk
[    0.000000@0] gxl_clkc_init initialization complete
[    0.000000@0] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000@0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000046@0] meson_bc_timer: mclk->mux_reg =ffffff8008006990,mclk->reg =ffffff8008008994
[    0.000447@0] Console: colour dummy device 80x25
[    0.001565@0] console [tty0] enabled
[    0.001588@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001620@0] pid_max: default: 32768 minimum: 301
[    0.001719@0] Security Framework initialized
[    0.001738@0] SELinux:  Initializing.
[    0.001820@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.001840@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002441@0] ftrace: allocating 39536 entries in 155 pages
[    0.058320@0] sched-energy: CPU device node has no sched-energy-costs
[    0.058354@0] Invalid sched_group_energy for CPU0
[    0.058372@0] CPU0: update cpu_capacity 1024
[    0.058397@0] ASID allocator initialised with 65536 entries
[    0.090174@0] EFI services will not be available.
[    0.090299@0] Meson chip version = RevD (21:D - 84:0)
[    0.138361@1] Detected VIPT I-cache on CPU1
[    0.138408@1] Invalid sched_group_energy for CPU1
[    0.138412@1] CPU1: update cpu_capacity 1024
[    0.138414@1] CPU1: Booted secondary processor [410fd034]
[    0.170424@2] Detected VIPT I-cache on CPU2
[    0.170464@2] Invalid sched_group_energy for CPU2
[    0.170467@2] CPU2: update cpu_capacity 1024
[    0.170469@2] CPU2: Booted secondary processor [410fd034]
[    0.202505@3] Detected VIPT I-cache on CPU3
[    0.202542@3] Invalid sched_group_energy for CPU3
[    0.202544@3] CPU3: update cpu_capacity 1024
[    0.202547@3] CPU3: Booted secondary processor [410fd034]
[    0.202626@0] Brought up 4 CPUs
[    0.202805@0] SMP: Total of 4 processors activated.
[    0.202825@0] CPU features: detected feature: 32-bit EL0 Support
[    0.202883@0] CPU: All CPU(s) started at EL2
[    0.202921@0] alternatives: patching kernel code
[    0.203065@0] Invalid sched_group_energy for CPU3
[    0.203087@0] CPU3: update max cpu_capacity 1024
[    0.203105@0] Invalid sched_group_energy for CPU2
[    0.203123@0] Invalid sched_group_energy for CPU1
[    0.203141@0] Invalid sched_group_energy for CPU0
[    0.203985@0] devtmpfs: initialized
[    0.206480@1] CPU1: update max cpu_capacity 1024
[    0.216591@0] DMI not present or invalid.
[    0.216877@0] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.216925@0] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.229116@0] pinctrl core: initialized pinctrl subsystem
[    0.230279@0] NET: Registered protocol family 16
[    0.246576@0] cpuidle: using governor menu
[    0.246704@0] register canvas platform driver
[    0.246759@0] register rdma platform driver
[    0.246812@0] aml_vdac_init: module init
[    0.247483@0] vdso: 2 pages (1 code @ ffffff8009bf7000, 1 data @ ffffff800a035000)
[    0.247529@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.248621@0] DMA: preallocated 256 KiB pool for atomic allocations
[    0.248734@0] codec_mm_module_init
[    0.249222@0] pstore: using zlib compression
[    0.249754@0] console [pstore-1] enabled
[    0.249774@0] pstore: Registered ramoops as persistent store backend
[    0.249796@0] ramoops: attached 0x100000@0x7400000, ecc: 0/0
[    0.252165@0] aml_iomap: amlogic iomap probe done
[    0.255595@0] vpu: driver version: v02
[    0.255645@0] vpu: load vpu_clk: 666667000Hz(7)
[    0.255753@0] vpu: vpu_clktree_init
[    0.255828@0] vpu: vpu_probe OK
[    0.267926@0] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.268057@0] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_cma
[    0.268424@0] canvas_probe reg=00000000c8838000,size=400
[    0.268468@0] canvas maped reg_base =ffffff800819d000
[    0.276422@0] cvbs_out: cvbsout_probe
[    0.276458@0] cvbs_out: chrdev devno 265289728 for disp
[    0.276479@0] vout: vout_register_server
[    0.276497@0] cvbs_out: register cvbs module server ok
[    0.276727@0] cvbs_out: create cdev cvbs
[    0.276753@0] cvbs_out: cvbsout_probe OK
[    0.279311@0] rdma_probe
[    0.533320@1] SCSI subsystem initialized
[    0.533644@1] usbcore: registered new interface driver usbfs
[    0.533736@1] usbcore: registered new interface driver hub
[    0.533861@1] usbcore: registered new device driver usb
[    0.534015@1] Linux video capture interface: v2.00
[    0.534112@1] pps_core: LinuxPPS API ver. 1 registered
[    0.534136@1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.534187@1] PTP clock support registered
[    0.534416@1] dmi: Firmware registration failed.
