ALIGMSTEN Posted January 19, 2023 Posted January 19, 2023 Hello, While testing adding efuse_xlate to extract the efuse version for h616 'opiz2' so that h6 and h616 can coexist, found the following with htop. Issue raised with: htop 2.2.0 aborting. Please report bug at http://hisham.hm/htop >>>> pointed me back here. Please have a look and let me know if help needed. Thanks, Alistair Welcome to ARMBIAN! Documentation: https://docs.armbian.com | Community: https://forum.armbian.com IP address: 10.0.0.14 Create root password: ******* Repeat root password: ******* Shell: BASH Creating a new user account. Press <Ctrl-C> to abort Please provide a username (eg. your first name): alistair Create user (alistair) password: ******* Repeat user (alistair) password: ******* Please provide your real name: Alistair Dear Alistair, your account alistair has been created and is sudo enabled. Please use this account for your daily work from now on. Detected timezone: Africa/Johannesburg Set user language based on your location? [Y/n] Y At your location, more locales are possible: 1) af_ZA.UTF-8 4) xh_ZA.UTF-8 2) en_ZA.UTF-8 5) zu_ZA.UTF-8 3) st_ZA.UTF-8 6) Skip generating locales Please enter your choice:2 Generating locales: en_ZA.UTF-8 root@orangepizero2:~# htop htop 2.2.0 aborting. Please report bug at http://hisham.hm/htop Please include in your report the following backtrace: htop(CRT_handleSIGSEGV+0x44)[0xaaaabbfc560c] linux-vdso.so.1(__kernel_rt_sigreturn+0x0)[0xffffbd51d788] /lib/aarch64-linux-gnu/libc.so.6(cfree+0x1c)[0xffffbd2bfc8c] htop(String_freeArray+0x24)[0xaaaabbfb9624] htop(Settings_delete+0x38)[0xaaaabbfb89c0] htop(main+0x53c)[0xaaaabbfae13c] /lib/aarch64-linux-gnu/libc.so.6(__libc_start_main+0xe8)[0xffffbd266e18] htop(+0xe2c0)[0xaaaabbfae2c0] Additionally, in order to make the above backtrace useful, please also run the following command to generate a disassembly of your binary: objdump -d `which htop` > ~/htop.objdump and then attach the file ~/htop.objdump to your bug report. Thank you for helping to improve htop! Aborted root@orangepizero2:~# Here is the objdump: op1z2_htop.7zFetching info... 0 Quote
going Posted January 19, 2023 Posted January 19, 2023 On 1/19/2023 at 6:00 AM, ALIGMSTEN said: htop 2.2.0 aborting. Expand Hello Alistair. What operating system? Just delete this old one and install the one that comes with the system. 0 Quote
ALIGMSTEN Posted January 19, 2023 Author Posted January 19, 2023 Thanks Leo, That was straight from output of 'my' minimal test build conf. Built on win 7 virtual disk, I think mistakenly as oracle(64-bit) and not ubuntu, then quick check htop from root to see if the patches are working as expected. It looks like old version, unsure why, haven't delved that deep into build scripts. ___ ____ _ _____ ____ / _ \| _ \(_) |__ /___ _ __ ___|___ \ | | | | |_) | | / // _ \ '__/ _ \ __) | | |_| | __/| | / /| __/ | | (_) / __/ \___/|_| |_| /____\___|_| \___/_____| Welcome to Armbian 23.02.0-trunk Bullseye with Linux 5.19.17-sunxi64 No end-user support: built from trunk System load: 2% Up time: 4:00 Memory usage: 9% of 984M IP: 10.0.0.14 CPU temp: 46°C Usage of /: 10% of 29G Tip of the day: Looking for snap-free Ubuntu for Intel / AMD? https://www.armbian.com/uefi-x86/ Last login: Thu Jan 19 00:18:56 2023 from 10.0.0.10 alistair@orangepizero2:~$ htop --version htop 2.2.0 - (C) 2004-2020 Hisham Muhammad Released under the GNU GPL. alistair@orangepizero2:~$ Have now started build from older ubuntu(64-bit) virtual disk, really don't know if that difference could be reason, not so clued up on this part of things, and probably not an effect. Will let you know effect of different build and update the 'oracle' builds htop. 0 Quote
ALIGMSTEN Posted January 19, 2023 Author Posted January 19, 2023 Well that strange apt says already latest? alistair@orangepizero2:~$ sudo apt install htop [sudo] password for alistair: Reading package lists... Done Building dependency tree... Done Reading state information... Done htop is already the newest version (3.1.0-0~armbian20.08.2+1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. alistair@orangepizero2:~$ 0 Quote
ALIGMSTEN Posted January 19, 2023 Author Posted January 19, 2023 If am doing this right here result. Cpufreq and temperature not displaying. alistair@orangepizero2:~$ sudo apt remove htop Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: htop 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. After this operation, 257 kB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 131780 files and directories currently installed.) Removing htop (3.1.0-0~armbian20.08.2+1) ... Processing triggers for man-db (2.9.4-2) ... Processing triggers for mailcap (3.69) ... Processing triggers for desktop-file-utils (0.26-1) ... alistair@orangepizero2:~$ sudo apt install htop Reading package lists... Done Building dependency tree... Done Reading state information... Done Suggested packages: strace The following NEW packages will be installed: htop 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 88.5 kB of archives. After this operation, 257 kB of additional disk space will be used. Get:1 http://apt.armbian.com bullseye/bullseye-utils arm64 htop arm64 3.1.0-0~armbian20.08.2+1 [88.5 kB] Fetched 88.5 kB in 3s (34.7 kB/s) Selecting previously unselected package htop. (Reading database ... 131772 files and directories currently installed.) Preparing to unpack .../htop_3.1.0-0~armbian20.08.2+1_arm64.deb ... Unpacking htop (3.1.0-0~armbian20.08.2+1) ... Setting up htop (3.1.0-0~armbian20.08.2+1) ... Processing triggers for mailcap (3.69) ... Processing triggers for desktop-file-utils (0.26-1) ... Processing triggers for man-db (2.9.4-2) ... alistair@orangepizero2:~$ htop --version htop 2.2.0 - (C) 2004-2020 Hisham Muhammad Released under the GNU GPL. 0 Quote
