Fran A100 Posted August 9, 2023 Posted August 9, 2023 (edited) Hi Guys! This is my fist post on this forum. I have been spending a lot of time these days to make the MCP2515 CAN Controller on the RISCV computer, but I am not able to make it work even if everything seems to be on place. It is obvious that I am not understanding something correclty and that is why is not working. I am using the MangoPi Mqpro that has the SPI port on the 40 pin connector. Right now is not possible to add overlays on mangopi with the arbiam, but I managed to upload my custom overlays using the grub and Ubuntu, that part is not relevant for the topic. Let's assume for the topic that I am able to upload overlays and they are correctly applied on device tree. ### Connections The SPI interface is defined as follows, extracted from /sys/kernel/debug/pinctrl/2000000.pinctrl/pinmux-pins: pin 106 (PD10): device 4026000.spi function spi1 group PD10 pin 107 (PD11): device 4026000.spi function spi1 group PD11 pin 108 (PD12): device 4026000.spi function spi1 group PD12 pin 109 (PD13): device 4026000.spi function spi1 group PD13 pin 110 (PD14): device 4026000.spi function spi1 group PD14 pin 111 (PD15): device 4026000.spi function spi1 group PD15 pin 112 (PD16): device 2000c00.pwm function pwm group PD16 pin 113 (PD17): device spi1.0 function irq group PD17 Basically is connected to the SPI interface of the MCP2515, and the interrupt is connected to PD17. SPI_INT PD17 SPI_SCK PD11 SPI_SI PD12 SPI_SO PD13 SPI_CS PD10 The overlay that I am applying is the next one: /dts-v1/; /plugin/; / { compatible = "allwinner,d1-nezha\0allwinner,sun20i-d1"; fragment@0 { target-path = "/clocks"; __overlay__ { #address-cells = <1>; #size-cells = <1>; /* External crystal oscillator on the board */ can0_osc_fixed: can0_osc_fixed { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <8000000>; phandle = <0x81>; }; }; }; fragment@1 { target = <&pinctrl>; // pinctrl@2000000 __overlay__ { can0_pin_irq: can0_pin_irq { pins = "PD17"; function = "irq"; phandle = <0x85>; }; }; }; fragment@2 { target = <&spi>; //spi@4026000 __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; mcp2515 { reg = <0>; // SPI 1 compatible = "microchip,mcp2515"; pinctrl-names = "default"; pinctrl-0 = <0x85>; spi-max-frequency = <10000000>; interrupt-parent = <0x22>; // pinctrl@2000000 interrupts = <0 113 2>; // IRQ LINE, try with <0 65 2> clocks = <0x81>; status = "okay"; }; }; }; }; However when I boot up I look to the interrupts and there is nothing related to the irq line for the CAN/spi, output of /proc/interrupts: CPU0 2: 79503 sun20i-intc 75 Edge timer@2050000 3: 0 sun20i-intc 109 Edge 5500000.hdmi, dw-hdmi-cec 4: 0 sun20i-intc 25 Edge mv64xxx_i2c 5: 0 RISC-V INTC 5 Edge riscv-timer 6: 14 sun20i-intc 68 Edge sun8i-ce-ns 7: 0 sun20i-intc 47 Edge ohci_hcd:usb3 74: 0 sun20i-intc 31 Edge sun6i-spi 78: 5926 sun20i-intc 74 Edge ths 79: 0 sun20i-intc 50 Edge ohci_hcd:usb4 80: 0 sun20i-intc 46 Edge ehci_hcd:usb1 81: 1336 sun20i-intc 18 Edge ttyS1 82: 189890 sun20i-intc 57 Edge sunxi-mmc 83: 0 sun20i-intc 82 Edge 1c0e000.video-codec 84: 0 sun20i-intc 80 Edge 2010000.iommu 85: 0 sun20i-intc 107 Edge 5470000.lcd-controller 88: 0 sun20i-intc 49 Edge ehci_hcd:usb2 89: 0 sun20i-intc 160 Edge 7090000.rtc 90: 2 sun20i-intc 27 Edge mv64xxx_i2c 98: 0 sun20i-intc 45 Edge musb-hdrc.2.auto 101: 8630 sun20i-intc 56 Edge sunxi-mmc 109: 0 sun20i-intc 66 Edge 3002000.dma-controller 111: 4 sun20i-intc 32 Edge sun6i-spi 112: 0 sun20i-intc 77 Edge sun4i-a10-lradc-keys 113: 0 sun20i-intc 106 Edge 5461000.lcd-controller 114: 7 sun20i-intc 167 Edge sunxi-ir 119: 0 sun20i-intc 36 Edge 2008000.led-controller 204: 1 sunxi_pio_edge 84 Edge usb0-vbus-det 205: 1 sunxi_pio_edge 85 Edge usb0-id-det 254: 1 sunxi_pio_edge 134 Edge 4020000.mmc cd IPI0: 0 Rescheduling interrupts IPI1: 0 Function call interrupts IPI2: 0 CPU stop interrupts IPI3: 0 