ZFS to old (2.1.4) in Armbian_22.11.1_Odroidhc4_jammy_current_5.19.17
The zfs-dkms included in Armbian_22.11.1_Odroidhc4_jammy in version 2.1.4 is to old for 5.19.17 kernel.
It should be 2.1.6 like in Armbian_22.08.7.
Loading new zfs-2.1.4 DKMS files...
Building for 5.19.17-meson64
Building initial module for 5.19.17-meson64
configure: error:
    *** None of the expected "blk_queue_discard" interfaces were detected.
    *** This may be because your kernel version is newer than what is
    *** supported, or you are using a patched custom kernel with
    *** incompatible modifications.
    *** ZFS Version: zfs-2.1.4-0ubuntu0.1
    *** Compatible Kernels: 3.10 - 5.17
http://paste.debian.net/1267188/
On 1/14/2023 at 4:49 PM, ChrisO said:
It should be 2.1.6
Update has been initiated. 24 - 48h until it shows up in CDN.
require zfs as well.
bulsseye minimal pulls even older zfs
configure: error:
    *** None of the expected "PDE_DATA" interfaces were detected.
    *** ZFS Version: zfs-2.0.3-9
    *** Compatible Kernels: 3.10 - 5.10
Therefore on yammy route then still same error
configure: error:
What does
Actually mean and how to build zfs 2.16 then ?
Was unable to pull zfs-dkms 2.1.6 being available on cdn https://armbian.hosthatch.com/apt/pool/jammy-utils/z/zfs-linux/
After armbian-config and apt reconfigure mirrors and apt update && apt upgrade i could pull the zfs 2.1.6 goods (dkms and zfs-utils)
These values are and where fine
cat /etc/apt/sources.list
deb http://ports.ubuntu.com/ jammy main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ jammy main restricted universe multiverse
deb http://ports.ubuntu.com/ jammy-security main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ jammy-security main restricted universe multiverse
deb http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ jammy-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ jammy-backports main restricted universe multiverse
cat /etc/apt/sources.list.d/armbian.list
deb http://apt.armbian.com jammy main jammy-utils jammy-desktop
Not sure why apt reconfigure mirrors solved this.. but never the less, happy eyes with the zfs goods to play with.
