Posted (edited)
@MattWestBThank you for your answer! I admit I'm not really savy on this stuff, so thanks for the clarification!
So I don't know what to do with this WiFi, I think I won't be able to make it work since it's not detected. I find hard to believe it failed honestly, it used to work when I use the box as an Android box, but I don't have idea on what to do.
I was messing around: it looks like the bluetooth is working?
I've been reading around this thread, if I'm not wrong WiFi and Bluetooth are embedded but have separate firmware (?), but this should rule out hardware defect, right?
EDIT: if I just run rk3318-config and chose X88 PRO B this output disappears, if I go into armbian-config and chose "SP6330" tree overlay bluetooth looks like it works (output in photo), but wifi does not work.
https://paste.armbian.com/irewiretip
Edited by CtrlValCanc
Bluetooth works if i load with armbian-config overlay?
If you have selecting one working (LED)configure in rk3318-config you shall have somthing like "brcmfmac" then the chip is initiating and then more then the system is loading the firmware in it in the log and i have not seen it then looking.
In your log i see:
[ 2.987024] mmc3: Failed to initialize a non-removable card
[ 3.032919] mmc1: Failed to initialize a non-removable card
and mmc0 is not conected and mmc1 is the eMMC
Posted (edited)
@MattWestBThank you for your time.
I attachboard photos, it's a X88 Pro 10 android-box. I can read on the second photo, under the sticker, X88 PRO B RK3318 D4 V1 2 so I chose X88 PRO B config, but it won't work neither bluetooth or wifi (at least if I chose SP6330 in armbian-config I have an output to that grep).
I look at the overlays and it should be loading the config (the last one is rk3318-box-wlan-ap66330, the one added by armbian-config).
I might be missing something, I feel quite clueless.
Keep adding images. I really hope people don't get notification with every edit
The Linux kernel is not detecting the WiFi card then its need the power being enabled by one GPIO from the system.
Try other LED / board config in rk3318-config and also look in the head of it if its showing if the system have detecting some card (your screenshot its written: Wifi device: Not available) after doing the change and rebooting the device (some config can making the device not booting at all !!).
Posted (edited)
@mattwestB
Yes yesterday I tried to enable them all and got an unbootable system!
I just tried all of them, one by one, except the one for rk3328, reboot and re-run rk3318-config, still says wifi not detected. I was reading yesterday something about double reboot to make rk3318-config apply the settings, is it something I should still do or is it "fixed"?
Because I really don't know what is not working oof
If you have one backup of the original firmware or log from it then booting perhaps @jock can helping digging what is needed for getting the WiFi card being powered on but this boxes is little trashy how they have implementing the hardware.
Posted (edited)
@MattWestB I don't have a backup, but I flashed this https://mega.nz/file/f1okwZjB#7VrJQQRP9QLEJsT1MazpQO0rQAxSssnajUp4uhvpF4Y and I remember it working. Unfortunatly I like tech stuff but I'm not really tech savy.
Btw it's a common box, it's an x88 pro 10, I saw people in this post with the same box as me having wifi working easily, so I'm starting to think it's a me problem.
Also, I'm not sure about the ethernet. It stopped working AGAIN (and I had put static ip). It shows eth0
: <NO-CARRIER,BROADCAST,MULTICAST,UP>, doesn't have a local ip and doesn't ping anything. but if I connect the usb-ethernet adapter it immediatly works @jock. Is this the problem you were talking about in your first answer?
Maybe my box is failing, idk
Installed Stock Android Image: it can read WiFi network, but I am not able to connect to a password-protected wifi. I did a hotspot with no security password and it connects, so the wifi card is working!!!! Why is it not working under Armbian??
Ethernet looks dead instead, it says "not connected" even if I connect it.
It is common for tv boxes that some devices don't work out of the box. Tv boxes are not officially supported and will never be officially supported in armbian mainly for the reason they carry wildly different hardware and it is not feasible to give any kind of official support, hence it is totally a community effort.
The reason rk3318-config does not show any wifi chip is that the wifi chip is either connected to a different mmc bus, or the "power on" gpio pin is the wrong one. Inspection of the device tree from the original firmware will surely clarify what is going on.  Your particular board (X88 PRO B) is known to have the wifi chip on the "alternative" sdmmc_ext bus. In your case you have to run rk3318-config for a first time, configure the board with led-conf2, reboot, run again rk3318-config (this time it should show the wifi vendor and device IDs), let it configure the proper device tree overlay, reboot again and you should finally be able to see the wifi adapter.
