[Armbian build PR] - Convert from using uImage to Image for aml-s9xx-box
This is needed to bring this board in line with the expectations of the new main build (armbian-next), which dropped uImage from meson64 kernel packages.
Changes to be committed: modified: packages/bsp/aml-s9xx-box/boot/extlinux/extlinux.conf
Description
Please include a summary of the change and which issue is fixed. Please also include relevant motivation and context. List any dependencies that are required for this change.
More information can be found in Issue #4874
How Has This Been Tested?
  • [x] Build and install aml-s9xx-box
View the full article
@SteeMan: My h96 max x2 s095x2 2G/16G box doesn't boot with the weekly roms in this link:
https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus/
It does boot with the stable roms.
The main difference, if I understand correctly, is because the latest weekly roms use Image instead of uImage in extlinux.cfg file. The stable roms still have the uImage file.
I've also seen someone attempted to fix uImage build here:
https://forum.armbian.com/topic/26971-armbian-build-pr-fix-uimage-build/#replyForm
Please consider building uImage again in the future. I know I may need to go the long way to rebuild everything, so I may need help building armbian from scratch later, with uImage enabled.
Thanks!
@Thang The weekly images should work.  Are you installing a weekly image, or upgrading to it?  If you are upgrading, then you will need to edit the extlinux.conf file and change uImage to Image.
4 hours ago, SteeMan said:
The weekly
Daily ATM and if it performs well, it stays that way.
