I use the desktop version of Legacy with my Cubietruck. My problem is that I can’t launch Kodi. I installed it with 'sudo apt-get install kodi' but If I start the program I have a black screen and then kodi is closed.
I reinstalled Kodi and updated the system. But the problem was not solve.
Have anyone an idea how I can solve this problem?
I haven't saw a solution to this yet. Chances to run Kodi on A10/A20 within Debian / Ubuntu are slim, perhaps it can run on Android but I am not sure if any Android is stable / good enough for daily usage.
The only (Allwinner based chip) working KODI is within Openelec but on H3 boards only.
@Cubietruck,
Please search for kodi log and upload it. I think it is located at /home/<username>/.kodi/temp But even if we manage to get it running, it won't be HW accelerated. For that you need modified Kodi. mosterta (https://github.com/mosterta) is trying to do that for A10/A20 boards. I don't have such board, so you should ask him for help. Usually, he can be found on IRC - #linux-sunxi channel on freenode.
I had found two log files.
The first file is called 'kodi.old_1793118617.log' and the second file 'kodi_-1102397886.log'.
This are the information of 'kodi_-1102397886.log' file.
21:33:57 T:2954948608  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:33:57 T:2954948608  NOTICE: -----------------------------------------------------------------------
21:33:57 T:2954948608  NOTICE: Starting Kodi from Debian (16.1 Debian package version: 16.1+dfsg1-2~bpo8+1). Platform: Linux ARM (Thumb) 32-bit
21:33:57 T:2954948608  NOTICE: Using Release Kodi from Debian x32 build
21:33:57 T:2954948608  NOTICE: Kodi from Debian compiled from 16.1+dfsg1-2~bpo8+1 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.36 (200740)
21:33:57 T:2954948608  NOTICE: Running on Debian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 3.4.112-sun7i
21:33:57 T:2954948608  NOTICE: FFmpeg version: 3.1.3-1~bpo8+1
21:33:57 T:2954948608  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 2 cores available
21:33:57 T:2954948608  NOTICE: ARM Features: Neon disabled
21:33:57 T:2954948608  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:33:57 T:2954948608  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
21:33:57 T:2954948608  NOTICE: special://masterprofile/ is mapped to: /home/raik/.kodi/userdata
21:33:57 T:2954948608  NOTICE: special://home/ is mapped to: /home/raik/.kodi
21:33:57 T:2954948608  NOTICE: special://temp/ is mapped to: /home/raik/.kodi/temp
21:33:57 T:2954948608  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
21:33:57 T:2954948608  NOTICE: Local hostname: cubietruck
21:33:57 T:2954948608  NOTICE: Log File is located: /home/raik/.kodi/temp/kodi.log
21:33:57 T:2954948608   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
21:33:57 T:2954948608  NOTICE: load settings...
21:33:57 T:2954948608  NOTICE: Found 1 Lists of Devices
21:33:57 T:2954948608  NOTICE: Enumerated PULSE devices:
21:33:57 T:2954948608  NOTICE:     Device 1
21:33:57 T:2954948608  NOTICE:         m_deviceName      : Default
21:33:57 T:2954948608  NOTICE:         m_displayName     : Default
21:33:57 T:2954948608  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
21:33:57 T:2954948608  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
21:33:57 T:2954948608  NOTICE:         m_channels        : FL,FR
21:33:57 T:2954948608  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
21:33:57 T:2954948608  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
21:33:57 T:2954948608  NOTICE:     Device 2
21:33:57 T:2954948608  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-codec.analog-stereo
21:33:57 T:2954948608  NOTICE:         m_displayName     : sunxi-CODEC Analog Stereo
21:33:57 T:2954948608  NOTICE:         m_displayNameExtra: Analog Output (PULSEAUDIO)
21:33:57 T:2954948608  NOTICE:     Device 3
21:33:57 T:2954948608  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndi2s.0.analog-stereo
21:33:57 T:2954948608  NOTICE:         m_displayName     : sunxi-sndi2s Analog Stereo
21:33:57 T:2954948608  NOTICE:     Device 4
21:33:57 T:2954948608  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndspdif.0.analog-stereo
21:33:57 T:2954948608  NOTICE:         m_displayName     : sunxi-sndspdif Analog Stereo
21:33:57 T:2954948608  NOTICE:     Device 5
21:33:57 T:2954948608  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndhdmi.0.analog-stereo
21:33:57 T:2954948608  NOTICE:         m_displayName     : sunxi-sndhdmi Analog Stereo
21:33:57 T:2954948608  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:33:57 T:2954948608  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:33:57 T:2954948608  NOTICE: Default DVD Player: dvdplayer
21:33:57 T:2954948608  NOTICE: Default Video Player: dvdplayer
21:33:57 T:2954948608  NOTICE: Default Audio Player: paplayer
21:33:57 T:2954948608  NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:33:57 T:2954948608  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:33:57 T:2954948608  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:33:57 T:2954948608  NOTICE: Loaded playercorefactory configuration
21:33:57 T:2954948608  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:33:57 T:2954948608  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:33:57 T:2954941280  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 199 ms
21:33:57 T:2954948608  NOTICE: Running database version Addons20
21:33:57 T:2954948608  NOTICE: ADDONS: Using repository repository.xbmc.org
21:33:58 T:2954948608  NOTICE: Checking resolution 16
21:33:58 T:2954948608  NOTICE: Using visual 0x42
This are the information of 'kodi.old_1793118617.log' file.
