I've downloaded the latest two images from the links mentioned https://disk.yandex.ru/d/-zSW21XKN0pfIA/ArmbianTV/20230103-edge
But none of them boot from SD on my M3 box.
The only one booting is the image from this link https://redirect.armbian.com/station-m3/Bullseye_legacy_xfce
But this makes the cooling fan on the M3 to always spin at full speed and it's not usable because of this (it's really noisy).
How can I make the other images boot?
Tried both Etcher and USBimager.
Please help.
Thanks.
Tried the image mentioned above and it boots OK.
Problem is that the cooling fan is running at full speed and it's noisy as hell.
Is there a solution to make the fan run at lower speed?
Firefly's support is not too helpful, at least on the M3. I gave up asking them for support.
But I tried Firefly's Debian and Ubuntu images and those run the fan at normal/lower speed.
I don't know much about this stuff and can't tell what drivers Firefly is using for that.
Maybe you can take a look at their image as you know what to look for.
I'd appreciate that.
It could be useful for others as well.
