MattWestB Posted July 19 Share Posted July 19 By the way i agree with @Netraam31 with the install is using edge and its no download of current install so for new users is one no go then the edge kernel is being broken if not having one one year old current image that is working OK. 0 Quote Link to comment Share on other sites More sharing options...
pakos96 Posted July 20 Share Posted July 20 (edited) I updated the armbian kernel without reading the thread and now I have my TV box down. How can I revert the kernel to the previous version without losing data? is that possible? thanks in advance EDIT: OK I used .deb packages to force the old kernel version, everything is now OK. How can I upgrade the kernel to the pre-bug version? What is the appropriate version? Edited July 20 by pakos96 0 Quote Link to comment Share on other sites More sharing options...
mrdotdotdot Posted July 20 Share Posted July 20 I was able to chroot into my existing installation after booting from the Armbian_22.05.0-trunk_Rk3318-box_jammy_current_5.15.35_xfce_desktop image from a usb stick, then i ran armbian-config to install the 6.6.32 kernel and freeze it without issue fwiw. 1 Quote Link to comment Share on other sites More sharing options...
Netraam31 Posted July 20 Share Posted July 20 14 hours ago, MattWestB said: By the way i agree with @Netraam31 with the install is using edge and its no download of current install so for new users is one no go then the edge kernel is being broken if not having one one year old current image that is working OK. Partly a "parse error" for me (also not a native speaker so could be me), so not sure what you agree with 😉 0 Quote Link to comment Share on other sites More sharing options...
Netraam31 Posted July 20 Share Posted July 20 I want to share an observation, and have a question linked to that. Not sure if this is the right place to ask, so please guide me to other threads if it would be more applicable there. Observation / steps: - installed one of the standard trunk images (bookworm/minimal), running a -current kernel - go into armbian-config and switch to -edge kernel - apt update, apt upgrade - that would install newer -current kernel and seems to be booting from that instead of from -edge (or at least there are cases where this happens, probably related to availablility of new -current and no new -edge packages in the repo) So it looks like armbian-config wouldn't remove the -current kernel package (even though I do see so messages during that process, indicating it would be removing the current kernel) and just installing the -edge kernel (+dtb) package alongside. Question: could it be that the switch to -edge kernel would indeed not uninstall the -current kernel package but only remove some of the files in /boot, that would be placed back by an upgrade of the -current kernel package? My current workaround to prevent going back to -current, and to prevent having an unbootable system, is to first remove the -current linux-image and linux-dtb packages, and then reinstalling the -edge linux-image and linux-dtb packages. But it seems a bit backwards to first go through armbian-config and then still doing this manually. Not sure if armbian-config does more than just install these two packages? 0 Quote Link to comment Share on other sites More sharing options...
pakos96 Posted July 20 Share Posted July 20 (edited) <deleted> Edited July 20 by pakos96 Message deleted 0 Quote Link to comment Share on other sites More sharing options...
MattWestB Posted July 20 Share Posted July 20 @mrdotdotdot or some one else have one good instruction how booting external media and chroot and fixing the kernel package installed ? 0 Quote Link to comment Share on other sites More sharing options...
mrdotdotdot Posted July 20 Share Posted July 20 Sure it wasn't too complicated really, I can give you the gist of it from memory. 1. Burn Armbian_22.05.0-trunk_Rk3318-box_jammy_current_5.15.35_xfce_desktop to usb drive, plug into usb otg port to boot. 2. Go through basic install routine as usual until you get to armbian desktop 3. You should see your emmc drive as a desktop icon 4. open terminal 5. mount your emmc and important dirs, I don't think I had to mount boot dir ymmv example mount /dev/mmcblk2p1 /mnt mount -t proc proc /mnt/proc mount -t sysfs sys /mnt/sys mount -o bind /dev /mnt/dev mount -t devpts pts /mnt/dev/pts chroot /mnt 6. Use armbian-config to install working kernel (6.6.32) as well as update bootloader. 7. Exit terminal and shut down system, once you no longer get a signal to display unplug usb drive and power cycle to verify bootup and you can freeze with armbian-config once booted up. 4 Quote Link to comment Share on other sites More sharing options...
MattWestB Posted July 21 Share Posted July 21 Great thanks @mrdotdotdot it was fixed in some minutes !! Was already having Armbian 24.5.1 Jammy with Linux 6.1.63-current-rockchip64 (last found current image) on USB-stick so it was only booting and mounting and configuring and shutting down and connecting the Thread RCP and HA is working well !! And as you was writing dont forgetting freeze the kernel update or must redoing all more times. 0 Quote Link to comment Share on other sites More sharing options...