[    0.534608@1] aml_i2c version: 20140813
[    0.535298@1] ion_dev ion_dev: assigned reserved memory node linux,ion-dev
[    0.536297@1] hdmitx: system: amhdmitx_init
[    0.536332@1] hdmitx: system: Ver: 20170622
[    0.536369@1] hdmitx: system: amhdmitx_probe
[    0.536757@1] vout: vout_register_server
[    0.536787@1] hdmitx: hdmi_init_chip_type: 0
[    0.537010@1] hdmitx: system: not find match pwr-ctl
[    0.537058@1] hdmitx hpd irq = 161
[    0.537794@1] hdmitx20: Mapped PHY: 0xc1100000
[    0.537836@1] hdmitx20: Mapped PHY: 0xc8834400
[    0.537860@1] hdmitx20: Mapped PHY: 0xd0100000
[    0.537896@1] hdmitx20: Mapped PHY: 0xc8100000
[    0.537918@1] hdmitx20: Mapped PHY: 0xc883c000
[    0.537940@1] hdmitx20: Mapped PHY: 0xc1104400
[    0.537961@1] hdmitx20: Mapped PHY: 0xc883a000
[    0.537982@1] hdmitx20: Mapped PHY: 0xda83a000
[    0.538004@1] hdmitx20: Mapped PHY: 0xd0044000
[    0.538262@1] avmute set to 1
[    0.538284@1] hdmitx: attr default
[    0.538752@1] hdmitx_set_current_vmode[2333]
[    0.538789@1] hdmitx: video: get current mode: 2160p60hz
[    0.538810@1] hdmitx: update rx hdr info 0
[    0.538830@1] hdmitx: update physcial size: 16 9
[    0.538862@1] config: hdmitx: unknown cmd: 0x14000000
[    0.538901@1] hdmitx: system: already init VIC = 0  Now VIC = 0
[    0.538950@1] 2160p60hz 60 1
[    0.538969@1] 2160p60hz 60 1
[    0.538987@1] hdmtix: set audio
[    0.539009@1] hdmitx tx_aud_src = 0
[    0.539046@1] hdmitx: fs = 0, cd = 4, tmds_clk = 594000
[    0.539067@1] hdmitx aud_n_para = 6144
[    0.539097@1] hdmitx set channel status
[    0.539169@1] vout: init mode
[    0.539242@1] vout: create vout attribute OK
[    0.539263@1] vout: aml_tvout_mode_monitor
[    0.539288@1] vout: aml_vout_probe OK
[    0.539497@1] fb: osd_init_module
[    0.539759@1] fb: viu vsync irq: 152
[    0.540099@1] osd_rdma: osd_rdma_init: rdma_table p=0x5f441000,op=0x5f441000 , v=0xffffff80081d7000
[    0.540154@1] rdma_register, rdma_table_addr ffffff80081d9000 rdma_table_addr_phy 5f442000 reg_buf ffffffc05d406000
[    0.540187@1] rdma_register success, handle 1 table_size 4096
[    0.540208@1] osd_rdma: osd_rdma_init:osd reset rdma handle = 1.
[    0.540246@1] rdma_register, rdma_table_addr ffffff80081db000 rdma_table_addr_phy 5f443000 reg_buf ffffffc05d405000
[    0.540278@1] rdma_register success, handle 2 table_size 4096
[    0.540298@1] osd_rdma: osd_rdma_init:osd rdma handle = 2.
[    0.540376@1] meson-fb meson-fb: assigned reserved memory node linux,meson-fb
[    0.540400@1] fb: reserved memory base:7f800000, size:800000
[    0.540527@1] fb: init fbdev bpp is:32
[    0.541287@1] fb: set osd0 reverse as NONE
[    0.599482@1] fb: osd probe OK
[    0.599710@1] Advanced Linux Sound Architecture Driver Initialized.
[    0.600425@1] Bluetooth: Core ver 2.22
[    0.600510@1] NET: Registered protocol family 31
[    0.600532@1] Bluetooth: HCI device and connection manager initialized
[    0.600563@1] Bluetooth: HCI socket layer initialized
[    0.600590@1] Bluetooth: L2CAP socket layer initialized
[    0.600646@1] Bluetooth: SCO socket layer initialized
[    0.601146@1] NetLabel: Initializing
[    0.601177@1] NetLabel:  domain hash size = 128
[    0.601196@1] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.601271@1] NetLabel:  unlabeled traffic allowed by default
[    0.602252@1] clocksource: Switched to clocksource arch_sys_counter
[    0.687550@1] VFS: Disk quotas dquot_6.6.0
[    0.687645@1] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.687873@1] fb: osd_open, cma:ffffff800a2689a0
[    0.687877@1] fb: use ion buffer for fb memory
[    0.695658@1] meson-fb meson-fb: create ion_client ffffffc0003cd800, handle=ffffffc05cc24e00
[    0.695666@1] meson-fb meson-fb: ion memory(0): created fb at 0x0000000075c00000, size 24 MiB
[    0.695672@1] fb: Frame buffer memory assigned at
[    0.695673@1] fb:  0, phy: 0x0000000075c00000, vir:0xffffff800ba01000, size=24576K
[    0.695673@1]
[    0.695677@1] fb: ---------------clear fb0 memory ffffff800ba01000
[    0.705796@1] fb: osd[0] canvas.idx =0x40
[    0.705799@1] fb: osd[0] canvas.addr=0x75c00000
[    0.705802@1] fb: osd[0] canvas.width=7680
[    0.705804@1] fb: osd[0] canvas.height=3240
[    0.705806@1] fb: osd[0] frame.width=1920
[    0.705809@1] fb: osd[0] frame.height=1080
[    0.814277@1] Console: switching to colour frame buffer device 240x67
[    0.849849@3] jtag: module init
[    0.850152@3] jtag: select is configured apao
[    0.850384@3] jtag: request gpio 33  for apao
[    0.850495@3] jtag: request gpio 34  for apao
[    0.850597@3] jtag: request gpio 35  for apao
[    0.850699@3] jtag: request gpio 36  for apao
[    0.850789@3] jtag: set state 2
[    0.857653@0] jtag: module probed ok
[    0.858091@0] NET: Registered protocol family 2
[    0.858808@0] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.859076@0] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.859429@0] TCP: Hash tables configured (established 16384 bind 16384)
[    0.859633@0] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.859800@0] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.860146@0] NET: Registered protocol family 1
[    0.860629@0] RPC: Registered named UNIX socket transport module.
[    0.860761@0] RPC: Registered udp transport module.
[    0.860858@0] RPC: Registered tcp transport module.