About the ethernet problem, I see NO-CARRIER: either the cable is not connected properly or the ethernet port is faulty.
dmesg log is always very appreciated for debugging.
@jock thank you again for your time. Since the ethernet looks dead/faulty, i would like to have my WiFi working.
that's the problem, it still shows WiFi not avaible like the pics I posted earlier, it makes me run it like the first time. In /boot/armbianEnv.txt I do see the overlays and uboot says it applys them.
I thought armbianmonitor log would be enough, sorry (posting the new one e here in case it is useful), and here the dmseg:mesg.txt
My fault, didn't notice the log in the previous post. I will look into them.
Posted (edited)
@jock don't worry, my posts are kinda messy and full of edits. You're doing me a favour, so I'm just grateful you're taking your time for me.
If you need some other stuff, let me know.
Posted (edited)
@jock DUDE!!!!! I rebooted it and it immediatly showed wlan0 in ip -a, I used armbian-config to connect to my home wifi, ping 1.1.1.1 AND IT WORKS!!!
THANK YOU SO MUCH!!! I don't know what and how you did it, but you are a wizard and saved this box since ethernet is dead!!!!!
Grazie mille ancora.
@CtrlValCanc glad to hear you got it working, prego! ;)
About the ethernet, if the hardware is really failing, you may want to try and set the port to 10Mbps instead of 100Mbps with ethtool; it won't give you a fast connection, but at least the device could be reached on the net for maintenance.
Posted (edited)
@jock  tried ethtool -s eth0 speed 10 duplex full autoneg off, but if I run ip a I still see no-carrier.
also, output of ethtool eth0 is:
ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes:
				10baseT/Half 10baseT/Full
				100baseT/Half 100baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotlation: No
Advertised FEC modes: Not reported
Speed: 10Mb/s
Duplex: Full
Auto-negotiation: off
Port: Twisted Pair
PHYAD: 0
Transceiver: external
MDI-X: Unknown
Supports Wake-on: Ug
Wake-on: d
Current messoge level: 0x0000003f_(63)
						drv probe ink timer ifdown ifup
Link detected: no
ethtool -i etho
driver: st gmac
version: 6.12.19-current-rockchip64
firmware-version:
expansion-rom-version:
bus-info: ff550000.ethernet
supports-statistics: yes
supports-test: No
supports-eeprom-access: no
supports-register-dump: yes
supports-priy-fla
There might be some error as I used phone photo-to-text and i corrected manually.
but the output is the same one.
The Link detected: no makes me think it does not even know there is an ethernet cable plugged in.
Visually it looks like the ethernet port and the chip are fine.
ALSO: now everytime I upgrade kernel should I copy the dtb file you made me? Should I stop upgrading? Because I just upgraded (running update&&upgrade in hope my eth will be bringed back to life) and WiFi was not showing. I repasted it and it works. Do I risk incompabilities? Will it be updated to mainstream? (I don't even know if this question makes sense lol)
Thank you once again for your time thought, at least one of the two is working I guess. It just bugs me that the card is detected but not functional!
I have a T9 rk3328 tv box with rtl8723bs wifi. This chip got burned out a hot day and the box powers off when is on.
There is a way to kill the sdio?
Posted (edited)
Hello, after update my h96 max (rk3318 armbian 25.2.3 rockchip rc7 6.14 to rockchip 6.14) system dont start.
Cant upload image, connect to monitor show:
Failed to load `/boot/dtb/rockchip/rk3318-box.dtb`
Failed to load `/boot/dtb/rockchip/overlay/rockchip-rk3318-box-led-conf2.dtbo`
Failed to load `/boot/dtb/rockchip/overlay/rockchip-rk3318-box-wlan-ap6334.dtbo`
Failed to load `/boot/dtb/rockchip/overlay/rockchip-rk3318-fixup.scr`
unknow command `kaslrseed` - try `help`
Error: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Edited by Андрей Димов
Hello, you may want to edit the device tree and turn off the mmc@... node where the sdio wifi chip is connected. You may find it easily looking for supports-sdio property, then switch status property do disabled
Posted (edited)
i have the similar issue as
my box is H96 Max RK3318_V1.4 2020/06/29, upgraded from 24.11.3 to latest
stuck on red light and no display
Edited by EAZY BLACK
Posted (edited)
the same thing...
