I am having trouble installing Armbian on the NVMe drive Orange Pi 5 plus.
I tried
sudo armbian-install
But it will never list the nvme drive there.
lsblk clearly can see the drive as is seen in the image bellow?
Does anyone have any idea how I am supposed to do this. Thanks
I got it finally to copy.
But if removing the SD card and attempting to boot only from the NVMe then it boots into BusyBox only.
(further more then if trying to install the Display driver listed with the Armbian for Orange Pi 5 on Orange Pi 5 plus then system will no longer boot).
Cannot reproduce. First thing I did when I received mine was install on NVMe. So verified working.
As NicoD mentioned there needs to be a partition created on the nvme beforehand, then armbian-install detects it.
Select boot from MTD and let it flash SPI which takes a while.
After power off remove sd and power on again. Boots.
