bluetooth not working on rk3318 running Armbian 23.02.2 Bullseye with Linux 5.15.93-rockchip64
I am new to this. I have an H96Max Android TV box which I flashed successfully with Armbian 23.02.2 Bullseye with Linux 5.15.93-rockchip64the latest armbian image. Wifi is running fine. However, I failed to activate bluetooth. I read several post around the same topic with no luck.
I am attaching several logs I collected and hope it can clarify more the case, so someone can help resolving this.
root@rk3318-box:/# dmesg | egrep -i 'blue|firm'
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    6.838446] Bluetooth: Core ver 2.22
[    6.838756] NET: Registered PF_BLUETOOTH protocol family
[    6.838775] Bluetooth: HCI device and connection manager initialized
[    6.838804] Bluetooth: HCI socket layer initialized
[    6.838821] Bluetooth: L2CAP socket layer initialized
[    6.838868] Bluetooth: SCO socket layer initialized
[    9.513260] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43342-sdio.rockchip,rk3318-box.bin failed with error -2
[    9.525849] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43342-sdio.rockchip,rk3318-box.txt failed with error -2
[    9.693623] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43342/1 wl0: Oct 18 2016 17:43:42 version 6.25.134.25 (r662387) FWID 01-281dd9d9
[   38.183427] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   38.183447] Bluetooth: BNEP filters: protocol multicast
[   38.183468] Bluetooth: BNEP socket layer initialized
root@rk3318-box:/# rfkill
ID TYPE DEVICE      SOFT      HARD
 0 wlan phy0   unblocked unblocked
root@rk3318-box:/# systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2023-03-05 19:55:27 +04; 28min ago
       Docs: man:bluetoothd(8)
   Main PID: 1867 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 4587)
     Memory: 2.5M
        CPU: 97ms
     CGroup: /system.slice/bluetooth.service
             └─1867 /usr/libexec/bluetooth/bluetoothd
Mar 05 19:55:27 rk3318-box systemd[1]: Starting Bluetooth service...
Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Bluetooth daemon 5.55
Mar 05 19:55:27 rk3318-box systemd[1]: Started Bluetooth service.
Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Starting SDP server
Mar 05 19:55:27 rk3318-box bluetoothd[1867]: Bluetooth management interface 1.21 initialized
root@rk3318-box:/# bluetoothctl
Agent registered
[bluetooth]# power on
No default controller available
root@rk3318-box:/# lsmod
bnep                   32768  2
ir_nec_decoder         20480  0
nft_chain_nat          16384  4
xt_MASQUERADE          20480  1
nf_nat                 49152  2 nft_chain_nat,xt_MASQUERADE
nft_counter            16384  3
xt_state               16384  0
xt_conntrack           16384  1
nf_conntrack          163840  4 xt_conntrack,nf_nat,xt_state,xt_MASQUERADE
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
nft_compat             20480  2
nf_tables             212992  15 nft_compat,nft_counter,nft_chain_nat
nfnetlink              20480  2 nft_compat,nf_tables
lz4hc                  16384  0
lz4                    16384  0
brcmfmac              385024  0
brcmutil               28672  1 brcmfmac
cfg80211              876544  1 brcmfmac
snd_soc_spdif_tx       16384  1
hantro_vpu            118784  0
rockchip_vdec          32768  0
gpio_ir_recv           16384  0
rc_core                57344  3 gpio_ir_recv,ir_nec_decoder
snd_soc_hdmi_codec     24576  1
snd_soc_rockchip_spdif    16384  2
v4l2_h264              16384  2 rockchip_vdec,hantro_vpu
snd_soc_rk3328         16384  1
rockchip_rga           28672  0
videobuf2_vmalloc      20480  1 hantro_vpu
snd_soc_simple_card    24576  4
snd_soc_simple_card_utils    28672  1 snd_soc_simple_card
rockchip_iep           20480  0
snd_soc_rockchip_i2s    24576  4
snd_soc_rockchip_pcm    16384  1 snd_soc_rockchip_i2s
snd_soc_core          262144  8 snd_soc_spdif_tx,snd_soc_rockchip_pcm,snd_soc_hdmi_codec,snd_soc_rockchip_spdif,snd_soc_rk3328,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card
videobuf2_dma_sg       24576  1 rockchip_rga
videobuf2_dma_contig    24576  3 rockchip_vdec,hantro_vpu,rockchip_iep
v4l2_mem2mem           40960  4 rockchip_vdec,hantro_vpu,rockchip_rga,rockchip_iep
videobuf2_memops       20480  3 videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_dma_sg
videobuf2_v4l2         32768  5 rockchip_vdec,hantro_vpu,rockchip_rga,rockchip_iep,v4l2_mem2mem