[    0.860954@0] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.862217@0] wifi: power_on_pin_OD = 0;
[    0.862361@0] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[    0.862563@0] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[    0.862707@0] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[    0.862842@0] aml_wifi wifi: [wifi_dev_probe] dhd_static_buf setup
[    0.863022@0] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allocated
[    0.863175@0] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=97
[    0.863294@0] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[    0.863434@0] aml_wifi wifi: [wifi_dev_probe] power_on_pin=96
[    0.868529@0] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[    0.873669@0] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[    0.878563@0] aml_wifi wifi: [wifi_setup_dt] irq num is:(132)
[    0.883325@0] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(97)
[    0.888049@0] aml_wifi wifi: [wifi_setup_dt] power_on_pin(96)
[    0.893163@0] Unpacking initramfs...
[    1.078016@2] Freeing initrd memory: 4232K (ffffffc073a9e000 - ffffffc073ec0000)
[    1.083679@2] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.090146@2] audit: initializing netlink subsys (disabled)
[    1.095097@2] audit: type=2000 audit(1.060:1): initialized
[    1.100780@2] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.116879@2] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.123540@2] NFS: Registering the id_resolver key type
[    1.128459@2] Key type id_resolver registered
[    1.133276@2] Key type id_legacy registered
[    1.138107@2] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.143715@2] fuse init (API version 7.26)
[    1.152701@2] NET: Registered protocol family 38
[    1.157938@2] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.163012@2] io scheduler noop registered
[    1.168016@2] io scheduler deadline registered
[    1.173187@2] io scheduler cfq registered (default)
[    1.239699@1] [drm] Initialized
[    1.244800@1] Unable to detect cache hierarchy from DT for CPU 0
[    1.256715@1] loop: module loaded
[    1.262561@1] zram: Added device: zram0
[    1.267852@1] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.273478@1] libphy: Fixed MDIO Bus: probed
[    1.278678@1] tun: Universal TUN/TAP device driver, 1.6
[    1.283536@1] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.289416@1] PPP generic driver version 2.4.2
[    1.294508@1] PPP BSD Compression module registered
[    1.299323@1] PPP Deflate Compression module registered
[    1.304141@1] PPP MPPE Compression module registered
[    1.308955@1] NET: Registered protocol family 24
[    1.313942@1] usbcore: registered new interface driver asix
[    1.318992@1] usbcore: registered new interface driver ax88179_178a
[    1.324061@1] usbcore: registered new interface driver cdc_ether
[    1.329055@1] usbcore: registered new interface driver net1080
[    1.333978@1] usbcore: registered new interface driver cdc_subset
[    1.338894@1] usbcore: registered new interface driver zaurus
[    1.343800@1] usbcore: registered new interface driver cdc_ncm
[    1.349744@1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.354711@1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.360213@1] usbcore: registered new interface driver cdc_acm
[    1.365253@1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.370512@1] usbcore: registered new interface driver usb-storage
[    1.375839@1] usbcore: registered new interface driver usbserial
[    1.381450@1] mousedev: PS/2 mouse device common for all mice
[    1.386875@1] usbcore: registered new interface driver xpad
[    1.392150@1] i2c /dev entries driver
[    1.397305@1] usbcore: registered new interface driver uvcvideo
[    1.402349@1] USB Video Class driver (1.1.1)
[    1.407795@1] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.413114@1] Bluetooth: HCI UART driver ver 2.3
[    1.418271@1] Bluetooth: HCI UART protocol H4 registered
[    1.424417@1] cpu cpu0: bL_cpufreq_init: CPU 0 initialized
[    1.431367@0] arm_big_little: bL_cpufreq_register: Registered platform driver: scpi
[    1.437579@0] usbcore: registered new interface driver usbhid
[    1.442069@0] usbhid: USB HID core driver
[    1.446762@0] logger: created 512K log 'log_main'
[    1.451413@0] logger: created 1K log 'log_events'
[    1.456037@0] logger: created 1K log 'log_radio'
[    1.460590@0] logger: created 16K log 'log_system'
[    1.465052@0] c81004c0.serial: clock gate not found
[    1.469407@0] meson_uart c81004c0.serial: ==uart0 reg addr = ffffff80083164c0
[    1.473802@0] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 23, base_baud = 1500000) is a meson_uart
[    1.478289@0] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 0 to 115200
[    3.260991@0] console [ttyS0] enabled
[    3.266082@3] c11084c0.serial: clock gate not found
[    3.270808@3] meson_uart c11084c0.serial: ==uart1 reg addr = ffffff80083184c0
[    3.277068@3] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 24, base_baud = 10416666) is a meson_uart
