Tony3 Posted February 6, 2023 Share Posted February 6, 2023 (edited) I am trying to compile the Kernel on my PC with the Ubuntu recommended version. I get the error below: arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c FATAL ERROR: Couldn't open "./u-boot.dtb": No such file or directory ./tools/mkimage: Can't read u-boot.itb.tmp: Invalid argument make: *** [Makefile:1053: u-boot.itb] Error 255 Any idea what this could be? It is the first time I am running ./.compile.sh potential-paths.log Thank you. == u-boot make orangepi_5_defconfig == arch/../configs/orangepi_5_defconfig:245:warning: override: reassigning to symbol CMD_SETEXPR == u-boot make BL31=/home/eric/installed/build/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.28.elf tpl/u-boot-tpl.bin spl/u-boot-spl.bin u-boot.itb BL31=/home/eric/installed/build/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.28.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb == .config:1667:warning: override: reassigning to symbol BOOTDELAY tools/rockchip/boot_merger.c: In function ‘mergeBoot’: tools/rockchip/boot_merger.c:700:43: warning: ‘%s’ directive output may be truncated writing up to 813 bytes into a region of size 5 [-Wformat-truncation=] 700 | snprintf(buffer, sizeof(buffer), "%s", chip); | ^~ ...... 742 | chipType = convertChipType(chip + 2); | ~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from /usr/include/stdio.h:894, from ././include/compiler.h:25, from <command-line>: /usr/include/x86_64-linux-gnu/bits/stdio2.h:71:10: note: ‘__builtin_snprintf’ output between 1 and 814 bytes into a destination of size 5 71 | return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 72 | __glibc_objsize (__s), __fmt, | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 73 | __va_arg_pack ()); | ~~~~~~~~~~~~~~~~~ tools/rockchip/boot_merger.c: In function ‘main’: tools/rockchip/boot_merger.c:895:18: warning: array subscript 20 is outside array bounds of ‘char[20]’ [-Warray-bounds] 895 | str[len] = 0; | ~~~~~~~~~^~~ tools/rockchip/boot_merger.c:933:14: note: while referencing ‘name’ 933 | char name[MAX_NAME_LEN]; | ^~~~ tools/rockchip/bmp2gray16.c: In function ‘usage’: tools/rockchip/bmp2gray16.c:121:25: warning: ‘%s’ directive argument is not a nul-terminated string [-Wformat-overflow=] 121 | printf("Version %s (zwp@rock-chips.com)\n", version); | ^~ ~~~~~~~ tools/rockchip/bmp2gray16.c:109:19: note: referenced argument declared here 109 | static const char version[4] = "1.00"; | ^~~~~~~ arch/arm/dts/rk3126-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1) arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3126-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3128-evb.dtb: Warning (reg_format): "reg" property in /syscon@20008000/usb2-phy@17c has invalid length (8 bytes) (#address-cells == 2, #size-cells == 1) arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #address-cells value for /syscon@20008000/usb2-phy@17c arch/arm/dts/rk3128-evb.dtb: Warning (avoid_default_addr_size): Relying on default #size-cells value for /syscon@20008000/usb2-phy@17c FATAL ERROR: Couldn't open "./u-boot.dtb": No such file or directory ./tools/mkimage: Can't read u-boot.itb.tmp: Invalid argument make: *** [Makefile:1053: u-boot.itb] Error 255 make: *** Waiting for unfinished jobs.... Edited February 6, 2023 by Tony3 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 7, 2023 Share Posted February 7, 2023 Check output/debug folder for further clues. Try building from armbian-next branch. 0 Quote Link to comment Share on other sites More sharing options...
