zador.blood.stained Posted October 19, 2016 Posted October 19, 2016 However, EDID dump is a bit misterious (a bit short comparing to dmesg edid output), but this may be bug in the driver. I guess that interlaced resolutions may need multiplication, but first let's make prefered EDID mode working. BTW, I can try to make EDID dumps from a PC or a laptop if you need a comparison.
jernej Posted October 19, 2016 Posted October 19, 2016 BTW, I can try to make EDID dumps from a PC or a laptop if you need a comparison. That would be most helpful, thanks.
zador.blood.stained Posted October 19, 2016 Posted October 19, 2016 Added new dumps, TV one looks the same except for zeroes at the end, 1280x1024 monitor is probably affected by HDMI-VGA converter since connecting via this converter adds additional data at the end of sysfs "file".
jernej Posted October 19, 2016 Posted October 19, 2016 Yes, they seems to be correct, but still resolutions at the end for 1280x1024 monitor seems off. Can you check which supported resolutions are reported if you connect it throug HDMI adapter and which when you connect directly. It seems that VGA converter adds additional info, which is not correctly formed. I guess that xrandr should report all of them.
zador.blood.stained Posted October 19, 2016 Posted October 19, 2016 When I connected DVI -> HDMI-VGA converter -> VGA monitor, it resulted in "Unsupported resolution" BTW. Same monitor reports these supported modes when connected directly to another PC: 720 X 400 70 Hz 640 X 480 60 Hz 640 X 480 75 Hz 800 X 600 60 Hz 800 X 600 75 Hz 1024 X 768 60 Hz 1024 X 768 70 Hz 1024 X 768 75 Hz 1280 X 1024 60 Hz 1280 X 1024 75 Hz
jernej Posted October 20, 2016 Posted October 20, 2016 Here is another OPiPC test image: https://transfer.sh/JxiVl/openelec-h3.arm-7.0-devel-20161020202145-r23108-g97f809b-opipc.img.gz Framebuffer size is still 1920x1080 in size, but only the portion corresponding to HDMI resolution is used. That reminds me, EDID resolutions, which are too big, must be discarded...
zador.blood.stained Posted October 20, 2016 Posted October 20, 2016 Here is another OPiPC test image: https://transfer.sh/JxiVl/openelec-h3.arm-7.0-devel-20161020202145-r23108-g97f809b-opipc.img.gz Log and picture uploaded to the same Dropbox folder
jernej Posted October 20, 2016 Posted October 20, 2016 What about boot screen? Does it have right proportions, e.g. nicely centered? Can you also please check which resolution is reported in "System Info" in Kodi?
zador.blood.stained Posted October 20, 2016 Posted October 20, 2016 What about boot screen? Does it have right proportions, e.g. nicely centered? Can you also please check which resolution is reported in "System Info" in Kodi? No, boot logo was shifted to the right. Not sure about proportions, if you replace it with some squares or a mesh, it would be easier to tell that square turns into a rectangle. I'm not sure I can navigate Kodi with this resolution/quality, I never used it before. If you don't make a new image, I'll try to do this on TV where output should at least have the right proportions. Edit: Kodi reports 1280x1024@60Hz (on this monitor)
jernej Posted October 20, 2016 Posted October 20, 2016 No need, boot logo is great indicator if everything is fine. Kodi needs some additional code to get screen width and height, which may be wrong. Maybe I used wrong term - proportions is not the right word, because image should stretch to full screen. I meant if it looks ok. Last request before I dive into the code again. Please upload kodi log located at /storage/.kodi/temp/kodi.log
zador.blood.stained Posted October 20, 2016 Posted October 20, 2016 No need, boot logo is great indicator if everything is fine. Kodi needs some additional code to get screen width and height, which may be wrong. Maybe I used wrong term - proportions is not the right word, because image should stretch to full screen. I meant if it looks ok. I mean boot logo seems to have correct or close to correct proportions (doesn't look stretched vertically or horizontally), but it is touching the right screen border (I can make a photo if you need it), while Kodi interface is touching the left border. Kodi logs uploaded.
jernej Posted October 20, 2016 Posted October 20, 2016 I mean boot logo seems to have correct or close to correct proportions (doesn't look stretched vertically or horizontally), but it is touching the right screen border (I can make a photo if you need it) Please do.
jernej Posted October 20, 2016 Posted October 20, 2016 That means that something still reports 1920x1080 screen size.
zador.blood.stained Posted October 20, 2016 Posted October 20, 2016 That means that something still reports 1920x1080 screen size. I believe yesterdays image displayed 2 boot logos side by side Edit: Checked, previous image shows top parts of 2 logos stretched vertically. Uploaded a photo of this
jernej Posted October 20, 2016 Posted October 20, 2016 I just figured it out. Taking shortcuts rarely pays off, so I need to do this fb screen size setting differently. Zador, thanks for all your help.