[    3.287223@3] secmon secmon: assigned reserved memory node linux,secmon
[    3.293874@3] secmon: share in base: 0xffffffc0050fe000, share out base: 0xffffffc0050ff000
[    3.301402@3] secmon: phy_in_base: 0x50fe000, phy_out_base: 0x50ff000
[    3.308846@3] amlogic-new-usb2 d0078000.usb2phy: USB2 phy probe:phy_mem:0xd0078000, iomap phy_base:0xffffff800833b000
[    3.319173@3] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port
[    3.325547@3] amlogic-new-usb3 d0078080.usb3phy: USB3 phy probe:phy_mem:0xd0078080, iomap phy_base:0xffffff800833d080
[    3.336789@3] meson_reset c1104404.reset-controller: meson_reset_probe: register reset controller ok,ret: 0
[    3.346372@3] clkmsr: msr_clk_reg0=ffffff80083c675c,msr_clk_reg2=ffffff80083c8764
[    3.353597@3] clkmsr: clkmsr: driver init
[    3.359555@3] meson-remote: Driver init
[    3.364793@3] meson-remote: remote_probe
[    3.369738@3] meson-remote c8100580.rc: protocol = 0x2
[    3.374683@3] meson-remote c8100580.rc: platform_data irq =148
[    3.379943@3] meson-remote c8100580.rc: custom_number = 5
[    3.385273@3] meson-remote c8100580.rc: ptable->map_size = 50
[    3.390950@3] meson-remote c8100580.rc: ptable->custom_name = amlogic-remote-1
[    3.398102@3] meson-remote c8100580.rc: ptable->custom_code = 0xfb04
[    3.404401@3] meson-remote c8100580.rc: ptable->release_delay = 80
[    3.410555@3] meson-remote c8100580.rc: ptable->map_size = 53
[    3.416219@3] meson-remote c8100580.rc: ptable->custom_name = amlogic-remote-2
[    3.423372@3] meson-remote c8100580.rc: ptable->custom_code = 0xfe01
[    3.429667@3] meson-remote c8100580.rc: ptable->release_delay = 80
[    3.435822@3] meson-remote c8100580.rc: ptable->map_size = 17
[    3.441484@3] meson-remote c8100580.rc: ptable->custom_name = amlogic-remote-3
[    3.448642@3] meson-remote c8100580.rc: ptable->custom_code = 0xbd02
[    3.454938@3] meson-remote c8100580.rc: ptable->release_delay = 80
[    3.461075@3] meson-remote c8100580.rc: ptable->map_size = 12
[    3.466754@3] meson-remote c8100580.rc: ptable->custom_name = xiaomi-ir-0
[    3.473482@3] meson-remote c8100580.rc: ptable->custom_code = 0x86
[    3.479606@3] meson-remote c8100580.rc: ptable->release_delay = 80
[    3.485740@3] meson-remote c8100580.rc: ptable->map_size = 1
[    3.491335@3] meson-remote c8100580.rc: ptable->custom_name = xiaomi-ir-1
[    3.498063@3] meson-remote c8100580.rc: ptable->custom_code = 0x3c
[    3.504187@3] meson-remote c8100580.rc: ptable->release_delay = 80
[    3.510314@3] meson-remote c8100580.rc: default protocol = 0x2 and id = 0
[    3.517038@3] meson-remote c8100580.rc: reg=0x0, val=0x46001e
[    3.522730@3] meson-remote c8100580.rc: reg=0x4, val=0x32000f
[    3.528429@3] meson-remote c8100580.rc: reg=0x8, val=0x1e001a
[    3.534115@3] meson-remote c8100580.rc: reg=0xc, val=0x420028
[    3.539808@3] meson-remote c8100580.rc: reg=0x10, val=0x304e2013
[    3.545759@3] meson-remote c8100580.rc: reg=0x18, val=0x5010800
[    3.551624@3] meson-remote c8100580.rc: reg=0x1c, val=0x9300
[    3.557230@3] meson-remote c8100580.rc: reg=0x20, val=0xb90b
[    3.562836@3] meson-remote c8100580.rc: reg=0x24, val=0x610050
[    3.568615@3] meson-remote c8100580.rc: reg=0x28, val=0x780061
[    3.574394@3] meson-remote c8100580.rc: reg=0x38, val=0x1388
[    3.580673@2] input: aml_keypad as /devices/platform/c8100580.rc/input/input0
[    3.587567@2] meson-remote: IR XMP protocol handler initialized
[    3.593399@2] efusekeynum: 4
[    3.597407@2] efusekeyname:             mac  offset:     0   size:     6
[    3.602190@2] efusekeyname:          mac_bt  offset:     6   size:     6
[    3.608565@2] efusekeyname:        mac_wifi  offset:    12   size:     6
[    3.614952@2] efusekeyname:            usid  offset:    18   size:    16
[    3.621558@2] efuse efuse: probe OK!
[    3.626037@3] ge2d: ge2d_init_module
[    3.630082@3] ge2d: ge2d_dev major:241
[    3.634144@3] ge2d: clock source clk_ge2d_gate ffffffc05ba85d00
[    3.638333@3] ge2d: clock clk_ge2d source ffffffc05ba85180
[    3.643713@3] ge2d: clock source clk_vapb_0 ffffffc05ba85000
[    3.649318@3] ge2d: ge2d clock is 250 MHZ
[    3.653275@3] ge2d: ge2d: pdev=ffffffc05d5e6800, irq=164, rstc=0x          (null), clk=ffffffc05ba85d00
[    3.662640@3] ge2d: ge2d start monitor
[    3.666444@1] ge2d: ge2d workqueue monitor start
[    3.666830@3] [tsync_pcr_init]init success.
[    3.667068@3] amvideom vsync irq: 152
[    3.667715@3] hdmitx_hdcp_init
[    3.667784@3] DI: di_module_init ok.
[    3.667788@3] DI: di_module_init: major 239
[    3.668078@3] DI: di_probe
[    3.668280@3] deinterlace deinterlace: assigned reserved memory node linux,di_cma
[    3.668285@3] DI-di_probe: flag_cma: 1
[    3.668288@3] DI: CMA size 0x2000000.
[    3.668319@3] di_irq:167,timerc_irq:168
[    3.668422@3] rdma_register, rdma_table_addr ffffff80083e1000 rdma_table_addr_phy 5f444000 reg_buf ffffffc05bd70000
[    3.668425@3] rdma_register success, handle 4 table_size 8192
[    3.668427@3] DI: di_probe allocate rdma channel 4.
[    3.668431@3] DI: DI hw version 2.
