On 11/21/2025 at 4:02 AM, QwertyChouskie said:
Is there any chance of this image running on a device using the RKPX30 chip?  From some research, it seems to be a variant of the RK3326, and I'm not sure how similar the 3328 and 3326 are or are not.  Or is there another Armbian image for the RKPX30/RK3326?  Specifically looking to run Armbian on this: https://docs.revrobotics.com/duo-control/control-system-overview/driver-hub-specifications
rk3326 and rk3328 are not the same thing, neither is px30. Definitely no chances to run this on those SoCs; I don't know if there are images for boards using px30/rk3326 in armbian.
Hi,
First of all, sorry for lengthy post and that I ask a lot of things at once, I am very new to linux and this would be my first real experience.
I am trying to set up home automation and home assistant server. As I am just getting started to learn all the ropes, I thought about what could be used for sečrver and I remembered that I have an old T9 android TV box see the attachement, I read through this thread and tried to follow the instructions throughout the posts.
I burned the armbian image to sd card, which insterted into the sd slot on the T9 board, however I am unable to get the board to boot from the sd card.
The box boots normally into android, when no SD card is insterted. When the card is inserted, nothing happens and the box does not turn on at all. It may be a big ask, but would someone be able and willing to help me find out the next possible steps? I feel a bit overwhemed as I am not very knowledgable in this field and unsure how to follow the instructions, or better said, I am not sure if I am following the instructions right.
Thank you!
