SvenHz Posted June 30, 2023 Share Posted June 30, 2023 Hi all, just a quick note here that I am running 23.05 Bookworm successfully on Helios4 with ZFS. I did a clean install with a self-built image. Why the self-build? For two reasons: I wanted to have working fancontrol and that required the recent patch of @Heisath - https://github.com/armbian/build/pull/5392 I ran into an issue with not being able to install kernel headers (see below) so I needed to build an image with kernel headers built-in Build steps I wanted the release version so I did this in a clean build environment (WSL2 Ubuntu): git clone --depth=1 --branch=v23.05.2 https://github.com/armbian/build And then manually place this file in your local tree https://github.com/armbian/build/blob/main/patch/kernel/archive/mvebu-6.1/92-mvebu-gpio-remove-hardcoded-timer-assignment.patch. You need to touch .ignore_changes. Then run compile.sh INSTALL_HEADERS=yes. Testing After booting the image, I only did the following steps: systemctl disable helios4-wol # not sure why this service is failing but I do not use this anyway apt update apt upgrade reboot apt install zfs-dkms apt install zfsutils-linux Kernel header issue This is after apt update / apt upgrade / reboot. The repo seems to be out of sync. Also armbian-config fails altogether with a grep error (something with maximum count). root@helios4:~# apt search linux-headers|grep mvebu WARNING: apt does not have a stable CLI interface. Use with caution in scripts. linux-headers-current-mvebu/bookworm 23.02.2 armhf Linux kernel headers for 5.15.93-mvebu on armhf current linux-headers-edge-mvebu/bookworm 23.02.2 armhf Linux kernel headers for 6.1.11-mvebu on armhf edge root@helios4:~# uname -a Linux helios4 6.1.36-mvebu #2 SMP Wed Jun 28 11:12:41 CEST 2023 armv7l GNU/Linux root@helios4:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=helios4 BOARD_NAME="Helios4" BOARDFAMILY=mvebu BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=961a103 VERSION=23.05.1 LINUXFAMILY=mvebu ARCH=arm IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage FORCE_BOOTSCRIPT_UPDATE=yes VENDOR=Armbian REVISION=23.05.1 BOOTSCRIPT_FORCE_UPDATE="yes" BOOTSCRIPT_DST="boot.cmd" root@helios4:~# 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 30, 2023 Share Posted June 30, 2023 37 minutes ago, SvenHz said: The repo seems to be out of sync https://www.armbian.com/newsflash/armbian-leaflet-8/ 0 Quote Link to comment Share on other sites More sharing options...
FredK Posted July 10, 2023 Share Posted July 10, 2023 @Werner In Armbian Leaflet #8 from June 8th we read (bold typing by me): Zitat We have fixed images that didn’t boot and we decided to hold back the repository update for now. Rest assured, our dedicated team is working tirelessly to identify and resolve any critical bugs within the next two weeks. Now we are in week 5. Any news about Helios4 23.05 Bookworm? 0 Quote Link to comment Share on other sites More sharing options...