jernej Posted October 22, 2016 Posted October 22, 2016 zador, please test this image: https://transfer.sh/csfbi/openelec-h3.arm-7.0-devel-20161022185621-r23108-g97f809b-opipc.img.gz
zador.blood.stained Posted October 22, 2016 Posted October 22, 2016 Image quality in Kodi is better than previously, but boot logo is displayed in the right part of the screen and Kodi is displayed in the left part (same as before) Dmesg log uploaded Edit: Quickly tested on 720p, and it looks like center of the boot logo is exactly close to the bottom right corner of the screen
@lex Posted October 22, 2016 Posted October 22, 2016 only thing interface is greyed in guvcview and i load manually gc2035 camera driver and vie_v4l2 Fixed, the Gui Gtk3 starts correctly with any available win sizes for the sensor and you can change resolutions on the fly, seems now much more usable, please, recompile it and try: https://github.com/avafinger/guvcview to load the driver automagically, add the two lines in the /etc/modules
jernej Posted October 23, 2016 Posted October 23, 2016 Uploaded photos for 720p Ok, now I'm confused, why this still doesn't work. Can you also upload content of "/sys/class/disp/disp/attr/sys"?
zador.blood.stained Posted October 23, 2016 Posted October 23, 2016 OpenELEC:~ # cat /sys/class/disp/disp/attr/sys screen 0: hdmi output mode(255) fps:55.5 1280x1024 under_flow:0 skip:0 irq:7725 BUF enable ch[1] lyr[0] z[0] prem[N] a[globl 255] fmt[ 0] fb[1920,1080;1920,1080;1920,1080] crop[ 0,1080,1920,1080] frame[ 0, 0,1280,1024] addr[50200000, 0, 0] flags[0x 0] trd[0,0] acquire: 0, 25.5 fps release: 0, 25.5 fps display: 0, 25.5 fps OpenELEC:~ # fbset mode "1920x1080-0" # D: 0.000 MHz, H: 0.000 kHz, V: 0.000 Hz geometry 1920 1080 1920 2160 32 timings 0 0 0 0 0 0 0 accel false rgba 8/16,8/8,8/0,8/24 endmode OpenELEC:~ #
jernej Posted October 25, 2016 Posted October 25, 2016 Please test this: https://transfer.sh/CBnwJ/openelec-h3.arm-7.0-devel-20161025231458-r23111-g2d8f6bd-opipc.img.gz It should work, except boot logo will be funny. I guess that boot logo reads out old informations... Anyway, this video driver is so bloated, that I will probably lose interest for some time (I will commit changes to github before that). I think it is much better to invest all this time to mainline kernel or U-Boot.
zador.blood.stained Posted October 26, 2016 Posted October 26, 2016 Please test this: https://transfer.sh/CBnwJ/openelec-h3.arm-7.0-devel-20161025231458-r23111-g2d8f6bd-opipc.img.gz OK, this works, apart from some minor issues unrelated to EDID / screen resolution.
jernej Posted October 26, 2016 Posted October 26, 2016 apart from some minor issues unrelated to EDID / screen resolution. like what?
zador.blood.stained Posted October 26, 2016 Posted October 26, 2016 like what? systemd-modules-load.service is reported as "failed" during boot, and shutdown from Kodi menu hangs (leaves a frozen Kodi screen, lit red LED and blinking network LEDs, and doesn't turn the display off), while "poweroff" from serial console finishes normally.
jernej Posted October 26, 2016 Posted October 26, 2016 ok, systemd can't load CEC driver, which is not included in this test image. Shutdown in Kodi is actually sleep, which might be related to hacked display driver or if you have USB hub connected with additional devices. So nothing out of the ordinary. Sleep works ok on normal image (apart this usb hub issue). Do you see any interest to use such feature on Armbian? I mean edid modes.
zador.blood.stained Posted October 26, 2016 Posted October 26, 2016 ok, systemd can't load CEC driver, which is not included in this test image. Shutdown in Kodi is actually sleep, which might be related to hacked display driver or if you have USB hub connected with additional devices. So nothing out of the ordinary. Sleep works ok on normal image (apart this usb hub issue). No hubs, only Logitech Unifying receiver, which is a composite device emulating a keyboard and a mouse (or 2 mice, don't remember if old mouse is still paired with this receiver). You can find it in my old dmesg logs, and there was no issues with it in previous images.
zador.blood.stained Posted October 26, 2016 Posted October 26, 2016 Do you see any interest to use such feature on Armbian? I mean edid modes. Yes. And maybe it will work on Pine64 too, if disp2 driver there doesn't have too much differences. Just to be sure, does this automatically add support for any exotic resolutions (supported by hardware), or still limited to predefined ones in the driver?
