hello
i am new user of armbian and i really like it. so i am experimenting with it a little. yesterday i successfully installed armbian on one of my old laptops in the lab (Armbian Bullseye with XFCE desktop with kernel 5.15.y released on feb 27, 2023), so currently it boots from internal hard drive. today i wanted to try another image, so i wanted to do the same thing:
1. boot from USB key
2. download the new image on USB key
3. run
xzcat armbian.img.xz | dd of=/dev/sda status=progress
4. reboot laptop (to new system)
but the step 1 failed - instead of booting the system from USB key (yes - i selected the USB key on laptop start), system started from the laptop's hard drive.
i think, this is not expected behavior. or am i missing something and it is really a feature? 🙂
anyway - thanks for the project. it gives my old laptops new life ;)
mirek
Edited by bletvaska
forgot to mention the image, which i installed
2 minutes ago, bletvaska said:
yesterday i successfully installed armbian on one of my old laptops in the lab, so currently it boots from internal hard drive
What was the install procedure?
Strange.
Perhaps there was something wrong with burning to USB? Use some other USB key? Usually its something stupid ;)
the installation procedure on USB key was (probably) with Etcher (i usually use it for this). and installation procedure on laptop was as mentioned:
i thought, that the USB key can be possibly wrong, but i am currently using it again to install different armbian image on another laptop. and it works fine - it recognized the setup from USB key.
small update. i've just installed armbian jammy with xfce from rolling releases from ci pipeline, which was released on mar 7, 2023. i installed the system same way as before without any issues. and the booting on that laptop from usb key also works as it should.
i was thinking about and rembered, that yesterday i was playing with the tools and tried for the installation tool armbian-install. currently there is only support for installing on sd/emmc, but i tried. i don't have deep understanding about linux boot sequence, but i thought, if there is exact uuid of the root disk, it will start booting from the laptop instead of usb key then (but it's strange, that on the disk without that disk, is booting from usb key normally). to check this, i tried to do the same procedure on the second laptop with newly installed armbian jammy. so i ran armbian-install, rebooted the computer and tried to boot from usb key. and the system was loaded from usb key as it should. when i tried to boot on laptop with armbian bullseye, the system again started from laptop.
so i don't know, where is the problem 😞
