No wifi detected on the orange pi zero 2
Same issue as
Hardware is supported. (https://www.armbian.com/orange-pi-zero-2/)
Any help is appreciated, if i resolve the issue i will post the solution here.
ubuntu@orangepizero2:~$ sudo nmcli device wifi rescan
Error: No Wi-Fi device found.
ubuntu@orangepizero2:~$ armbianmonitor -U
     1
     2    ### Activated 1 lzo-rle zram swap devices with 492MB each.
     3    ### Activated Armbian ramlog partition with zstd compression
     4
     5    ### Activated lzo-rle compressed /tmp
     6
     7    ### Activated 1 lzo-rle zram swap devices with 492MB each.
     8    ### Activated Armbian ramlog partition with zstd compression
     9
    10    ### Activated 1 lzo-rle zram swap devices with 492MB each.
    11    ### Activated Armbian ramlog partition with zstd compression
    12
    13    Sat 22 Oct 2022 07:17:07 PM UTC | Orange Pi Zero2 | 22.08.6 | arm64 | aarch64 | 5.19.16-sunxi64
    14
    15    ### dmesg:
    16
    17    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    18    [    0.000000] Linux version 5.19.16-sunxi64 (root@6d820ce0d5d6) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #22.08.6 SMP Tue Oct 18 06:56:22 UTC 2022
    19    [    0.000000] Machine model: OrangePi Zero2
    20    [    0.000000] NUMA: No NUMA configuration found
    21    [    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
    22    [    0.000000] NUMA: NODE_DATA [mem 0x7fdde040-0x7fddffff]
    23    [    0.000000] Zone ranges:
    24    [    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
    25    [    0.000000]   DMA32    empty
    26    [    0.000000]   Normal   empty
    27    [    0.000000] Movable zone start for each node
    28    [    0.000000] Early memory node ranges
    29    [    0.000000]   node   0: [mem 0x0000000040000000-0x000000004007ffff]
    30    [    0.000000]   node   0: [mem 0x0000000040080000-0x000000007fffffff]
    31    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
    32    [    0.000000] cma: Reserved 128 MiB at 0x0000000076c00000
    33    [    0.000000] psci: probing for conduit method from DT.
    34    [    0.000000] psci: PSCIv1.1 detected in firmware.
    35    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    36    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    37    [    0.000000] psci: SMC Calling Convention v1.2
    38    [    0.000000] percpu: Embedded 19 pages/cpu s37608 r8192 d32024 u77824
    39    [    0.000000] pcpu-alloc: s37608 r8192 d32024 u77824 alloc=19*4096
    40    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    41    [    0.000000] Detected VIPT I-cache on CPU0
    42    [    0.000000] CPU features: detected: ARM erratum 845719
    43    [    0.000000] Fallback order for Node 0: 0
    44    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
    45    [    0.000000] Policy zone: DMA
    46    [    0.000000] Kernel command line: root=UUID=0ae80c94-60cd-4b15-b7f3-065f13ca80b6 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=da74ae41-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
    47    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=da74ae41-01 cgroup_enable=memory", will be passed to user space.
    48    [    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
    49    [    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
    50    [    0.000000] printk: log_buf_len min size: 16384 bytes
    51    [    0.000000] printk: log_buf_len: 32768 bytes
    52    [    0.000000] printk: early log buf free: 14048(85%)
    53    [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    54    [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    55    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    56    [    0.000000] Memory: 862824K/1048576K available (13888K kernel code, 1038K rwdata, 4112K rodata, 2496K init, 387K bss, 54680K reserved, 131072K cma-reserved)
    57    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    58    [    0.000000] rcu: Hierarchical RCU implementation.
    59    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    60    [    0.000000]     Tracing variant of Tasks RCU enabled.
    61    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    62    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    63    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    64    [    0.000000] Root IRQ handler: gic_handle_irq
    65    [    0.000000] GIC: Using split EOI/Deactivate mode
    66    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    67    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    68    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    69    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    70    [    0.000389] Console: colour dummy device 80x25
    71    [    0.000474] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    72    [    0.000487] pid_max: default: 32768 minimum: 301
    73    [    0.000559] LSM: Security Framework initializing
    74    [    0.000589] Yama: becoming mindful.
    75    [    0.000682] AppArmor: AppArmor initialized
    76    [    0.000781] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    77    [    0.000794] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    78    [    0.002411] cblist_init_generic: Setting adjustable number of callback queues.
    79    [    0.002430] cblist_init_generic: Setting shift to 2 and lim to 1.
    80    [    0.002596] rcu: Hierarchical SRCU implementation.
    81    [    0.002601] rcu:     Max phase no-delay instances is 1000.
    82    [    0.003865] smp: Bringing up secondary CPUs ...
    83    [    0.004465] Detected VIPT I-cache on CPU1
    84    [    0.004544] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    85    [    0.005165] Detected VIPT I-cache on CPU2
    86    [    0.005232] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    87    [    0.005819] Detected VIPT I-cache on CPU3
    88    [    0.005884] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    89    [    0.005980] smp: Brought up 1 node, 4 CPUs
    90    [    0.005989] SMP: Total of 4 processors activated.
    91    [    0.005994] CPU features: detected: 32-bit EL0 Support
    92    [    0.005999] CPU features: detected: CRC32 instructions
    93    [    0.006331] CPU: All CPU(s) started at EL2
    94    [    0.006349] alternatives: patching kernel code
    95    [    0.007762] devtmpfs: initialized
    96    [    0.012256] Registered cp15_barrier emulation handler
    97    [    0.012276] Registered setend emulation handler
    98    [    0.012464] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    99    [    0.012483] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   100    [    0.016804] pinctrl core: initialized pinctrl subsystem
   101    [    0.018088] NET: Registered PF_NETLINK/PF_ROUTE protocol family
   102    [    0.019476] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
   103    [    0.019774] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   104    [    0.019901] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   105    [    0.019970] audit: initializing netlink subsys (disabled)
   106    [    0.020216] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
   107    [    0.020729] thermal_sys: Registered thermal governor 'fair_share'
   108    [    0.020738] thermal_sys: Registered thermal governor 'bang_bang'
   109    [    0.020742] thermal_sys: Registered thermal governor 'step_wise'
   110    [    0.020745] thermal_sys: Registered thermal governor 'user_space'
   111    [    0.021227] cpuidle: using governor menu
   112    [    0.021451] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   113    [    0.021564] ASID allocator initialised with 65536 entries
   114    [    0.021572] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
   115    [    0.021578] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
   116    [    0.021583] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
   117    [    0.021588] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
   118    [    0.021781] Serial: AMBA PL011 UART driver
   119    [    0.035060] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   120    [    0.035076] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   121    [    0.035082] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   122    [    0.035088] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   123    [    0.035752] cryptd: max_cpu_qlen set to 1000
   124    [    0.104293] raid6: neonx8   gen()  1808 MB/s
   125    [    0.172368] raid6: neonx4   gen()  1851 MB/s
   126    [    0.240454] raid6: neonx2   gen()  1754 MB/s
   127    [    0.308518] raid6: neonx1   gen()  1519 MB/s
   128    [    0.376593] raid6: int64x8  gen()  1252 MB/s
   129    [    0.444673] raid6: int64x4  gen()  1398 MB/s
   130    [    0.512738] raid6: int64x2  gen()  1185 MB/s
   131    [    0.580818] raid6: int64x1  gen()   883 MB/s
   132    [    0.580823] raid6: using algorithm neonx4 gen() 1851 MB/s
   133    [    0.648882] raid6: .... xor() 1334 MB/s, rmw enabled
   134    [    0.648887] raid6: using neon recovery algorithm
   135    [    0.649809] iommu: Default domain type: Translated
   136    [    0.649822] iommu: DMA domain TLB invalidation policy: strict mode
   137    [    0.650106] SCSI subsystem initialized
   138    [    0.650318] usbcore: registered new interface driver usbfs
   139    [    0.650356] usbcore: registered new interface driver hub
   140    [    0.650391] usbcore: registered new device driver usb
   141    [    0.650677] pps_core: LinuxPPS API ver. 1 registered
   142    [    0.650682] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   143    [    0.650695] PTP clock support registered
   144    [    0.651110] ARM FF-A: FFA_VERSION returned not supported
   145    [    0.651494] Advanced Linux Sound Architecture Driver Initialized.
   146    [    0.652150] NetLabel: Initializing
   147    [    0.652155] NetLabel:  domain hash size = 128
   148    [    0.652160] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   149    [    0.652222] NetLabel:  unlabeled traffic allowed by default
   150    [    0.652226] mctp: management component transport protocol core
   151    [    0.652230] NET: Registered PF_MCTP protocol family
   152    [    0.652790] clocksource: Switched to clocksource arch_sys_counter
   153    [    0.653129] VFS: Disk quotas dquot_6.6.0
   154    [    0.653177] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   155    [    0.653724] AppArmor: AppArmor Filesystem Enabled
   156    [    0.660572] NET: Registered PF_INET protocol family
   157    [    0.660799] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
   158    [    0.662031] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
   159    [    0.662060] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
   160    [    0.662072] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
   161    [    0.662141] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
   162    [    0.662263] TCP: Hash tables configured (established 8192 bind 8192)
   163    [    0.662379] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
   164    [    0.662413] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
   165    [    0.662609] NET: Registered PF_UNIX/PF_LOCAL protocol family
   166    [    0.663166] Trying to unpack rootfs image as initramfs...
   167    [    0.669907] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   168    [    0.671431] Initialise system trusted keyrings
   169    [    0.671526] Key type blacklist registered
   170    [    0.671814] workingset: timestamp_bits=44 max_order=18 bucket_order=0
   171    [    0.677497] zbud: loaded
   172    [    0.679166] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   173    [    0.681807] integrity: Platform Keyring initialized
   174    [    0.725142] xor: automatically using best checksumming function   32regs
   175    [    0.725161] async_tx: api initialized (async)
   176    [    0.725170] Key type asymmetric registered
   177    [    0.725175] Asymmetric key parser 'x509' registered
   178    [    1.259655] Freeing initrd memory: 11500K
   179    [    1.278369] alg: self-tests for CTR-KDF (hmac(sha256)) passed
   180    [    1.278486] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
   181    [    1.278625] io scheduler mq-deadline registered
   182    [    1.278632] io scheduler kyber registered
   183    [    1.278776] io scheduler bfq registered
   184    [    1.284943] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
   185    [    1.288589] cacheinfo: Unable to detect cache hierarchy for CPU 0
   186    [    1.293332] loop: module loaded
   187    [    1.295068] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   188    [    1.295092] ehci-platform: EHCI generic platform driver
   189    [    1.295189] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   190    [    1.295201] ohci-platform: OHCI generic platform driver
   191    [    1.295472] usbcore: registered new interface driver usb-storage
   192    [    1.295915] mousedev: PS/2 mouse device common for all mice
   193    [    1.297025] sun6i-rtc 7000000.rtc: registered as rtc0
   194    [    1.297070] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T00:00:04 UTC (86404)
   195    [    1.297188] sun6i-rtc 7000000.rtc: RTC enabled
   196    [    1.297299] i2c_dev: i2c /dev entries driver
   197    [    1.298050] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   198    [    1.299463] sdhci: Secure Digital Host Controller Interface driver
   199    [    1.299477] sdhci: Copyright(c) Pierre Ossman
   200    [    1.299500] Synopsys Designware Multimedia Card Interface Driver
   201    [    1.299908] sdhci-pltfm: SDHCI platform and OF driver helper
   202    [    1.300380] ledtrig-cpu: registered to indicate activity on CPUs
   203    [    1.300648] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000
   204    [    1.300974] hid: raw HID events driver (C) Jiri Kosina
   205    [    1.301092] usbcore: registered new interface driver usbhid
   206    [    1.301097] usbhid: USB HID core driver
   207    [    1.310566] NET: Registered PF_INET6 protocol family
   208    [    1.329283] Segment Routing with IPv6
   209    [    1.329362] In-situ OAM (IOAM) with IPv6
   210    [    1.329449] NET: Registered PF_PACKET protocol family
   211    [    1.329632] 8021q: 802.1Q VLAN Support v1.8
   212    [    1.329786] 9pnet: Installing 9P2000 support
   213    [    1.329869] Key type dns_resolver registered
   214    [    1.330413] registered taskstats version 1
   215    [    1.330438] Loading compiled-in X.509 certificates
   216    [    1.334214] Loaded X.509 cert 'Build time autogenerated kernel key: 05920f111eead6a51cb60d55d842ed91645758e7'
   217    [    1.336646] zswap: loaded using pool zstd/z3fold
   218    [    1.337295] Key type ._fscrypt registered
   219    [    1.337308] Key type .fscrypt registered
   220    [    1.337311] Key type fscrypt-provisioning registered
   221    [    1.338437] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
   222    [    1.338796] Key type encrypted registered
   223    [    1.338815] AppArmor: AppArmor sha1 policy hashing enabled
   224    [    1.338852] ima: No TPM chip found, activating TPM-bypass!