i burn this image again
https://users.armbian.com/jock/web/rk3318/Armbian_23.08.0-trunk_Rk3318-box_bookworm_edge_6.3.13_minimal.img.xz
then after updates (apt update && apt full-upgrade -y)
i found that there is no file rk3318-box.dtb in the /boot/dtb/rockchip folder
i copied rk3318-box.dtb to this location https://drive.google.com/drive/folders/1cXGTblufMjlu-I2aH3hPjgUcU3DzfVQt?usp=sharing
I just copied rk3318-box.dtb from original image (after fresh install), then after update before reboot copied it to boot folder, don't know if it's right or not...
hardware:  H96 Max RK3318_V1.4
Edited by Agitech
some info add
Posted (edited)
Hi all
i am using H96 Max RK3318_V1.4 with armbian for ipkvm purposes
this project
https://github.com/srepac/kvmd-armbian.git
After fresh installation, the USB3 port on the TV box is in host mode and needs to be switched to OTG mode.
To do this need to change the usb3 port section in the device tree information.
dr_mode = “host”
need modify to
dr_mode = “peripheral”
For this i copy the /boot/dtb/rockchip/rk3318-box.dtb file to some location (/root/dtc/original for example)
then i run a command
dtc -I dtb -O dts /root/dtc/original/rk3318-box.dtb -o /root/dtc/original/rk3318-box.dts
after i modify dts file as i need (above) and copy them to the /root/dtc/modified folder for example
after run command
dtc -I dts -O dtb /root/dtc/modified/rk3318-box.dts -o /root/dtc/modified/rk3318-box.dtb
and then i overwrite the original file in the /boot/dtb/rockchip/ folder with this modified.
Then after reboot usb port in otg mode.
Is this the right way or not?
Edited by Agitech
some update
You really should create a device tree overlay that just changes that attribute.
The biggest downside of what you have done, is that every time you upgrade the linux kernel your change will be lost (as the new dtb file from that kernel will be installed) and you will need to redo this work with each upgrade.
Posted (edited)
There is another problem. When running armbian-config and going to System->Kernel->SY210-Manage device tree overlays
the program closes with the message "Invalid overlay prefix rockchip"
root@rk3318-box:~# armbian-config
Initializing script
Loaded Runtime variables...
The current Armbian 25.2.3 stable (bookworm) is supported.
Check distro
Loaded Dialog...
Loaded Docs...
Loaded System helpers...
Loaded Network helpers...
Loaded Software helpers...
Loaded Runtime conditions...
Invalid overlay_prefix rockchip
root@rk3318-box:~#
Edited by Agitech
Good day people. Tell me, there is an ancient 4k ULTRA HD PRO 2/16 Gb H96MAX box (blue board). After installing armbian 23.08.0 on it, everything works well RIGHT AWAY even without using overlays. However, after apt upgrade, armbian25.2.3 arrives and the system hangs at boot. The inspection showed that in/boot/dtb/( in reality it is/boot/dtb-6.3.13-rockchip64/rockchip) there is no hardware tree). Moving the hardware tree from 23.08.0 allows the system to boot, but hdmi hangs (by ssh the system works, but the screen of the real console hangs). In addition, WiFi is no longer visible (it is not in the settings at all), connection is possible only by RJ45. Question: are there any chances to make 25.2.3 work normally (and what is needed from me for this) or just fix the system on 23.08.0? PS Many thanks to the community for working image 23.08.0
hey so i have a rk3328 tv box with 1gb and 8gb flash , wanted to install linux on it for fun , but failed here is what i did.
i couldnt boot from sd so followed (https://forum.armbian.com/topic/17597-csc-armbian-for-rk3318rk3328-tv-box-boards/?do=findComment&comment=130453) the file in the comment was unavailabe so i got the MiniLoaderAll.bin from here (http://112.124.9.243/dvdfiles/RK3328/tools/)
everything with rkdeveloptool went okay , but after flashing the image on the emmc it still didnt want to boot , but now i could boot multitool from the sd card and flash the image from there. however still nothing , tried to burn the image directly on the sd card and boot form there but still doesnt boot , tried rkdeveloptool again , nothing  , but now i cant even use rkdeveloptool , when i plug it to my laptop "lsusb" doesnt even show it .  it still boots form the sd card with multitool and thats it . it only boots when the sd card has multitool.
tried flashing it a few more times from multitool but still nothing.
is it bricked?
also sorry if the post is hard to read , my english is not good and im new to this stuff. help appreciated
/ i dont know how to get my device's dtb
/ the only dmesg i found was inside multitool
message (3).txt