videobuf2_common       65536  10 rockchip_vdec,videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_dma_sg,rockchip_iep,v4l2_mem2mem,videobuf2_memops
snd_pcm_dmaengine      20480  1 snd_soc_core
videodev              262144  7 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,rockchip_iep,v4l2_mem2mem
snd_pcm               131072  3 snd_soc_hdmi_codec,snd_soc_core,snd_pcm_dmaengine
mc                     61440  6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
snd_timer              40960  1 snd_pcm
snd                    94208  12 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
cpufreq_dt             20480  0
soundcore              16384  1 snd
zram                   40960  3
btusb                  65536  0
btrtl                  24576  1 btusb
btbcm                  28672  1 btusb
btintel                40960  1 btusb
bluetooth             638976  11 btrtl,btintel,btbcm,bnep,btusb
rfkill                 36864  6 bluetooth,cfg80211
sunrpc                581632  1
ip_tables              32768  0
x_tables               49152  5 xt_conntrack,nft_compat,xt_state,ip_tables,xt_MASQUERADE
autofs4                49152  2
dwmac_rk               28672  0
stmmac_platform        24576  1 dwmac_rk
stmmac                237568  2 stmmac_platform,dwmac_rk
dw_hdmi_cec            16384  0
pcs_xpcs               24576  1 stmmac
dw_hdmi_i2s_audio      16384  0
lima                   61440  0
gpu_sched              40960  1 lima
gpio_syscon            20480  1
adc_keys               16384  0
To debug the problem, it is better to paste the link coming from armbianmonitor -u ; also photos of the board are very useful to identify which board you have.
Also this is the reference thread  for rk3318 boxes
This is an old thread. I made some progress by running the rk3318-config and accepting the default. Using bluetoothctl I see it works, and I can scan on. However, either it scans very few devices or none.
Following is the dmesg outcome. It complains about a missing patch for BCM43342A. How can I add this patch?
dmesg | grep -i blue
[   10.361265] Bluetooth: Core ver 2.22
[   10.361501] NET: Registered PF_BLUETOOTH protocol family
[   10.361514] Bluetooth: HCI device and connection manager initialized
[   10.361545] Bluetooth: HCI socket layer initialized
[   10.361559] Bluetooth: L2CAP socket layer initialized
[   10.361607] Bluetooth: SCO socket layer initialized
[   10.432142] Bluetooth: HCI UART driver ver 2.3
[   10.432184] Bluetooth: HCI UART protocol H4 registered
[   10.432193] Bluetooth: HCI UART protocol BCSP registered
[   10.432374] Bluetooth: HCI UART protocol LL registered
[   10.432397] Bluetooth: HCI UART protocol ATH3K registered
[   10.432489] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   10.432863] Bluetooth: HCI UART protocol Intel registered
[   10.435956] Bluetooth: HCI UART protocol Broadcom registered
[   10.436076] Bluetooth: HCI UART protocol QCA registered
[   10.436085] Bluetooth: HCI UART protocol AG6XX registered
[   10.441003] Bluetooth: HCI UART protocol Marvell registered
[   10.820901] Bluetooth: hci0: BCM: chip id 83
[   10.821724] Bluetooth: hci0: BCM: features 0x0f
[   10.823414] Bluetooth: hci0: BCM43342A
[   10.823458] Bluetooth: hci0: BCM (001.002.003) build 0000
[   10.823836] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[   10.823862] Bluetooth: hci0: BCM: 'brcm/BCM.rockchip,rk3318-box.hcd'
[   10.823869] Bluetooth: hci0: BCM: 'brcm/BCM.hcd'
[   18.309192] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   18.309238] Bluetooth: BNEP filters: protocol multicast
[   18.309273] Bluetooth: BNEP socket layer initialized
[   18.357504] Bluetooth: MGMT ver 1.22
[   56.740638] Bluetooth: RFCOMM TTY layer initialized
[   56.740700] Bluetooth: RFCOMM socket layer initialized
[   56.740747] Bluetooth: RFCOMM ver 1.11
The outcome link from armbianmonitor -u is:
https://paste.armbian.com/qusikoqege
Edited by aht2000
Thank you very much. Yes it did. After creating the symbolic link, Bluetooth is now working successfully and I am able to pair and connect to my Airpods.
For your version of RK3318_V1.4 (without display) its needs the configure file as you was doing OK.
For other users its the command "ln -s  /usr/lib/firmware/brcm/BCM43342.hcd /usr/lib/firmware/brcm/BCM.hcd"
And its stop using different BT MAC-addresses after every reboot so can being used with BT devices.
