On 11/21/2025 at 4:02 AM, QwertyChouskie said:
Is there any chance of this image running on a device using the RKPX30 chip?  From some research, it seems to be a variant of the RK3326, and I'm not sure how similar the 3328 and 3326 are or are not.  Or is there another Armbian image for the RKPX30/RK3326?  Specifically looking to run Armbian on this: https://docs.revrobotics.com/duo-control/control-system-overview/driver-hub-specifications
rk3326 and rk3328 are not the same thing, neither is px30. Definitely no chances to run this on those SoCs; I don't know if there are images for boards using px30/rk3326 in armbian.
Hi,
First of all, sorry for lengthy post and that I ask a lot of things at once, I am very new to linux and this would be my first real experience.
I am trying to set up home automation and home assistant server. As I am just getting started to learn all the ropes, I thought about what could be used for sečrver and I remembered that I have an old T9 android TV box see the attachement, I read through this thread and tried to follow the instructions throughout the posts.
I burned the armbian image to sd card, which insterted into the sd slot on the T9 board, however I am unable to get the board to boot from the sd card.
The box boots normally into android, when no SD card is insterted. When the card is inserted, nothing happens and the box does not turn on at all. It may be a big ask, but would someone be able and willing to help me find out the next possible steps? I feel a bit overwhemed as I am not very knowledgable in this field and unsure how to follow the instructions, or better said, I am not sure if I am following the instructions right.
Thank you!
Probably you have to read again the installation instructions in the first page, in particular you have to use the multitool
Excuse me,jock. My TV-Box is the H96Max rk3318 4+64G.The box was installed Ubuntu 24.04,kenel 4.4,desktop vension by the seller。But now, i want to install the armbian system in the box.There are some problem for me that i have no HDMI-wire and no usb-keyboard,just only an usb-A to usb-A data-wire and a notepad computer。i think that i can't use the multitool.img to help me install the armbian. So, can you give me some help to install the armbian by USB-A to USB-A data-wire?I through some search some article to know maybe the RKdevtool can help me,but the tool need the loader.bin to flash the image. I don't know where is the loader.bin for rk3318.can you help me?
https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/page/66/#findComment-231768
Thanks your help,jock.  I hava a try to use the rkdevtool to install armbian. I just choose the iamge in url https://github.com/armbian/community/releases/download/26.2.0-trunk.151/Armbian_community_26.2.0-trunk.151_Rk3318-box_trixie_current_6.12.63_minimal.img.xz.
But,there catch a error message in the tool. I don't known is this image is error or other reason?
Posted (edited)
Hello everyone, I hope I'm in the right place. So I got an H50 tv box (T98) that I found lying around, and installed via the multitool everything including armbian itself, which works properly. The issue that I have is that I had to do all via ssh and haven't been able to get any HDMI output, tried updating lightdm, switching it to sleek, and at this point idk what else to do.
Thank you in advance!
Edited by OmegaCyclops
Posted (edited)
Quote
@jockLater, I tried to install rkdeveloptool on another Linux server and flashed the loader.bin first and then the image by entering the command. Finally successfully flashed. But tragedy is about to be born, when the flash is successful, I did not SSH to connect to the new armbian and configure the relevant configuration immediately, but shut down and prepare to re-enter maskrom mode to flash the desktop version of the image again, the result is that this time I can no longer enter maskrom mode, no matter how long I press the reset button to plug in USB 2.0 OTG or press it, the box will no longer enter maskrom mode. Along with this, it could not start the Armbian system that was flashed before. I began to wonder if it was painted into bricks, but this board shouldn't be so fragile.
Edited by 0230826
@jockNow, I've finally solved this problem. Successfully flashed the latest version of armbian, https://github.com/armbian/community/releases/download/26.2.0-trunk.151/Armbian_community_26.2.0-trunk.151_Rk3318-box_noble_current_6.12.63_gnome_ desktop.img.xz
Next, I will share my problem-solving journey. I found that I couldn't enter maskrom/loader mode anyway, and when I accidentally inserted the USB flash drive into the multitool.img into the TV box and powered it directly on, I found that it actually started the system directly in the USB flash drive. So I guess that it may have changed the boot order after flashing the loader.bin before, and the armbian system I flashed in before it continued to toss before it could be configured, probably because the system files of the root partition were corrupted, causing it to not boot normally. Therefore, I simply tried to flash the firmware of the rk3188-box in the official community directly into the USB flash drive, because after these images are flashed into the USB flash drive, there is only the root partition, that is, the system. And there is no boot partition. I guess the boot partition may have been written somewhere else, and I don't need to worry about it anymore. So, I plugged the USB flash drive into the latest rk3318 firmware into the box and waited for a few minutes after powering on it directly and starting it, it obtained the IP address assigned by my router DHCP, I was so excited, I quickly connected to the rk3318-box through SSH, and made the preliminary configuration. Quickly enter the command armbian-install and select item 2, and immediately write the system on the USB flash drive to emmc. After the writing is completed, turn it off, unplug the USB flash drive, power on, wait for a few minutes, and the startup is successful. It means that I have successfully flashed the phone this time. Thank you very much for your help. @jockand @fabiobassa, You're passionate and highly skilled.
I'm looking for a ROM because this Android box only stops at the logo. However, there's a problem with the PCB board type 3328 but the chip is 3318. How do I find the firmware? Is there anyone here who has it? And I've tried flashing with RK3328 but it still bootloops.
What model is your device? Got a photo?
This is not a place for Android ROMs, only armbian here.
