I have a problem with connecting to ILI9341 hummingboard
postaebuje as described
I do entry
Add this to your / etc / modules: fbtft_device name = adafruit22a rotate speed = 90 = 48000000 fps = 50 GPIOs reset = 67, led 72, dc 195 busnum = 1
reboot
but the display is lit only shows nothing
What may be the problem
wyśietlacz exactly
Double check wiring ... it should work out of the box. Which kernel do you use?
It should be only slightly lit, just background ... than try to test with:
fbi -d /dev/fb2 -T 1 -noverbose -a yourimage.jpg
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 4.7.3-cubox
after entering
fbi -d / dev / fb2 -T 1 -noverbose -a mini.jpg
using "DejaVu Sans Mono-16", pixelsize = 16.67 file = / usr / share / fonts / truetype / dejavu / DejaVuSansMono.ttf
and nothing shows on the LCD backlight only
Aha. It's not tested on Vanilla 4.x ... no idea if it works here. Get legacy version.
by typing:
fbi -d / dev / fb2 -T 1 -noverbose -a 23.jpg
the display is not lit.
Remove driver from auto loading and start manually.
modprobe fbtft_device name=adafruit22a rotate=90 speed=48000000 fps=50 gpios=reset:67,led:72,dc:195 busnum=1
and proceed with image loading.
Edit:
For auto loading, try this: add only fbtft_device to /etc/modules and create conf file for parameters.
echo 'options fbtft_device name=adafruit22a rotate=90 speed=48000000 fps=50 gpios=reset:67,led:72,dc:195 busnum=1' >/etc/modprobe.d/fbtft_device.conf
Edit:
It works but once you start the system must enter
manually
modprobe fbtft_device name = adafruit22a rotate speed = 90 = 48000000 fps = 50 GPIOs reset = 67, led 72, dc 195 busnum = 1
add an entry to the rc.local?
if I can somehow view the desktop instead of the display on hdmi?
No, you don't need to start it via rc.local - try method to create module parameters. This is usual way in recent system ... I realized later that the manual was done when in Debian Wheezy era.
You need to tell desktop to use /dev/fb2 some. I was using it only this way:
https://github.com/igorpecovnik/homedisplay
Check here.
Check here.
How do you think did so to do the same with two displays?
SPI bus allows you to have multiple devices attached to a bus but here is edge of my experimenting / knowledge ... so I hope someone else could provide more details how to do it.
Kernel config file, TFT enabled.
https://drive.google.com/file/d/0B5PY...
cmdline.txt including TFT configuration.
I planned to create a patch, but I did not find the original RPi kernel source (3.6.y). I have the working copy of the modified kernel source, however:
Unfortunately, there is no schematic, however wiring is pretty simple:
LCD0 - RPi
SDO(MISO) - MISO/GPIO9, pin21 (common)
LED - 5V through 1k resistor, pin 2 (common)
SCK - CLK/GPIO11, pin23 (common)
SDI(MOSI) - MOSI/GPIO10, pin19 (common)
D/C - GPIO24, pin18
RESET - GPIO25, pin22
CS - CE0/GPIO8, pin24
GND - GND, pin 6 (common)
VCC - 3.3V, pin 1 (common)
LCD1 - RPi
D/C - GPIO18, pin12
RESET - GPIO23, pin16
CS - CE1/GPIO7, pin26
I am sure about one thing. Forget about RPi kernel parameters and kernel config ... they are irrelevant. You already have all support for display within kernel and you got one working ... if you need two working, seek how to switch between them. It's probably only loading another module with different parameters and changing with GPIOs which is active. Probably.
so far I've been able to run one of the link :(
root@cubox-i:~/RPi.GPIO_BP/homedisplay# FRAMEBUFFER=/dev/fb1 startx
X.Org X Server 1.16.4
Release Date: 2014-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.16.0-0.bpo.4-armmp-lpae armv7l Debian
Current Operating System: Linux cubox-i 3.14.79-cubox #7 SMP Wed Sep 14 22:56:30 CEST 2016 armv7l
Kernel command line: root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=ttymxc0,115200 console=tty1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1 consoleblank=0 vt.global_cursor_default=0 quiet loglevel=3
Build Date: 11 February 2015  01:18:06AM
xorg-server 2:1.16.4-1 (http://www.debian.org/support)
Current version of pixman: 0.32.6
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.5.log", Time: Sat Oct 22 20:29:00 2016
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
/dev/fb2
2 is correct device number for this small display.
/dev/fb2
Now it works and how to add to auto start?
because now the system is booting up I have to enter:
lights up the display and now fits:
Framebuffer = / dev / fb2 startx
Read above
http://forum.armbian.com/index.php/topic/2615-problems-ili9341and-hummingboard/?p=18199
1. Create a file /etc/modprobe.d/fbtft_device.conf with content:
2. Add:
fbtft_device
 to /etc/modules (without anything)
3. Reboot
hello, or touch-screen also supports the armbian as plug in?
and if you can control the brightness of the display?
Touch screen should be doable but I haven't done it.
Brightness of this display. No idea if this is supported on this display / driver ... most likely not. Try to get this info from driver maker ... if it's implemented, it will work on Armbian too.
Armbian_5.20_Cubox-i_Debian_jessie_3.14.79_desktop.7z
hello, I am searching for the img Cubox where can I find it?