[    3.668446@3] 0x000000d8:Y=d8,U=0,V=0
[    3.668448@3] 0x000000d9:Y=d9,U=0,V=0
[    3.668451@3] 0x000000da:Y=da,U=0,V=0
[    3.668453@3] 0x000000db:Y=db,U=0,V=0
[    3.668455@3] 0x000000dc:Y=dc,U=0,V=0
[    3.668457@3] 0x000000dd:Y=dd,U=0,V=0
[    3.668460@3] 0x000000de:Y=de,U=0,V=0
[    3.668462@3] 0x000000df:Y=df,U=0,V=0
[    3.668464@3] 0x000000e0:Y=e0,U=0,V=0
[    3.668466@3] 0x000000e1:Y=e1,U=0,V=0
[    3.668471@3] DI: pre canvas:
[    3.668471@3]        [216]   [216]
[    3.668473@3]        [217]   [217]
[    3.668475@3]        [218]   [218]
[    3.668476@3]        [219]   [219]
[    3.668478@3]        [220]   [220]
[    3.668480@3]        [221]   [221]
[    3.668482@3]        [222]   [222]
[    3.668483@3]        [223]   [223]
[    3.668485@3]        [224]   [224]
[    3.668487@3]        [225]   [225]
[    3.668488@3]
[    3.668496@3] 0x000000e2:Y=e2,U=0,V=0
[    3.668498@3] 0x000000e3:Y=e3,U=0,V=0
[    3.668500@3] 0x000000f0:Y=f0,U=0,V=0
[    3.668502@3] 0x000000f1:Y=f1,U=0,V=0
[    3.668505@3] 0x000000f2:Y=f2,U=0,V=0
[    3.668507@3] 0x000000f3:Y=f3,U=0,V=0
[    3.668509@3]        [226]   [226]
[    3.668511@3]        [227]   [227]
[    3.668512@3]        [240]   [240]
[    3.668514@3]        [241]   [241]
[    3.668516@3]        [242]   [242]
[    3.668518@3]        [243]   [243]
[    3.668521@3] DI: post canvas:
[    3.668523@3]         [226] [226]
[    3.668525@3]         [227] [227]
[    3.668527@3]         [240] [240]
[    3.668529@3]         [241] [241]
[    3.668531@3]         [242] [242]
[    3.668532@3]         [243] [243]
[    3.668532@3]
[    3.668707@3] DI: di_probe here.
[    3.668838@3] vdin_drv_init: major 238
[    3.669319@3]
[    3.669319@3]  vdin memory resource undefined!!
[    3.669324@3] vdin0 cma_mem_size = 16 MB
[    3.669330@3] vdin0 irq: 169 rdma irq: 2
[    3.669345@3] get fclk_div5 err
[    3.669349@3] vdin_drv_probe: vdin cannot get msr clk !!!
[    3.669430@3] vdin_drv_probe: driver initialized ok
[    3.669693@3] vdin vdin1: assigned reserved memory node linux,vdin1_cma
[    3.669695@3]
[    3.669695@3]  vdin memory resource done.
[    3.669700@3] vdin1 cma_mem_size = 16 MB
[    3.669704@3] vdin1 irq: 170 rdma irq: 4
[    3.669723@3] get fclk_div5 err
[    3.669726@3] vdin_drv_probe: vdin cannot get msr clk !!!
[    3.673835@3] vdin_drv_probe: driver initialized ok
[    3.673897@3] vdin_drv_init: vdin driver init done
[    3.673901@3] [viuin..]viuin_init_module viuin module init
[    3.674216@3] [viuin..]viuin_probe probe ok.
[    3.674528@3] amlvid:info: amlvideo_init called
[    3.674528@3] amlvid:info: amlvideo_create_instance called
[    3.674533@3] amlvid:info: v4l2_dev.name=:amlvideo-000
[    3.674784@3] amlvideo-000: V4L2 device registered as video10
[    3.675139@3] amlvideo2 probe called
[    3.675356@3] amlvideo2_create_node
[    3.675356@3] amlvideo2: V4L2 device registered as video11
[    3.675393@3] amlvideo2 probe called
[    3.675564@3] amlvideo2_create_node
[    3.675565@3] amlvideo2: V4L2 device registered as video12
[    3.675613@3] PPMGRDRV: warn: ppmgr module init func called
[    3.675851@3] PPMGRDRV: err: ppmgr_driver_probe called
[    3.675900@3] Reserved memory: failed to init DMA memory pool at 0x0000000074c00000, size 0 MiB
[    3.675908@3] PPMGRDRV: info: ppmgr_dev major:237
[    3.677063@3] ionvideo-000: V4L2 device registered as video13
[    3.677066@3] ionvid: info: Video Technology Magazine Ion Video
[    3.677069@3] ionvid: info: Capture Board ver 1.0 successfully loaded
[    3.677165@3] module init
[    3.677418@3]
[    3.677418@3]  VECM probe start
[    3.677711@3] aml_vecm_probe: ok
[    3.677998@3] amlogic mtd driver init
[    3.678746@0] aml_vrtc rtc: rtc core: registered aml_vrtc as rtc0
[    3.679952@0] input: cec_input as /devices/virtual/input/input1
[    3.680195@0] cectx c810023c.aocec: no hdmirx reg resource
[    3.680199@0] cectx c810023c.aocec: no hhi reg resource
[    3.680253@0] cectx c810023c.aocec: can't find hdmirx
[    3.681307@0] cec: wake up flag:0
[    3.682133@0] key unify config unifykey-num is 17
[    3.682225@0] key unify fact unifykey-num is 17
[    3.682229@0] CHRDEV "unifykeys" major number 233 goes below the dynamic allocation range
[    3.682232@0] aml_unifykeys_probe:1383=============unifykey_devno:e900000
[    3.682519@0] unifykey: device unifykeys created ok
[    3.682562@0] aml_unifykeys_init done!
[    3.682675@0] storage: storage in base: 0xffffffc005000000
[    3.682678@0] storage: storage out base: 0xffffffc005040000
[    3.682680@0] storage: storage block base: 0xffffffc005080000
[    3.682681@0] storage: probe done!