Totally new to this system, need some help where to start and how to do it i have the RK3328, i verified this via AIDA,
how can i install armbian system on this one can someone please help which are the correct images etc..
any steps would be highly appreciated.
thanks
Suz
Hello everyone!
I have TV box MX10 based on RK3328.
It freezes on the manufacturer's label on boot.
So I need to update the firmware. I followed the instructions from 1st post but didn't get success.
When I run "Erase eMMC" it change modal windows with messages very fast and at the end shows "Successfully done". The same when I run "Write new image". It shows immediately that it is flashed.
I have run the shell and checked `dmesg` and found there errors like "group start error -110, status 0x0".
What does it mean?
Then I installed "rkdeveloptool" and followed steps from this thread:
 - ld - I see TV box in Loader mode
 - rd 3 - switch to Maskrom mode
 - dd loader.bin - done
- wl 0x0 armbian.img - done
 - rd - toexit
when I run tv box I got the same freeze on logo and that's all
Is eMMC died? or?
7 hours ago, SanchopansA said:
Is eMMC died? or?
Probably dead, yes. It looks like it is in read-only mode, so you cannot even erase it.
Unfortunately for you, the way I designed the armbian boot requires either an empty flash or an installed u-boot that boots from sdcard first.
You have three options:
1) hack the armbian boot using the multitool bootloader, but I don't suggest doing so because updates may overwrite the changes
2) remove the eMMC phisically, desoldering it
3) short the eMMC clock pins permanently, similar to what you would do when you want maskrom mode. The board will then always boot from sdcard. See the unbrick paragraph in the first post for some instructions.
@jock Thank you for your reply.
Unfortunately, I can't do it :(
I tried to short it, but it doesn't load from the SD card. I shorted it with a piece of wire.
When I do it with USB connected, I see the device is in Maskrom.
Here the console output from rkdeveloptool using:
root@lensky-lp:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 10c4:8105 Silicon Labs USB OPTICAL MOUSE
Bus 001 Device 005: ID 04ca:707f Lite-On Technology Corp. HP Wide Vision HD Camera
Bus 001 Device 006: ID 0bda:b00b Realtek Semiconductor Corp. Realtek Bluetooth 4.2 Adapter
Bus 001 Device 008: ID 1ea7:0066 SHARKOON Technologies GmbH [Mediatrack Edge Mini Keyboard]
Bus 001 Device 009: ID 2207:320c Fuzhou Rockchip Electronics Company RK3328 in Mask ROM mode
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
root@lensky-lp:~# rkdeveloptool ld
DevNo=1	Vid=0x2207,Pid=0x320c,LocationID=104	Maskrom
root@lensky-lp:~# rkdeveloptool td
Test Device failed!
---------------------Tool Usage ---------------------
Help:			-h or --help
Version:		-v or --version
ListDevice:		ld
DownloadBoot:		db <Loader>
UpgradeLoader:		ul <Loader>
ReadLBA:		rl  <BeginSec> <SectorLen> <File>
WriteLBA:		wl  <BeginSec> <File>
WriteLBA:		wlx  <PartitionName> <File>
WriteGPT:		gpt <gpt partition table>
WriteParameter:		prm <parameter>
PrintPartition:		ppt
EraseFlash:		ef
TestDevice:		td
ResetDevice:		rd [subcode]
ChangeStorage:		cs [storage: 1=EMMC, 2=SD, 9=SPINOR]
ReadFlashID:		rid
ReadFlashInfo:		rfi
ReadChipInfo:		rci
ReadCapability:		rcb
PackBootLoader:		pack
UnpackBootLoader:	unpack <boot loader>
TagSPL:			tagspl <tag> <U-Boot SPL>
root@lensky-lp:~# rkdeveloptool rid
Reading flash ID failed!
root@lensky-lp:~# rkdeveloptool cs 2
AMO: ERR_DEVICE_WRITE_FAILED
Change Storage failed!
root@lensky-lp:~# rkdeveloptool ppt
Read GPT failed!
Read parameter failed!
Not found any partition table!
root@lensky-lp:~# rkdeveloptool db /home/lensky/Downloads/For\ RK3328\ devices/RK3328MiniLoaderAll_V2.50.bin
Downloading bootloader succeeded.
**********Partition Info(parameter)**********
NO  LBA       Name
00  00002000  uboot
01  00004000  trust
02  00008000  misc
03  0000A000  baseparamer
04  0000A800  resource
05  00012000  kernel
06  00022000  boot
07  00032000  recovery
08  00042000  backup
09  00062000  cache
10  000A2000  metadata
11  000AA000  kpanic
12  000AC000  system
13  003AC000  userdata
As you see after boot it looks like the flash is empty. I can't ready any info and there no partitions. But after download bootloader command I see partiosions and can read flash info and chip info. After reboot all is disappear again.
This is my board:
This is my eMMC chip:
I have found YouTube video how to short the clock pin for my board. On the opposite side, I need to short these pins:
When I insert the SD card and boot the device, it just lights the red led and nothing more.
Is something I do wrong?
image.png.6838b531d4fe94b0dd88503aa9d72d20.pngThanks for the feedback , i have finally downloaded this version and burn into sd card , put in sd card then reconnect power, the system normal boot i cant see armbian screen,
the blue light is on, and nothing on screen or dark screen
can someone point me please what is happening.
Posted (edited)
I have a T9 2017 rk3328 box running Ubuntu xcfe many hours for downloading. There are not problems but xcfe displays lunchs himself many times and i have to close 20 or more instances of this application when checking the progress. Box is not crashed by this funny clonning. is it  possible to avoid this?
p.d. la test trunk
Edited by maka