   225    [    1.338877] ima: Allocated hash algorithm: sha1
   226    [    1.338910] ima: No architecture policies found
   227    [    1.338958] evm: Initialising EVM extended attributes:
   228    [    1.338961] evm: security.selinux
   229    [    1.338965] evm: security.SMACK64
   230    [    1.338968] evm: security.SMACK64EXEC
   231    [    1.338972] evm: security.SMACK64TRANSMUTE
   232    [    1.338975] evm: security.SMACK64MMAP
   233    [    1.338978] evm: security.apparmor
   234    [    1.338981] evm: security.ima
   235    [    1.338984] evm: security.capability
   236    [    1.338987] evm: HMAC attrs: 0x1
   237    [    1.361280] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
   238    [    1.362805] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
   239    [    1.363482] printk: console [ttyS0] disabled
   240    [    1.363581] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 283, base_baud = 1500000) is a 16550A
   241    [    1.363788] printk: console [ttyS0] enabled
   242    [    1.364741] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
   243    [    1.365178] sun6i-spi 5010000.spi: Failed to request TX DMA channel
   244    [    1.365194] sun6i-spi 5010000.spi: Failed to request RX DMA channel
   245    [    1.365793] spi-nor spi0.0: supply vdd not found, using dummy regulator
   246    [    1.380999] spi-nor spi0.0: mx25l1606e (2048 Kbytes)
   247    [    1.396823] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
   248    [    1.398055] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
   249    [    1.398098] ehci-platform 5200000.usb: EHCI Host Controller
   250    [    1.398124] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 1
   251    [    1.398236] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
   252    [    1.398261] ehci-platform 5200000.usb: irq 286, io mem 0x05200000
   253    [    1.400181] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
   254    [    1.400483] ohci-platform 5200400.usb: Generic Platform OHCI controller
   255    [    1.400519] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 2
   256    [    1.400667] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz
   257    [    1.400673] ohci-platform 5200400.usb: irq 288, io mem 0x05200400
   258    [    1.401040] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found
   259    [    1.405045] axp20x-rsb sunxi-rsb-745: AXP20X driver loaded
   260    [    1.406317] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
   261    [    1.406342] ALSA device list:
   262    [    1.406350]   No soundcards found.
   263    [    1.407353] sunxi-mmc 4020000.mmc: Got CD GPIO
   264    [    1.412817] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
   265    [    1.413138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
   266    [    1.413153] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   267    [    1.413162] usb usb1: Product: EHCI Host Controller
   268    [    1.413170] usb usb1: Manufacturer: Linux 5.19.16-sunxi64 ehci_hcd
   269    [    1.413178] usb usb1: SerialNumber: 5200000.usb
   270    [    1.413755] hub 1-0:1.0: USB hub found
   271    [    1.413800] hub 1-0:1.0: 1 port detected
   272    [    1.432969] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
   273    [    1.461048] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
   274    [    1.461072] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   275    [    1.461082] usb usb2: Product: Generic Platform OHCI controller
   276    [    1.461089] usb usb2: Manufacturer: Linux 5.19.16-sunxi64 ohci_hcd
   277    [    1.461097] usb usb2: SerialNumber: 5200400.usb
   278    [    1.461685] hub 2-0:1.0: USB hub found
   279    [    1.461734] hub 2-0:1.0: 1 port detected
   280    [    1.463056] Freeing unused kernel memory: 2496K
   281    [    1.467747] mmc0: host does not support reading read-only switch, assuming write-enable
   282    [    1.469515] mmc0: Problem switching card into high-speed mode!
   283    [    1.469618] mmc0: new SDHC card at address 0001
   284    [    1.470529] mmcblk0: mmc0:0001 SD32G 28.9 GiB
   285    [    1.472739]  mmcblk0: p1
   286    [    1.476876] Run /init as init process
   287    [    1.476893]   with arguments:
   288    [    1.476900]     /init
   289    [    1.476905]   with environment:
   290    [    1.476910]     HOME=/
   291    [    1.476915]     TERM=linux
   292    [    1.476920]     splash=verbose
   293    [    1.476925]     ubootpart=da74ae41-01
   294    [    1.476930]     cgroup_enable=memory
   295    [    1.807499] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator
   296    [    1.807968] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
   297    [    1.807993] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
   298    [    1.808301] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
   299    [    1.808535] dwmac-sun8i 5020000.ethernet: PTP uses main clock
   300    [    1.808574] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 51fe6 (expect 50000)
   301    [    1.809220] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
   302    [    1.809246] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
   303    [    1.809253] dwmac-sun8i 5020000.ethernet: COE Type 2
   304    [    1.809260] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
   305    [    1.809268] dwmac-sun8i 5020000.ethernet: Normal descriptors
   306    [    1.809275] dwmac-sun8i 5020000.ethernet: Chain mode enabled
   307    [    1.812478] panfrost 1800000.gpu: clock rate = 432000000
   308    [    1.812527] panfrost 1800000.gpu: bus_clock rate = 200000000
   309    [    1.813390] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
   310    [    1.813426] panfrost 1800000.gpu: features: 00000000,000017f7, issues: 00000000,00000400
   311    [    1.813437] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
   312    [    1.813450] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1
   313    [    1.830174] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 0
   314    [    2.659071] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
   315    [    3.966156] systemd[1]: System time before build time, advancing clock.
   316    [    4.015834] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
   317    [    4.016480] systemd[1]: Detected architecture arm64.
   318    [    4.031496] systemd[1]: Set hostname to <orangepizero2>.
   319    [    4.829581] systemd[255]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
   320    [    5.132473] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
   321    [    5.348678] systemd[1]: Queued start job for default target Graphical Interface.
   322    [    6.708793] random: crng init done
   323    [    6.712242] systemd[1]: Created slice system-getty.slice.
   324    [    6.714578] systemd[1]: Created slice system-modprobe.slice.
   325    [    6.716434] systemd[1]: Created slice system-serial\x2dgetty.slice.
   326    [    6.718014] systemd[1]: Created slice User and Session Slice.
   327    [    6.718672] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
   328    [    6.719929] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
   329    [    6.720683] systemd[1]: Reached target Slices.
   330    [    6.721061] systemd[1]: Reached target Swap.
   331    [    6.721320] systemd[1]: Reached target System Time Set.
   332    [    6.739291] systemd[1]: Listening on RPCbind Server Activation Socket.
   333    [    6.740382] systemd[1]: Listening on Syslog Socket.
   334    [    6.741454] systemd[1]: Listening on fsck to fsckd communication Socket.
   335    [    6.742157] systemd[1]: Listening on initctl Compatibility Named Pipe.
   336    [    6.743421] systemd[1]: Listening on Journal Audit Socket.
   337    [    6.744374] systemd[1]: Listening on Journal Socket (/dev/log).
   338    [    6.745608] systemd[1]: Listening on Journal Socket.
   339    [    6.748150] systemd[1]: Listening on udev Control Socket.
   340    [    6.749121] systemd[1]: Listening on udev Kernel Socket.
   341    [    6.754056] systemd[1]: Mounting Huge Pages File System...
   342    [    6.759276] systemd[1]: Mounting POSIX Message Queue File System...
   343    [    6.764546] systemd[1]: Mounting RPC Pipe File System...
   344    [    6.771087] systemd[1]: Mounting Kernel Debug File System...
   345    [    6.772220] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   346    [    6.773263] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
   347    [    6.780753] systemd[1]: Starting Restore / save the current clock...
   348    [    6.786975] systemd[1]: Starting Set the console keyboard layout...
   349    [    6.792818] systemd[1]: Starting Create list of static device nodes for the current kernel...
   350    [    6.798764] systemd[1]: Starting Load Kernel Module configfs...
   351    [    6.805381] systemd[1]: Starting Load Kernel Module drm...
   352    [    6.812160] systemd[1]: Starting Load Kernel Module fuse...
   353    [    6.818731] systemd[1]: Started Nameserver information manager.
   354    [    6.821019] systemd[1]: Reached target Network (Pre).
   355    [    6.861101] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   356    [    6.861401] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
   357    [    6.870018] RPC: Registered named UNIX socket transport module.
   358    [    6.870043] RPC: Registered udp transport module.
   359    [    6.870048] RPC: Registered tcp transport module.
   360    [    6.870052] RPC: Registered tcp NFSv4.1 backchannel transport module.
   361    [    6.893527] systemd[1]: Starting Load Kernel Modules...
   362    [    6.899288] systemd[1]: Starting Remount Root and Kernel File Systems...
   363    [    6.904641] systemd[1]: Starting Coldplug All udev Devices...
   364    [    6.915146] fuse: init (API version 7.36)
   365    [    6.918019] systemd[1]: Mounted Huge Pages File System.
   366    [    6.920098] systemd[1]: Mounted POSIX Message Queue File System.
   367    [    6.921636] systemd[1]: Mounted RPC Pipe File System.
   368    [    6.923139] systemd[1]: Mounted Kernel Debug File System.
   369    [    6.925729] systemd[1]: Finished Restore / save the current clock.
   370    [    6.929018] systemd[1]: Finished Create list of static device nodes for the current kernel.
   371    [    6.931957] systemd[1]: modprobe@configfs.service: Succeeded.
   372    [    6.934013] systemd[1]: Finished Load Kernel Module configfs.
   373    [    6.936879] systemd[1]: modprobe@drm.service: Succeeded.
   374    [    6.938858] systemd[1]: Finished Load Kernel Module drm.
   375    [    6.942215] systemd[1]: modprobe@fuse.service: Succeeded.
   376    [    6.943882] systemd[1]: Finished Load Kernel Module fuse.
   377    [    6.954571] systemd[1]: Mounting FUSE Control File System...
   378    [    6.960654] systemd[1]: Mounting Kernel Configuration File System...
   379    [    6.966095] systemd[1]: Finished Load Kernel Modules.
   380    [    6.974572] systemd[1]: Mounted FUSE Control File System.
   381    [    6.975841] systemd[1]: Mounted Kernel Configuration File System.
   382    [    6.982055] systemd[1]: Starting Apply Kernel Variables...
   383    [    6.985073] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
   384    [    6.992219] systemd[1]: Finished Remount Root and Kernel File Systems.
   385    [    7.024350] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
   386    [    7.024729] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   387    [    7.029927] systemd[1]: Starting Load/Save Random Seed...
   388    [    7.036305] systemd[1]: Starting Create System Users...
   389    [    7.072405] systemd[1]: Finished Apply Kernel Variables.
   390    [    7.102901] systemd[1]: Finished Load/Save Random Seed.
   391    [    7.104739] systemd[1]: Condition check resulted in First Boot Complete being skipped.
   392    [    7.120859] systemd[1]: Finished Create System Users.
   393    [    7.127195] systemd[1]: Starting Create Static Device Nodes in /dev...
   394    [    7.201420] systemd[1]: Finished Create Static Device Nodes in /dev.
   395    [    7.210641] systemd[1]: Starting Rule-based Manager for Device Events and Files...
   396    [    7.325546] systemd[1]: Finished Set the console keyboard layout.
   397    [    7.326680] systemd[1]: Reached target Local File Systems (Pre).
   398    [    7.333121] systemd[1]: Mounting /tmp...
   399    [    7.346543] systemd[1]: Mounted /tmp.
   400    [    7.347567] systemd[1]: Reached target Local File Systems.
   401    [    7.353092] systemd[1]: Starting Armbian leds state...
   402    [    7.358758] systemd[1]: Starting Armbian ZRAM config...
   403    [    7.364567] systemd[1]: Starting Set console font and keymap...
   404    [    7.371542] systemd[1]: Starting Preprocess NFS configuration...
   405    [    7.380738] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
   406    [    7.381532] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   407    [    7.381937] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   408    [    7.383796] systemd[1]: Started Rule-based Manager for Device Events and Files.
   409    [    7.391704] systemd[1]: Finished Coldplug All udev Devices.
   410    [    7.410488] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
   411    [    7.416974] systemd[1]: Starting Show Plymouth Boot Screen...
   412    [    7.424206] systemd[1]: nfs-config.service: Succeeded.
   413    [    7.426541] systemd[1]: Finished Preprocess NFS configuration.
   414    [    7.428139] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
   415    [    7.428288] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
   416    [    7.428410] systemd[1]: Reached target NFS client services.
   417    [    7.441295] systemd[1]: Finished Set console font and keymap.
   418    [    7.466334] systemd[1]: Received SIGRTMIN+20 from PID 215 (plymouthd).
   419    [    7.513797] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
   420    [    7.522256] systemd[1]: Starting Raise network interfaces...
   421    [    7.527756] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
   422    [    7.572859] systemd[1]: Started Show Plymouth Boot Screen.
   423    [    7.574842] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   424    [    7.575854] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
   425    [    7.576318] systemd[1]: Reached target Local Encrypted Volumes.
   426    [    7.576749] systemd[1]: Reached target Paths.
   427    [    7.611280] systemd[1]: Finished Armbian leds state.
   428    [    7.760275] systemd[1]: Found device /dev/ttyS0.
   429    [    7.901050] systemd[1]: Reached target Hardware activated USB gadget.
   430    [    7.969034] mc: Linux media interface: v0.10
   431    [    8.044065] videodev: Linux video capture interface: v2.00
   432    [    8.350568] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
   433    [    8.352685] cedrus 1c0e000.video-codec: Device registered as /dev/video0
   434    [    8.378582] zram: Added device: zram0
   435    [    8.380544] zram: Added device: zram1
   436    [    8.381898] zram: Added device: zram2
   437    [    8.542259] zram0: detected capacity change from 0 to 1007896
   438    [    8.566239] systemd[1]: Finished Raise network interfaces.