[    3.682903@0] audio_dsp: [dsp]register dsp to char divece(257)
[    3.683109@0] sysled: module init
[    3.683779@0] amlogic rfkill init
[    3.683905@0] enter bt_probe of_node
[    3.683929@0] not get gpio_en
[    3.683935@0] power on valid level is high
[    3.683935@0] bt: power_on_pin_OD = 0;
[    3.684744@0] usbcore: registered new interface driver snd-usb-audio
[    3.685862@0] aml_codec_T9015 c8832000.t9015: aml_T9015_audio_codec_probe
[    3.686911@0] clock source gate top_glue : ffffffc05bd1c580
[    3.686939@0] clock source gate aud_buf : ffffffc05c3cb400
[    3.686968@0] clock source gate i2s_out : ffffffc05ba85f80
[    3.686999@0] clock source gate amclk_measure : ffffffc05bd18600
[    3.687041@0] clock source gate aififo2 : ffffffc05bc88080
[    3.687080@0] clock source gate aud_mixer : ffffffc05bc88180
[    3.687124@0] clock source gate mixer_reg : ffffffc05bc88280
[    3.687171@0] clock source gate adc : ffffffc05bc88380
[    3.687223@0] clock source gate top_level : ffffffc05bc88480
[    3.687279@0] clock source gate aoclk : ffffffc05bc88580
[    3.687338@0] clock source gate aud_in : ffffffc05bc88680
[    3.687502@0] aml-i2s-dai I2S: I2S Mic is in platform!
[    3.687506@0] aml-i2s-dai I2S: i2s_pos_sync is 0
[    3.687964@0] aml_pcm_dai: pcm mode detection =1
[    3.688558@0] aml_spdif_dai: Can't set i958 clk parent: -22
[    3.688575@0] aml-spdif-dai: probe of SPDIF failed with error -22
[    3.688912@0] aml_snd_dmic d0042000.snd_dmic: Dmic probe!
[    3.689063@0] Can't set dmic pdm clk parent err: -22
[    3.689080@0] aml_snd_dmic: probe of d0042000.snd_dmic failed with error -22
[    3.690038@0] aml_snd_card: aml_card_dai_parse_of codec_node count:1
[    3.690203@0] aml_snd_card: aml_card_dai_parse_of codec_node count:1
[    3.690230@0] aml_meson_snd_card aml_sound_meson: ASoC: DAI link has no CODECs
[    3.690233@0] aml_meson_snd_card aml_sound_meson: ASoC: failed to init multicodec
[    3.690267@0] aml_meson_snd_card aml_sound_meson: ASoC: failed to init link (null)
[    3.690271@0] aml_meson_snd_card aml_sound_meson: register aml sound card error -22
[    3.690274@0] aml_meson_snd_card aml_sound_meson: Can't probe snd_soc_card
[    3.690300@0] aml_meson_snd_card: probe of aml_sound_meson failed with error -22
[    3.691631@0] GACT probability NOT on
[    3.691643@0] Mirror/redirect action on
[    3.691651@0] u32 classifier
[    3.691652@0]     Actions configured
[    3.691659@0] Netfilter messages via NETLINK v0.30.
[    3.691921@0] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.692190@0] ctnetlink v0.93: registering with nfnetlink.
[    3.692433@0] xt_time: kernel timezone is -0000
[    3.692444@0] IPVS: Registered protocols ()
[    3.692622@0] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[    3.692722@0] IPVS: Creating netns size=1408 id=0
[    3.699450@0] IPVS: ipvs loaded.
[    3.699456@0] IPVS: [rr] scheduler registered.
[    3.699529@0] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    3.703172@0] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.703296@0] arp_tables: arp_tables: (C) 2002 David S. Miller
[    3.710529@0] Initializing XFRM netlink socket
[    3.711011@0] NET: Registered protocol family 10
[    3.712094@0] mip6: Mobile IPv6
[    3.712118@0] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.726728@0] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.727915@0] NET: Registered protocol family 17
[    3.727940@0] NET: Registered protocol family 15
[    3.727991@0] Bridge firewalling registered
[    3.728082@0] Bluetooth: RFCOMM TTY layer initialized
[    3.728090@0] Bluetooth: RFCOMM socket layer initialized
[    3.728115@0] Bluetooth: RFCOMM ver 1.11
[    3.728125@0] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.728127@0] Bluetooth: BNEP filters: protocol multicast
[    3.728135@0] Bluetooth: BNEP socket layer initialized
[    3.728137@0] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.728143@0] Bluetooth: HIDP socket layer initialized
[    3.728214@0] l2tp_core: L2TP core driver, V2.0
[    3.728225@0] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    3.728227@0] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    3.728252@0] l2tp_netlink: L2TP netlink interface
[    3.728290@0] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    3.728311@0] l2tp_debugfs: L2TP debugfs support
[    3.728313@0] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    3.728497@0] NET: Registered protocol family 35
[    3.728665@0] 8021q: 802.1Q VLAN Support v1.8
[    3.728708@0] Key type dns_resolver registered
[    3.739580@0] dwc3 c9000000.dwc3: Configuration mismatch. dr_mode forced to host
[    4.440962@0] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.440980@0] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.441236@0] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x02010010
[    4.441284@0] xhci-hcd xhci-hcd.0.auto: irq 158, io mem 0xc9000000
[    4.442381@0] hub 1-0:1.0: USB hub found
[    4.442420@0] hub 1-0:1.0: 2 ports detected
[    4.442724@0] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.442734@0] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.442806@0] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.443527@0] hub 2-0:1.0: USB hub found
[    4.443559@0] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    4.444440@3] aml_vrtc rtc: setting system clock to 2017-01-01 00:00:11 UTC (1483228811)
[    4.444838@3] dwc_otg: usb0: type: 0 speed: 0,
[    4.444840@3] config: 0, dma: 0, id: 0,
[    4.444840@3] phy: d0078000, ctrl: 0
[    4.545072@3] dwc_otg: Core Release: 3.10a
[    4.545077@3] dwc_otg: Setting default values for core params
[    4.545088@3] dwc_otg: curmode: 0, host_only: 0
[    4.557378@3] dwc_otg: Using Buffer DMA mode
[    4.557382@3] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[    4.557386@3] dwc_otg: Working on port type = OTG
[    4.557389@3] dwc_otg: Current port type: SLAVE
[    4.557595@3] dwc_otg c9100000.dwc2_a: DWC OTG Controller
[    4.557627@3] dwc_otg c9100000.dwc2_a: new USB bus registered, assigned bus number 3
[    4.557667@3] dwc_otg c9100000.dwc2_a: irq 160, io mem 0x00000000
[    4.558607@3] hub 3-0:1.0: USB hub found
[    4.558639@3] hub 3-0:1.0: 1 port detected
[    4.558965@3] dwc_otg: Dedicated Tx FIFOs mode
[    4.559394@3] dwc_otg: using timer detect
[    4.559395@3] id change, ffffffc05d2ab800
[    4.560766@3] cpucore_cooling_register, max_cpu_core_num:4
[    4.560890@3] thermal: read num_of_pp failed
[    4.566408@3] gxbb_pm: enter meson_pm_probe!
