HI! I have debian wheezy with kernel 3.4.106. When I ran nand-sata-install script, it executed successfully. But after that system doesn't boot from nand. Just black screen. Any help please?
Check bugs and limitation section on the board description / download page. Legacy kernel.
Thank you, after installing lubuntu and executing nand-sata-install system booted. But I've got one error. I compiled wi-fi driver to use usb wifi module. Wifi works well while system was on sd-card. After copying system to nand driver shows some errors and module doesn't work. Can you give me some advice to make it work?
error messages looks like this:
RtmpAsicLoadFirmware: ver 21/21, sum cdf7/cdf7, mac cdf72100
NICLoadFirmware: firmware loaded already
Error in Alloc Bulk buffer for HTTxContext!
RTMPAllocTxRxMemory failed, Status[=0x00000003]
RTMPFreeTxRxRingMemory
rt28xx Initialized fail!!!
If everything was correctly installed the only difference is u-boot and separate boot partition. This can provoke certain troubles but I never heard for such.
Double check that you have correct script.bin on (boot) nand1 partition. When you install to nand, script bin from SD card /boot/script.bin is copied there, kernel zImage is converted to uImage and copied there ...
If you copy it won't work. Simple as that. ;) zImage kernel type is not supported by that boot loader for which I don't have sources or newer version. Yet.
Eventually this will be solved too but now there is no other way.
You mean in a combination with NAND? Doubt, I don't think it exits.
If you need a modern kernel, go for Vanilla, latest stable which is available for download is 4.2 and it's in much better condition than any kernel down to 3.4.108 (latest legacy).
All my images are upgradable from 3.4.x to 4.1x and back. Check docs for details. Just remember to upgrade an u-boot not just kernel.
I need to use i2c, uart, sound, gpio and nand. As I understood not all of this would work in vanilla kernel?
I thought about newer kernel because my wifi adapter driver is in kernel since 3.10.
Than you only can go for 3.4.x at the moment. For WiFi try to build the module or change for supported one.
Wrote on mobile phone
Oh, God! Got it worked. After installing your latest image I saw a message from driver that 256KiB of coherent pool is insufficient. Added coherent_pool=2M to extraags of uEnv.txt and became very happy!!!
On 3.4.106 kernel worked too!
That's a fork of my early script :) Lubuntu flash is needed if this procedure fails, if your NAND come without boot loader, ... It's not possible to achieve this otherwise.
I remebered that some time ago I wrote a script to partition nand based on someones script.
#!/bin/bash
card='/dev/disk/by-id/mmc-SD02G_0xa361fa92'
targetdir='rootfs'
echo "Copying nand-install.sh to rootfs/root..."
echo ""
cp ./sd2nand/nand-install.sh ${targetdir}/root
cp ./sd2nand/nand-install-no-prompt.sh ${targetdir}/etc/init.d
echo "Copying bootpartition.tar.gz to rootfs/root..."
echo ""
cd ./sd2nand/bootpartition/
tar -zcvf bootpartition.tar.gz ./*
cd ../../
mv ./sd2nand/bootpartition/bootpartition.tar.gz ${targetdir}/root
read -p "Done. Press Enter... " -n1 -s
echo ""
echo "Unmounting partitions..."
echo ""
umount ${card}-part1
umount ${card}-part2
echo ""
echo "Cleaning 1 MB..."
dd if=/dev/zero of=${card} bs=1M count=1
echo ""
echo "Writing u-boot..."
dd if=u-boot-sunxi-with-spl-ct-20131102.bin of=${card} bs=1024 seek=8
echo ""
echo "Making partitions..."
cat <<EOT | sfdisk --force --in-order -uS $card
2048,524288,L
526336,,L
EOT
echo ""
echo "Creating fs part1... "
mkfs.ext2 ${card}-part1
read -p "Creating fs part2. Press enter... " -n1 -s
echo ""
mkfs.ext4 ${card}-part2
echo ""
mkdir /run/ct1
mkdir /run/ct2
mount ${card}-part1 /run/ct1
mount ${card}-part2 /run/ct2
#tar -C /run/ct1 -xvf bootfs-part1.tar.gz
echo "Copying bootfs..."
cp bootfs/* /run/ct1
echo ""
echo "Rsyncing rootfs..."
rsync -axPHS --delete $targetdir/ /run/ct2 > /dev/null
echo ""
echo "Umounting bootfs..."
umount /run/ct1
echo "Umounting rootfs..."
umount /run/ct2
echo  "Done."
echo "Removing temp folders..."
rm /run/ct1 -R
rm /run/ct2 -R
echo "Done."
echo "Ejecting card..."
eject $card
echo "Done."
Why don't you use something similar in your nand-sata-install script. Maybe you know some drawbacks of this method? Sorry for my english, if it sounds rude.