   439    [    8.582567] Adding 503944k swap on /dev/zram0.  Priority:5 extents:1 across:503944k SSFS
   440    [    8.804624] zram1: detected capacity change from 0 to 102400
   441    [    8.896180] systemd[1]: Finished Armbian ZRAM config.
   442    [    8.901609] systemd[1]: Starting Armbian memory supported logging...
   443    [    8.985388] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
   444    [    8.985439] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
   445    [   11.776447] systemd[1]: Finished Armbian memory supported logging.
   446    [   11.785039] systemd[1]: Starting Journal Service...
   447    [   11.996335] systemd[1]: Started Journal Service.
   448    [   12.041159] systemd-journald[528]: Received client request to flush runtime journal.
   449    [   12.055902] systemd-journald[528]: File /var/log/journal/0591d2673a8840eb8c934f5eaf48cb73/system.journal corrupted or uncleanly shut down, renaming and replacing.
   450
   451    ### armbian-release:
   452
   453    # PLEASE DO NOT EDIT THIS FILE
   454    BOARD=orangepizero2
   455    BOARD_NAME="Orange Pi Zero2"
   456    BOARDFAMILY=sun50iw9
   457    BUILD_REPOSITORY_URL=https://github.com/armbian/build
   458    BUILD_REPOSITORY_COMMIT=aa881a6ecd6
   459    VERSION=22.08.6
   460    LINUXFAMILY=sunxi64
   461    ARCH=arm64
   462    IMAGE_TYPE=stable
   463    BOARD_TYPE=conf
   464    INITRD_ARCH=arm64
   465    KERNEL_IMAGE_TYPE=stable
   466    BRANCH=edge
   467
   468    ### boot environment:
   469
   470    verbosity=1
   471    bootlogo=false
   472    console=serial
   473    disp_mode=1920x1080p60
   474    rootdev=UUID=0ae80c94-60cd-4b15-b7f3-065f13ca80b6
   475    rootfstype=ext4
   476    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
   477
   478
   479    ### lsusb:
   480
   481    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   482    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   483
   484    ### lscpu:
   485
   486    Architecture:                    aarch64
   487    CPU op-mode(s):                  32-bit, 64-bit
   488    Byte Order:                      Little Endian
   489    CPU(s):                          4
   490    On-line CPU(s) list:             0-3
   491    Thread(s) per core:              1
   492    Core(s) per socket:              4
   493    Socket(s):                       1
   494    NUMA node(s):                    1
   495    Vendor ID:                       ARM
   496    Model:                           4
   497    Model name:                      Cortex-A53
   498    Stepping:                        r0p4
   499    BogoMIPS:                        48.00
   500    NUMA node0 CPU(s):               0-3
   501    Vulnerability Itlb multihit:     Not affected
   502    Vulnerability L1tf:              Not affected
   503    Vulnerability Mds:               Not affected
   504    Vulnerability Meltdown:          Not affected
   505    Vulnerability Mmio stale data:   Not affected
   506    Vulnerability Retbleed:          Not affected
   507    Vulnerability Spec store bypass: Not affected
   508    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
   509    Vulnerability Spectre v2:        Not affected
   510    Vulnerability Srbds:             Not affected
   511    Vulnerability Tsx async abort:   Not affected
   512    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   513
   514    ### cpuinfo:
   515
   516    processor    : 0
   517    BogoMIPS    : 48.00
   518    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   519    CPU implementer    : 0x41
   520    CPU architecture: 8
   521    CPU variant    : 0x0
   522    CPU part    : 0xd03
   523    CPU revision    : 4
   524
   525    processor    : 1
   526    BogoMIPS    : 48.00
   527    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   528    CPU implementer    : 0x41
   529    CPU architecture: 8
   530    CPU variant    : 0x0
   531    CPU part    : 0xd03
   532    CPU revision    : 4
   533
   534    processor    : 2
   535    BogoMIPS    : 48.00
   536    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   537    CPU implementer    : 0x41
   538    CPU architecture: 8
   539    CPU variant    : 0x0
   540    CPU part    : 0xd03
   541    CPU revision    : 4
   542
   543    processor    : 3
   544    BogoMIPS    : 48.00
   545    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   546    CPU implementer    : 0x41
   547    CPU architecture: 8
   548    CPU variant    : 0x0
   549    CPU part    : 0xd03
   550    CPU revision    : 4
   551
   552
   553    ### meminfo:
   554
   555    MemTotal:        1007892 kB
   556    MemFree:          871400 kB
   557    MemAvailable:     867688 kB
   558    Buffers:           10336 kB
   559    Cached:            45300 kB
   560    SwapCached:            0 kB
   561    Active:            26520 kB
   562    Inactive:          38512 kB
   563    Active(anon):        252 kB
   564    Inactive(anon):    12548 kB
   565    Active(file):      26268 kB
   566    Inactive(file):    25964 kB
   567    Unevictable:        2876 kB
   568    Mlocked:               0 kB
   569    SwapTotal:        503944 kB
   570    SwapFree:         503944 kB
   571    Zswap:                 0 kB
   572    Zswapped:              0 kB
   573    Dirty:              1072 kB
   574    Writeback:             4 kB
   575    AnonPages:         12368 kB
   576    Mapped:            15732 kB
   577    Shmem:               428 kB
   578    KReclaimable:       7924 kB
   579    Slab:              26968 kB
   580    SReclaimable:       7924 kB
   581    SUnreclaim:        19044 kB
   582    KernelStack:        1992 kB
   583    PageTables:         1204 kB
   584    NFS_Unstable:          0 kB
   585    Bounce:                0 kB
   586    WritebackTmp:          0 kB
   587    CommitLimit:     1007888 kB
   588    Committed_AS:      37120 kB
   589    VmallocTotal:   133143592960 kB
   590    VmallocUsed:       19192 kB
   591    VmallocChunk:          0 kB
   592    Percpu:             1168 kB
   593    AnonHugePages:         0 kB
   594    ShmemHugePages:        0 kB
   595    ShmemPmdMapped:        0 kB
   596    FileHugePages:         0 kB
   597    FilePmdMapped:         0 kB
   598    CmaTotal:         131072 kB
   599    CmaFree:          130688 kB
   600    HugePages_Total:       0
   601    HugePages_Free:        0
   602    HugePages_Rsvd:        0
   603    HugePages_Surp:        0
   604    Hugepagesize:       2048 kB
   605    Hugetlb:               0 kB
   606
   607    ### virtual memory:
   608
   609    vm.admin_reserve_kbytes = 8192
   610    vm.compaction_proactiveness = 20
   611    vm.compact_unevictable_allowed = 1
   612    vm.dirty_background_bytes = 0
   613    vm.dirty_background_ratio = 10
   614    vm.dirty_bytes = 0
   615    vm.dirty_expire_centisecs = 3000
   616    vm.dirty_ratio = 20
   617    vm.dirtytime_expire_seconds = 43200
   618    vm.dirty_writeback_centisecs = 500
   619    vm.extfrag_threshold = 500
   620    vm.hugetlb_optimize_vmemmap = 0
   621    vm.hugetlb_shm_group = 0
   622    vm.laptop_mode = 0
   623    vm.legacy_va_layout = 0
   624    vm.lowmem_reserve_ratio = 256    256    32    0
   625    vm.max_map_count = 65530
   626    vm.min_free_kbytes = 22528
   627    vm.min_slab_ratio = 5
   628    vm.min_unmapped_ratio = 1
   629    vm.mmap_min_addr = 4096
   630    vm.mmap_rnd_bits = 18
   631    vm.mmap_rnd_compat_bits = 11
   632    vm.nr_hugepages = 0
   633    vm.nr_hugepages_mempolicy = 0
   634    vm.nr_overcommit_hugepages = 0
   635    vm.numa_stat = 1
   636    vm.numa_zonelist_order = Node
   637    vm.oom_dump_tasks = 1
   638    vm.oom_kill_allocating_task = 0
   639    vm.overcommit_kbytes = 0
   640    vm.overcommit_memory = 0
   641    vm.overcommit_ratio = 50
   642    vm.page-cluster = 0
   643    vm.page_lock_unfairness = 5
   644    vm.panic_on_oom = 0
   645    vm.percpu_pagelist_high_fraction = 0
   646    vm.stat_interval = 1
   647    vm.swappiness = 100
   648    vm.user_reserve_kbytes = 30913
   649    vm.vfs_cache_pressure = 100
   650    vm.watermark_boost_factor = 15000
   651    vm.watermark_scale_factor = 10
   652    vm.zone_reclaim_mode = 0
   653
   654    ### ip addr:
   655
   656    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   657        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   658        inet XXX.XXX.0.1/8 scope host lo
   659           valid_lft forever preferred_lft forever
   660        inet6 ::1/128 scope host
   661           valid_lft forever preferred_lft forever
   662    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   663        link/ether 02:00:62:71:18:3b brd ff:ff:ff:ff:ff:ff
   664
   665    ### partitions:
   666
   667    major minor  #blocks  name
   668
   669      31        0       2048 mtdblock0
   670     179        0   30263296 mmcblk0
   671     179        1   29945856 mmcblk0p1
   672     252        0     503948 zram0
   673     252        1      51200 zram1
   674
   675    ### df:
   676
   677    udev            422M     0  422M   0% /dev
   678    tmpfs            99M  428K   99M   1% /run
   679    /dev/mmcblk0p1   29G  1.5G   27G   6% /
   680    tmpfs           493M     0  493M   0% /dev/shm
   681    tmpfs           5.0M     0  5.0M   0% /run/lock
   682    tmpfs           493M  4.0K  493M   1% /tmp
   683    /dev/zram1       49M  688K   45M   2% /var/log
   684
   685    ### lsblk:
   686
   687    NAME        FSTYPE   SIZE MOUNTPOINT UUID
   688    mtdblock0              2M
   689    mmcblk0             28.9G
   690    └─mmcblk0p1 ext4    28.6G /          0ae80c94-60cd-4b15-b7f3-065f13ca80b6
   691    zram1                 50M /var/log
   692
   693    ### zramctl:
   694
   695    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
   696    /dev/zram1 zstd           50M  732K 115.4K  400K       4 /var/log
   697    /dev/zram0 lzo-rle     492.1M    4K    73B   12K       4 [SWAP]
   698
   699    ### mtab:
   700
   701    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   702    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   703    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
   704
   705    ### mmc0:0001 info:
   706
   707                   fwrev: 0x0
   708                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block
   709                     cid: 27504853443332476000000596015bf1
   710                     rca: 0x0001
   711                     csd: 400e00325b590000e6e37f800a4000c9
   712                  manfid: 0x000027
   713                     ocr: 0x00200000
   714    preferred_erase_size: 4194304
   715                    type: SD
   716                   hwrev: 0x6
   717                    date: 11/2021
   718                     dsr: 0x404
   719              erase_size: 512
   720                   oemid: 0x5048
   721                  serial: 0x00000596
   722                     ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   723                     scr: 0285808200000000
   724                    name: SD32G
   725
   726    ### Boot system health:
   727
   728    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
   729    19:17:09:   ---      0.15  47%  18%  12%   0%  15%   0% 41.0 °C
   730    19:17:10:   ---      1.02  96%  38%  45%   0%  12%   0% 41.0 °C
   731    19:17:10:   ---      1.02  97%  20%  34%   0%  42%   0% 41.9 °C
   732    19:17:10:   ---      1.02  79%   9%   7%   0%  62%   0% 41.9 °C
   733    19:17:11:   ---      1.02  93%  17%  31%   0%  44%   0% 41.1 °C
   734
   735    ### Activated 1 lzo-rle zram swap devices with 492MB each.
   736    ### Activated Armbian ramlog partition with zstd compression
   737
   738    ### Activated 1 lzo-rle zram swap devices with 492MB each.
   739    ### Activated Armbian ramlog partition with zstd compression
   740
   741    Fri 11 Nov 2022 06:33:04 PM EST | Orange Pi Zero2 | 22.08.6 | arm64 | aarch64 | 5.19.16-sunxi64
   742
   743    ### dmesg:
   744
   745    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   746    [    0.000000] Linux version 5.19.16-sunxi64 (root@6d820ce0d5d6) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #22.08.6 SMP Tue Oct 18 06:56:22 UTC 2022
   747    [    0.000000] Machine model: OrangePi Zero2
   748    [    0.000000] NUMA: No NUMA configuration found
   749    [    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
   750    [    0.000000] NUMA: NODE_DATA [mem 0x7fdde040-0x7fddffff]
   751    [    0.000000] Zone ranges:
   752    [    0.000000]   DMA      [mem 0x0000000040000000-0x000000007fffffff]
   753    [    0.000000]   DMA32    empty
   754    [    0.000000]   Normal   empty
   755    [    0.000000] Movable zone start for each node
   756    [    0.000000] Early memory node ranges
   757    [    0.000000]   node   0: [mem 0x0000000040000000-0x000000004007ffff]
   758    [    0.000000]   node   0: [mem 0x0000000040080000-0x000000007fffffff]
   759    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
   760    [    0.000000] cma: Reserved 128 MiB at 0x0000000076c00000
   761    [    0.000000] psci: probing for conduit method from DT.
   762    [    0.000000] psci: PSCIv1.1 detected in firmware.
