Ducdanh Nguyen Posted August 10 Posted August 10 On 11/27/2023 at 2:53 AM, Victorhtf said: Did anyone made any progress? I also bought a TVBox transpeed with H618 and I would like to install armbian to make my own server based in Linux. Anyone tried with H616 image? By the way, is it possible to backup original ROM before I run some tests? Cause if it not works I would like to keep my TV Box working on. you can install and boot from the sd card, also h616 uses nand flash, which can't write on it (or maybe it uses emmc) 0 Quote
Nick A Posted Thursday at 04:51 PM Posted Thursday at 04:51 PM (edited) @dale there’s a new patch to fix boards without external 32k clock. I haven’t tested it yet. https://github.com/warpme/minimyth2/commit/728a14a73924e349fe88fb4def7e5f50a79aed5c Edited Thursday at 04:52 PM by Nick A 1 Quote
dale Posted Sunday at 03:25 AM Posted Sunday at 03:25 AM (edited) On 6/26/2025 at 7:21 PM, c0rnelius said: You apply the patch to the kernel source-tree, In this case we will use meson64 as an example. Add the patch to: patch/kernel/archive/meson64-6.12/ Enable in the defconfig: echo "CONFIG_OPENVFD=m" >> config/kernel/linux-meson64-current.config Build a new IMG or KERNEL as one normally would for your unit. Hi I got error when applying the patch you shared. Can I know how to fix it? Edited yesterday at 02:04 AM by dale 0 Quote
buzz89 Posted 3 hours ago Posted 3 hours ago I just got an H618 board. It is able to boot using the Vontar image, but the onboard Ethernet is not working. USB Ethernet works fine. The Ethernet chip is RTL8211F, I’m hoping to get some guidance on this issue. Here’s the relevant dmesg output related to Ethernet: dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 2.422638] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 2.422669] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 2.422678] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 2.422989] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 2.423245] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 2.423316] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 2.426176] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 2.426204] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 2.426211] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 2.426220] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 2.426226] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 2.426232] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 2.469198] dwmac-sun8i 5030000.ethernet end0: renamed from eth0 [ 3.060680] asix 2-1:1.0 eth0: register 'asix' at usb-5200000.usb-1, ASIX AX88772B USB 2.0 Ethernet, 00:0e:c6:c5:f5:e5 [ 3.068667] asix 2-1:1.0 enx000ec6c5f5e5: renamed from eth0 [ 11.377369] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.388786] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 11.388838] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found [ 11.388849] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available [ 11.388859] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW [ 11.393925] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode 0 Quote