[    4.566428@3] gxbb_pm: system suspend level: 1
[    4.566474@3] gxbb_pm: meson_pm_probe done
[    4.566857@3] ALSA device list:
[    4.566860@3]   No soundcards found.
[    4.730078@3] Freeing unused kernel memory: 1024K (ffffffc001f30000 - ffffffc002030000)
[    4.763297@1] vout: vmode set to 720p60hz
[    4.763297@1]
[    4.771341@1] fb: current vmode=720p60hz, cmd: 0x10000
[    4.776401@1] hdmitx_set_current_vmode[2333]
[    4.780627@1] hdmitx: video: get current mode: 720p60hz
[    4.785796@1] hdmitx: update rx hdr info 0
[    4.789858@1] hdmitx: update physcial size: 16 9
[    4.794442@1] config: hdmitx: unknown cmd: 0x14000000
[    4.799452@1] hdmitx: system: already init VIC = 0  Now VIC = 4
[    4.805292@1] hdmitx: rx edid only support RGB format
[    4.812299@1] hdmitx: ddc rd8b error 0x54 0x01
[    4.818358@1] hdmitx: ddc rd8b error 0x54 0x01
[    4.822371@1] hdmirx version is 1.4 or below
[    4.826384@1] hdmitx div40: 0
[    4.858262@1] hdmitx: system: set mode VIC 4 (cd0,cs0,pm1,vd0,1)
[    4.864667@1] hdmitx: ddc w1b error 0x54 0x20 0x00
[    4.866675@1] hdmitx: ddc w1b error 0x54 0x20 0x00
[    4.868681@1] hdmitx: ddc rd8b error 0x54 0x21
[    4.881019@1] hdmitx: system: set pll
[    4.884954@1] hdmitx: system: param->VIC:4
[    4.888860@1] hdmitx: set clk: VIC = 4  cd = 4  frac_rate = 0
[    4.894393@1] config HPLL = 2970000
[    4.898328@1] HPLL: 0x4000027b
[    4.902146@1] config HPLL done
[    4.905957@1] set_hpll_od3_clk_div[456] div = 6
[    4.909796@1] j = 2  vid_clk_div = 1
[    4.913575@1] hdmitx: set enc for VIC: 4
[    4.914264@0] usb 1-2: new high-speed USB device number 2 using xhci-hcd
[    4.922891@1] HDMITX-DWC addr=0x10004006 rd_data=0x40
[    4.927726@1] Error: HDMITX-DWC exp_data=0xff mask=0x9f
[    5.055787@0] usb-storage 1-2:1.0: USB Mass Storage device detected
[    5.060613@0] scsi host0: usb-storage 1-2:1.0
[    5.064582@0] hdmitx: system: irq 80000001
[    5.066268@1] Sink is DVI device
[    5.066326@1] 720p60hz 60 1
[    5.066331@1] 720p60hz 60 1
[    5.066334@1] hdmtix: set audio
[    5.066341@1] hdmitx tx_aud_src = 0
[    5.066361@1] hdmitx: fs = 0, cd = 4, tmds_clk = 74250
[    5.066364@1] hdmitx aud_n_para = 6144
[    5.066377@1] hdmitx set channel status
[    5.066432@1] vout: new mode 720p60hz
[    5.066432@1]  set ok
[    5.066436@1] fb: current vmode=720p60hz, cmd: 0x20000
[    5.068629@0] Start = 0x10000100   End = 0x100001ff
[    5.068730@0] [0x10000180]: 0x000000ff
[    5.068733@0] [0x10000181]: 0x000000ff
[    5.068735@0] [0x10000182]: 0x00000003
[    5.068738@0] [0x10000183]: 0x00000007
[    5.068741@0] [0x10000184]: 0x0000003f
[    5.068743@0] [0x10000185]: 0x00000002
[    5.068747@0] [0x10000187]: 0x000000ff
[    5.068749@0] [0x10000188]: 0x00000003
[    5.180102@1] fb: osd[0] enable: 1 (hdmi_init.sh)
[    5.200068@1] fb: osd[1] enable: 0 (hdmi_init.sh)
[    5.256979@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.259779@2] random: udevadm: uninitialized urandom read (16 bytes read)
[    5.259865@2] random: udevadm: uninitialized urandom read (16 bytes read)
[    5.275863@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.282780@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.311625@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.316684@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.323939@1] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    5.328735@2] random: udevadm: uninitialized urandom read (16 bytes read)
[    5.328872@2] random: udevadm: uninitialized urandom read (16 bytes read)
[    5.672177@1] mali-utgard d00c0000.mali: set min pp to default 1
[    5.676588@1] mali-utgard d00c0000.mali: set min clk default to 0
[    5.682476@0] mali-utgard d00c0000.mali: max clk set 5
[    5.686937@0] mali-utgard d00c0000.mali: turbo clk set to 6
[    5.700269@0] Mali: [    5.700344@1] Mali device driver loaded
[    6.146559@0] random: fast init done
[    6.178950@0] scsi 0:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
[    6.186345@2] sd 0:0:0:0: [sda] 30930944 512-byte logical blocks: (15.8 GB/14.7 GiB)
[    6.193230@2] sd 0:0:0:0: [sda] Write Protect is off
[    6.198064@1] sd 0:0:0:0: [sda] No Caching mode page found
[    6.203258@1] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    6.212005@2]  sda: sda1 sda2
[    6.216983@2] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.032681@1] EXT4-fs (sda2): mounted filesystem with writeback data mode. Opts: data=writeback
[    7.496230@3] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[    7.513466@3] systemd[1]: Detected architecture arm64.
