mariusco Posted October 17, 2016 Posted October 17, 2016 Hi, Board: nanopi neo, running xenial ubuntu server from:http://www.armbian.com/donate/?f=Armbian_5.20_Nanopineo_Ubuntu_xenial_3.4.112.7z I am trying to enable the hostapd for nanopi neo, on Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter The default drivers cocam@nanopineo:~$ lsmodModule Size Used byrtl8192cu 61143 0rtlwifi 45784 1 rtl8192curtl8192c_common 33420 1 rtl8192cusnd_usb_audio 80300 0mac80211 358429 3 lrtlwifi,rtl8192c_common,rtl8192cu came with 3.4.112-sun8i looks ok and my wlan0 is AP-advertised, wlan0 Link encap:Ethernet HWaddr ec:08:6b:1d:10:20 inet addr:10.5.5.1 Bcast:10.5.5.255 Mask:255.255.255.0 inet6 addr: fe80::ee08:6bff:fe1d:1020/64 Scope:Link As soon I connect a device to the AP I get a kernel crash: [ 264.757288] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM[ 264.757288] Modules linked in: rtl8192cu rtlwifi rtl8192c_common mac80211 snd_usb_audio uvcvideo snd_hwdep snd_usbmidi_lib snd_rawmidi[ 264.757288] CPU: 0 Not tainted (3.4.112-sun8i #14)[ 264.757288] PC is at __queue_work+0x23c/0x3d8[ 264.757288] LR is at __queue_work+0x204/0x3d8[ 264.757288] pc : [<c0044c9c>] lr : [<c0044c64>] psr: 00030093[ 264.757288] sp : d50c1a58 ip : d50c1a58 fp : d50c1a8c[ 264.757288] r10: 00000000 r9 : 40030013 r8 : d50c1b98[ 264.757288] r7 : d581d0c0 r6 : d5069438 r5 : c0ff4a00 r4 : c0fef5c0[ 264.757288] r3 : d506943c r2 : 00000000 r1 : d581d0c0 r0 : c0ff4a00[ 264.757288] Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user[ 264.757288] Control: 10c5387d Table: 5512806a DAC: 00000015[ 264.757288][ 264.757288] PC: 0xc0044c1c:[ 264.757288] 4c1c e5933004 e1570003 01a04005 0a00000a e1a01009 e1a00005 eb193046 e1a00004[[[[ .... oitted ...]]] [ 264.757288] 1fc0: 01c7c638 0000012c bec3f678 00000004 bec3f5f4 00000002 bec3fdbc bec3fd94[ 264.757288] 1fe0: 00000000 bec3f5d4 000510d9 b6d0e1d6 00030030 00000005 003ff001 1c03f81a[ 264.757288] [<c0044c9c>] (__queue_work+0x23c/0x3d8) from [<c0044e7c>] (queue_work_on+0x44/0x54)[ 264.757288] [<c0044e7c>] (queue_work_on+0x44/0x54) from [<c0044ec8>] (queue_work+0x3c/0x64)[ 264.757288] [<c0044ec8>] (queue_work+0x3c/0x64) from [<c0044f14>] (schedule_work+0x24/0x2c)[ 264.757288] [<c0044f14>] (schedule_work+0x24/0x2c) from [<bf0d307c>] (rtl_is_special_data+0xdc/0x100 [rtlwifi])Every 0.1s: dmesg | tail -n -6 Mon Oct 17 20:17:21 2016[ 14.289970] ADDRCONF(NETDEV_UP): wlan0: link is not ready[ 17.600243] PHY: gmac0-0:00 - Link is Up - 100/Full[ 33.232108] rtl8192cu: MAC auto ON okay![ 264.757288] [<bf0d307c>] (rtl_is_special_data+0xdc/0x100 [rtlwifi]) from [<bf0d7f44>] (rtl_get_rate+0x8c/0x158 [rtlwifi])[ 264.757288] [<bf0d7f44>] (rtl_get_rate+0x8c/0x158 [rtlwifi]) from [<bf05d75c>] (rate_control_get_rate+0xa4/0x240 [mac80211])[ 264.757288] [<bf05d75c>] (rate_control_get_rate+0xa4/0x240 [mac80211]) from [<bf067d38>] (invoke_tx_handlers+0x8d4/0x11e4 [mac80211])[ 264.757288] [<bf067d38>] (invoke_tx_handlers+0x8d4/0x11e4 [mac80211]) from [<bf0686e4>] (ieee80211_tx+0x9c/0xd0 [mac80211])[ 264.757288] [<bf0686e4>] (ieee80211_tx+0x9c/0xd0 [mac80211]) from [<bf0690ec>] (ieee80211_xmit+0xdc/0xe4 [mac80211])[ 264.757288] [<bf0690ec>] (ieee80211_xmit+0xdc/0xe4 [mac80211]) from [<bf069c98>] (ieee80211_subif_start_xmit+0x8dc/0x9f4 [mac80211]) I built against the /usr/src/linux-headers-3.4.112-sun8i kernel the rtl8192cu-fixes and I blacklisted /etc/modprobe/blacklist.conf the old drivers, allowing the new driver. blacklist rtl8192cu#blacklist rtl8192c_common#blacklist 8192cu But now I cannot start the hostapd service ifconfig ... wlan0 Link encap:Ethernet HWaddr ec:08:6b:1d:10:20 inet addr:10.5.5.1 Bcast:10.5.5.255 Mask:255.255.255.0 sudo iwlist scanning is OK sudo iwlist scanninglo Interface doesn't support scanning.tunl0 Interface doesn't support scanning.wlan0 Scan completed : Cell 01 - Address: 00:22:75:18:F9:18 ESSID:"Dyx" Protocol:IEEE 802.11bg Mode:Master Frequency:2.412 GHz (Channel 1)...... omitted... sudo hostapd -B /etc/hostapd/hostapd.confConfiguration file: /etc/hostapd/hostapd.confnl80211: deinit ifname=wlan0 disabled_11b_rates=0nl80211 driver initialization failed.wlan0: interface state UNINITIALIZED->DISABLEDwlan0: AP-DISABLEDhostapd_free_hapd_data: Interface wlan0 wasn't started My hostapd.conf and interfaces cat /etc/hostapd/hostapd.confinterface=wlan0driver=nl80211ssid=mynanopihw_mode=gchannel=6macaddr_acl=0ignore_broadcast_ssid=0 cat /etc/network/interfacesauto loiface lo inet loopbackauto eth0iface eth0 inet dhcp allow-hotplug wlan0iface wlan0 inet staticaddress 10.5.5.1netmask 255.255.255.0network 10.5.5.0broadcast 10.5.5.255What can I try next. I am kind of stuck.