Ben N Voutour Posted July 24 Share Posted July 24 i'm on Armbian 24.8.x and when kodi is the default windowmanager, after a little bit , the display goes blank and pressing the keyboard buttons wake it up, i want to know how to stop that from happening? i tried to set t it in /etc/X11/xorg.conf and nothing worked. help? 0 Quote Link to comment Share on other sites More sharing options...
Alucn Posted July 25 Share Posted July 25 Armbian_community_24.8.0-trunk.443_Rk3318-box_bookworm_current_6.6.41_minimal.img Fix startup errors 0 Quote Link to comment Share on other sites More sharing options...
Thomas Breu Posted July 27 Share Posted July 27 Hello I also need support. I have an x88 Pro 12 TV Box. I installed Armbian, but my wifi is not recognized. Also the clock display is black. I read a lot of X88 owners and what they did to bring both to work. But that is a miracle to me.... hopefully someon can help me, step by step. 0 Quote Link to comment Share on other sites More sharing options...
Alucn Posted July 30 Share Posted July 30 (edited) H96 MAX V12 successfully installed WIFI, unable to connect Spoiler wpa_supplicant v2.10 random: getrandom() support available Successfully initialized wpa_supplicant Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A' Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf' Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' ap_scan=1 update_config=1 ctrl_interface_group='0' p2p_disabled=1 wps_cred_add_sae=1 pmf=1 sae_pwe=2 Line: 8 - start of a new network block ssid - hexdump_ascii(len=5): 41 6c 75 63 6e Amser PSK (ASCII passphrase) - hexdump_ascii(len=9): [REMOVED] key_mgmt: 0x500 proto: 0x2 ieee80211w=1 (0x1) mode=2 (0x2) frequency=2472 (0x9a8) wps_disabled=1 (0x1) PSK (from passphrase) - hexdump(len=32): [REMOVED] Priority group 0 id=0 ssid='Amser' nl80211: Using driver-based roaming nl80211: Supported cipher 00-0f-ac:1 nl80211: Supported cipher 00-0f-ac:5 nl80211: Supported cipher 00-0f-ac:2 nl80211: Supported cipher 00-0f-ac:4 nl80211: Using driver-based off-channel TX nl80211: Supported vendor command: vendor_id=0x1018 subcmd=1 nl80211: Use separate P2P group interface (driver advertised support) nl80211: use P2P_DEVICE support nl80211: key_mgmt=0xd0f enc=0xf auth=0x7 flags=0x3804fac4 rrm_flags=0x0 probe_resp_offloads=0x0 max_stations=0 max_remain_on_chan=5000 max_scan_ssids=10 nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 3 iftype 2 (STATION) nl80211: Subscribe to mgmt frames with non-AP handle 0xaaaae2bb76a0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0104 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 01 04 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040a multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 04 0a nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040b multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 04 0b nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040c multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 04 0c nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040d multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 04 0d nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090a multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 09 0a nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090b multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 09 0b nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090c multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 09 0c nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090d multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 09 0d nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0409506f9a09 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 09 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=7f506f9a09 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=5): 7f 50 6f 9a 09 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0409506f9a1a multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 1a nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0800 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 08 00 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0801 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 08 01 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=12 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 12 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=06 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=1): 06 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a07 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 0a 07 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a11 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 0a 11 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a0b multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 0a 0b nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a1a multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 0a 1a nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1101 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 11 01 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1102 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 11 02 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0505 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 05 05 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0500 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 05 00 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1301 