berin Posted January 8, 2023 Posted January 8, 2023 (edited) The OPI5 has an onboard RTC. On the back of the board near the RTC chip there are two pcb "test points". One says RTC1, the other says GRD1, I would assume a CR2032 could be connected to those points to maintain RTC function. I don't dare do anything till I get a solid answer. Can anyone give me any feedback as to options. Edited January 8, 2023 by berin 0 Quote
b-baka Posted January 9, 2023 Posted January 9, 2023 On 1/8/2023 at 6:59 PM, rosco_pc said: According to the schematics yes Expand How did you removed SDcard/USB incompactible warning in status bar(that asking to format disk)? 0 Quote
berin Posted January 9, 2023 Author Posted January 9, 2023 If you guys have not seen it I am designing a micro tower for the OPI5. hence the RTC battery backup is one of the features I want to add to the CAD design. OPEN design. If you guys have not seen it I am designing a micro tower for the OPI5. hence the RTC battery backup is one of the features I want to add to the CAD design. OPEN design. 0 Quote
berin Posted January 10, 2023 Author Posted January 10, 2023 I am working on creating an RTC backup battery mount for CR2032. There are a lot of different types out there. I would like any suggestions on what kind of setup would be desired. If I do anything it will be a custom PCB that would tie into front access ports for headphone/mic. I'm looking for design suggestions if anyone has any good ideas. . . 0 Quote
berin Posted January 14, 2023 Author Posted January 14, 2023 Has anyone tried a cr2032 for the RTC? 0 Quote
berin Posted January 18, 2023 Author Posted January 18, 2023 Just mounted my ICE tower for RPI. first OPI5 ICE TOWER IN THE WORLD next working on building the shell. and the RTC setup. 0 Quote
berin Posted February 18, 2023 Author Posted February 18, 2023 I have added RTC features to my case design. 0 Quote
ScottN Posted April 27, 2023 Posted April 27, 2023 Whose idea was it to use test points to connect the RTC battery? Wow, what a pain to solder to those. Pin headers would've been much easier to work with. Anyone have any ideas on a better way to connect wires or are we just to deal with the tiny pads and solder? 0 Quote
