Hi,
First of all i'd like to thanks thanks all of you for your job or questions that help me to rescue from trash rk3318 based devices.
I recover from a friend a X88 pro 10 (4G/128G), witch is a really chip old android-box. I looking for making a media center running kodi and and minimal web browser for unsupported kodi streaming services.
I successfully install armbian_community trunk (Rk3318-box_noble_current_6.xx.xx_xfce_desktop.img.xz) using multitool.
Spoiler
recover with original X88pro_B_rk3318_d4_11.0_SP6330_20210125_r1(X88pro10 1.0.1).img with Linux_Upgrade_Tool (RK-wiki | github)
    _             _    _                                         _ _
   /_\  _ _ _ __ | |__(_)__ _ _ _    __ ___ _ __  _ __ _  _ _ _ (_) |_ _  _
  / _ \| '_| '  \| '_ \ / _` | ' \  / _/ _ \ '  \| '  \ || | ' \| |  _| || |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|_\__\___/_|_|_|_|_|_\_,_|_||_|_|\__|\_, |
                                 |___|                                 |__/
 v26.2 rolling for RK3318 Box running Armbian Linux 6.18.21-current-rockchip64
 Packages:     Ubuntu stable (noble)
 Support:      for advanced users (rolling release)
 IPv4:         (LAN) 192.168.xxx.xxx (WAN) xxx.xxx.xxx.xxx
 Performance:
 Load:         2%                Uptime:         1d 22h 21m
 Memory usage: 14% of 3.87G
 CPU temp:     45°C                Usage of /:   6% of 114G
 RX today:     1 MiB
 Tips:
 Becoming a sponsor? https://github.com/sponsors/armbian
I run rk3318-config and choose this config:
  • RK3318 (max 1.1Ghz...)
  • no selection on eMMC additional speed options
  • rk3318-box-led-conf2 X88_PR_B_boards
Reboot and Install kodi and codec with :
sudo apt install ffmpeg mpv kodi kodi-repository-kodi --install-recommends
I have some issues :
  1. xfce menu is quite slow when I navigate for choosing app.
  2. chromium is very very slow and video on youtube are too lagy when decoding
  3. Kodi works on xfce but can't decode video, i try on standalone (choose on connection window), still can't decode.
I looking on this post without success and this one, same issue.
If anyone have a idea to help me to save this device and make me able to use it as a media center.
Thanks
22 hours ago, Sharkam said:
can we achieve in browser video hardware acceleration now, and how?
I haven't looked at this use case for a very long time. I can no longer remember since when it has worked out-of-the-box for me. Since decoder support has been part of the GStreamer framework for a very long time, hardware-supported video decoding works for all browsers that use this framework with the standard packages of the distribution of my choice.
When v4lrequest support was still implemented with the out-of-tree patches using the stateful method, it also worked with Firefox out-of-the-box. Just an accordingly patched FFmpeg framework was required. This is likely no longer going to work with the current patches for the FFmpeg framework and requires an additional implementation in Firefox. I suspect, however, that this will only happen after the official inclusion of v4lrequest support in the FFmpeg framework, as is also the case with MPV. To what extent patches for Firefox are already available is unknown to me. For the distribution of my choice, I have in any case rebuilt the FFmpeg and MPV packages with the corresponding patches.
I have to confess that I usually use Firefox and the video decoding works flawlessly for my use cases. However, I cannot say whether this is actually hardware-accelerated, because the SBCs I use with a graphical Desktop are powerful enough to function sufficiently even with only software decoding.
I'm just taking the lazy way here and waiting for it to end up in Manline. For SBCs that need hardware acceleration, I simply use a browser that uses the GStreamer framework.
Hello
I am trying to install armbian on this box (Bqeel U1 Max 4/128G but unable to boot multitool from SD. tried multiple cards and sw (rufus/etcher) does anyone know what could be the reason and how to solve it? I took pics and serial logs also of a successful factory boot.
Spoiler
sdfail.txt boot DC.txt
@lsdlsd88 hello! Thanks for sharing the photos and the serial logs; it looks like the stock firmware did not pick up the sdcard at all. The sdcard seems to be detected, but for some reason the rockchip miniloader of the stock firmware does not it as first source.
