I'm using the Odroid N2/N2+ 23.5 Jammy minimal image.
I then updated and upgraded successfully.  I then attempted to install MATE via tasksel (which I installed) but that immediate fails with an apt package missing error.  SO then I tried to install MATE manually by:
$ sudo apt install mate-desktop-environment mate-desktop-environement-extras
$ reboot
There didn't seem to be any display manger installed so I stalled lighdm
$ sudo apt install lightdm lighdm-gtk-greeter
$ reboot
Then I noticed that Xserver was not installed (really, that's no a MATE dependency!!!)
$ sudo aqt install xserver-xorg
$ reboot
But the xserver was not starting and so I noticed xinit was not installed (really. why wouldn't this be a dependency of MATE or the xserver)
$ sudo apt install xinit
$ reboot
Now it boots and starts everything and then switches to console tty07 but is just a black screen.  I can see from console tty01 that all the correct (I assume) processes have started but nothing but a black screen.
Xorg is running
lightdm session is running
lightdm-greeter-session is running
lightdm-gtk-greeter is running
But still no login screen (or mouse) is visible (just a blank screen)
I can see the ~/.Xauthority file is blank so don't know what has happened.
What else have I missed?
Edited by Walter Zambotti
additional info added
Thanks I went into armbian-config but can't see any setting that would be relevant as GUI is already set to enabled!
I tried disabling and re-enabling but no difference.  Blank screen!
I managed to get it going!
I suspected it was working so unplugged the HDMI cable from my QHD monitor and plugged it into a FHD and wala instant picture.  Then I plugged it back into my QHD monitor and it was still displaying.  I then used the display control to set the resolution to 2560x1440 and it still worked.
So the problem seems to be using QHD from boot.  That doesn't work.
Seems like a firmware setting that should be changed.
I suspect it doesn't see a FHD single so assumes a 4K monitor instead.
I noticed this on the download page for the Odroid N2/N2+:
On modern kernels adding “video=HDMI-A-1:1920x1080M@60D” to boot /boot/armbianEnv.txt (extraargs=) should force HDMI to 1080p instead of the 4K native resolution.
I'll check if that will also works with 2560x1440 monitors!
The problem turns out to be the kernel version.  The minimal image comes with 6.1.30 which provides a new video device (called None-1) and the desktop image comes with 6.1.11 which does not have this mystery video device.   All working with the reverted kernel.