   763    [    0.000000] psci: Using standard PSCI v0.2 function IDs
   764    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
   765    [    0.000000] psci: SMC Calling Convention v1.2
   766    [    0.000000] percpu: Embedded 19 pages/cpu s37608 r8192 d32024 u77824
   767    [    0.000000] pcpu-alloc: s37608 r8192 d32024 u77824 alloc=19*4096
   768    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   769    [    0.000000] Detected VIPT I-cache on CPU0
   770    [    0.000000] CPU features: detected: ARM erratum 845719
   771    [    0.000000] Fallback order for Node 0: 0
   772    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
   773    [    0.000000] Policy zone: DMA
   774    [    0.000000] Kernel command line: root=UUID=0ae80c94-60cd-4b15-b7f3-065f13ca80b6 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=da74ae41-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
   775    [    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=da74ae41-01 cgroup_enable=memory", will be passed to user space.
   776    [    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
   777    [    0.000000] printk: log_buf_len total cpu_extra contributions: 12288 bytes
   778    [    0.000000] printk: log_buf_len min size: 16384 bytes
   779    [    0.000000] printk: log_buf_len: 32768 bytes
   780    [    0.000000] printk: early log buf free: 14048(85%)
   781    [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
   782    [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
   783    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
   784    [    0.000000] Memory: 862824K/1048576K available (13888K kernel code, 1038K rwdata, 4112K rodata, 2496K init, 387K bss, 54680K reserved, 131072K cma-reserved)
   785    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   786    [    0.000000] rcu: Hierarchical RCU implementation.
   787    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   788    [    0.000000]     Tracing variant of Tasks RCU enabled.
   789    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   790    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   791    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
   792    [    0.000000] Root IRQ handler: gic_handle_irq
   793    [    0.000000] GIC: Using split EOI/Deactivate mode
   794    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
   795    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   796    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   797    [    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   798    [    0.000388] Console: colour dummy device 80x25
   799    [    0.000473] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   800    [    0.000486] pid_max: default: 32768 minimum: 301
   801    [    0.000559] LSM: Security Framework initializing
   802    [    0.000589] Yama: becoming mindful.
   803    [    0.000682] AppArmor: AppArmor initialized
   804    [    0.000777] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
   805    [    0.000790] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
   806    [    0.002405] cblist_init_generic: Setting adjustable number of callback queues.
   807    [    0.002423] cblist_init_generic: Setting shift to 2 and lim to 1.
   808    [    0.002589] rcu: Hierarchical SRCU implementation.
   809    [    0.002593] rcu:     Max phase no-delay instances is 1000.
   810    [    0.003874] smp: Bringing up secondary CPUs ...
   811    [    0.004476] Detected VIPT I-cache on CPU1
   812    [    0.004556] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   813    [    0.005174] Detected VIPT I-cache on CPU2
   814    [    0.005242] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   815    [    0.005827] Detected VIPT I-cache on CPU3
   816    [    0.005889] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   817    [    0.005986] smp: Brought up 1 node, 4 CPUs
   818    [    0.005995] SMP: Total of 4 processors activated.
   819    [    0.006000] CPU features: detected: 32-bit EL0 Support
   820    [    0.006004] CPU features: detected: CRC32 instructions
   821    [    0.006339] CPU: All CPU(s) started at EL2
   822    [    0.006356] alternatives: patching kernel code
   823    [    0.007765] devtmpfs: initialized
   824    [    0.012263] Registered cp15_barrier emulation handler
   825    [    0.012283] Registered setend emulation handler
   826    [    0.012470] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   827    [    0.012489] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   828    [    0.016819] pinctrl core: initialized pinctrl subsystem
   829    [    0.018104] NET: Registered PF_NETLINK/PF_ROUTE protocol family
   830    [    0.019497] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
   831    [    0.019800] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   832    [    0.019924] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   833    [    0.019996] audit: initializing netlink subsys (disabled)
   834    [    0.020237] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
   835    [    0.020743] thermal_sys: Registered thermal governor 'fair_share'
   836    [    0.020751] thermal_sys: Registered thermal governor 'bang_bang'
   837    [    0.020755] thermal_sys: Registered thermal governor 'step_wise'
   838    [    0.020758] thermal_sys: Registered thermal governor 'user_space'
   839    [    0.021240] cpuidle: using governor menu
   840    [    0.021463] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   841    [    0.021571] ASID allocator initialised with 65536 entries
   842    [    0.021579] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
   843    [    0.021585] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
   844    [    0.021590] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
   845    [    0.021595] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
   846    [    0.021794] Serial: AMBA PL011 UART driver
   847    [    0.035091] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   848    [    0.035108] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   849    [    0.035114] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   850    [    0.035120] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   851    [    0.035785] cryptd: max_cpu_qlen set to 1000
   852    [    0.104313] raid6: neonx8   gen()  1807 MB/s
   853    [    0.172391] raid6: neonx4   gen()  1854 MB/s
   854    [    0.240468] raid6: neonx2   gen()  1754 MB/s
   855    [    0.308540] raid6: neonx1   gen()  1519 MB/s
   856    [    0.376603] raid6: int64x8  gen()  1251 MB/s
   857    [    0.444689] raid6: int64x4  gen()  1398 MB/s
   858    [    0.512761] raid6: int64x2  gen()  1185 MB/s
   859    [    0.580834] raid6: int64x1  gen()   882 MB/s
   860    [    0.580839] raid6: using algorithm neonx4 gen() 1854 MB/s
   861    [    0.648901] raid6: .... xor() 1334 MB/s, rmw enabled
   862    [    0.648906] raid6: using neon recovery algorithm
   863    [    0.649823] iommu: Default domain type: Translated
   864    [    0.649836] iommu: DMA domain TLB invalidation policy: strict mode
   865    [    0.650119] SCSI subsystem initialized
   866    [    0.650332] usbcore: registered new interface driver usbfs
   867    [    0.650369] usbcore: registered new interface driver hub
   868    [    0.650404] usbcore: registered new device driver usb
   869    [    0.650687] pps_core: LinuxPPS API ver. 1 registered
   870    [    0.650692] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   871    [    0.650706] PTP clock support registered
   872    [    0.651113] ARM FF-A: FFA_VERSION returned not supported
   873    [    0.651494] Advanced Linux Sound Architecture Driver Initialized.
   874    [    0.652156] NetLabel: Initializing
   875    [    0.652161] NetLabel:  domain hash size = 128
   876    [    0.652165] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   877    [    0.652227] NetLabel:  unlabeled traffic allowed by default
   878    [    0.652231] mctp: management component transport protocol core
   879    [    0.652235] NET: Registered PF_MCTP protocol family
   880    [    0.652813] clocksource: Switched to clocksource arch_sys_counter
   881    [    0.653150] VFS: Disk quotas dquot_6.6.0
   882    [    0.653198] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   883    [    0.653747] AppArmor: AppArmor Filesystem Enabled
   884    [    0.660579] NET: Registered PF_INET protocol family
   885    [    0.660819] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
   886    [    0.662051] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
   887    [    0.662081] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
   888    [    0.662093] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
   889    [    0.662161] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
   890    [    0.662283] TCP: Hash tables configured (established 8192 bind 8192)
   891    [    0.662400] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
   892    [    0.662433] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
   893    [    0.662625] NET: Registered PF_UNIX/PF_LOCAL protocol family
   894    [    0.663180] Trying to unpack rootfs image as initramfs...
   895    [    0.669928] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   896    [    0.671452] Initialise system trusted keyrings
   897    [    0.671538] Key type blacklist registered
   898    [    0.671825] workingset: timestamp_bits=44 max_order=18 bucket_order=0
   899    [    0.677514] zbud: loaded
   900    [    0.679183] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   901    [    0.681832] integrity: Platform Keyring initialized
   902    [    0.724930] xor: automatically using best checksumming function   32regs
   903    [    0.724952] async_tx: api initialized (async)
   904    [    0.724963] Key type asymmetric registered
   905    [    0.724969] Asymmetric key parser 'x509' registered
   906    [    1.259380] Freeing initrd memory: 11500K
   907    [    1.277965] alg: self-tests for CTR-KDF (hmac(sha256)) passed
   908    [    1.278073] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
   909    [    1.278215] io scheduler mq-deadline registered
   910    [    1.278222] io scheduler kyber registered
   911    [    1.278365] io scheduler bfq registered
   912    [    1.284387] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
   913    [    1.288025] cacheinfo: Unable to detect cache hierarchy for CPU 0
   914    [    1.292675] loop: module loaded
   915    [    1.294543] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   916    [    1.294568] ehci-platform: EHCI generic platform driver
   917    [    1.294662] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   918    [    1.294676] ohci-platform: OHCI generic platform driver
   919    [    1.294945] usbcore: registered new interface driver usb-storage
   920    [    1.295386] mousedev: PS/2 mouse device common for all mice
   921    [    1.296412] sun6i-rtc 7000000.rtc: registered as rtc0
   922    [    1.296452] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T00:00:04 UTC (86404)
   923    [    1.296557] sun6i-rtc 7000000.rtc: RTC enabled
   924    [    1.296660] i2c_dev: i2c /dev entries driver
   925    [    1.297482] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   926    [    1.298867] sdhci: Secure Digital Host Controller Interface driver
   927    [    1.298881] sdhci: Copyright(c) Pierre Ossman
   928    [    1.298903] Synopsys Designware Multimedia Card Interface Driver
   929    [    1.299332] sdhci-pltfm: SDHCI platform and OF driver helper
   930    [    1.299801] ledtrig-cpu: registered to indicate activity on CPUs
   931    [    1.300061] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000
   932    [    1.300349] hid: raw HID events driver (C) Jiri Kosina
   933    [    1.300447] usbcore: registered new interface driver usbhid
   934    [    1.300452] usbhid: USB HID core driver
   935    [    1.310100] NET: Registered PF_INET6 protocol family
   936    [    1.328711] Segment Routing with IPv6
   937    [    1.328821] In-situ OAM (IOAM) with IPv6
   938    [    1.328910] NET: Registered PF_PACKET protocol family
   939    [    1.329086] 8021q: 802.1Q VLAN Support v1.8
   940    [    1.329243] 9pnet: Installing 9P2000 support
   941    [    1.329329] Key type dns_resolver registered
   942    [    1.329889] registered taskstats version 1
   943    [    1.329912] Loading compiled-in X.509 certificates
   944    [    1.333699] Loaded X.509 cert 'Build time autogenerated kernel key: 05920f111eead6a51cb60d55d842ed91645758e7'
   945    [    1.336164] zswap: loaded using pool zstd/z3fold
   946    [    1.336754] Key type ._fscrypt registered
   947    [    1.336765] Key type .fscrypt registered
   948    [    1.336769] Key type fscrypt-provisioning registered
   949    [    1.337921] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
   950    [    1.338336] Key type encrypted registered
   951    [    1.338357] AppArmor: AppArmor sha1 policy hashing enabled
   952    [    1.338395] ima: No TPM chip found, activating TPM-bypass!
   953    [    1.338421] ima: Allocated hash algorithm: sha1
   954    [    1.338466] ima: No architecture policies found
   955    [    1.338513] evm: Initialising EVM extended attributes:
   956    [    1.338516] evm: security.selinux
   957    [    1.338520] evm: security.SMACK64
   958    [    1.338523] evm: security.SMACK64EXEC
   959    [    1.338526] evm: security.SMACK64TRANSMUTE
   960    [    1.338530] evm: security.SMACK64MMAP
   961    [    1.338533] evm: security.apparmor
   962    [    1.338536] evm: security.ima
   963    [    1.338539] evm: security.capability
   964    [    1.338542] evm: HMAC attrs: 0x1
   965    [    1.360713] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
   966    [    1.362320] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
   967    [    1.362984] printk: console [ttyS0] disabled
   968    [    1.363069] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 283, base_baud = 1500000) is a 16550A
   969    [    1.363265] printk: console [ttyS0] enabled
   970    [    1.364125] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
   971    [    1.364461] sun6i-spi 5010000.spi: Failed to request TX DMA channel
   972    [    1.364472] sun6i-spi 5010000.spi: Failed to request RX DMA channel
   973    [    1.365096] spi-nor spi0.0: supply vdd not found, using dummy regulator
   974    [    1.381032] spi-nor spi0.0: mx25l1606e (2048 Kbytes)
   975    [    1.397028] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
   976    [    1.398320] ehci-platform 5200000.usb: EHCI Host Controller
   977    [    1.398345] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
   978    [    1.398360] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 1
   979    [    1.398475] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
   980    [    1.398483] ehci-platform 5200000.usb: irq 286, io mem 0x05200000
   981    [    1.400439] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
   982    [    1.400869] ohci-platform 5200400.usb: Generic Platform OHCI controller
   983    [    1.400910] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 2
   984    [    1.400979] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz
   985    [    1.401024] ohci-platform 5200400.usb: irq 288, io mem 0x05200400
   986    [    1.401305] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found
   987    [    1.405182] axp20x-rsb sunxi-rsb-745: AXP20X driver loaded
   988    [    1.406465] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
   989    [    1.406504] ALSA device list:
   990    [    1.406512]   No soundcards found.
