grablife Posted February 27, 2023 Share Posted February 27, 2023 I was running on Armbian_23.02.0-trunk.0112_Orangepi5_jammy_legacy_5.10.110_cinnamon_desktop. For the most part, it worked but the mouse cursor would randomly disappear while remaining functional but invisible. I tried to upgrade using apt-get update and apt-get full-upgrade and after a reboot, it now just displays a flashing underscore. I can SSH into the OS so it's partially functional. Shows as Armbian 23.02.2 Jammy with Linux 5.10.110-rockchip-rk3588 Contents of boot.log: ------------ Mon Feb 27 07:24:15 PST 2023 ------------ done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.37.2 [/usr/sbin/fsck.ext4 (1) -- /dev/nvme0n1p2] fsck.ext4 -a -C0 /dev/nvme0n1p2 /dev/nvme0n1p2: clean, 246632/29294592 files, 4225509/117146880 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to ^[[1mUbuntu 22.04.2 LTS^[[0m! [^[[0;32m OK ^[[0m] Created slice ^[[0;1;39mSlice /system/modprobe^[[0m. [^[[0;32m OK ^[[0m] Created slice ^[[0;1;39mSlice /system/serial-getty^[[0m. [^[[0;32m OK ^[[0m] Created slice ^[[0;1;39mUser and Session Slice^[[0m. [^[[0;32m OK ^[[0m] Started ^[[0;1;39mForward Password Requests to Wall Directory Watch^[[0m. [^[[0;32m OK ^[[0m] Set up automount ^[[0;1;39mArbitrary Executable File Formats File System Automount Point^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mUser and Group Name Lookups^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mSlice Units^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mMounting snaps^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mSwaps^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mSystem Time Set^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mLocal Verity Protected Volumes^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mSyslog Socket^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mfsck to fsckd communication Socket^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39minitctl Compatibility Named Pipe^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mJournal Audit Socket^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mJournal Socket (/dev/log)^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mJournal Socket^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mudev Control Socket^[[0m. [^[[0;32m OK ^[[0m] Listening on ^[[0;1;39mudev Kernel Socket^[[0m. Mounting ^[[0;1;39mHuge Pages File System^[[0m... Mounting ^[[0;1;39mPOSIX Message Queue File System^[[0m... Mounting ^[[0;1;39mKernel Debug File System^[[0m... Mounting ^[[0;1;39mKernel Trace File System^[[0m... Starting ^[[0;1;39mRestore / save the current clock^[[0m... Starting ^[[0;1;39mSet the console keyboard layout^[[0m... Starting ^[[0;1;39mCreate List of Static Device Nodes^[[0m... Starting ^[[0;1;39mLoad Kernel Module chromeos_pstore^[[0m... Starting ^[[0;1;39mLoad Kernel Module configfs^[[0m... Starting ^[[0;1;39mLoad Kernel Module drm^[[0m... Starting ^[[0;1;39mLoad Kernel Module efi_pstore^[[0m... Starting ^[[0;1;39mLoad Kernel Module fuse^[[0m... Starting ^[[0;1;39mLoad Kernel Module pstore_blk^[[0m... Starting ^[[0;1;39mLoad Kernel Module pstore_zone^[[0m... Starting ^[[0;1;39mLoad Kernel Module ramoops^[[0m... Starting ^[[0;1;39mLoad Kernel Modules^[[0m... Starting ^[[0;1;39mRemount Root and Kernel File Systems^[[0m... Starting ^[[0;1;39mColdplug All udev Devices^[[0m... [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mHuge Pages File System^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mPOSIX Message Queue File System^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mKernel Debug File System^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mKernel Trace File System^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mRestore / save the current clock^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mCreate List of Static Device Nodes^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module chromeos_pstore^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module configfs^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module drm^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module efi_pstore^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module fuse^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module pstore_blk^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module pstore_zone^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Module ramoops^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad Kernel Modules^[[0m. Mounting ^[[0;1;39mFUSE Control File System^[[0m... Mounting ^[[0;1;39mKernel Configuration File System^[[0m... Starting ^[[0;1;39mApply Kernel Variables^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mRemount Root and Kernel File Systems^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mFUSE Control File System^[[0m. Starting ^[[0;1;39mPlatform Persistent Storage Archival^[[0m... Starting ^[[0;1;39mLoad/Save Random Seed^[[0m... Starting ^[[0;1;39mCreate System Users^[[0m... [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mKernel Configuration File System^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mApply Kernel Variables^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mCreate System Users^[[0m. Starting ^[[0;1;39mCreate Static Device Nodes in /dev^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mPlatform Persistent Storage Archival^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad/Save Random Seed^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mCreate Static Device Nodes in /dev^[[0m. Starting ^[[0;1;39mRule-based Manager for Device Events and Files^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mSet the console keyboard layout^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mPreparation for Local File Systems^[[0m. Mounting ^[[0;1;39mMount unit for bare, revision 5^[[0m... Mounting ^[[0;1;39mMount unit for core, revision 14452^[[0m... Mounting ^[[0;1;39mMount unit for core, revision 14789^[[0m... Mounting ^[[0;1;39mMount unit for core20, revision 1826^[[0m... Mounting ^[[0;1;39mMount unit for gtk-common-themes, revision 1535^[[0m... Mounting ^[[0;1;39m/tmp^[[0m... [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mMount unit for bare, revision 5^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mMount unit for core, revision 14452^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mMount unit for core, revision 14789^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mMount unit for core20, revision 1826^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39m/tmp^[[0m. [^[[0;32m OK ^[[0m] Mounted ^[[0;1;39mMount unit for gtk-common-themes, revision 1535^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mMounted snaps^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mLocal File Systems^[[0m. Starting ^[[0;1;39mArmbian leds state^[[0m... Starting ^[[0;1;39mArmbian ZRAM config^[[0m... Starting ^[[0;1;39mSet console font and keymap^[[0m... Starting ^[[0;1;39mTell Plymouth To Write Out Runtime Data^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mSet console font and keymap^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mTell Plymouth To Write Out Runtime Data^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mArmbian leds state^[[0m. [^[[0;32m OK ^[[0m] Started ^[[0;1;39mRule-based Manager for Device Events and Files^[[0m. [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mColdplug All udev Devices^[[0m. Starting ^[[0;1;39mHelper to synchronize boot up for ifupdown^[[0m... Starting ^[[0;1;39mShow Plymouth Boot Screen^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mHelper to synchronize boot up for ifupdown^[[0m. Starting ^[[0;1;39mRaise network interfaces^[[0m... [^[[0;32m OK ^[[0m] Started ^[[0;1;39mShow Plymouth Boot Screen^[[0m. [^[[0;32m OK ^[[0m] Started ^[[0;1;39mForward Password Requests to Plymouth Directory Watch^[[0m. [^[[0;32m OK ^[[0m] Reached target ^[[0;1;39mLocal Encrypted Volumes^[[0m. [^[[0;32m OK ^[[0m] Created slice ^[[0;1;39mSlice /system/systemd-backlight^[[0m. Starting ^[[0;1;39mLoad/Save Screen Backlight Brightness of backlight:backlight_1^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad/Save Screen Backlight Brightness of backlight:backlight_1^[[0m. Starting ^[[0;1;39mLoad/Save Screen Backlight Brightness of backlight:backlight^[[0m... [^[[0;32m OK ^[[0m] Finished ^[[0;1;39mLoad/Save Screen Backlight Brightness of backlight:backlight^[[0m. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 27, 2023 Share Posted February 27, 2023 Hooking up a serial console is best possible way to debug boot issues. 0 Quote Link to comment Share on other sites More sharing options...