IRQ work interrupts IPI4: 0 Timer broadcast interrupts Some outputs from the Kernel: [ 52.133406] CAN device driver interface [ 52.918270] mcp251x spi1.0 can0: MCP2515 successfully initialized. [ 1163.417322] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 1182.919088] can: controller area network core [ 1182.919249] NET: Registered PF_CAN protocol family [ 1183.000429] can: raw protocol And after booting I run the next: $ sudo ip link set can0 up type can bitrate 500000 $ sudo ifconfig can0 up $ sudo cansend can0 5A1#00.01.02.03.04 This configuration is not working because when I try to connect, I am not receiving anything. I suppose that I am not configuring correctly the interrupt line of the IRQ of SPI. My knowledge on this is very narrow, and I am not able to understand what is failing. All the feedback is totally welcome. I can give more documentation if my explanation is not complete enought. Thanks! Edited August 9, 2023 by Fran A100 0 Quote
going Posted August 9, 2023 Posted August 9, 2023 On 8/9/2023 at 12:54 PM, Fran A100 said: 74: 0 sun20i-intc 31 Edge sun6i-spi Expand On 8/9/2023 at 12:54 PM, Fran A100 said: 111: 4 sun20i-intc 32 Edge sun6i-spi Expand This is an interrupt for SPI But I don't see the mcp251x driver here. On 8/9/2023 at 12:54 PM, Fran A100 said: compatible = "microchip,mcp2515"; Expand This line should cause the driver to load. Check the presence of the module in the kernel: grep -n CONFIG_CAN_MCP251X /boot/conf* Check the correct application of the overlay in the dts: dtc --sort -I fs -O dts /sys/firmware/devicetree/base > $HOME/device_tree.txt 0 Quote
going Posted August 9, 2023 Posted August 9, 2023 On 8/9/2023 at 12:54 PM, Fran A100 said: Some outputs from the Kernel: [ 52.133406] CAN device driver interface [ 52.918270] mcp251x spi1.0 can0: MCP2515 successfully initialized. [ 1163.417322] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready [ 1182.919088] can: controller area network core [ 1182.919249] NET: Registered PF_CAN protocol family [ 1183.000429] can: raw protocol Expand Good! The driver is loaded. After you try to connect, no error messages appear in dmesg? 0 Quote
going Posted August 9, 2023 Posted August 9, 2023 The overlay is not described quite correctly. Make in the image and likeness with this: Reveal hidden contents /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-r40"; fragment@0 { target-path = "/aliases"; __overlay__ { spi0 = "/soc/spi@1c05000"; }; }; fragment@1 { target = <0xffffffff>; __overlay__ { pinctrl-names="default","default"; #address-cells = <0x01>; #size-cells = <0x00>; status = "okay"; pinctrl-0 = <&spi0_pc_pins>; pinctrl-1 = <&spi0_cs0_pc_pin>; spidev@0 { compatible = "armbian,spi-dev"; status = "okay"; reg = <0x00>; spi-max-frequency = <0xf4240>; }; }; }; fragment@2 { target = <&pio>; __overlay__ { spi0_pc_pins: spi0-pc-pins { pins = "PC0", "PC1", "PC2"; function = "spi0"; }; spi0_cs0_pc_pin: spi0-cs0-pc-pin { pins = "PC23"; function = "spi0"; }; }; }; __fixups__ { spi0 = "/fragment@1:target:0"; }; }; This should be described in a separate fragment pinctrl-0 = <&spi0_pc_pins>; pinctrl-1 = <&spi0_cs0_pc_pin>; 0 Quote
going Posted August 9, 2023 Posted August 9, 2023 And please post your working overlay here when you finish successfully checking. 0 Quote
Solution Fran A100 Posted August 9, 2023 Author Solution Posted August 9, 2023 Finally I made it! Thanks a lot for the help but it was something else. The final overlay is the next one: /dts-v1/; /plugin/; / { compatible = "allwinner,d1-nezha\0allwinner,sun20i-d1"; fragment@0 { target-path = "/clocks"; __overlay__ { #address-cells = <1>; #size-cells = <1>; /* External crystal oscillator on the board */ can0_osc_fixed: can0_osc_fixed { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <8000000>; phandle = <0x81>; }; }; }; fragment@1 { target = <&pinctrl>; // pinctrl@2000000 __overlay__ { can0_pin_irq: can0_pin_irq { pins = "PD17"; function = "irq"; phandle = <0x85>; bias-pull-up; }; }; }; fragment@2 { target = <&spi>; //spi@4026000 __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; mcp2515 { reg = <0>; // SPI 1 compatible = "microchip,mcp2515"; pinctrl-names = "default"; pinctrl-0 = <0x85>; spi-max-frequency = <10000000>; interrupt-parent = <0x22>; // pinctrl@2000000 interrupts = <3 17 8>; // IRQ LINE, try with <0 65 2> clocks = <0x81>; status = "okay"; }; }; }; }; I learnt some things about the interrupts field: * The part of interrupts is like this, <BANK NUMBER TYPE_INTERRUPT> * BANK is like, A -> 0, B-> 1, C->2, D->3 * NUMBER, PD17 -> 17 * TYPE_INTERRUPT, is described here 2 Quote
Something Name Posted August 10, 2023 Posted August 10, 2023 Fran A100, Hello Could you say about add overlay through "Grub and Ubuntu" on the mango pi mq-pro board? Please 0 Quote
Fran A100 Posted August 10, 2023 Author Posted August 10, 2023 Hi! Normally in a normal SBC you add an overlay with something like /boot/uEnv.txt etc... But this is not done yet. The workarround I made to work is to use Ubuntu (from oficial webpage of ubuntu, I used the Lichee version, or even the one shipped for the lichee that has the wifi driver already installedd), that is prepared also for running the mangoPi) and change group. My explanation: On the default installation of ubuntu, the only way to add overlays is with grub. The default ubuntu is configured to load the devicetree overlays with grub. So if we want to add overlays, we need to change the grub. To add a new entry on the grub we need to go to `/etc/grub.d/40_custom` and there we put the entry we want. The best way is to copy the same information that is in /boot/grub/grub.cfg regarding to the OS, like: menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-90836834-7e07-48ca-b0f9-29880429770d' { load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 90836834-7e07-48ca-b0f9-29880429770d echo 'Loading Linux 5.19.0-1015-allwinner ...' linux /boot/vmlinuz-5.19.0-1015-allwinner root=/dev/mmcblk0p1 ro quiet splash echo 'Loading device tree blob...' devicetree /boot/dtb } My modified version would be: menuentry 'UbuntuWithOverlays' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'ubuntu-custom-overlay'' { load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 search --no-floppy --fs-uuid --set=root 90836834-7e07-48ca-b0f9-29880429770d echo 'Loading Linux 5.17.0-1003-allwinner ...' linux /boot/vmlinuz-5.17.0-1003-allwinner root=LABEL=cloudimg-rootfs ro quiet splash echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-5.17.0-1003-allwinner echo 'Loading device tree blob...' devicetree /boot/overlay/my_overlay.dtb } To make that entry the default in grub you need to add `GRUB_DEFAULT="ubuntu-custom-overlay"` to `/etc/default/grub`. After some testing I realized that there can be only one command of devicetree, it is not supported the overlays, the comfiguration is cleaned in every devicetree command. But you can get the original devicetree, modify and put it in the command, that works. Dont forget to do `update-grub` after. To get the device tree blob that comes with the board, you need to run `dtc -I fs /proc/device-tree` PD: In this post I confuse Overlay with the device tree configuration. There is no overlay, is a complete device tree blob, have that in mind. 1 Quote
Something Name Posted August 17, 2023 Posted August 17, 2023 On 8/10/2023 at 12:49 PM, Fran A100 said: Hi! Normally in a normal SBC you add an overlay with something like /boot/uEnv.txt etc... But this is not done yet. The workarround I made to work is to use Ubuntu (from oficial webpage of ubuntu, I used the Lichee version, or even the one shipped for the lichee that has the wifi driver already installedd), that is prepared also for running the mangoPi) and change group. My explanation: Expand Many many thanks you ! 0 Quote