   991    [    1.407495] sunxi-mmc 4020000.mmc: Got CD GPIO
   992    [    1.412821] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
   993    [    1.413117] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
   994    [    1.413133] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   995    [    1.413142] usb usb1: Product: EHCI Host Controller
   996    [    1.413149] usb usb1: Manufacturer: Linux 5.19.16-sunxi64 ehci_hcd
   997    [    1.413157] usb usb1: SerialNumber: 5200000.usb
   998    [    1.413737] hub 1-0:1.0: USB hub found
   999    [    1.413791] hub 1-0:1.0: 1 port detected
  1000    [    1.433106] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1001    [    1.465043] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
  1002    [    1.465069] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1003    [    1.465079] usb usb2: Product: Generic Platform OHCI controller
  1004    [    1.465087] usb usb2: Manufacturer: Linux 5.19.16-sunxi64 ohci_hcd
  1005    [    1.465094] usb usb2: SerialNumber: 5200400.usb
  1006    [    1.465672] hub 2-0:1.0: USB hub found
  1007    [    1.465721] hub 2-0:1.0: 1 port detected
  1008    [    1.467038] Freeing unused kernel memory: 2496K
  1009    [    1.467836] mmc0: host does not support reading read-only switch, assuming write-enable
  1010    [    1.469607] mmc0: Problem switching card into high-speed mode!
  1011    [    1.469722] mmc0: new SDHC card at address 0001
  1012    [    1.470630] mmcblk0: mmc0:0001 SD32G 28.9 GiB
  1013    [    1.472694]  mmcblk0: p1
  1014    [    1.480880] Run /init as init process
  1015    [    1.480900]   with arguments:
  1016    [    1.480907]     /init
  1017    [    1.480912]   with environment:
  1018    [    1.480917]     HOME=/
  1019    [    1.480922]     TERM=linux
  1020    [    1.480927]     splash=verbose
  1021    [    1.480932]     ubootpart=da74ae41-01
  1022    [    1.480937]     cgroup_enable=memory
  1023    [    1.840883] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator
  1024    [    1.841316] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
  1025    [    1.841340] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
  1026    [    1.841692] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
  1027    [    1.842000] dwmac-sun8i 5020000.ethernet: PTP uses main clock
  1028    [    1.842063] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 51fe6 (expect 50000)
  1029    [    1.846392] panfrost 1800000.gpu: clock rate = 432000000
  1030    [    1.846436] panfrost 1800000.gpu: bus_clock rate = 200000000
  1031    [    1.846926] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
  1032    [    1.846951] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
  1033    [    1.846959] dwmac-sun8i 5020000.ethernet: COE Type 2
  1034    [    1.846968] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
  1035    [    1.846976] dwmac-sun8i 5020000.ethernet: Normal descriptors
  1036    [    1.846982] dwmac-sun8i 5020000.ethernet: Chain mode enabled
  1037    [    1.850548] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
  1038    [    1.850592] panfrost 1800000.gpu: features: 00000000,000017f7, issues: 00000000,00000400
  1039    [    1.850603] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
  1040    [    1.850615] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1
  1041    [    1.857125] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 0
  1042    [    2.698073] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  1043    [    4.091151] systemd[1]: System time before build time, advancing clock.
  1044    [    4.140950] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
  1045    [    4.141618] systemd[1]: Detected architecture arm64.
  1046    [    4.157085] systemd[1]: Set hostname to <orangepizero2>.
  1047    [    4.938803] systemd[255]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  1048    [    5.240894] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
  1049    [    5.456090] systemd[1]: Queued start job for default target Graphical Interface.
  1050    [    6.800801] random: crng init done
  1051    [    6.804255] systemd[1]: Created slice system-getty.slice.
  1052    [    6.806559] systemd[1]: Created slice system-modprobe.slice.
  1053    [    6.808408] systemd[1]: Created slice system-serial\x2dgetty.slice.
  1054    [    6.809997] systemd[1]: Created slice User and Session Slice.
  1055    [    6.810656] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1056    [    6.811902] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  1057    [    6.812642] systemd[1]: Reached target Slices.
  1058    [    6.813004] systemd[1]: Reached target Swap.
  1059    [    6.813277] systemd[1]: Reached target System Time Set.
  1060    [    6.831442] systemd[1]: Listening on RPCbind Server Activation Socket.
  1061    [    6.832531] systemd[1]: Listening on Syslog Socket.
  1062    [    6.833598] systemd[1]: Listening on fsck to fsckd communication Socket.
  1063    [    6.834270] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1064    [    6.835523] systemd[1]: Listening on Journal Audit Socket.
  1065    [    6.836480] systemd[1]: Listening on Journal Socket (/dev/log).
  1066    [    6.837681] systemd[1]: Listening on Journal Socket.
  1067    [    6.840507] systemd[1]: Listening on udev Control Socket.
  1068    [    6.841487] systemd[1]: Listening on udev Kernel Socket.
  1069    [    6.846376] systemd[1]: Mounting Huge Pages File System...
  1070    [    6.851622] systemd[1]: Mounting POSIX Message Queue File System...
  1071    [    6.857000] systemd[1]: Mounting RPC Pipe File System...
  1072    [    6.863557] systemd[1]: Mounting Kernel Debug File System...
  1073    [    6.864750] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  1074    [    6.865743] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  1075    [    6.874264] systemd[1]: Starting Restore / save the current clock...
  1076    [    6.880499] systemd[1]: Starting Set the console keyboard layout...
  1077    [    6.886191] systemd[1]: Starting Create list of static device nodes for the current kernel...
  1078    [    6.892105] systemd[1]: Starting Load Kernel Module configfs...
  1079    [    6.899060] systemd[1]: Starting Load Kernel Module drm...
  1080    [    6.906236] systemd[1]: Starting Load Kernel Module fuse...
  1081    [    6.912337] systemd[1]: Started Nameserver information manager.
  1082    [    6.914121] systemd[1]: Reached target Network (Pre).
  1083    [    6.953370] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  1084    [    6.953629] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1085    [    6.962301] RPC: Registered named UNIX socket transport module.
  1086    [    6.962325] RPC: Registered udp transport module.
  1087    [    6.962330] RPC: Registered tcp transport module.
  1088    [    6.962334] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1089    [    6.985174] systemd[1]: Starting Load Kernel Modules...
  1090    [    6.990748] systemd[1]: Starting Remount Root and Kernel File Systems...
  1091    [    6.996198] systemd[1]: Starting Coldplug All udev Devices...
  1092    [    7.007572] fuse: init (API version 7.36)
  1093    [    7.010404] systemd[1]: Mounted Huge Pages File System.
  1094    [    7.012317] systemd[1]: Mounted POSIX Message Queue File System.
  1095    [    7.013956] systemd[1]: Mounted RPC Pipe File System.
  1096    [    7.015239] systemd[1]: Mounted Kernel Debug File System.
  1097    [    7.017889] systemd[1]: Finished Restore / save the current clock.
  1098    [    7.020875] systemd[1]: Finished Create list of static device nodes for the current kernel.
  1099    [    7.023030] systemd[1]: modprobe@configfs.service: Succeeded.
  1100    [    7.024406] systemd[1]: Finished Load Kernel Module configfs.
  1101    [    7.026682] systemd[1]: modprobe@drm.service: Succeeded.
  1102    [    7.028198] systemd[1]: Finished Load Kernel Module drm.
  1103    [    7.031261] systemd[1]: modprobe@fuse.service: Succeeded.
  1104    [    7.033449] systemd[1]: Finished Load Kernel Module fuse.
  1105    [    7.043000] systemd[1]: Mounting FUSE Control File System...
  1106    [    7.048534] systemd[1]: Mounting Kernel Configuration File System...
  1107    [    7.054017] systemd[1]: Finished Load Kernel Modules.
  1108    [    7.064287] systemd[1]: Mounted FUSE Control File System.
  1109    [    7.065935] systemd[1]: Mounted Kernel Configuration File System.
  1110    [    7.072476] systemd[1]: Starting Apply Kernel Variables...
  1111    [    7.096997] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  1112    [    7.104404] systemd[1]: Finished Remount Root and Kernel File Systems.
  1113    [    7.114106] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
  1114    [    7.114483] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1115    [    7.119873] systemd[1]: Starting Load/Save Random Seed...
  1116    [    7.126176] systemd[1]: Starting Create System Users...
  1117    [    7.156972] systemd[1]: Finished Apply Kernel Variables.
  1118    [    7.192934] systemd[1]: Finished Load/Save Random Seed.
  1119    [    7.194158] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  1120    [    7.218789] systemd[1]: Finished Create System Users.
  1121    [    7.225388] systemd[1]: Starting Create Static Device Nodes in /dev...
  1122    [    7.299084] systemd[1]: Finished Create Static Device Nodes in /dev.
  1123    [    7.308153] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  1124    [    7.418174] systemd[1]: Finished Set the console keyboard layout.
  1125    [    7.419418] systemd[1]: Reached target Local File Systems (Pre).
  1126    [    7.425709] systemd[1]: Mounting /tmp...
  1127    [    7.429129] systemd[1]: Finished Coldplug All udev Devices.
  1128    [    7.437192] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  1129    [    7.442963] systemd[1]: Mounted /tmp.
  1130    [    7.444107] systemd[1]: Reached target Local File Systems.
  1131    [    7.449648] systemd[1]: Starting Armbian leds state...
  1132    [    7.454895] systemd[1]: Starting Armbian ZRAM config...
  1133    [    7.461389] systemd[1]: Starting Set console font and keymap...
  1134    [    7.466960] systemd[1]: Starting Preprocess NFS configuration...
  1135    [    7.473497] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
  1136    [    7.474034] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1137    [    7.474348] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1138    [    7.477359] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  1139    [    7.483800] systemd[1]: Starting Raise network interfaces...
  1140    [    7.514473] systemd[1]: Finished Set console font and keymap.
  1141    [    7.516491] systemd[1]: nfs-config.service: Succeeded.
  1142    [    7.518580] systemd[1]: Finished Preprocess NFS configuration.
  1143    [    7.519575] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
  1144    [    7.519669] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  1145    [    7.519756] systemd[1]: Reached target NFS client services.
  1146    [    7.538000] systemd[1]: Received SIGRTMIN+20 from PID 214 (plymouthd).
  1147    [    7.548028] systemd[1]: Started Rule-based Manager for Device Events and Files.
  1148    [    7.552320] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
  1149    [    7.559561] systemd[1]: Starting Show Plymouth Boot Screen...
  1150    [    7.676959] systemd[1]: Started Show Plymouth Boot Screen.
  1151    [    7.685667] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1152    [    7.686706] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
  1153    [    7.688656] systemd[1]: Reached target Local Encrypted Volumes.
  1154    [    7.690569] systemd[1]: Reached target Paths.
  1155    [    7.759697] systemd[1]: Finished Armbian leds state.
  1156    [    7.915450] systemd[1]: Found device /dev/ttyS0.
  1157    [    8.065058] systemd[1]: Reached target Hardware activated USB gadget.
  1158    [    8.117080] mc: Linux media interface: v0.10
  1159    [    8.190232] videodev: Linux video capture interface: v2.00
  1160    [    8.514625] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  1161    [    8.516822] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  1162    [    8.545282] zram: Added device: zram0
  1163    [    8.546185] zram: Added device: zram1
  1164    [    8.547900] zram: Added device: zram2
  1165    [    8.624553] systemd[1]: Finished Raise network interfaces.
  1166    [    8.682138] zram0: detected capacity change from 0 to 1007896
  1167    [    8.720060] Adding 503944k swap on /dev/zram0.  Priority:5 extents:1 across:503944k SSFS
  1168    [    8.945381] zram1: detected capacity change from 0 to 102400
  1169    [    9.037309] systemd[1]: Finished Armbian ZRAM config.
  1170    [    9.042681] systemd[1]: Starting Armbian memory supported logging...
  1171    [    9.126907] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  1172    [    9.126956] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1173    [   11.975541] systemd[1]: Finished Armbian memory supported logging.
  1174    [   11.984136] systemd[1]: Starting Journal Service...
  1175    [   12.185043] systemd[1]: Started Journal Service.
  1176    [   12.230126] systemd-journald[528]: Received client request to flush runtime journal.
  1177    [   12.256905] systemd-journald[528]: File /var/log/journal/0591d2673a8840eb8c934f5eaf48cb73/system.journal corrupted or uncleanly shut down, renaming and replacing.
