I am unable to configure Xorg to ignore (and stop using as its default) the None-1 video device causing me not to be able to display a desktop via the HMDI-1-1 device.
It has been suggested (https://ubuntu-mate.community/t/how-to-configure-xorg/26732/3) that I disable this device in the kernel, hopefully, via a kernel option such as :
video=None-1:d
Does anyone know where (which file) and how (specific method) I should do this?
You can try to edit /boot/boot.cmd. Search for the line starting with setenv bootargs and add this at the end. Then recompile the boot script with the command mentioned at the end of this file.
So I edited the boot.cmd file and added this line after each of the setenv bootarg ... lines :
setenv bootargs "${bootargs}
video=None-1:d"
recompiled with
sudo mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
checked the lines had made it to boot.scr and rebooted.
But the None-1 video device still persists and xrandr still shows that device is being used by Xorg!!!
