Like it happened to @Grogorio in 2016, I need to introduce a boot delay on my OrangePi Zero Plus (Armbian 23.02.2 Focal) to allow time for other network elements in my setup to boot.
As per what I have read somewhere, this can done by adding a 'boot_delay=n' line in /boot/config.txt, however I don't see this file in Armbian; I've also tried to add the line, but it does not seems to be working.
Furthermore, the max delay that can be setup there is 10 seconds, but I need a longer delay.
Can someone help?
TIA
So, basically you're saying that the /boot/config.txt file does not exist, and that /boot/armbianEnv.txt has to be used instead.
Unfortunately, it seems that an overview of all possible parameters for armbianEnv.txt does not exist, as it depends on the kernel version.
Anyway, as per the Kernel Parameters page for the kernel version I'm on, I believe the boot_delay parameter is not what I need, as it will delay each printk during boot.
I just need to add a pause of 30 seconds at boot... before the network is brought up.
Edited by lollapalooza
This is Raspbian & Raspberry Pi proprietary config file you won't find it anywhere else. Every HW vendor has its own config way, Armbian keeps this consistent regardless of hardware.
Correct.
extraargs=boot_delay=30
that would would be passed to the kernel. But as you already figured out, this doesn't help in the problem you have. I would dig into documentation of network manager or systemd-networking, depending on which way you plan to configure your network.