Are you able to retrieve the first 100-200 megabytes of the original firmware via serial? You should be able to use dd even within Android.
edit: ah-ha ok, I understand! there is misconfiguration in the webserver and the link changes; thanks, I updated it!
Hi everyone. I have this RK3318 chip box running Ubuntu, but I can't enable SSH to reinstall it. It doesn't have a display output port. Is there any way to reinstall the OS without desoldering the eMMC to reflash it? (I don't know how to put it back if I take it off). I've already tried flashing via USB and the RX/TX/GND lines, but neither worked.
Model: AROP-01
CPU: Quad-core ARM processor
Memory: 2GB
System Storage: 64GB eMMC
Network Interface: 1 × Ethernet
USB Interface: 1 × USB Type-C
Power: 5V/2A
Dimensions: 103 × 103 × 20 mm
Package Contents: 1 × Manual, 1 × Ethernet Cable, 1 × Power Cable
Thank you.
Hello everyone,
I am reaching out to see if anyone in the community has successfully managed to get the internal Wi-Fi working on a box with the Realtek RTL8703bs chip.
I have a MXQ Pro max (t9-RK3328) and I am using the latest Armbian build (Armbian_community_26.2.0-trunk.904_Rk3318-box_trixie_current_6.18.30_minimal.img.xz) provided by @jock for RK3318/RK3328 TV boxes.
Here is the situation:
1. Using `rk3318-config` with `rk3318-box-led-conf1`, the chip is correctly powered and detected on the SDIO bus.
2. `dmesg` shows: `mmc1: new high speed SDIO card at address 0001`.
3. The hardware ID is confirmed as `024c:b703`.
My questions :
- Has anyone ever managed to make this specific chip (RTL8703bs) work on Armbian?
- Does anyone have a patched driver (`.ko`), a specific `.dtbo` overlay, or a workaround that doesn't require recompiling the entire kernel from scratch?
Here is my system log for reference:
https://paste.armbian.com/ecadekazaz
Thank you very much for your time and any advice you can share!
@Suly rtl8703bs works with 8723cs driver, but the proprietary driver has been disabled so far in newer kernels because maintenance was becoming more and more complex. Actually I don't remember if it works with the mainline kernel driver. Probably it works, but I don't know if it is enable in rockchip64 kernel; it is surely enabled in rockchip armhf family.
Hello @jock,
thank you for the quick reply! Indeed, the drivers for the 8723cs have been disabled in the rockchip64 version, as confirmed by my config file:
grep -i "8723" /boot/config-$(uname -r)
# CONFIG_RTL8723CS is not set
# CONFIG_RTW88_8723CS is not set
I found 2 GitHub repos with the uncompiled drivers for the 8723cs chipset:
- https://github.com/VictorIstratii151/rtl8703bs_rtl8723cs_linux_driver
https://github.com/TinkerBoard-Android/rockchip-android-external-wifi_driver/tree/android14-rockchip
I tried to compile them natively on my machine but without success. They relies on Android-specific headers that are missing in Armbian.
Regarding the rockchip armhf family you mentioned, do I need to completely reinstall Armbian on my board using a different image (the 32-bit armhf one)? Do I have to use the Armbian build framework to achieve this? Or is there a way/tool to cross-compile this specific module for my current 64-bit setup?
Thanks again for your help!
Hi, All.
I've make brick X88 PRO B while update firmware.
So, I'm trying recoverying from MASK ROM mode, PC recognized Rockchip USB VID/PID, but rockchip tool makes error like below,
(in Admin mode with PowerShell  or CMD prompt are same, even windows 10/11 )
using tool:
GitHub - cpebit/rkdeveloptool-bin
PS C:\prog\rkdeveloptool-bin-master\bin> .\rkdeveloptool.exe ld
DevNo=1 Vid=0x2207,Pid=0x320c,LocationID=201    Maskrom
PS C:\prog\rkdeveloptool-bin-master\bin> .\rkdeveloptool.exe rd 3
Reset Device quit, creating comm object failed!
I'm tryed install a rockchip device driver but it not effects totally.
GUI tools (like RKDevTool.exe ) also make error result.
Please someone give me a hint that makes progress....
Thank you advance.