going Posted January 19, 2023 Posted January 19, 2023 On 1/19/2023 at 11:20 AM, ALIGMSTEN said: Bullseye with Linux 5.19.17-sunxi64 Expand Unfortunately, the system package from this OS will not work properly for CPU temperature and frequency. I learned how to make the latest version from the developer's website: https://github.com/htop-dev/htop/releases/tag/3.2.1 But it shows the processor frequency not constantly, but with some different time intervals. The temperature does not show at all. The situation for today is like this. The old package that currently exists in the build system is either not being built (jammy) or is being built but does not work (Bullseye). 0 Quote
Solution Igor Posted January 19, 2023 Solution Posted January 19, 2023 I have removed htop from our repository. We are at least good for the future. 1 Quote
ALIGMSTEN Posted January 19, 2023 Author Posted January 19, 2023 Right thank you both for the reasons and solutions, to add must be bullseye here, because same issue with new build. On 1/19/2023 at 12:12 PM, going said: The situation for today is like this. The old package that currently exists in the build system is either not being built (jammy) or is being built but does not work (Bullseye). Expand Other info: from htop-dev Quote NB: htop relies on libsensors for temperature and fan readings, and libsensors is not known to the State of California (or us) to be particularly good on ARM (especially the Pi and its clones). Expand 0 Quote
going Posted January 19, 2023 Posted January 19, 2023 On 1/19/2023 at 12:30 PM, ALIGMSTEN said: NB: htop relies on libsensors for temperature Expand pkg libsensors-config : /etc/sensors3.conf /etc/sensors.d/ Reveal hidden contents # libsensors configuration file # ----------------------------- # # This default configuration file only includes statements which do not # differ from one mainboard to the next. Only label, compute and set # statements for internal voltage and temperature sensors are included. # # In general, local changes should not be added to this file, but rather # placed in custom configuration files located in /etc/sensors.d. This # approach makes further updates much easier. # # Such custom configuration files for specific mainboards can be found in # "configs" directory of lm-sensors package. # # Please contribute back a configuration of your board so other users with # the same hardware won't need to recreate it again and again. chip "lm78-*" "lm79-*" "lm80-*" "lm96080-*" label temp1 "M/B Temp" chip "w83792d-*" .......... Now that Igor has cleared the repository of broken packages, you can install the system package and try to configure the library using this file 0 Quote
going Posted January 19, 2023 Posted January 19, 2023 @ALIGMSTEN If you succeed with the configuration file, I will immediately add to the build system the construction of the current version of the htop package and configure it for our devices. 0 Quote
ALIGMSTEN Posted January 19, 2023 Author Posted January 19, 2023 Thank you @going, will have a go later this evening. 0 Quote
nordonsimf Posted January 20, 2023 Posted January 20, 2023 so now i try to delete\install htop and its en error. Does htop avaible in future ? 0 Quote
going Posted January 21, 2023 Posted January 21, 2023 @Igor The package has been deleted, but the metadata stores information about it http://mirror.yandex.ru/mirrors/armbian/apt/pool/bullseye-utils/h/htop/htop_3.1.0-0~armbian20.08.2+1_armhf.deb 404 Not Found 0 Quote
going Posted January 21, 2023 Posted January 21, 2023 On 1/20/2023 at 8:59 PM, Женя Сидоров said: Does htop avaible in future ? Expand Женя конечно ДА. Of course YES. Now it will be possible to install the package that is already provided by the base operating system. In the future, perhaps we will collect the latest version being developed with our own fixes. 0 Quote
Igor Posted January 22, 2023 Posted January 22, 2023 On 1/21/2023 at 9:09 AM, going said: The package has been deleted, but the metadata stores information about it Expand Index is syncing 24h later to avoid "file not found" when adding packages. We rarely remove packages ... 0 Quote
ALIGMSTEN Posted January 23, 2023 Author Posted January 23, 2023 Building from htop source on the board and configuring very simple exercise. alistair@orangepizero2:~$ htop --version htop 3.2.2-dev libsensors finds thermal on device 'opiz2' without configuration. I had a try to use the library by writing to it in c++, unfortunately had numerous compile issues, have not been able to extract the info I wanted yet. Time intervals are as @going has noted I did not look at source, beyond build at all and did not find configuration option, could easily missed if there. 0 Quote
going Posted January 23, 2023 Posted January 23, 2023 On 1/23/2023 at 3:40 PM, ALIGMSTEN said: htop 3.2.2-dev Expand Ok! This means that something has been fixed. I was building this release htop/releases/tag/3.2.1 I'll check the build from the head git. 1 Quote
