Hi all, I am running armbian bookworm on a nanopi r6c (rk3588).
At boot, wireguard does not resolve the endpoint (strange, because it runs after network-online.target)
and instead of keep trying, it gives up.
If I manually restart it, all is good.
Attached screenshots show the different behaviour in a raspberry pi (rpi4 as hostname) running raspios,
where it keeps trying to resolve the endpoint, and nanopi r6c not retrying.
I will recompile kernel to enable wireguard debug (or is there a quicker way?)
Edited by Antonio Mignolli
Attached screenshots and removed debug question.
  • Antonio Mignolli changed the title to wireguard fails to connect at boot, rk3588 (nanopi r6c)
Exactly the same error using Radxa Zero and armbian bookworm. Like the exact same thing.
When i manualy restart the service all is good.
when i try to enable systemd-networkd-wait-online.service , the vendor preset is disabled meaning that the wg service has no way to know when the network is online :
After=network-online.target nss-lookup.target
Wants=network-online.target nss-lookup.target
any help appreciated.
Hi all.
I solved it, indeed, by "drastically" recompile wireguard-tools with a modification (makes sense, IMHO).
https://github.com/WireGuard/wireguard-tools/pull/19
Basically, I am telling wireguard to keep trying reconnection according to configuration (environment variable WG_ENDPOINT_RESOLUTION_RETRIES),
and don't modify this behaviour when some error types occur (EAI_NONAME or EAI_FAIL).
I just noticed there is another modification, maybe even better, here:
https://github.com/WireGuard/wireguard-tools/pull/18
Hello all,
another option is to modify the service directly to restart it automatically, here's an example provided by chat gpt :
[Unit]
Description=WireGuard via wg-quick(8) for %I
PartOf=wg-quick.target
Documentation=man:wg-quick(8)
Documentation=man:wg(8)
Documentation=https://www.wireguard.com/
Documentation=https://www.wireguard.com/quickstart/
Documentation=https://git.zx2c4.com/wireguard-tools/about/src/man/wg-quick.8
Documentation=https://git.zx2c4.com/wireguard-tools/about/src/man/wg.8
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/usr/bin/wg-quick up %i
ExecStop=/usr/bin/wg-quick down %i
ExecReload=/bin/bash -c 'exec /usr/bin/wg syncconf %i <(exec /usr/bin/wg-quick strip %i)'
Environment=WG_ENDPOINT_RESOLUTION_RETRIES=infinity
Restart=always
RestartSec=5
[Install]
WantedBy=multi-user.target
the restart always and restart sec makes the service restart automatically after 5 seconds if failed. this means that on boot it will fail and restart automatically after 5 seconds which might be enough time for network connection.
Please, use chat GPT when you know exactly what you're doing :)
With Type=oneshot Restart is NOT allowed.
One shot services exit immediately, so "restart" makes no sense.
Consider removing the post, it could lead to misinformation
