Hi,
I'm testing a visionfive2 board with 8GB ram and I can only see 4GB in the armbian installed system.
As far as I understand, the official image by StarFive has a extra u-boot partition on SD that tricks something to make the ram fully visible to the system.
In fact I can see 8GB when using the official debian image but only 4 under armbian.
Is there any way to fix this? I'd like to use the armbian environment while using the full ram available. I'm trying to mashup the two partition schemas but I'm probably doing someting wrong... :D
Thank you in advance for any (very appreciated) help!
-psi
I face the same problem, Armbian only reports 4GB on my VisionFive2 board with 8GB of RAM.
I also noticed that the system is very unstable and constantly hanging after some minutes of usage, especially when I install Debian packages with Apt.
I haven't tested the official Debian image yet. I hope it fixes both the reported RAM and that instability.
Here is the page for the official VisionFive2 Debian: https://rvspace.org/en/project/VisionFive2_Debian_Wiki_202409_Release
Links can be found there: https://debian.starfivetech.com/
