jock Posted November 22, 2025 Author Posted November 22, 2025 On 11/21/2025 at 4:02 AM, QwertyChouskie said: Is there any chance of this image running on a device using the RKPX30 chip? From some research, it seems to be a variant of the RK3326, and I'm not sure how similar the 3328 and 3326 are or are not. Or is there another Armbian image for the RKPX30/RK3326? Specifically looking to run Armbian on this: https://docs.revrobotics.com/duo-control/control-system-overview/driver-hub-specifications rk3326 and rk3328 are not the same thing, neither is px30. Definitely no chances to run this on those SoCs; I don't know if there are images for boards using px30/rk3326 in armbian. 0 Quote
sailorbg Posted November 29, 2025 Posted November 29, 2025 Good day, @jock the link of the Multitool is not valid anymore. Please help where I can download from? Thank you for your efford. 0 Quote
ДынеЗаур Posted December 7, 2025 Posted December 7, 2025 https://users.armbian.com/users.armbian.com/jock/web/rk3318/ It seems like old firmware is stored here. 1 Quote
Leneren Posted Friday at 09:01 PM Posted Friday at 09:01 PM Hi, First of all, sorry for lengthy post and that I ask a lot of things at once, I am very new to linux and this would be my first real experience. I am trying to set up home automation and home assistant server. As I am just getting started to learn all the ropes, I thought about what could be used for sečrver and I remembered that I have an old T9 android TV box see the attachement, I read through this thread and tried to follow the instructions throughout the posts. I burned the armbian image to sd card, which insterted into the sd slot on the T9 board, however I am unable to get the board to boot from the sd card. The box boots normally into android, when no SD card is insterted. When the card is inserted, nothing happens and the box does not turn on at all. It may be a big ask, but would someone be able and willing to help me find out the next possible steps? I feel a bit overwhemed as I am not very knowledgable in this field and unsure how to follow the instructions, or better said, I am not sure if I am following the instructions right. Thank you! 0 Quote
jock Posted 14 hours ago Author Posted 14 hours ago 16 hours ago, Leneren said: I burned the armbian image to sd card, which insterted into the sd slot on the T9 board, however I am unable to get the board to boot from the sd card. Probably you have to read again the installation instructions in the first page, in particular you have to use the multitool 0 Quote
0230826 Posted 11 hours ago Posted 11 hours ago Excuse me,jock. My TV-Box is the H96Max rk3318 4+64G.The box was installed Ubuntu 24.04,kenel 4.4,desktop vension by the seller。But now, i want to install the armbian system in the box.There are some problem for me that i have no HDMI-wire and no usb-keyboard,just only an usb-A to usb-A data-wire and a notepad computer。i think that i can't use the multitool.img to help me install the armbian. So, can you give me some help to install the armbian by USB-A to USB-A data-wire?I through some search some article to know maybe the RKdevtool can help me,but the tool need the loader.bin to flash the image. I don't know where is the loader.bin for rk3318.can you help me? 0 Quote
jock Posted 4 hours ago Author Posted 4 hours ago @0230826 you can follow instructions in this page by @fabiobassa The loader is there too 1 Quote
0230826 Posted 1 hour ago Posted 1 hour ago https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/page/66/#findComment-231768 Thanks your help,jock. I hava a try to use the rkdevtool to install armbian. I just choose the iamge in url https://github.com/armbian/community/releases/download/26.2.0-trunk.151/Armbian_community_26.2.0-trunk.151_Rk3318-box_trixie_current_6.12.63_minimal.img.xz. But,there catch a error message in the tool. I don't known is this image is error or other reason? 0 Quote
