Hi have two N2s (an N2+ and N2).  Both are connected to a Viewsonic 2560x1440 2 HDMI ports monitor where they both work well.
One system (N2+) is running Ubuntu 22.04 the other is running Armbian jammy 22.04.01 Kernel 6.0.13 #22.11.2.
I have purchased a ATEN CS22H 2 port HDMI/USB KIVM switch.
When I connect both systems to the monitor via the KVM I only get a picture from the Ubuntu system.  The Armbian system is always black.
Can I force the kernel/firmware to be 2560x1440x60hz.  I was looking at this post :
Regarding forcing the kernel to be a fixed resolution but wasn't sure it was relevant.
I am able to connect to the Artmbian system via ssh if I need to.
Any suggestions welcome!
Posted (edited)
I suspect something is missing from the Armbian meson hardware/firmware, because if I boot two copies of Ubuntu then the KVM appears to operate correctly and if I boot two copies of Armbian I see neither system.
Edited by Walter Zambotti
Kernel is defining hardware features. Which kernel are you using in "Ubuntu"?