[    7.541326@3] systemd[1]: Set hostname to <amlogic>.
[    7.604424@2] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 115200 to 115200
[    7.980873@3] systemd[1]: Started Trigger resolvconf update for networkd DNS.
[    7.992547@3] systemd[1]: Created slice System Slice.
[    8.002431@3] systemd[1]: Listening on Journal Audit Socket.
[    8.012308@3] systemd[1]: Listening on Journal Socket.
[    8.025040@3] systemd[1]: Starting Restore / save the current clock...
[    8.036206@3] systemd[1]: Listening on udev Control Socket.
[    8.052739@3] systemd[1]: Starting Load Kernel Modules...
[    8.230510@2] EXT4-fs (sda2): re-mounted. Opts: commit=600,errors=remount-ro
Ubuntu 16.04.3 LTS amlogic ttyS0
amlogic login:
Thats my fault : I didnt make dtb.img in the boot flashdrive (rename gxl_p212_1g to dtb.img)
Hi can anyone explain how this can load on a secure box (mi box S) but i cannot load android based images such as libreElec or lakka?  I'm guessing it's has something to do with the dtb signing but just wondering if someone can explain or if it's documented anywhere.  Thanks.
Hi, everybody, I have the TVbox Beelink GT1 Ultimate (with CPU Amlogic S-912 and with 32G di memory), I would like use it with Home assistant, Can I flash on the Tvbox the Armbian and if yes, wich version I must use and how I must procede for flash the  SO?
I read that the Armbian 5.37 based on 3.14.29 debian version is fine for my TVBOX but I can't find it, could someone upload it on megadrive?
Thanks and ciao
I haven't tested recently since I currently use this box as my home server (with armbian on sdcard+homeassistant+others). I use an image based on a recent kernel (4.19 or 4.20) and latest images from balbes should also work well. You'd better test the images from this topic:
You just have to find the relevant dtb file for the box. The khadas vim2 is often a good choice or the q201.
The only advantage of kernel 3.14 image is mali support, but with latest images panfrost can also work (not tested) and your use case seems to be a headless server.
Hello all I am new to this. I have numerous tv boxes around my house and I want to turn a couple into something useable besides a tv box.
First I have the MXQ pro 4k boxes.
I have downloaded armbian 20.02.02 I am using bionic current 5.5.0 rc6
I am using DTB file meson-gxbb-neobox-a95x.dtb. This file seems to be the only file that works with my box without loading errors. I am able to get the boxes to boot from the SD card but I am unable to install to the nand or emmc.
Has anyone else experienced this issue? is there a different file I should be using?
Any help is much appreciated.
I don't which SoC is MXQ pro 4k, but nand is not supported (no driver in kernel) and s905 does not support install to emmc, due to old uboot not supporting emmc structure when installing armbian.
Thanks for the quick reply!
I have the S905 on the MXQ pro it comes with 1g ram and 8g storage.
As far as not installing on s905 I was reading on this ondroid site where another guy has instructions for installing to emmc for the s905. I am not sure if my particular box does not have that feature or what.
I guess the main reason I want to install is I have to run a sd card adapter on my box and I don't want this big card sticking out of the side of the box all the time.
They also say to refer to this forum for help so this is why I am here.
Do we need to sign the aml_autoscript.zip file?
Whenever I try to install it in Android recovery it says signature verification failed and doesn't install anything. I tried multiple sd cards, multiple usb sticks and also tried with the update&backup app and booting directly into recovery with a tooth pick in the av port.
I self signed it and it didn't complain anymore but its also not booting from sd/usb. Too bad this board has no taxes to the uart pins. Such a waste to leave it on the very slow Android or throw it away. It could make a nice Linux box for sure.
I don't know how but holding down the av-button before turning the box on and with Armbian on sd card it started booting up Armbian! Now I can get rid of Android and see what this little badboy can do.
Hi guys I am trying to install an armbian image on my T95Q TV Box (Armbian_20.02.0-rc1.037_Aml-s9xxx_bionic_current_5.5.0-rc6_desktop_20200205.img.xz) but, after launched command
su -
(enter passwd root)
./install.sh
or
nand_sata_install
as said in first post of this topic, at the reboot the system not starting from emmc. (I get a black screen when I remove my sd card and trying to run from internal emmc)
I tried the procedure several times without results :(
Anyone had this issue? Thanks in advance!
21 hours ago, almotra said:
Could someone share non desktop armbian stretch for amlogic s905w?
I used version 4.78 but I deleted it!
Can you be a bit more specific, perhaps quoting full image file names, kernel level etc? I have a number of 'archive' images but mainly Ubuntu.
I would need a Debian amlogic no desktop.
Whatever the kernel version, the most recent version you get will be fine.
The only debian ones I have are:
Armbian_19.11.3_Aml-g12_buster_legacy_5.3.0_desktop_20191126_debian.img.xz
Armbian_5.44_S9xxx_Debian_stretch_3.14.29_xfce_20180601.img.xz
If its something from this year, try the single image TV box forum page.
