armbian-config reports not enouch space when installing Armbian to external USB HD
I have followed all threads dealing with this topic but got no where so maybe... just maybe someone has made it work somehow?
I have armbian (Armbian_23.02.2_Rk3318-box_bullseye_current_5.15.93) installed on a TV box with a Rockchip RK3318 inside it. I am using a microsd card and EVERYTHING is running wonderfully!
I have also attached a 500GB USB hard disk
(output from fdisk-l)
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: 5000BEV External
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
I ran armbian-config and tried to move the os to the hard disk while keeping the boot from sd card choice. That failed and I got the message "There is not enough free capacity on /dev/sda mmcblk2. Please check your device.
I tried mounting sda, deleteing all artitions on it ... etc but nothing worked. Any ideas?
Thanks
image.png.8ee69a6bc7b512939b6e997d3178ff0b.pngimage.png.de4bb14c64b3b0ddc86ce9e2ed9e31a2.pngimage.png.e96cd6b1816e933758f199505378ee75.png
On 6/13/2023 at 4:56 AM, Eddy_T said:
Any ideas?
Looking into the script and debugging it? armbian-config just calls this:
https://github.com/armbian/build/blob/main/packages/bsp/common/usr/sbin/armbian-install
There are known bugs
https://armbian.atlassian.net/browse/AR-1592
and ongoing tasks
https://armbian.atlassian.net/browse/AR-1001
that might be related to the problem you are facing.
