I have Orange Pi Plus 2 running Ubuntu Bionic with Armbian Linux 4.19.62-sunxi and I would like to upgrade it to recent Armbian build based on Ubuntu Linux Server and move OS to SSD connected to one of USB ports.
I tried to use Armbian_22.08.2_Orangepiplus_jammy_current_5.15.69.img.xz but it does not connect to both HDMI and network.
I tried unofficial command line interface images from product page and weekly released unsupported community builds.
Behavior of all these builds is the same - no output to HDMI, no network connection.
Finaly I found that recent image for Orange Pi Plus / Plus 2 which boots is Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63.img.xz.
 I was able to boot from this image and transfer OS to SSD but running "apt update" and "apt upgrade" breaks something in operating system even if Kernel is "frozen" using armbian-config utility.
After upgrade OS does not recognize usb-to-serial adapter CH341 connected to one of USB ports.
Amout of loaded Kernel modules essentially decrease:
orangepiplus:~:# lsmod
pwrseq_simple          16384  1
sy8106a_regulator      16384  0
gpio_keys              20480  0
uas                    24576  1
realtek                24576  1
orangepiplus:~:#
Attempt to load module using modprobe fails:
orangepiplus:~:# modprobe usbserial vendor=1a86 product=7523
modprobe: FATAL: Module usbserial not found in directory /lib/modules/5.15.63-sunxi
orangepiplus:~:#
It looks like kernel modules were upgraded by running "apt update" and "apt upgrade" although Kernel was "frozen" using armbian-config utility. There is no 5.15.63-sunxi folder in /lib/modules:
orangepiplus:~:# ls -la /lib/modules/
total 12
drwxr-xr-x  3 root root 4096 Nov 14 21:04 .
drwxr-xr-x 76 root root 4096 Nov 14 20:31 ..
drwxr-xr-x  3 root root 4096 Nov 14 20:31 5.15.74-sunxi
orangepiplus:~:#
Adding sym link to upgraded modules does not help. Load module fails due to exec format error:
orangepiplus:~:# ln -s /lib/modules/5.15.74-sunxi /lib/modules/5.15.63-sunxi
total 12
drwxr-xr-x  3 root root 4096 Nov 14 20:45 .
lrwxrwxrwx  1 root root   26 Nov 14 20:45 5.15.63-sunxi -> /lib/modules/5.15.74-sunxi
orangepiplus:~:#
modprobe: ERROR: could not insert 'usbserial': Exec format error
orangepiplus:~:#
All modules in /lib/modules before and after running "apt update" and "apt upgrade" are compressed and have extension ".xz".
It looks like upgraded Kernel has no ability to load compressed modules.
I understand that Orange Pi Plus / Plus 2 is not supported anymore but is it possible to check if Kernels newer then 5.15.63 were compiled with "CONFIG_MODULE_COMPRESS=y" and "CONFIG_MODULE_COMPRESS_XZ=y"?
Thanks,
Sergey
Edited by ls819011
It was a good idea to connect to serial interface of the Orabnge Pi board to see what is going on during boot.
Here is output of last image for Orange Pi Plus / Plus 2 which successfuly boot - Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.11.18 11:19:02 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2021.10-armbian (Aug 30 2022 - 06:51:06 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
U-Boot 2021.10-armbian (Aug 30 2022 - 06:51:06 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Plus / Plus 2
DRAM:  2 GiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface7
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1d000: USB EHCI 1.00
scanning bus usb@1c1b000 for devices... 4 USB Device(s) found
scanning bus usb@1c1d000 for devices... Device NOT ready
   Request Sense returned 02 3A 00
2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3964 bytes read in 3 ms (1.3 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
153 bytes read in 3 ms (49.8 KiB/s)
12601176 bytes read in 531 ms (22.6 MiB/s)
8382896 bytes read in 355 ms (22.5 MiB/s)
33404 bytes read in 15 ms (2.1 MiB/s)
4185 bytes read in 17 ms (240.2 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0x7fe9b0 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Data Size:    12601112 Bytes = 12 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 493fb000, end 49fff718 ... OK
   Loading Device Tree to 4938a000, end 493fafff ... OK
Starting kernel ...
[   13.170022] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[   13.533010] mtd device must be supplied (device name is empty)
[   14.739493] debugfs: File 'Capture' in directory 'dapm' already present!
[   14.902024] mtd device must be supplied (device name is empty)
orangepiplus login: root (automatic login)
Waiting for system to finish booting ...
Welcome to ARMBIAN!
Documentation: https://docs.armbian.com | Community: https://forum.armbian.com
Create root password:
All command line interface images newer then 22.08.1 which I tried does not boot.
Behavior looks similar for all of them: board does not connect HDMI and Ethernet, LED on the board lights green and blinks once per 4-5 seconds.
Output to serial interface is also similar. The difference is only in image build time in couple of lines in the beginning of output loops.