Igor Posted October 18, 2016 Posted October 18, 2016 There are two versions of hostapd, hostapd and hostapd-realtek, both accessible from our repository ... try both, since it's try to match which goes where, and make sure you use proper config, check power supply that it gives 5V and not 4.7 or something, under load. Check following, tested but prepared for bridged mode. ssid=BOARD interface=wlan0 hw_mode=g channel=5 driver=nl80211 bridge=br0 logger_syslog=0 logger_syslog_level=0 wmm_enabled=1 ieee80211n=1 wpa=2 preamble=1 wpa_psk=66eb31d2b48d19ba216f2e50c6831ee11be98e2fa3a8075e30b866f4a5ccda27 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP auth_algs=1 macaddr_acl=0 noscan=1 #ht_capab=[HT40-][SHORT-GI-40][SHORT-GI-40][DSSS_CCK-40] #country_code=SI #ieee80211d=1 interface=wlan0 ctrl_interface=/var/run/hostapd ssid=orangepi channel=5 noscan=1 wpa=2 wpa_passphrase=12345678 bridge=br0 wmm_enabled=1 driver=rtl871xdrv beacon_int=100 hw_mode=g ieee80211n=1 wme_enabled=1 ht_capab=[SHORT-GI-40][HT40+][HT40-][DSSS_CCK-40] wpa_key_mgmt=WPA-PSK wpa_pairwise=CCMP max_num_sta=8 wpa_group_rekey=86400
gepeto Posted October 18, 2016 Posted October 18, 2016 For me , after compiling hostapd with go.sh ( note ; add pkg-config into dependances and i'm not sure that the deb was made , i made a copie hostapd* by hands) it's the same hostapd run with wlan5 , it began to talk and crash the machine just before dnsmasq i have an extern power for a usb hub and make tests with 3 differents usb WIFI i notice that for me driver=rtl871xdrv make an error
gepeto Posted October 23, 2016 Posted October 23, 2016 in fact , it run :-) my dnsmasq.conf and network/interfaces was wrong then after all ( may be the apt-get update/upgrade are also important ) with driver=nl80211 it's ok I have a captiv portal with nginx/php/dokuwiki to share information, data, etc where i want for 12$ .. cool I 'll put documentation for that next week 1
Guest Posted November 10, 2016 Posted November 10, 2016 I can't succeed with "NanoPi Air" Armbian_5.24_Nanopiair_Debian_jessie_3.4.113) Hostpapd starts but I have no wifi, iwconfig show empty ESSID ! I tried go.sh but it tells me that some packages are held, event if I found nothing when "dpkg --get-selections | grep hold" Chip is an AP6212 on my board, so I use hostapd (I tested hostapd-realtek one time) /etc/hostapd/hostapd.conf interface=wlan0 driver=nl80211 ssid=ap6210_ap_test channel=6 hw_mode=g macaddr_acl=0 auth_algs=1 ignore_broadcast_ssid=0 wpa=2 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK wpa_pairwise=TKIP rsn_pairwise=CCMP /etc/network/interfaces auto lo iface lo inet loopback auto wlan0 iface wlan0 inet static address 192.168.101.1 netmask 255.255.255.0 dns-nameservers 192.168.101.1 output ◠hostapd.service - LSB: Advanced IEEE 802.11 management daemon Loaded: loaded (/etc/init.d/hostapd) Active: active (running) since Wed 2016-11-02 11:03:26 CET; 2s ago Process: 938 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS) CGroup: /system.slice/hostapd.service └─941 /usr/sbin/hostapd -B -P /run/hostapd.pid /etc/hostapd/hostap... Nov 02 11:03:26 nanopiair hostapd[938]: Starting advanced IEEE 802.11 manage.... Nov 02 11:03:26 nanopiair systemd[1]: Started LSB: Advanced IEEE 802.11 man...n. Hint: Some lines were ellipsized, use -l to show in full. root@nanopiair:~# hostapd /etc/hostapd/hostapd.conf Configuration file: /etc/hostapd/hostapd.conf nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Using interface wlan0 with hwaddr 94:a1:a2:a4:29:28 and ssid "ap6210_ap_test" wlan0: interface state UNINITIALIZED->ENABLED wlan0: AP-ENABLED
tkaiser Posted November 10, 2016 Posted November 10, 2016 Chip is an AP6212 on my board ...which needs dhd driver to be loaded with 'op_mode=2' to enter AP mode. You may create a file /etc/modprobe.d/dhd.conf with the following contents: options dhd op_mode=2
Guest Posted November 10, 2016 Posted November 10, 2016 Yes "It works" Haha !!! I did not see anything with lsmod..... and tried to add wrong things in /etc/modules Thank you master The next step for me will be to switch between AccesPoint and Default connection (I think I will need to reload kernel modules)
