Hi!
I am trying to use Armbian 23.5 Jammy XFCE for new Orange Pi Zero Plus 2.
I have TTL-USB connection through Serial port.
In pyutty window i see log
U-Boot SPL 2022.07-armbian (May 27 2023 - 19:28:04 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2022.07-armbian (May 27 2023 - 19:28:04 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero Plus 2
DRAM:  512 MiB
Core:  65 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
** Reading file would overwrite reserved memory **
Failed to load '/boot/boot.bmp'
There is no valid bmp file at the given address
starting USB...
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1d000: USB EHCI 1.00
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
4121 bytes read in 4 ms (1005.9 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
180 bytes read in 3 ms (58.6 KiB/s)
16682525 bytes read in 693 ms (23 MiB/s)
8477464 bytes read in 355 ms (22.8 MiB/s)
33498 bytes read in 10 ms (3.2 MiB/s)
504 bytes read in 6 ms (82 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4185 bytes read in 6 ms (680.7 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0x815b18 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Data Size:    16682461 Bytes = 15.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49017000, end 49fffddd ... OK
   Loading Device Tree to 48fa6000, end 49016fff ... OK
Starting kernel ...
and this is all.
My orange can not boot propertly.
Is it possible to do something? Other image...
Please help!