  1178
  1179    ### armbian-release:
  1180
  1181    # PLEASE DO NOT EDIT THIS FILE
  1182    BOARD=orangepizero2
  1183    BOARD_NAME="Orange Pi Zero2"
  1184    BOARDFAMILY=sun50iw9
  1185    BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1186    BUILD_REPOSITORY_COMMIT=aa881a6ecd6
  1187    VERSION=22.08.6
  1188    LINUXFAMILY=sunxi64
  1189    ARCH=arm64
  1190    IMAGE_TYPE=stable
  1191    BOARD_TYPE=conf
  1192    INITRD_ARCH=arm64
  1193    KERNEL_IMAGE_TYPE=stable
  1194    BRANCH=edge
  1195
  1196    ### boot environment:
  1197
  1198    verbosity=1
  1199    bootlogo=false
  1200    console=serial
  1201    disp_mode=1920x1080p60
  1202    rootdev=UUID=0ae80c94-60cd-4b15-b7f3-065f13ca80b6
  1203    rootfstype=ext4
  1204    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1205
  1206    ### lsusb:
  1207
  1208    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1209    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1210
  1211    ### lscpu:
  1212
  1213    Architecture:                    aarch64
  1214    CPU op-mode(s):                  32-bit, 64-bit
  1215    Byte Order:                      Little Endian
  1216    CPU(s):                          4
  1217    On-line CPU(s) list:             0-3
  1218    Thread(s) per core:              1
  1219    Core(s) per socket:              4
  1220    Socket(s):                       1
  1221    NUMA node(s):                    1
  1222    Vendor ID:                       ARM
  1223    Model:                           4
  1224    Model name:                      Cortex-A53
  1225    Stepping:                        r0p4
  1226    BogoMIPS:                        48.00
  1227    NUMA node0 CPU(s):               0-3
  1228    Vulnerability Itlb multihit:     Not affected
  1229    Vulnerability L1tf:              Not affected
  1230    Vulnerability Mds:               Not affected
  1231    Vulnerability Meltdown:          Not affected
  1232    Vulnerability Mmio stale data:   Not affected
  1233    Vulnerability Retbleed:          Not affected
  1234    Vulnerability Spec store bypass: Not affected
  1235    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  1236    Vulnerability Spectre v2:        Not affected
  1237    Vulnerability Srbds:             Not affected
  1238    Vulnerability Tsx async abort:   Not affected
  1239    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1240
  1241    ### cpuinfo:
  1242
  1243    processor    : 0
  1244    BogoMIPS    : 48.00
  1245    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1246    CPU implementer    : 0x41
  1247    CPU architecture: 8
  1248    CPU variant    : 0x0
  1249    CPU part    : 0xd03
  1250    CPU revision    : 4
  1251
  1252    processor    : 1
  1253    BogoMIPS    : 48.00
  1254    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1255    CPU implementer    : 0x41
  1256    CPU architecture: 8
  1257    CPU variant    : 0x0
  1258    CPU part    : 0xd03
  1259    CPU revision    : 4
  1260
  1261    processor    : 2
  1262    BogoMIPS    : 48.00
  1263    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1264    CPU implementer    : 0x41
  1265    CPU architecture: 8
  1266    CPU variant    : 0x0
  1267    CPU part    : 0xd03
  1268    CPU revision    : 4
  1269
  1270    processor    : 3
  1271    BogoMIPS    : 48.00
  1272    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1273    CPU implementer    : 0x41
  1274    CPU architecture: 8
  1275    CPU variant    : 0x0
  1276    CPU part    : 0xd03
  1277    CPU revision    : 4
  1278
  1279
  1280    ### meminfo:
  1281
  1282    MemTotal:        1007892 kB
  1283    MemFree:          871392 kB
  1284    MemAvailable:     866872 kB
  1285    Buffers:           10216 kB
  1286    Cached:            43648 kB
  1287    SwapCached:            0 kB
  1288    Active:            26260 kB
  1289    Inactive:          37236 kB
  1290    Active(anon):        260 kB
  1291    Inactive(anon):    12552 kB
  1292    Active(file):      26000 kB
  1293    Inactive(file):    24684 kB
  1294    Unevictable:        2876 kB
  1295    Mlocked:               0 kB
  1296    SwapTotal:        503944 kB
  1297    SwapFree:         503944 kB
  1298    Zswap:                 0 kB
  1299    Zswapped:              0 kB
  1300    Dirty:              1620 kB
  1301    Writeback:             4 kB
  1302    AnonPages:         12564 kB
  1303    Mapped:            14340 kB
  1304    Shmem:               404 kB
  1305    KReclaimable:       7856 kB
  1306    Slab:              26796 kB
  1307    SReclaimable:       7856 kB
  1308    SUnreclaim:        18940 kB
  1309    KernelStack:        1960 kB
  1310    PageTables:         1080 kB
  1311    NFS_Unstable:          0 kB
  1312    Bounce:                0 kB
  1313    WritebackTmp:          0 kB
  1314    CommitLimit:     1007888 kB
  1315    Committed_AS:      38148 kB
  1316    VmallocTotal:   133143592960 kB
  1317    VmallocUsed:       19016 kB
  1318    VmallocChunk:          0 kB
  1319    Percpu:             1120 kB
  1320    AnonHugePages:         0 kB
  1321    ShmemHugePages:        0 kB
  1322    ShmemPmdMapped:        0 kB
  1323    FileHugePages:         0 kB
  1324    FilePmdMapped:         0 kB
  1325    CmaTotal:         131072 kB
  1326    CmaFree:          130688 kB
  1327    HugePages_Total:       0
  1328    HugePages_Free:        0
  1329    HugePages_Rsvd:        0
  1330    HugePages_Surp:        0
  1331    Hugepagesize:       2048 kB
  1332    Hugetlb:               0 kB
  1333
  1334    ### virtual memory:
  1335
  1336    vm.admin_reserve_kbytes = 8192
  1337    vm.compaction_proactiveness = 20
  1338    vm.compact_unevictable_allowed = 1
  1339    vm.dirty_background_bytes = 0
  1340    vm.dirty_background_ratio = 10
  1341    vm.dirty_bytes = 0
  1342    vm.dirty_expire_centisecs = 3000
  1343    vm.dirty_ratio = 20
  1344    vm.dirtytime_expire_seconds = 43200
  1345    vm.dirty_writeback_centisecs = 500
  1346    vm.extfrag_threshold = 500
  1347    vm.hugetlb_optimize_vmemmap = 0
  1348    vm.hugetlb_shm_group = 0
  1349    vm.laptop_mode = 0
  1350    vm.legacy_va_layout = 0
  1351    vm.lowmem_reserve_ratio = 256    256    32    0
  1352    vm.max_map_count = 65530
  1353    vm.min_free_kbytes = 22528
  1354    vm.min_slab_ratio = 5
  1355    vm.min_unmapped_ratio = 1
  1356    vm.mmap_min_addr = 4096
  1357    vm.mmap_rnd_bits = 18
  1358    vm.mmap_rnd_compat_bits = 11
  1359    vm.nr_hugepages = 0
  1360    vm.nr_hugepages_mempolicy = 0
  1361    vm.nr_overcommit_hugepages = 0
  1362    vm.numa_stat = 1
  1363    vm.numa_zonelist_order = Node
  1364    vm.oom_dump_tasks = 1
  1365    vm.oom_kill_allocating_task = 0
  1366    vm.overcommit_kbytes = 0
  1367    vm.overcommit_memory = 0
  1368    vm.overcommit_ratio = 50
  1369    vm.page-cluster = 0
  1370    vm.page_lock_unfairness = 5
  1371    vm.panic_on_oom = 0
  1372    vm.percpu_pagelist_high_fraction = 0
  1373    vm.stat_interval = 1
  1374    vm.swappiness = 100
  1375    vm.user_reserve_kbytes = 30913
  1376    vm.vfs_cache_pressure = 100
  1377    vm.watermark_boost_factor = 15000
  1378    vm.watermark_scale_factor = 10
  1379    vm.zone_reclaim_mode = 0
  1380
  1381    ### ip addr:
  1382
  1383    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1384        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1385        inet XXX.XXX.0.1/8 scope host lo
  1386           valid_lft forever preferred_lft forever
  1387        inet6 ::1/128 scope host
  1388           valid_lft forever preferred_lft forever
  1389    2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1390        link/ether 02:00:62:71:18:3b brd ff:ff:ff:ff:ff:ff
  1391
  1392    ### partitions:
  1393
  1394    major minor  #blocks  name
  1395
  1396      31        0       2048 mtdblock0
  1397     179        0   30263296 mmcblk0
  1398     179        1   29945856 mmcblk0p1
  1399     252        0     503948 zram0
  1400     252        1      51200 zram1
  1401
  1402    ### df:
  1403
  1404    udev            422M     0  422M   0% /dev
  1405    tmpfs            99M  428K   99M   1% /run
  1406    /dev/mmcblk0p1   29G  1.5G   27G   6% /
  1407    tmpfs           493M     0  493M   0% /dev/shm
  1408    tmpfs           5.0M     0  5.0M   0% /run/lock
  1409    tmpfs           493M     0  493M   0% /tmp
  1410    /dev/zram1       49M  1.4M   44M   3% /var/log
  1411
  1412    ### lsblk:
  1413
  1414    NAME        FSTYPE   SIZE MOUNTPOINT UUID
  1415    mtdblock0              2M
  1416    mmcblk0             28.9G
  1417    └─mmcblk0p1 ext4    28.6G /          0ae80c94-60cd-4b15-b7f3-065f13ca80b6
  1418    zram1                 50M /var/log
  1419
  1420    ### zramctl:
  1421
  1422    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1423    /dev/zram1 zstd           50M  1.3M 192.5K  532K       4 /var/log
  1424    /dev/zram0 lzo-rle     492.1M    4K    73B   12K       4 [SWAP]
  1425
  1426    ### mtab:
  1427
  1428    /dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1429    /dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1430    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  1431
  1432    ### mmc0:0001 info:
  1433
  1434                   fwrev: 0x0
  1435                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD32G MODALIAS=mmc:block
  1436                     cid: 27504853443332476000000596015bf1
  1437                     rca: 0x0001
  1438                     csd: 400e00325b590000e6e37f800a4000c9
  1439                  manfid: 0x000027
  1440                     ocr: 0x00200000
  1441    preferred_erase_size: 4194304
  1442                    type: SD
  1443                   hwrev: 0x6
  1444                    date: 11/2021
  1445                     dsr: 0x404
  1446              erase_size: 512
  1447                   oemid: 0x5048
  1448                  serial: 0x00000596
  1449                     ssr: 000000000500000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1450                     scr: 0285808200000000
  1451                    name: SD32G
  1452
  1453    ### Boot system health:
  1454
  1455    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  1456    18:33:07:   ---      1.34  50%  18%  13%   0%  18%   0% 40.8 °C
  1457    18:33:07:   ---      1.34  97%  37%  51%   0%   9%   0% 40.8 °C
  1458    18:33:08:   ---      1.34  96%  23%  51%   0%  20%   0% 41.6 °C
  1459    18:33:08:   ---      1.34  62%   8%  13%   0%  41%   0% 41.6 °C
  1460    18:33:08:   ---      1.34  76%   3%   2%   1%  68%   0% 41.6 °C
  1461
  1462    ### lsusb:
  1463
  1464    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1465    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1466
  1467    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1468    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1469
  1470    ### Userland:
  1471
  1472    PRETTY_NAME="Armbian 22.08.7 Bullseye"
  1473
  1474    ### Installed packages:
  1475
  1476    ii  armbian-bsp-cli-orangepizero2   22.08.6                        arm64        Armbian board support files for orangepizero2
  1477    ii  armbian-config                  22.08.6                        all          Armbian configuration utility
  1478    ii  armbian-firmware                22.08.6                        all          Linux firmware
  1479    ii  armbian-zsh                     22.08.6                        all          Armbian improved ZShell
  1480    ii  hostapd                         3:2.10-6~armbian22.02.3+1      arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  1481    ii  htop                            3.1.0-0~armbian20.08.2+1       arm64        interactive processes viewer
  1482    ii  linux-base                      4.6                            all          Linux image base package
  1483    hi  linux-dtb-edge-sunxi64          22.08.6                        arm64        Armbian Linux DTB, version 5.19.16-sunxi64 edge
  1484    hi  linux-image-edge-sunxi64        22.08.6                        arm64        Linux kernel, armbian version 5.19.16-sunxi64 edge
  1485    ii  linux-libc-dev:arm64            22.11.0-trunk.0075             arm64        Armbian Linux support headers for userspace development
  1486    hi  linux-u-boot-orangepizero2-edge 22.08.6                        arm64        Uboot loader 2022.07
  1487
  1488    ### Loaded modules:
  1489
  1490    Module                  Size  Used by
  1491    rfkill                 32768  1
  1492    lz4hc                  16384  0
  1493    lz4                    16384  0
  1494    zram                   32768  3
  1495    sunxi_cedrus           49152  0
  1496    videobuf2_dma_contig    24576  1 sunxi_cedrus
  1497    v4l2_mem2mem           36864  1 sunxi_cedrus
  1498    videobuf2_memops       20480  1 videobuf2_dma_contig
  1499    videobuf2_v4l2         24576  2 sunxi_cedrus,v4l2_mem2mem
  1500    videobuf2_common       49152  5 sunxi_cedrus,videobuf2_dma_contig,videobuf2_v4l2,v4l2_mem2mem,videobuf2_memops
  1501    videodev              204800  4 sunxi_cedrus,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  1502    mc                     49152  5 sunxi_cedrus,videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  1503    fuse                  126976  1
  1504    sunrpc                278528  1
  1505    realtek                32768  1
  1506    panfrost               65536  0
  1507    dwmac_sun8i            28672  0
  1508    gpu_sched              32768  1 panfrost
  1509    drm_shmem_helper       20480  1 panfrost
  1510    mdio_mux               16384  1 dwmac_sun8i
  1511
  1512    ### Current system health:
  1513
  1514    Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  1515    18:44:33:   ---      0.32  17%   1%  13%   0%   1%   0% 43.6 °C
  1516    18:44:33:   ---      0.32   2%   2%   0%   0%   0%   0% 43.6 °C
  1517    18:44:34:   ---      0.32   2%   1%   0%   0%   0%   0% 44.1 °C
  1518    18:44:34:   ---      0.32   3%   2%   0%   0%   0%   0% 44.1 °C
  1519    18:44:34:   ---      0.32   2%   1%   0%   1%   0%   0% 43.8 °C
  1520    18:44:38:   ---      0.70  17%   1%  14%   0%   1%   0% 47.9 °C
  1521    18:44:38:   ---      0.70  46%   0%  45%   0%   0%   0% 47.9 °C
  1522    18:44:38:   ---      0.70   2%   2%   0%   0%   0%   0% 46.1 °C
  1523    18:44:39:   ---      0.70   2%   2%   0%   0%   0%   0% 46.1 °C
  1524    18:44:39:   ---      0.70   2%   2%   0%   0%   0%   0% 46.1 °C
  1525
  1526    ### resolv.conf
  1527
  1528    -rw-r--r-- 1 root root 92 Nov 11 18:33 /etc/resolv.conf
  1529    # Generated by NetworkManager
  1530    search home
  1531    nameserver XXX.XXX.2.1
  1532    nameserver XXX.XXX.234.129
  1533
  1534    ### Current sysinfo:
  1535
  1536    Linux 5.19.16-sunxi64 (orangepizero2)     2022-11-11     _aarch64_    (4 CPU)
  1537
  1538    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  1539              14.30    0.02    1.83    1.49    0.00   82.36
  1540
  1541    Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
  1542    mtdblock0         0.07         0.28         0.00         0.00        112          0          0
  1543    mmcblk0          14.26       856.07       333.11         0.00     342427     133245          0
  1544    mmcblk0p1        14.01       850.81       333.11         0.00     340323     133245          0
  1545    zram0             1.50         5.98         0.01         0.00       2392          4          0
  1546    zram1             0.68         1.19         4.60         0.00        476       1840          0
  1547    zram2             0.00         0.00         0.00         0.00          0          0          0
  1548
  1549    --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  1550       r    b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  1551       0    0            0       451224        12980       402824    0    0   215    85  308  485  14   2  82   1   0
  1552
  1553                   total        used        free      shared  buff/cache   available
  1554    Mem:           984Mi       137Mi       440Mi       1.0Mi       406Mi       776Mi
  1555    Swap:          492Mi          0B       492Mi
  1556
  1557    NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1558    /dev/zram1 zstd           50M  1.4M 242.1K  592K       4 /var/log
  1559    /dev/zram0 lzo-rle     492.1M    4K    73B   12K       4 [SWAP]
  1560
  1561     18:44:39 up 6 min,  3 users,  load average: 0.70, 0.60, 0.30
  1562
  1563    [    1.329086] 8021q: 802.1Q VLAN Support v1.8
  1564    [    1.329243] 9pnet: Installing 9P2000 support
  1565    [    1.329329] Key type dns_resolver registered
  1566    [    1.329889] registered taskstats version 1
  1567    [    1.329912] Loading compiled-in X.509 certificates
  1568    [    1.333699] Loaded X.509 cert 'Build time autogenerated kernel key: 05920f111eead6a51cb60d55d842ed91645758e7'
  1569    [    1.336164] zswap: loaded using pool zstd/z3fold
  1570    [    1.336754] Key type ._fscrypt registered
  1571    [    1.336765] Key type .fscrypt registered
  1572    [    1.336769] Key type fscrypt-provisioning registered
  1573    [    1.337921] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
  1574    [    1.338336] Key type encrypted registered
  1575    [    1.338357] AppArmor: AppArmor sha1 policy hashing enabled
  1576    [    1.338395] ima: No TPM chip found, activating TPM-bypass!
