Endian Posted May 7, 2023 Posted May 7, 2023 Building Jammy works fine, but if I select Kineic for example using this ./compile.sh BOARD=rock-5b BRANCH=legacy RELEASE=kinetic COMPRESS_OUTPUTIMAGE=img KERNEL_CONFIGURE=no BUILD_MINIMAL=no BUILD_DESKTOP=no it fails in this way [๐ฑ] Installing base system with 5 packages [ Stage 1/2 ] [๐จ] E: No such script: /usr/share/debootstrap/scripts/kinetic [๐ฅ] error! [ Debootstrap first stage failed kinetic no ] Now I re-fetched a new Armbian git but the problem remains. Why? 0 Quote
Werner Posted May 7, 2023 Posted May 7, 2023 - Building issues should go here: https://github.com/armbian/build - non-LTS variants are never really supported but added for interested people to play with without need for any kind of support (which there isn't) - Try Lunar instead of Kinetic since it is most recent non-LTS 0 Quote
Endian Posted May 8, 2023 Author Posted May 8, 2023 I did report it at github, but the end result was I have installed Ubuntu and build from that. Seems nice. 0 Quote
