Minor Legacy Linux Headers Build Issue (Lunar)
Main Makefile references python2 as python.
PYTHON        = python
PYTHON3        = python3
ideally change this to
PYTHON        = python2
PYTHON3        = python3
I quickly just made symlink and force a re-install via and removed the symlink afterwards
apt-get --reinstall install <package name>
Not an issue with later version of kernel header package (looks like only uses later python3 scripts.)
Sorry haven't had time to check if issue upstream or best way to patch it and submit to repo etc...
Kernel headers on this particular kernel are not in good shape as kernel is not in good shape :( RK3588 is using changed Linux kernel fork used by Rockchip to bring the hardware up - focus is their hardware functions only. More or less only they maintain it without general purpose fixes. Many standard functions are broken or unmaintained. Volunteers and people at board vendors can only try to fix most critical things to make hardware usable ... until this is not working decently (1Y+), there will be many strange problems to find.
Both is good I guess, but can't say how vendor takes care on PR. With Armbian - if its clear what it is about, tested, came from trustful author, ... its merged pretty fast https://github.com/armbian/build/pulls
Just been going through the build system
https://github.com/armbian/build/blob/master/lib/functions/compilation/patch/kernel-bootsplash-and-drivers.sh
Noticed that https://github.com/armbian/build/blob/master/patch/misc/general-packaging-5.10.y.patch, doesn't seem to be used
Is this on purpose or did i miss something
Anyway i submitted a pull request at https://github.com/armbian/build/pull/4818
Was afew places where
python needed tobe changed to python2
Symlink was not the ideal solution, considering there is a separate package to symlink python3 to python.