  1577    [    1.338421] ima: Allocated hash algorithm: sha1
  1578    [    1.338466] ima: No architecture policies found
  1579    [    1.338513] evm: Initialising EVM extended attributes:
  1580    [    1.338516] evm: security.selinux
  1581    [    1.338520] evm: security.SMACK64
  1582    [    1.338523] evm: security.SMACK64EXEC
  1583    [    1.338526] evm: security.SMACK64TRANSMUTE
  1584    [    1.338530] evm: security.SMACK64MMAP
  1585    [    1.338533] evm: security.apparmor
  1586    [    1.338536] evm: security.ima
  1587    [    1.338539] evm: security.capability
  1588    [    1.338542] evm: HMAC attrs: 0x1
  1589    [    1.360713] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
  1590    [    1.362320] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator
  1591    [    1.362984] printk: console [ttyS0] disabled
  1592    [    1.363069] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 283, base_baud = 1500000) is a 16550A
  1593    [    1.363265] printk: console [ttyS0] enabled
  1594    [    1.364125] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator
  1595    [    1.364461] sun6i-spi 5010000.spi: Failed to request TX DMA channel
  1596    [    1.364472] sun6i-spi 5010000.spi: Failed to request RX DMA channel
  1597    [    1.365096] spi-nor spi0.0: supply vdd not found, using dummy regulator
  1598    [    1.381032] spi-nor spi0.0: mx25l1606e (2048 Kbytes)
  1599    [    1.397028] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
  1600    [    1.398320] ehci-platform 5200000.usb: EHCI Host Controller
  1601    [    1.398345] usb_phy_generic usb_phy_generic.1.auto: supply vcc not found, using dummy regulator
  1602    [    1.398360] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 1
  1603    [    1.398475] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests
  1604    [    1.398483] ehci-platform 5200000.usb: irq 286, io mem 0x05200000
  1605    [    1.400439] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
  1606    [    1.400869] ohci-platform 5200400.usb: Generic Platform OHCI controller
  1607    [    1.400910] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 2
  1608    [    1.400979] sunxi-rsb 7083000.rsb: RSB running at 3000000 Hz
  1609    [    1.401024] ohci-platform 5200400.usb: irq 288, io mem 0x05200400
  1610    [    1.401305] axp20x-rsb sunxi-rsb-745: AXP20x variant AXP806 found
  1611    [    1.405182] axp20x-rsb sunxi-rsb-745: AXP20X driver loaded
  1612    [    1.406465] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
  1613    [    1.406504] ALSA device list:
  1614    [    1.406512]   No soundcards found.
  1615    [    1.407495] sunxi-mmc 4020000.mmc: Got CD GPIO
  1616    [    1.412821] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
  1617    [    1.413117] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
  1618    [    1.413133] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1619    [    1.413142] usb usb1: Product: EHCI Host Controller
  1620    [    1.413149] usb usb1: Manufacturer: Linux 5.19.16-sunxi64 ehci_hcd
  1621    [    1.413157] usb usb1: SerialNumber: 5200000.usb
  1622    [    1.413737] hub 1-0:1.0: USB hub found
  1623    [    1.413791] hub 1-0:1.0: 1 port detected
  1624    [    1.433106] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1625    [    1.465043] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.19
  1626    [    1.465069] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1627    [    1.465079] usb usb2: Product: Generic Platform OHCI controller
  1628    [    1.465087] usb usb2: Manufacturer: Linux 5.19.16-sunxi64 ohci_hcd
  1629    [    1.465094] usb usb2: SerialNumber: 5200400.usb
  1630    [    1.465672] hub 2-0:1.0: USB hub found
  1631    [    1.465721] hub 2-0:1.0: 1 port detected
  1632    [    1.467038] Freeing unused kernel memory: 2496K
  1633    [    1.467836] mmc0: host does not support reading read-only switch, assuming write-enable
  1634    [    1.469607] mmc0: Problem switching card into high-speed mode!
  1635    [    1.469722] mmc0: new SDHC card at address 0001
  1636    [    1.470630] mmcblk0: mmc0:0001 SD32G 28.9 GiB
  1637    [    1.472694]  mmcblk0: p1
  1638    [    1.480880] Run /init as init process
  1639    [    1.480900]   with arguments:
  1640    [    1.480907]     /init
  1641    [    1.480912]   with environment:
  1642    [    1.480917]     HOME=/
  1643    [    1.480922]     TERM=linux
  1644    [    1.480927]     splash=verbose
  1645    [    1.480932]     ubootpart=da74ae41-01
  1646    [    1.480937]     cgroup_enable=memory
  1647    [    1.840883] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pi not found, using dummy regulator
  1648    [    1.841316] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
  1649    [    1.841340] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
  1650    [    1.841692] dwmac-sun8i 5020000.ethernet: supply phy-io not found, using dummy regulator
  1651    [    1.842000] dwmac-sun8i 5020000.ethernet: PTP uses main clock
  1652    [    1.842063] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 51fe6 (expect 50000)
  1653    [    1.846392] panfrost 1800000.gpu: clock rate = 432000000
  1654    [    1.846436] panfrost 1800000.gpu: bus_clock rate = 200000000
  1655    [    1.846926] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
  1656    [    1.846951] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
  1657    [    1.846959] dwmac-sun8i 5020000.ethernet: COE Type 2
  1658    [    1.846968] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
  1659    [    1.846976] dwmac-sun8i 5020000.ethernet: Normal descriptors
  1660    [    1.846982] dwmac-sun8i 5020000.ethernet: Chain mode enabled
  1661    [    1.850548] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
  1662    [    1.850592] panfrost 1800000.gpu: features: 00000000,000017f7, issues: 00000000,00000400
  1663    [    1.850603] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
  1664    [    1.850615] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1
  1665    [    1.857125] [drm] Initialized panfrost 1.2.0 20180908 for 1800000.gpu on minor 0
  1666    [    2.698073] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
  1667    [    4.091151] systemd[1]: System time before build time, advancing clock.
  1668    [    4.140950] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
  1669    [    4.141618] systemd[1]: Detected architecture arm64.
  1670    [    4.157085] systemd[1]: Set hostname to <orangepizero2>.
  1671    [    4.938803] systemd[255]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  1672    [    5.240894] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
  1673    [    5.456090] systemd[1]: Queued start job for default target Graphical Interface.
  1674    [    6.800801] random: crng init done
  1675    [    6.804255] systemd[1]: Created slice system-getty.slice.
  1676    [    6.806559] systemd[1]: Created slice system-modprobe.slice.
  1677    [    6.808408] systemd[1]: Created slice system-serial-getty.slice.
  1678    [    6.809997] systemd[1]: Created slice User and Session Slice.
  1679    [    6.810656] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1680    [    6.811902] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  1681    [    6.812642] systemd[1]: Reached target Slices.
  1682    [    6.813004] systemd[1]: Reached target Swap.
  1683    [    6.813277] systemd[1]: Reached target System Time Set.
  1684    [    6.831442] systemd[1]: Listening on RPCbind Server Activation Socket.
  1685    [    6.832531] systemd[1]: Listening on Syslog Socket.
  1686    [    6.833598] systemd[1]: Listening on fsck to fsckd communication Socket.
  1687    [    6.834270] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1688    [    6.835523] systemd[1]: Listening on Journal Audit Socket.
  1689    [    6.836480] systemd[1]: Listening on Journal Socket (/dev/log).
  1690    [    6.837681] systemd[1]: Listening on Journal Socket.
  1691    [    6.840507] systemd[1]: Listening on udev Control Socket.
  1692    [    6.841487] systemd[1]: Listening on udev Kernel Socket.
  1693    [    6.846376] systemd[1]: Mounting Huge Pages File System...
  1694    [    6.851622] systemd[1]: Mounting POSIX Message Queue File System...
  1695    [    6.857000] systemd[1]: Mounting RPC Pipe File System...
  1696    [    6.863557] systemd[1]: Mounting Kernel Debug File System...
  1697    [    6.864750] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  1698    [    6.865743] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  1699    [    6.874264] systemd[1]: Starting Restore / save the current clock...
  1700    [    6.880499] systemd[1]: Starting Set the console keyboard layout...
  1701    [    6.886191] systemd[1]: Starting Create list of static device nodes for the current kernel...
  1702    [    6.892105] systemd[1]: Starting Load Kernel Module configfs...
  1703    [    6.899060] systemd[1]: Starting Load Kernel Module drm...
  1704    [    6.906236] systemd[1]: Starting Load Kernel Module fuse...
  1705    [    6.912337] systemd[1]: Started Nameserver information manager.
  1706    [    6.914121] systemd[1]: Reached target Network (Pre).
  1707    [    6.953370] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  1708    [    6.953629] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1709    [    6.962301] RPC: Registered named UNIX socket transport module.
  1710    [    6.962325] RPC: Registered udp transport module.
  1711    [    6.962330] RPC: Registered tcp transport module.
  1712    [    6.962334] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1713    [    6.985174] systemd[1]: Starting Load Kernel Modules...
  1714    [    6.990748] systemd[1]: Starting Remount Root and Kernel File Systems...
  1715    [    6.996198] systemd[1]: Starting Coldplug All udev Devices...
  1716    [    7.007572] fuse: init (API version 7.36)
  1717    [    7.010404] systemd[1]: Mounted Huge Pages File System.
  1718    [    7.012317] systemd[1]: Mounted POSIX Message Queue File System.
  1719    [    7.013956] systemd[1]: Mounted RPC Pipe File System.
  1720    [    7.015239] systemd[1]: Mounted Kernel Debug File System.
  1721    [    7.017889] systemd[1]: Finished Restore / save the current clock.
  1722    [    7.020875] systemd[1]: Finished Create list of static device nodes for the current kernel.
  1723    [    7.023030] systemd[1]: modprobe@configfs.service: Succeeded.
  1724    [    7.024406] systemd[1]: Finished Load Kernel Module configfs.
  1725    [    7.026682] systemd[1]: modprobe@drm.service: Succeeded.
  1726    [    7.028198] systemd[1]: Finished Load Kernel Module drm.
  1727    [    7.031261] systemd[1]: modprobe@fuse.service: Succeeded.