The following images were tested:
Armbian_22.08.2_Orangepiplus_bullseye_current_5.15.69.img.xz
Armbian_22.08.2_Orangepiplus_sid_edge_5.19.10.img.xz
Armbian_22.11.0-trunk_Orangepiplus_kinetic_edge_6.0.7.img.xz
Armbian_22.11.0-trunk_Orangepiplus_sid_edge_6.0.7.img.xz
Armbian_22.11.0_Orangepiplus_bullseye_current_5.15.79.img.xz
Armbian_22.11.0_Orangepiplus_jammy_current_5.15.79.img.xz
Here is output of last image in the list above:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.11.18 11:52:33 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot SPL 2022.07-armbian (Nov 16 2022 - 23:27:28 +0000)
DRAM: 2048 MiB
U-Boot 2022.07-armbian (Nov 16 2022 - 23:27:28 +0000) Allwinner Technology
DRAM:  2 GiB
Core:  65 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface9
starting USB...
prefetch abort
pc : [<fffefffa>]       lr : [<bffaa4b3>]
reloc pc : [<8a067ffa>]       lr : [<4a0224b3>]
sp : b8a99728  ip : bbf95008     fp : bffdec47
r10: fffeffff  r9 : bbf67ec0     r8 : b8a99780
r7 : 00000000  r6 : 00000001     r5 : e59ff014  r4 : 00000000
r3 : b8a99780  r2 : 00000001     r1 : 00000000  r0 : e59ff014
Flags: nzcv  IRQs off  FIQs off  Mode SVC_32 (T)
Code: 0000 0000 0000 0000 (0000) 0000
Resetting CPU ...
resetting ...
Attached is archive of boot logs of images mentioned above.
Images later 22.08.1 which does not boot have the same but different to 22.08.1 version of U-Boot.
So, the question now is: is there everything Ok with U-Boot in Orange Pi Plus / Plus 2 images later then 22.08.1?
20221118-orangepiplus-boot-logs.zip
Edited by ls819011
I was able to boot my Orange Pi Plus 2 using Armbian 22.11.1 Jammy but only after replacing boot loader with boot loader from working image 22.08.1.
Here is a procedure of replacing boot loader:
1) Get root privilegies, make directory for doing a job and change working directory:
sudo -i
mkdir <whatever_you_want>
cd <whatever_you_want>
2) Download recent working image, unpack it, save boot loader and remove image:
wget https://archive.armbian.com/orangepiplus/archive/Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63.img.xz
unxz -d Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63.img.xz
dd if=Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63.img of=armbian_bootloader.bin bs=512 count=8192
rm Armbian_22.08.1_Orangepiplus_jammy_current_5.15.63.img
3) Download recent non-working image, unpack it, associate image with loop device:
wget https://dl.armbian.com/orangepiplus/archive/Armbian_22.11.1_Orangepiplus_jammy_current_5.15.80.img.xz
unxz -d Armbian_22.11.1_Orangepiplus_jammy_current_5.15.80.img.xz
losetup -P -f Armbian_22.11.1_Orangepiplus_jammy_current_5.15.80.img
4) You can run losetup command without parameters to see loop device which image is associated with.
5) Backup image partition table, replace boot loader, restore partition table, remove loop device, compress image (replace "loop#" with actual device name):
sfdisk --dump /dev/loop# >partition_table_backup.txt
dd if=armbian_bootloader.bin of=/dev/loop# bs=512 count=8192
sfdisk /dev/loop# <partition_table_backup.txt
losetup -d /dev/loop#
unxz -z Armbian_22.11.1_Orangepiplus_jammy_current_5.15.80.img
Solution is to set to previous boot loader in a board config, similar to those.
I have Orange Pi Plus 2,
I tested with Orange Pi Plus 2E image, And sort of functions works.
Wifi and WAN works, HDMI works... but USB did not work properly.
It's critical problem...
I think can be port a '2E patch' for Plus 2, but I'm not professional about Armbian and Linux...
Anyway, You need to apt-hold bootloader package for blocking automatic bootloader upgrade.
If you can boot Orange Pi Plus / 2 successfully, type this on you shell;
sudo apt-mark hold linux-u-boot-orangepiplus-current
TIP) You can upgrade to latest armbian from 22.08.1 image directly.
Install 22.08.1 Image, type `sudo apt-mark hold linux-u-boot-orangepiplus-current`, and type `sudo apt update && sudo apt upgrade -y`.
Edited by Choryu Park
Hello, has anyone an image that works ? .. can anyone provide a link.?
interested only on uart's usbs and sd-card.
I actually managed using tutorial provided above by ls819011 to make a bootable image .. usig latest Armbian 23.8 Bookworm Kernel 6.2.y,  and   Armbian_23.5.1_Orangepiplus2e_bookworm_current_6.1.30_minimal.img to extract boot loader .. but functionality is affected ..usb aren't detected and also uart's arent working.
Thanks. in advance,
Regards.
