armbian on odroid c2 is there any default firewall
Go to solution Solved by jumbo125,
Hello
I'm a newbie and want to start my tour with my odroid c2
for the beginn i want to install a vnc server.
So i tried to setup the port 5901 tcp (opoen/free)
if i try  ufw allow 5901/tcp i get ufw not found
if i try iptables -a ........ dport 5901  i get dport not found
So my question, is there any firwall on the default system?
Thank you a lot
There is not. Install iptables or nftables or a framework like ufw via apt that makes use of either one of those.
This can only be answered by you since you are responsible for the security of your device so decision is yours if firewalling is necessary.
  • Solution
okay thank you!!!!!
p.s. for something who needs the same fix:
Solution is three post before.
Edited by jumbo125
