sgjava Posted December 3, 2022 Posted December 3, 2022 (edited) Tried a few builds such as https://github.com/armbian/community/releases/download/202248/Armbian_22.11.0-trunk_Nanopiduo_kinetic_edge_6.0.10.img.xz#nanopiduo and the image doesn't even expand. No heartbeat flaching. Not sure how to troubleshoot this. Board: NanoPi Duo Edited December 3, 2022 by sgjava 0 Quote
Igor Posted December 3, 2022 Posted December 3, 2022 1 hour ago, sgjava said: Not sure how to troubleshoot this. This is in the boot logs: ERROR: Did not find a cmdline Flattened Device Tree Nanopi Duo never reached mainline. It only lives in Armbian and it seems this problem is because our complete patch-set was not adopted to 6.x yet. @going is still working on it and dunno how much work there is behind. It will work if you build a CURRENT image. 0 Quote
sgjava Posted December 3, 2022 Author Posted December 3, 2022 Thanks @Igor, I'm actually building Jammy image now based on current kernel (not CSC). Great minds think alike. Waiting on 6.x kernel though, hahaha 0 Quote
going Posted December 3, 2022 Posted December 3, 2022 2 часа назад, Igor сказал: @going is still working https://github.com/armbian/build/pull/4515 armbian-build/cache/sources/linux-mainline/6.0> ls arch/arm/boot/dts/*nanopi* arch/arm/boot/dts/sun8i-h2-plus-nanopi-duo.dts arch/arm/boot/dts/sun8i-h3-nanopi-m1.dts arch/arm/boot/dts/sun8i-h3-nanopi-neo.dts arch/arm/boot/dts/sun8i-h3-nanopi.dtsi arch/arm/boot/dts/sun8i-h3-nanopi-m1-plus.dts arch/arm/boot/dts/sun8i-h3-nanopi-r1.dts arch/arm/boot/dts/sun8i-h3-nanopi-duo2.dts arch/arm/boot/dts/sun8i-h3-nanopi-neo-air.dts 0 Quote
Igor Posted December 3, 2022 Posted December 3, 2022 Aha, ok, we merge this then. Remaining ones for H616 some other day ... 0 Quote