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 13 01 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1305 multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=2): 13 05 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=7e506f9a1a multicast=0 nl80211: kernel reports: Match already configured nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress) nl80211: Register frame match - hexdump(len=5): 7e 50 6f 9a 1a nl80211: Failed to register Action frame processing - ignore for now rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0 netlink: Operstate: ifindex=3 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT) Add interface wlan0 to a new radio phy0 nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR) nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 nl80211: Mode IEEE 802.11a: 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 wlan0: Own MAC address: 88:32:9b:1d:87:ba wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument wlan0: RSN: flushing PMKID list in the driver nl80211: Flush PMKIDs TDLS: TDLS operation not supported by driver TDLS: Driver uses internal link setup TDLS: Driver does not support TDLS channel switching wlan0: WPS: UUID based on MAC address: 8e1f1172-d538-596e-a4ca-a015357511e9 ENGINE: Loading builtin engines ENGINE: Loading builtin engines EAPOL: SUPP_PAE entering state DISCONNECTED EAPOL: Supplicant port status: Unauthorized nl80211: Skip set_supp_port(unauthorized) while not associated EAPOL: KEY_RX entering state NO_KEY_RECEIVE EAPOL: SUPP_BE entering state INITIALIZE EAP: EAP entering state DISABLED MBO: Update non-preferred channels, non_pref_chan=N/A wlan0: Added interface wlan0 wlan0: State: DISCONNECTED -> DISCONNECTED nl80211: Set wlan0 operstate 0->0 (DORMANT) netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT) Daemonize.. wlan0: Starting delayed sched scan wlan0: Use normal scan instead of sched_scan for initial scans (normal_scans=0) wlan0: Setting scan request: 0.000000 sec wlan0: State: DISCONNECTED -> SCANNING wlan0: Starting AP scan for wildcard SSID wlan0: Add radio work 'scan'@0xaaaae2c25f40 wlan0: First radio work item in the queue - schedule start immediately wlan0: Starting radio work 'scan'@0xaaaae2c25f40 after 0.000045 second wait wlan0: nl80211: scan request nl80211: Scan SSID nl80211: Scan extra IEs - hexdump(len=24): 7f 0b 00 00 0a 02 00 40 40 00 00 01 20 72 00 dd 07 50 6f 9a 16 03 01 03 nl80211: Event message available Scan requested (ret=0) - scan timeout 10 seconds nl80211: Event message available nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received wlan0: External program started a scan nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0 wlan0: nl80211: Scan trigger wlan0: Event SCAN_STARTED (47) received wlan0: Own scan request started a scan in 0.000188 seconds EAPOL: disable timer tick RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x1003 ([UP]) nl80211: Event message available nl80211: Event message available nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0 wlan0: nl80211: New scan results available wlan0: nl80211: New scan results available nl80211: Scan probed for SSID '' nl80211: Scan probed for SSID '' nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 wlan0: Event SCAN_RESULTS (3) received wlan0: Event SCAN_RESULTS (3) received wlan0: Scan completed in 2.771232 seconds nl80211: Received scan results (10 BSSes) nl80211: Received scan results (10 BSSes) wlan0: BSS: Start scan result update 2 wlan0: BSS: Add new id 10 BSSID 10:04:c1:03:5a:72 SSID 'Amser' freq 5180 wlan0: BSS: Add new id 11 BSSID 10:04:c1:03:5a:73 SSID 'Amser' freq 2412 BSS: last_scan_res_used=10/32 wlan0: BSS: Start scan result update 1 wlan0: New scan results available (own=0 ext=1) wlan0: BSS: Add new id 0 BSSID 10:04:c1:03:5a:72 SSID 'Amser' freq 5180 wlan0: BSS: Add new id 1 BSSID 10:04:c1:03:5a:73 SSID 'Amser' freq 2412 wlan0: Do not use results from externally requested scan operation for network selection BSS: last_scan_res_used=10/32 wlan0: New scan results available (own=1 ext=0) WPS: AP 08:6b:d1:31:e5:10 type 0 added WPS: AP 6c:b1:58:58:ef:a0 type 0 added WPS: AP f6:39:09:60:45:bc type 0 added WPS: AP a8:3b:5c:fa:c6:6c type 0 added WPS: AP[0] 08:6b:d1:31:e5:10 type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0 WPS: AP[1] 6c:b1:58:58:ef:a0 type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0 WPS: AP[2] f6:39:09:60:45:bc type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0 WPS: AP[3] a8:3b:5c:fa:c6:6c type=0 tries=0 last_attempt=-1 sec ago bssid_ignore=0 wlan0: Radio work 'scan'@0xaaaae2c25f40 done in 2.802839 seconds wlan0: radio_work_free('scan'@0xaaaae2c25f40): num_active_works --> 0 wlan0: Selecting BSS from priority group 0 wlan0: 0: 10:04:c1:03:5a:72 ssid='Amser' wpa_ie_len=0 rsn_ie_len=28 caps=0x31 level=-62 freq=5180 wlan0: selected based on RSN IE wlan0: selected BSS 10:04:c1:03:5a:72 ssid='Amser' wlan0: Considering connect request: reassociate: 0 selected: 10:04:c1:03:5a:72 bssid: 00:00:00:00:00:00 pending: 00:00:00:00:00:00 wpa_state: SCANNING ssid=0xaaaae2bb7780 current_ssid=(nil) wlan0: Request association with 10:04:c1:03:5a:72 SAE: Derive PT - group 19 SAE: SSID - hexdump_ascii(len=5): 41 6c 75 63 6e Amser SAE: password - hexdump_ascii(len=9): [REMOVED] SAE: pwd-seed - hexdump(len=32): [REMOVED] SAE: pwd-value (u1 P1) - hexdump(len=48): [REMOVED] SAE: u1 - hexdump(len=32): [REMOVED] SSWU: m - hexdump(len=32): [REMOVED] SSWU: t - hexdump(len=32): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=32): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=32): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=32): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=32): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=32): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=32): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=32): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=32): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=32): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=32): [REMOVED] SSWU: p - y - hexdump(len=32): [REMOVED] SSWU: P.x - hexdump(len=32): [REMOVED] SSWU: P.y - hexdump(len=32): [REMOVED] SAE: pwd-value (u2 P2) - hexdump(len=48): [REMOVED] SAE: u2 - hexdump(len=32): [REMOVED] SSWU: m - hexdump(len=32): [REMOVED] SSWU: t - hexdump(len=32): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=32): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=32): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=32): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=32): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=32): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=32): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=32): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=32): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=32): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=32): [REMOVED] SSWU: p - y - hexdump(len=32): [REMOVED] SSWU: P.x - hexdump(len=32): [REMOVED] SSWU: P.y - hexdump(len=32): [REMOVED] SAE: Derive PT - group 20 SAE: SSID - hexdump_ascii(len=5): 41 6c 75 63 6e Amser SAE: password - hexdump_ascii(len=9): [REMOVED] SAE: pwd-seed - hexdump(len=48): [REMOVED] SAE: pwd-value (u1 P1) - hexdump(len=72): [REMOVED] SAE: u1 - hexdump(len=48): [REMOVED] SSWU: m - hexdump(len=48): [REMOVED] SSWU: t - hexdump(len=48): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=48): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=48): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=48): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=48): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=48): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=48): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=48): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=48): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=48): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=48): [REMOVED] SSWU: p - y - hexdump(len=48): [REMOVED] SSWU: P.x - hexdump(len=48): [REMOVED] SSWU: P.y - hexdump(len=48): [REMOVED] SAE: pwd-value (u2 P2) - hexdump(len=72): [REMOVED] SAE: u2 - hexdump(len=48): [REMOVED] SSWU: m - hexdump(len=48): [REMOVED] SSWU: t - hexdump(len=48): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=48): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=48): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=48): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=48): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=48): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=48): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=48): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=48): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=48): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=48): [REMOVED] SSWU: p - y - hexdump(len=48): [REMOVED] SSWU: P.x - hexdump(len=48): [REMOVED] SSWU: P.y - hexdump(len=48): [REMOVED] SAE: Derive PT - group 21 SAE: SSID - hexdump_ascii(len=5): 41 6c 75 63 6e Amser SAE: password - hexdump_ascii(len=9): [REMOVED] SAE: pwd-seed - hexdump(len=64): [REMOVED] SAE: pwd-value (u1 P1) - hexdump(len=99): [REMOVED] SAE: u1 - hexdump(len=66): [REMOVED] SSWU: m - hexdump(len=66): [REMOVED] SSWU: t - hexdump(len=66): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=66): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=66): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=66): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=66): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=66): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=66): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=66): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=66): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=66): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=66): [REMOVED] SSWU: p - y - hexdump(len=66): [REMOVED] SSWU: P.x - hexdump(len=66): [REMOVED] SSWU: P.y - hexdump(len=66): [REMOVED] SAE: pwd-value (u2 P2) - hexdump(len=99): [REMOVED] SAE: u2 - hexdump(len=66): [REMOVED] SSWU: m - hexdump(len=66): [REMOVED] SSWU: t - hexdump(len=66): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=66): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=66): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=66): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=66): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=66): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=66): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=66): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=66): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=66): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=66): [REMOVED] SSWU: p - y - hexdump(len=66): [REMOVED] SSWU: P.x - hexdump(len=66): [REMOVED] SSWU: P.y - hexdump(len=66): [REMOVED] Setting up AP (SSID='Amser') nl80211: Set mode ifindex 3 iftype 3 (AP) nl80211: Unsubscribe mgmt