  1728    [    7.033449] systemd[1]: Finished Load Kernel Module fuse.
  1729    [    7.043000] systemd[1]: Mounting FUSE Control File System...
  1730    [    7.048534] systemd[1]: Mounting Kernel Configuration File System...
  1731    [    7.054017] systemd[1]: Finished Load Kernel Modules.
  1732    [    7.064287] systemd[1]: Mounted FUSE Control File System.
  1733    [    7.065935] systemd[1]: Mounted Kernel Configuration File System.
  1734    [    7.072476] systemd[1]: Starting Apply Kernel Variables...
  1735    [    7.096997] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
  1736    [    7.104404] systemd[1]: Finished Remount Root and Kernel File Systems.
  1737    [    7.114106] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
  1738    [    7.114483] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1739    [    7.119873] systemd[1]: Starting Load/Save Random Seed...
  1740    [    7.126176] systemd[1]: Starting Create System Users...
  1741    [    7.156972] systemd[1]: Finished Apply Kernel Variables.
  1742    [    7.192934] systemd[1]: Finished Load/Save Random Seed.
  1743    [    7.194158] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  1744    [    7.218789] systemd[1]: Finished Create System Users.
  1745    [    7.225388] systemd[1]: Starting Create Static Device Nodes in /dev...
  1746    [    7.299084] systemd[1]: Finished Create Static Device Nodes in /dev.
  1747    [    7.308153] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  1748    [    7.418174] systemd[1]: Finished Set the console keyboard layout.
  1749    [    7.419418] systemd[1]: Reached target Local File Systems (Pre).
  1750    [    7.425709] systemd[1]: Mounting /tmp...
  1751    [    7.429129] systemd[1]: Finished Coldplug All udev Devices.
  1752    [    7.437192] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  1753    [    7.442963] systemd[1]: Mounted /tmp.
  1754    [    7.444107] systemd[1]: Reached target Local File Systems.
  1755    [    7.449648] systemd[1]: Starting Armbian leds state...
  1756    [    7.454895] systemd[1]: Starting Armbian ZRAM config...
  1757    [    7.461389] systemd[1]: Starting Set console font and keymap...
  1758    [    7.466960] systemd[1]: Starting Preprocess NFS configuration...
  1759    [    7.473497] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
  1760    [    7.474034] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1761    [    7.474348] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1762    [    7.477359] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  1763    [    7.483800] systemd[1]: Starting Raise network interfaces...
  1764    [    7.514473] systemd[1]: Finished Set console font and keymap.
  1765    [    7.516491] systemd[1]: nfs-config.service: Succeeded.
  1766    [    7.518580] systemd[1]: Finished Preprocess NFS configuration.
  1767    [    7.519575] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
  1768    [    7.519669] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  1769    [    7.519756] systemd[1]: Reached target NFS client services.
  1770    [    7.538000] systemd[1]: Received SIGRTMIN+20 from PID 214 (plymouthd).
  1771    [    7.548028] systemd[1]: Started Rule-based Manager for Device Events and Files.
  1772    [    7.552320] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
  1773    [    7.559561] systemd[1]: Starting Show Plymouth Boot Screen...
  1774    [    7.676959] systemd[1]: Started Show Plymouth Boot Screen.
  1775    [    7.685667] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1776    [    7.686706] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
  1777    [    7.688656] systemd[1]: Reached target Local Encrypted Volumes.
  1778    [    7.690569] systemd[1]: Reached target Paths.
  1779    [    7.759697] systemd[1]: Finished Armbian leds state.
  1780    [    7.915450] systemd[1]: Found device /dev/ttyS0.
  1781    [    8.065058] systemd[1]: Reached target Hardware activated USB gadget.
  1782    [    8.117080] mc: Linux media interface: v0.10
  1783    [    8.190232] videodev: Linux video capture interface: v2.00
  1784    [    8.514625] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
  1785    [    8.516822] cedrus 1c0e000.video-codec: Device registered as /dev/video0
  1786    [    8.545282] zram: Added device: zram0
  1787    [    8.546185] zram: Added device: zram1
  1788    [    8.547900] zram: Added device: zram2
  1789    [    8.624553] systemd[1]: Finished Raise network interfaces.
  1790    [    8.682138] zram0: detected capacity change from 0 to 1007896
  1791    [    8.720060] Adding 503944k swap on /dev/zram0.  Priority:5 extents:1 across:503944k SSFS
  1792    [    8.945381] zram1: detected capacity change from 0 to 102400
  1793    [    9.037309] systemd[1]: Finished Armbian ZRAM config.
  1794    [    9.042681] systemd[1]: Starting Armbian memory supported logging...
  1795    [    9.126907] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
  1796    [    9.126956] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
  1797    [   11.975541] systemd[1]: Finished Armbian memory supported logging.
  1798    [   11.984136] systemd[1]: Starting Journal Service...
  1799    [   12.185043] systemd[1]: Started Journal Service.
  1800    [   12.230126] systemd-journald[528]: Received client request to flush runtime journal.
  1801    [   12.256905] systemd-journald[528]: File /var/log/journal/0591d2673a8840eb8c934f5eaf48cb73/system.journal corrupted or uncleanly shut down, renaming and replacing.
  1802    [   15.081417] systemd-journald[528]: Received client request to relinquish /var/log/journal/0591d2673a8840eb8c934f5eaf48cb73 access.
  1803    [   19.029930] phy_rtl8211f_led_fixup in
  1804    [   19.120890] dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
  1805    [   19.122058] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
  1806    [   19.122826] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found
  1807    [   19.122844] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available
  1808    [   19.122853] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW
  1809    [   19.123436] dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii link mode
  1810    [   23.238199] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
  1811    [   23.238266] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  1812    [   31.717022] cldo1: disabling
  1813
  1814
  1815
  1816    ### interrupts:
  1817               CPU0       CPU1       CPU2       CPU3
  1818     11:      26070      31515      19988      15365     GICv2  30 Level     arch_timer
  1819     14:          0          0          0          0     GICv2 172 Level     arm-pmu
  1820     15:          0          0          0          0     GICv2 173 Level     arm-pmu
  1821     16:          0          0          0          0     GICv2 174 Level     arm-pmu
  1822     17:          0          0          0          0     GICv2 175 Level     arm-pmu
  1823     18:          0          0          0          0     GICv2 133 Level     7000000.rtc
  1824    161:          0          0          0          0  sunxi_pio_edge 134 Edge      4020000.mmc cd
  1825    283:        831          0          0          0     GICv2  32 Level     ttyS0
  1826    284:       9690          0          0          0     GICv2  44 Level     sun6i-spi
  1827    285:       1594          0          0          0     GICv2  51 Level     ths
  1828    286:          0          0          0          0     GICv2  60 Level     ehci_hcd:usb1
  1829    287:          0          0          0          0     GICv2  57 Level     musb-hdrc.2.auto
  1830    288:          0          0          0          0     GICv2  61 Level     ohci_hcd:usb2
  1831    289:         23          0          0          0     GICv2 141 Level     sunxi-rsb
  1832    290:       3183          0          0       7453     GICv2  67 Level     sunxi-mmc
  1833    291:       2964          0          0          0     GICv2  46 Level     eth0
  1834    292:          2          0          0          0     GICv2 129 Level     panfrost-gpu
  1835    293:          0          0          0          0     GICv2 128 Level     panfrost-mmu
  1836    294:          0          0          0          0     GICv2 127 Level     panfrost-job
  1837    295:          0          0          0          0     GICv2 125 Level     1c0e000.video-codec
  1838    IPI0:      1307       1862       1173       1202       Rescheduling interrupts
  1839    IPI1:     31059     125571     124519      86335       Function call interrupts
  1840    IPI2:         0          0          0          0       CPU stop interrupts
  1841    IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  1842    IPI4:         0          0          0          0       Timer broadcast interrupts
  1843    IPI5:         0          0          0          0       IRQ work interrupts
  1844    IPI6:         0          0          0          0       CPU wake-up interrupts
  1845    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
  On 11/12/2022 at 5:18 PM, mantouboji said:
It'true , because none to port DTS from SUNXI to mainline source.
In the latest 6.0.x kernel, even all USB its stuff has lost. why?
Expand
I am also trying to bring up all the hardware components but in Yocto and so far I managed to enable Ethernet. I also noticed that a lot o things have been cropped out from the device tree in Kernel 6.0.x. Do you have perhaps a link to the device tree that contains everything that is needed to bring up eg wifi?
Edited by pprdr
For me it's quite a mess when it comes with Orange Pi Zero 2, Does anybody know where I can find Linux sources (doesn't matter which kernel version) for a wifi driver?
Edited by pprdr
Expand
wifi driver & dts available here
There has been some movement, not sure where it is in the pipeline.  https://armbian.atlassian.net/browse/AR-1396
For giggles, I tried Armbian_23.02.0-trunk.0130_Orangepizero2_jammy_edge_6.1.2.img.xz   which was compiled a few hours ago, and it did *not* have a wlan0 interface upon boot.   I'm not great with github, so I'm not sure how to track the above issue to a downloadable build.
Like others, I have tried Orangepizero2_3.0.6_debian_bullseye_server_linux5.16.17.img from the manufacturer site and it works, but I'd rather support this project.  Anyway, just a datapoint.
Expand
I can understand you have good intentions, so thank you, but do you really think you (and community at large) are supporting this project in any way or it is perhaps the other way around? https://liberapay.com/armbian
If you report a bug in software that you have downloaded for free, developers (you don't support), maintainers (you don't support) and support staff (you don't support) just looses more of their precious time and more of their private money. Development and fixing of those things is hard and time consuming work.
Vendors that sold you hardware together are also unable to provide you quality software with their small sales margin and competition.
FYI.
Well, that escalated quickly.
I recieved one of these devices a few days ago, discovered this project, and wanted to join the discussion by adding my own findings.  This was my first post on the 'community forums'.
Judging from the tone of the above comment any dialog isn't welcome.
On a side note, I was employed by a software company from the startup phase through venture capital investments and eventual IPO. Even in the early days, our team focused on messaging to and from the community, as that foundation led to our success.
Best of luck.
Expand
Just keep it on community level - you are a peer at best, not a customer. If you want that someone do your homework, trade, provide a compensation. Keeping this project alive, without helping you, costs. Developers are fully aware of troubles, but the problem is that resources are 1/1000 of needed. We are shooting monsters with slingshots, while you remain blind and ignorant no matter what is sent your way.
Expand
Your startup dug lets say 5M EUR of starting capital which you waste to develop software that anyone can download for free and you also support it for free until you ran out money? I am sure you were not that stupid.
Expand
This is automated test report from a few days ago:
  Reveal hidden contents
It is called "smoke test". It power boards on, checks basic functions following by reboot and powers off when done. And record few things ...  We can run this at any moment and the plan is that it runs automatically at every code change.
If end users refuse to fund software development and you do, perhaps rather help where project is asking for help? We are also asking for help developing this test system, which saves us a lot of time, or armbian-configurator, which saves you a lot of time, for several years now. Nice way or with applying a pressure (as now). Nothing. Cash to code with pros? Nothing. At least for things you want and need (problem from this topic) and you can't just steal from someone / download for free? Nothing.
Back to topic? Who will spent several weeks digging into this driver? Biggest frustration is that I can't give that person anything, not even a comfort: "Its a hard work, there is a big possibility of failure and you will get no compensation because users do not respect this work or you". While our competitors will tell: "Dear John, we are working hard to solve this problem for you. You are important to us. It will probably take several months", while they will be opening a bug to us and applying a constant pressure. Welcome to the dark side of the FOSS projects.
Expand
Don't worry, we weren't that stupid, and I wish it were that simple.  The years I spent at Tenable ( Nasdaq: TENB ) taught me a lot, and I'm aware of the hard work required to get everything off the ground and transition from OSS to profit. I'm semi-retired at this point, so my Network/Systems Engineering skills and interest are a few years out of date, otherwise I would make a play for 'Board Maintainer' on OPiz2.
Just to be clear - my original post wasn't intended to take you from your duties, I thought it was a community board and maybe another kind soul could steer me in the direction to track progress, or point to a different branch to test.
The Liberapay site claims "armbian receives €26.56 per week from 24 patrons."   So ... if I mimic some of the guys donating €0.25/week can I make forum posts?  Just kidding!
Anyway, best of luck. No further comments from me.
Edited by sclebo05
minor verbiage tweak
Expand
Profit is that sweet deal when you cover costs. Community / amateurs rarely work on boring cases that last weeks or months to finish in exchange for absolutely nothing, not even satisfaction of helping people as nobody will notice or understand their sacrifice. You can bump into the people, this community is full of them, that will help you with extremely valuable advise or hint - most things are solved for free. By us, by community. But you also want that hard things are solved for free and here things stops, sometimes brutally. In most cases they don't progress as they are costly in technical and organisational sense. If you treat this project with 20 or 200 USD per week, while we need 5000 USD per day to match costs, we are very very far apart.
Most used business model to profit in OSS is to steal from someone and sign below. Nobody will sue you as its too complicated and how a non-profit can allocate money for that? Certain % of people will fill sick, some will complain and point towards dirty players, while you / end users just want to have free fun.
Expand
This seems to be pretty typical profile around here ;) I could point myself close to that, except that I am using my experiences and skills to progress this project. Alongside with others.