21:33:24 T:2955206656  NOTICE: special://profile/ is mapped to: special://masterprofile/
21:33:24 T:2955206656  NOTICE: -----------------------------------------------------------------------
21:33:24 T:2955206656  NOTICE: Starting Kodi from Debian (16.1 Debian package version: 16.1+dfsg1-2~bpo8+1). Platform: Linux ARM (Thumb) 32-bit
21:33:24 T:2955206656  NOTICE: Using Release Kodi from Debian x32 build
21:33:24 T:2955206656  NOTICE: Kodi from Debian compiled from 16.1+dfsg1-2~bpo8+1 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.36 (200740)
21:33:24 T:2955206656  NOTICE: Running on Debian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 3.4.112-sun7i
21:33:24 T:2955206656  NOTICE: FFmpeg version: 3.1.3-1~bpo8+1
21:33:24 T:2955206656  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 2 cores available
21:33:24 T:2955206656  NOTICE: ARM Features: Neon disabled
21:33:24 T:2955206656  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:33:24 T:2955206656  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
21:33:24 T:2955206656  NOTICE: special://masterprofile/ is mapped to: /home/raik/.kodi/userdata
21:33:24 T:2955206656  NOTICE: special://home/ is mapped to: /home/raik/.kodi
21:33:24 T:2955206656  NOTICE: special://temp/ is mapped to: /home/raik/.kodi/temp
21:33:24 T:2955206656  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
21:33:24 T:2955206656  NOTICE: Local hostname: cubietruck
21:33:24 T:2955206656  NOTICE: Log File is located: /home/raik/.kodi/temp/kodi.log
21:33:24 T:2955206656   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
21:33:24 T:2955206656  NOTICE: load settings...
21:33:24 T:2955206656  NOTICE: Found 1 Lists of Devices
21:33:24 T:2955206656  NOTICE: Enumerated PULSE devices:
21:33:24 T:2955206656  NOTICE:     Device 1
21:33:24 T:2955206656  NOTICE:         m_deviceName      : Default
21:33:24 T:2955206656  NOTICE:         m_displayName     : Default
21:33:24 T:2955206656  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
21:33:24 T:2955206656  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
21:33:24 T:2955206656  NOTICE:         m_channels        : FL,FR
21:33:24 T:2955206656  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
21:33:24 T:2955206656  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
21:33:24 T:2955206656  NOTICE:     Device 2
21:33:24 T:2955206656  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-codec.analog-stereo
21:33:24 T:2955206656  NOTICE:         m_displayName     : sunxi-CODEC Analog Stereo
21:33:24 T:2955206656  NOTICE:         m_displayNameExtra: Analog Output (PULSEAUDIO)
21:33:24 T:2955206656  NOTICE:     Device 3
21:33:24 T:2955206656  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndi2s.0.analog-stereo
21:33:24 T:2955206656  NOTICE:         m_displayName     : sunxi-sndi2s Analog Stereo
21:33:24 T:2955206656  NOTICE:     Device 4
21:33:24 T:2955206656  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndspdif.0.analog-stereo
21:33:24 T:2955206656  NOTICE:         m_displayName     : sunxi-sndspdif Analog Stereo
21:33:24 T:2955206656  NOTICE:     Device 5
21:33:24 T:2955206656  NOTICE:         m_deviceName      : alsa_output.platform-sunxi-sndhdmi.0.analog-stereo
21:33:24 T:2955206656  NOTICE:         m_displayName     : sunxi-sndhdmi Analog Stereo
21:33:24 T:2955206656  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:33:24 T:2955206656  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:33:24 T:2955206656  NOTICE: Default DVD Player: dvdplayer
21:33:24 T:2955206656  NOTICE: Default Video Player: dvdplayer
21:33:24 T:2955206656  NOTICE: Default Audio Player: paplayer
21:33:24 T:2955206656  NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:33:24 T:2955206656  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:33:24 T:2955206656  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:33:24 T:2955206656  NOTICE: Loaded playercorefactory configuration
21:33:24 T:2955206656  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:33:24 T:2955206656  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:33:24 T:2955199328  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 199 ms
21:33:24 T:2955206656  NOTICE: Running database version Addons20
21:33:24 T:2955206656  NOTICE: ADDONS: Using repository repository.xbmc.org
21:33:24 T:2955206656  NOTICE: Checking resolution 16
21:33:25 T:2955206656  NOTICE: Using visual 0x42