frames handle 0x888822226a33fe29 (start AP) nl80211: Setup AP(wlan0) - device_ap_sme=1 use_monitor=0 nl80211: Subscribe to mgmt frames with AP handle 0xaaaae2bb76a0 (device SME) nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=04 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0501 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0503 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0504 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=06 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=08 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=09 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=11 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=12 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=7f multicast=0 nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xaaaae2bb76a0 match= multicast=0 nl80211: Enable Probe Request reporting nl_preq=0xaaaae2c31f40 nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xaaaae2c31f40 match= multicast=0 nl80211: Set freq 2472 (ht_enabled=0, vht_enabled=0, he_enabled=0, bandwidth=0 MHz, cf1=0 MHz, cf2=0 MHz) * freq=2472 * he_enabled=0 * vht_enabled=0 * ht_enabled=0 * channel_type=0 Determining HT/VHT options based on driver capabilities (freq=2472 chan=13) Enable HT support (p2p_group=0 11a=0 ht40_hw_capab=1 ssid->ht40=0) HT secondary channel offset 0 for AP phy: phy0 BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits) nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR) nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 nl80211: Mode IEEE 802.11a: 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=14 freq=2484 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=34 freq=5170 MHz max_tx_power=0 dBm Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=38 freq=5190 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=42 freq=5210 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=46 freq=5230 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=52 freq=5260 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=56 freq=5280 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=60 freq=5300 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=64 freq=5320 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=100 freq=5500 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=104 freq=5520 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=108 freq=5540 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=112 freq=5560 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=116 freq=5580 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=120 freq=5600 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=124 freq=5620 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=128 freq=5640 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=132 freq=5660 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=136 freq=5680 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=140 freq=5700 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=144 freq=5720 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=14 freq=2484 MHz max_tx_power=20 dBm Completing interface initialization Mode: IEEE 802.11g Channel: 13 Frequency: 2472 MHz hostapd_handle_dfs_offload: iface->cac_started: 0 hostapd_handle_dfs_offload: freq 2472 MHz does not require DFS. Continue channel/AP setup Proceed with AP/channel setup nl80211: Set freq 2472 (ht_enabled=1, vht_enabled=0, he_enabled=0, bandwidth=20 MHz, cf1=2472 MHz, cf2=0 MHz) * freq=2472 * he_enabled=0 * vht_enabled=0 * ht_enabled=1 * sec_channel_offset=0 * channel_type=1 RATE[0] rate=10 flags=0x1 RATE[1] rate=20 flags=0x1 RATE[2] rate=55 flags=0x1 RATE[3] rate=110 flags=0x1 RATE[4] rate=60 flags=0x0 RATE[5] rate=90 flags=0x0 RATE[6] rate=120 flags=0x0 RATE[7] rate=180 flags=0x0 RATE[8] rate=240 flags=0x0 RATE[9] rate=360 flags=0x0 RATE[10] rate=480 flags=0x0 RATE[11] rate=540 flags=0x0 hostapd_setup_bss(hapd=0xaaaae2c347e0 (wlan0), first=1) nl80211: flush -> DEL_STATION wlan0 (all) nl80211: Station flush failed: ret=-14 (Bad address) Using interface wlan0 with hwaddr 88:32:9b:1d:87:ba and ssid "Amser" SAE: Derive PT - group 19 SAE: SSID - hexdump_ascii(len=5): 41 6c 75 63 6e Amser SAE: password - hexdump_ascii(len=9): [REMOVED] SAE: pwd-seed - hexdump(len=32): [REMOVED] SAE: pwd-value (u1 P1) - hexdump(len=48): [REMOVED] SAE: u1 - hexdump(len=32): [REMOVED] SSWU: m - hexdump(len=32): [REMOVED] SSWU: t - hexdump(len=32): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=32): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=32): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=32): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=32): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=32): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=32): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=32): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=32): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=32): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=32): [REMOVED] SSWU: p - y - hexdump(len=32): [REMOVED] SSWU: P.x - hexdump(len=32): [REMOVED] SSWU: P.y - hexdump(len=32): [REMOVED] SAE: pwd-value (u2 P2) - hexdump(len=48): [REMOVED] SAE: u2 - hexdump(len=32): [REMOVED] SSWU: m - hexdump(len=32): [REMOVED] SSWU: t - hexdump(len=32): [REMOVED] SSWU: x1a = b / (z * a) - hexdump(len=32): [REMOVED] SSWU: x1b = (-b/a) * (1 + t) - hexdump(len=32): [REMOVED] SSWU: x1 = CSEL(l, x1a, x1b) - hexdump(len=32): [REMOVED] SSWU: gx1 = x1^3 + a * x1 + b - hexdump(len=32): [REMOVED] SSWU: x2 = z * u^2 * x1 - hexdump(len=32): [REMOVED] SSWU: gx2 = x2^3 + a * x2 + b - hexdump(len=32): [REMOVED] SSWU: gx1^((p-1)/2) modulo p - hexdump(len=32): [REMOVED] SSWU: v = CSEL(l, gx1, gx2) - hexdump(len=32): [REMOVED] SSWU: x = CSEL(l, x1, x2) - hexdump(len=32): [REMOVED] SSWU: y = sqrt(v) - hexdump(len=32): [REMOVED] SSWU: p - y - hexdump(len=32): [REMOVED] SSWU: P.x - hexdump(len=32): [REMOVED] SSWU: P.y - hexdump(len=32): [REMOVED] Deriving WPA PSK based on passphrase SSID - hexdump_ascii(len=5): 41 6c 75 63 6e Amser PSK (ASCII passphrase) - hexdump_ascii(len=9): [REMOVED] PSK (from passphrase) - hexdump(len=32): [REMOVED] random: Got 20/20 random bytes Get randomness: len=32 entropy=10 GMK - hexdump(len=32): [REMOVED] Get randomness: len=32 entropy=0 Key Counter - hexdump(len=32): [REMOVED] WPA: Delay group state machine start until Beacon frames have been configured nl80211: Set beacon (beacon_set=0) nl80211: Beacon head - hexdump(len=56): 80 00 00 00 ff ff ff ff ff ff 88 32 9b 1d 87 ba 88 32 9b 1d 87 ba 00 00 00 00 00 00 00 00 00 00 64 00 11 04 00 05 41 6c 75 63 6e 01 08 82 84 8b 96 0c 12 18 24 03 01 0d nl80211: Beacon tail - hexdump(len=120): 2a 01 04 32 04 30 48 60 6c 30 1c 01 00 00 0f ac 02 02 00 00 0f ac 04 00 0f ac 02 02 00 00 0f ac 06 00 0f ac 08 8c 00 2d 1a 2c 00 1f ff 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 3d 16 0d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f4 01 20 dd 18 00 50 f2 02 01 01 01 00 03 a4 00 00 27 a4 00 00 42 43 5e 00 62 32 2f 00 nl80211: ifindex=3 nl80211: beacon_int=100 nl80211: beacon_rate=0 nl80211: rate_type=0 nl80211: dtim_period=2 nl80211: ssid=Amser * beacon_int=100 * dtim_period=2 nl80211: hidden SSID not in use nl80211: privacy=2 nl80211: auth_algs=0x3 nl80211: wpa_version=0x2 nl80211: key_mgmt_suites=0x500 nl80211: pairwise_ciphers=0x18 nl80211: group_cipher=0x8 nl80211: assocresp_ies - hexdump(len=3): f4 01 20 nl802111: sae_pwe=2 nl80211: Event message available nl80211: Drv Event 15 (NL80211_CMD_START_AP) received for wlan0 wlan0: Deauthenticate all stations at BSS start wlan0: nl80211: Ignored unknown event (cmd=15) RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP]) nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success) WPA: Start group state machine to set initial keys WPA: group state machine entering state GTK_INIT (VLAN-ID 0) Get randomness: len=32 entropy=0 GTK - hexdump(len=32): [REMOVED] Get randomness: len=16 entropy=0 IGTK - hexdump(len=16): [REMOVED] WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=2 addr=0xaaaad97a7130 key_idx=1 set_tx=1 seq_len=0 key_len=32 key_flag=0x1a nl80211: NEW_KEY nl80211: KEY_DATA - hexdump(len=32): [REMOVED] broadcast key nl80211: NL80211_CMD_SET_KEY - default key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=4 addr=0xaaaad97a7130 key_idx=4 set_tx=1 seq_len=0 key_len=16 key_flag=0x1a nl80211: NEW_KEY nl80211: KEY_DATA - hexdump(len=16): [REMOVED] broadcast key nl80211: kernel reports: key setting validation failed nl80211: set_key failed; err=-22 Invalid argument WPA: group state machine entering state FATAL_FAILURE wlan0: Flushing old station entries nl80211: flush -> DEL_STATION wlan0 (all) nl80211: Station flush failed: ret=-14 (Bad address) wlan0: Could not connect to kernel driver wlan0: Deauthenticate all stations nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument Failed to clear default encryption keys (ifname=wlan0 keyidx=0) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument Failed to clear default encryption keys (ifname=wlan0 keyidx=2) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument Failed to clear default encryption keys (ifname=wlan0 keyidx=3) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument Failed to clear default mgmt encryption keys (ifname=wlan0 keyidx=4) wpa_driver_nl80211_set_key: ifindex=3 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0 key_flag=0x10 nl80211: DEL_KEY broadcast key nl80211: set_key failed; err=-22 Invalid argument Failed to clear default mgmt encryption keys (ifname=wlan0 keyidx=5) hostapd_free_hapd_data(wlan0) Interface initialization failed wlan0: interface state UNINITIALIZED->DISABLED wlan0: AP-DISABLED wlan0: Unable to setup interface. Failed to initialize AP interface hostapd_interface_deinit(0xaaaae2c32bb0) wlan0: interface state DISABLED->DISABLED hostapd_bss_deinit: deinit bss wlan0 wlan0: Deauthenticate all stations nl80211: sta_remove -> DEL_STATION wlan0 ff:ff:ff:ff:ff:ff --> 0 (Success) wlan0: AP-DISABLED hostapd_cleanup(hapd=0xaaaae2c347e0 (wlan0)) hostapd_free_hapd_data: Interface wlan0 wasn't started hostapd_interface_free(0xaaaae2c32bb0) hostapd_interface_free: free hapd 0xaaaae2c347e0 hostapd_cleanup_iface(0xaaaae2c32bb0) hostapd_cleanup_iface_partial(0xaaaae2c32bb0) hostapd_cleanup_iface: free iface=0xaaaae2c32bb0 nl80211: Remove beacon (ifindex=3) nl80211: Set mode ifindex 3 iftype 2 (STATION) nl80211: Teardown AP(wlan0) - device_ap_sme=1 use_monitor=0 nl80211: Disable Probe Request reporting nl_preq=0x888822226a4b97c9 nl80211: Unsubscribe mgmt frames handle 0x888822226a33fe29 (AP teardown (dev SME)) nl80211: Subscribe to mgmt frames with non-AP handle 0xaaaae2bb76a0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0104 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040b multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040c multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=040d multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090b multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090c multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=090d multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0409506f9a09 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=7f506f9a09 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0409506f9a1a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0800 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0801 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=12 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=06 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a07 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a11 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a0b multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0a1a multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1101 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1102 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0505 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=0500 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1301 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=1305 multicast=0 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xaaaae2bb76a0 match=7e506f9a1a multicast=0 wlan0: CTRL-EVENT-DISCONNECTED bssid=88:32:9b:1d:87:ba reason=3 locally_generated=1 wlan0: State: SCANNING -> DISCONNECTED nl80211: Set wlan0 operstate 0->0 (DORMANT) netlink: Operstate: ifindex=3 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT) RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP]) nl80211: Event message available nl80211: Drv Event 15 (NL80211_CMD_START_AP) received for wlan0 wlan0: nl80211: Ignored unknown event (cmd=15) nl80211: Event message available nl80211: Event message available nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlan0 nl80211: Regulatory domain change * initiator=0 * type=1 wlan0: Event CHANNEL_LIST_CHANGED (27) received wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD wlan0: Updating hw mode nl80211: Drv Event 36 (NL80211_CMD_REG_CHANGE) received for wlan0 nl80211: Regulatory domain change * initiator=0 * type=1 wlan0: Event CHANNEL_LIST_CHANGED (27) received wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD wlan0: Updating hw mode nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR) nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 nl80211: Mode IEEE 802.11a: 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz 20 mBm nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR) nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR) nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR) nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR) nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR) nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR) nl80211: 57240-63720 @ 2160 MHz 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 nl80211: Mode IEEE 802.11a: 5170 5180 5190 5200 5210 5220 5230 5240 5260 5280 5300 5320 5500 5520 5540 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765 5785 5805 5825 nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484 RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP]) RTM_NEWLINK: ifi_index=3 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x1003 ([UP]) wlan0: BSS: Remove id 1 BSSID 16:6f:b0:b1:34:1e SSID '' due to wpa_bss_flush_by_age wlan0: BSS: Remove id 2 BSSID 68:77:24:3f:21:9a SSID 'SJKJ-1503' due to wpa_bss_flush_by_age wlan0: BSS: Remove id 5 BSSID f8:6f:b0:b1:34:1e SSID '\xe5\xbe\xae\xe7\xac\x91\xe8\x8d\x89\xe8\x8e\x932.4G' due to wpa_bss_flush_by_age wlan0: BSS: Remove id 6 BSSID 7e:77:24:3f:21:9a SSID '' due to wpa_bss_flush_by_age wlan0: BSS: Remove id 8 BSSID 46:fe:95:89:32:03 SSID 'xingjixincheng' due to wpa_bss_flush_by_age wlan0: BSS: Remove id 9 BSSID a6:ef:15:36:64:dd SSID 'DIRECT-4b-Pantum M7100 Series' due to wpa_bss_flush_by_age Edited July 30 by Alucn 0 Quote Link to comment Share on other sites More sharing options...
Ben N Voutour Posted August 6 Share Posted August 6 (edited) This DTB enables all the ram speeds and the Mali 450 MP2 GPU is set so it can boost to 750 MHz well within safe operating voltages and the CPU is set to be able to scale to 1.5 GHz (also well-within safe operating voltages. Tings Fixed : Mali450-MP2 GPU Clock [added 600 / 700 / 750 MHZ OPP] RK3318 CPU Clock [600 MHz to 1.5 GHz] DDR RAM [All Enabled] thanks to the support of Bing copilot in precise prompt feel free to test now that i got everything nearly sorted out. (WARNING!!! Large Heat Sink + 12V Fan Required) The DTS File is also here if you want to tweak the settings you need. place the File "rk3318.DTB" in /boot/dtb/rockchip/rk3318.dtb and reboot. and point /boot/armbianEnv.txt so that rk3318-box.dtb is "rk3318.dtb" rk3318.dtb rk3318.dts Edited August 6 by Ben N Voutour added directions on how to use new dtb file 1 Quote Link to comment Share on other sites More sharing options...
jock Posted August 7 Author Share Posted August 7 13 hours ago, Ben N Voutour said: This DTB enables all the ram speeds and the Mali 450 MP2 GPU is set so it can boost to 750 MHz well within safe operating voltages and the CPU is set to be able to scale to 1.5 GHz (also well-within safe operating voltages. Which ram speeds? are you aware that ddr scaling does not work on these tv boxes? 0 Quote Link to comment Share on other sites More sharing options...
