NanoPi R1 eMMC install fails to start
ScottV
Armbian Jammy (Minimal CLI) boots/works fine from an SD Card. (Armbian_23.5.2_Nanopi-r1_jammy_current_6.1.30_minimal.img.xz)
apt update && apt upgrade -y && apt autoremove
apt install armbian-config -y
armbian-install
I choose option #2 - Boot from eMMC - System on eMMC
Accept the warning.
I choose option #1 - ext4
The install appears to move along smoothly.
I choose the "Power Off" option.
Pull the power, remove the SD Card.
Reconnect the power.
I never see the "heartbeat" on the "System"(red) LED.
The NanoPi never boot or obtains an IP address.
Edited by ScottV
I have observed the same problem. My NanoPi-R1 - which interestingly identifies at a NEO on the boot UART console......
I do have a serial UART console. So have captured my findings. Albeit limited as verbosity isnt set high and the console log when booting the SD armbian image
Armbian_23.5.2_Nanopi-r1_bookworm_current_6.1.30_minimal.img.xz SHA: ea10d9a0940a516be9f627f4a943caf39f3c2f3d1e80afafc95f78c65e4d2d10
Written to a 8G Sandisk SD. Put into the SD slot and powered the unit on.
Console output gets to Starting Kernel ... and then the red LED light just blinks and blinks for a long time with no change.
Unit has DHCPd and I am able to ssh into it with the root defaults. Establish my new root passwd and setup a user account and locale details etc.
I then run the
nand-sata-install
Select the emmc and it takes about 2 minutes to copy over after all the warnings etc.
 Armbian for NanoPi R1 install script, https://www.armbian.com
 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
                                   lqqqqqqqqqqqqqqqqqqqqqqqqqqqeMMC installqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
                                   x        x
                                   x All done. Power off                                                x
                                   x        x
                                   tqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqu
                                   x                 <Power off>         <  Exit   >                    x
                                   mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
root@nanopi-r1:~#
Then the unit reboots and the console comes alive and displays.
U-Boot SPL 2022.07-armbian (Jun 06 2023 - 04:52:59 +0000)
DRAM: 1024 MiB
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
https://paste.armbian.com/ivopizatot
Edited by Gul-Dukat
I have the same problem, the debug console output is as follows:
DRAM: 1024 MiB
This looks like a problem that has occurred in the past, the cause may be related to the eMMC driver in u-boot, I found some links:
https://community.ipfire.org/t/friendlyarm-nanopi-r1-flash-image-to-emmc/594/5
https://wiki.ipfire.org/hardware/arm/friendlyelec/nanopi-r1
Quote
The default bootloader in the image boots from mmc0 (SD-Card), however the eMMC (Flash-ROM) is connected to mmc2. To boot from the eMMC you need a special u-boot that switches mmc0 to mmc2.
34 minutes ago, Igor said:
Try latest images from CI automated build section - should be fixed by now.
Thanks for your reply, I just tried the latest ci build: Armbian_23.8.0-trunk.294, but it still doesn't work.
U-Boot SPL 2023.07.02-armbian (Aug 26 2023 - 11:57:38 +0000)
DRAM: 1024 MiB
Should i wait for the next build?
Debugging and fixing is not automatic. You will need to fix it first. When your fix will be merged, then new build will provide fixed results ... It could be this
