hemi03 Posted May 26, 2023 Posted May 26, 2023 I get Kernel Panics when i do a reboot of the device with the reboot command. I don't get any Panics, when doing a normal boot of the System by powering it. The Panics don't occur on Manjaro. Updating the kernel to 6.1, did nothing for me and the Panic messages are always different and occur at different points of the Boot process. The System runs stable for days, when it boots. I don't have any clues what is going on hear, but i it seems that the device and sdcards aren't broken. 0 Quote
Werner Posted May 26, 2023 Posted May 26, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
hemi03 Posted May 26, 2023 Author Posted May 26, 2023 Its not showing the Panics tho. https://paste.armbian.com/gukodizaqa Probably because they occur to early. 0 Quote
hemi03 Posted May 27, 2023 Author Posted May 27, 2023 So i poked at it a bit more. Here are some crash logs. It seems like when i use the reboot command the SD Card gets unstable. Is there a way of improving the stability at the reboot state? panik_2.logFetching info... panik_3.logFetching info... panik_1.logFetching info... 0 Quote