Ben N Voutour Posted August 7 Share Posted August 7 what gpu is in the rk3318, bing seems to think there are 2 variants one with the mali450-mp2 and one with the mali450-mp5? can you help me use the mali 450-mp2 utgard driver i know not to use ump but how do i install that instead of the lima driver. the source is from the arm developer site. DX940-SW-99002-r13p0-01eac0.tar 0 Quote Link to comment Share on other sites More sharing options...
pakos96 Posted August 22 Share Posted August 22 Sorry.. so has the kernel bug been fixed? can i update? 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 23 Author Share Posted August 23 @pakos96 apparently, the kernel bug has been fixed and it should work 0 Quote Link to comment Share on other sites More sharing options...
pakos96 Posted August 24 Share Posted August 24 @jock thank you. I've tried the 6.6.41 kernel but this version didn't fix the boot issues... is there a more up-to-date version? 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 24 Author Share Posted August 24 @pakos96 sorry 😔 , can't say exactly what version the server has built and when it did so... the patch is in mainline kernel armbian for more than one month now, 6.6.41 seems a bit old. 1 Quote Link to comment Share on other sites More sharing options...
pakos96 Posted August 24 Share Posted August 24 (edited) Unfortunately the 6.6.39 (Armbian 24.5.3 current) version seems to be the last version. After update I've the boot issue. I've rollbacked to 6.6.32 kernel version... Who can we report it to? Edited August 24 by pakos96 1 Quote Link to comment Share on other sites More sharing options...
MattWestB Posted August 24 Share Posted August 24 Unfreez i getting the kernel 6.6.39-current-rockchip64 (the bad one). Updating i getting the kernel 6.6.47-current-rockchip64 (not tested then it look being one bad one). Installing edge i getting kernel 6.10.6-edge-rockchip64 that booting but have not testing it for real if its working OK. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted August 24 Share Posted August 24 1 hour ago, pakos96 said: Unfortunately the 6.6.39 (Armbian 24.5.3 current) version seems to be the last version Armbian doesn't regularly release updated kernels to the stable channel, except once every three months with new releases. If you switch to the nightly/beta channel in Armbian-config you should be able to access more current kernels at anytime. 0 Quote Link to comment Share on other sites More sharing options...
MattWestB Posted August 25 Share Posted August 25 = three month not working stable if not jumping to nightly. Way not manually triggering one rebuild with latest commits for stable / current kernel of the RK33X8 so users can have working boxes without large problems ? I knowing CSC but having one OK working stable / current is also important for this devices and edge / best is not the way for most users. By the way the armbian-config scrip was working great getting old kernel back after getting changeroot mapping all OK. 0 Quote Link to comment Share on other sites More sharing options...
Minh Chau Posted August 26 Share Posted August 26 Hi Jock, Many thanks to your instructions and ROMs. I have a H96 Max alike and it cannot boot from SD card, I managed to installed via MARKROM with this https://users.armbian.com/jock/rk3318/Armbian_23.08.0-trunk_Rk3318-box_bookworm_edge_6.3.13_minimal.img.xz However, after susscessfully installed, I reboot the box WITHOUT creating root passwords and normal user name/ passwords, too. Then, I ssh to the box via cmd on windows and it asked for user name and passwords I typed ‘root’ and ‘root1234’ and, off course, I cannot login the box either via ssh nor the box via command line. I cannot put the box into Markrom anymore😭😭😭 Can you tell me what can I do to login or reset passwords? Thank you Minh Chau 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted August 26 Share Posted August 26 1 hour ago, Minh Chau said: I typed ‘root’ and ‘root1234’ The default is 'root' and '1234' 1 Quote Link to comment Share on other sites More sharing options...
Minh Chau Posted August 27 Share Posted August 27 Thanks SteeMan, I tried but failed 0 Quote Link to comment Share on other sites More sharing options...
jock Posted August 27 Author Share Posted August 27 I really don't understand where is the problem. You claim you cannot login, but root and 1234 are the default username and password, and those have always been for ages. You claim you cannot enter maskrom, but you should be perfectly able to boot from sdcard/USB either another armbian image or multitool to do maintenance or erase the eMMC and get back maskrom mode 0 Quote Link to comment Share on other sites More sharing options...
