On 11/27/2023 at 2:53 AM, Victorhtf said:
Did anyone made any progress? I also bought a TVBox transpeed with H618 and I would like to install armbian to make my own server based in Linux.
Anyone tried with H616 image? By the way, is it possible to backup original ROM before I run some tests? Cause if it not works I would like to keep my TV Box working on.
you can install and boot from the sd card, also h616 uses nand flash, which can't write on it (or maybe it uses emmc)
Posted (edited)
On 6/26/2025 at 7:21 PM, c0rnelius said:
You apply the patch to the kernel source-tree, In this case we will use meson64 as an example.
Add the patch to: patch/kernel/archive/meson64-6.12/
Enable in the defconfig: echo "CONFIG_OPENVFD=m" >> config/kernel/linux-meson64-current.config
Build a new  IMG or KERNEL as one normally would for your unit.
Hi I got error when applying the patch you shared.
Can I know how to fix it?
Edited by dale
I just got an H618 board. It is able to boot using the Vontar image, but the onboard Ethernet is not working. USB Ethernet works fine. The Ethernet chip is RTL8211F, I’m hoping to get some guidance on this issue.
Here’s the relevant dmesg output related to Ethernet:
dmesg  | grep eth
[    0.000000] psci: probing for conduit method from DT.
[    2.422638] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found
[    2.422669] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found
[    2.422678] dwmac-sun8i 5030000.ethernet: IRQ sfty not found
[    2.422989] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator
[    2.423245] dwmac-sun8i 5030000.ethernet: PTP uses main clock
[    2.423316] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0)
[    2.426176] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported
[    2.426204] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported
[    2.426211] dwmac-sun8i 5030000.ethernet: COE Type 2
[    2.426220] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported
[    2.426226] dwmac-sun8i 5030000.ethernet: Normal descriptors
[    2.426232] dwmac-sun8i 5030000.ethernet: Chain mode enabled
[    2.469198] dwmac-sun8i 5030000.ethernet end0: renamed from eth0
[    3.060680] asix 2-1:1.0 eth0: register 'asix' at usb-5200000.usb-1, ASIX AX88772B USB 2.0 Ethernet, 00:0e:c6:c5:f5:e5
[    3.068667] asix 2-1:1.0 enx000ec6c5f5e5: renamed from eth0
[   11.377369] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   11.388786] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL)
[   11.388838] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found
[   11.388849] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available
[   11.388859] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW
[   11.393925] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode
I have build a new image, but no luck, the ethernet is still not working.
Here is what I changed.
diff --git a/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch b/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch
index 747ddca7b..6a88acfcf 100644
--- a/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch
+++ b/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch
@@ -73,9 +73,9 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts
 +&mdio1 {
-+      rmii_phy: ethernet-phy@16 {
++      rmii_phy: ethernet-phy@0 {
 +              compatible = "ethernet-phy-ieee802.3-c22";
-+              reg = <16>;
++              reg = <0>;
dmesg:
root@vontar-h618:~# dmesg | grep ether
[    2.850576] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found
[    2.850587] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found
[    2.850597] dwmac-sun8i 5030000.ethernet: IRQ sfty not found
[    2.850841] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator
[    2.851059] dwmac-sun8i 5030000.ethernet: PTP uses main clock
[    2.851089] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0)
[    2.851770] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported
[    2.851780] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported
[    2.851787] dwmac-sun8i 5030000.ethernet: COE Type 2
[    2.851794] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported
[    2.851801] dwmac-sun8i 5030000.ethernet: Normal descriptors
[    2.851807] dwmac-sun8i 5030000.ethernet: Chain mode enabled
[    2.979923] dwmac-sun8i 5030000.ethernet: EMAC reset timeout
[    2.979966] dwmac-sun8i 5030000.ethernet eth0: stmmac_dvr_remove: removing driver
[    3.004135] dwmac-sun8i 5030000.ethernet: probe with driver dwmac-sun8i failed with error -110
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
3: enx000ec6c5f5e5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 00:0e:c6:c5:f5:e5 brd ff:ff:ff:ff:ff:ff
unable to build.
dts/upstream/src/arm64/allwinner/sun50i-h616-vontar-h618.dtb: ERROR (phandle_references): /soc/ethernet@5020000: Reference to non-existent node or label "reg_dcdce"
@@ -23,7 +23,7 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts
 +              mmc0 = &mmc0;
 +              mmc1 = &mmc1;
 +              mmc2 = &mmc2;
-+              ethernet0 = &emac1;
++              ethernet0 = &emac0;
 +              serial0 = &uart0;
@@ -61,21 +61,21 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts
 +      status = "okay";
-+&emac1 {
++&emac0 {
 +      pinctrl-names = "default";
-+      pinctrl-0 = <&rmii_pins>;
++      pinctrl-0 = <&ext_rgmii_pins>;
 +      phy-mode = "rmii";
-+      phy-handle = <&rmii_phy>;
-+      phy-supply = <&reg_aldo1>;
++      phy-handle = <&ext_rgmii_pins>;
++      phy-supply = <&reg_dcdce>;
 +      allwinner,rx-delay-ps = <3100>;
 +      allwinner,tx-delay-ps = <700>;
 +      status = "okay";
 +&mdio1 {
-+              reg = <16>;
++              reg = <0>;
Posted (edited)
@buzz89In oranges zero2 dts it has a 3.3v regulator defined as reg_dcdce. There’s only 5v defined in the vontar dts. You can add this to your dts
reg_dcdce: dcdce {
regulator-always-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-name = "vcc-eth-mmc";
https://linux.googlesource.com/linux/kernel/git/bpf/bpf/+/refs/tags/v6.9-rc2/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts
you can borrow code off these boards as well
https://linux-sunxi.org/index.php?search=RTL8211F&title=Special%3ASearch&go=Go
if you can extract your android dts for more clues.
Edited by Nick A
Sorry, I don't have the Android dts, the Android image is erased.
I have tried the image from niulinkcloud,  The ethernet is working on this image, can we extract dts from this image?
Posted (edited)
@Nick AI tried to extract the dts from the working image, cloud you help me find any clues. Thank you.
I was able to gain access to the os that works, this is the dmesg:
dmesg | grep eth
[ 8.550757] libphy: 5020000.eth: probed
[ 8.568109] sunxi-gmac 5020000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (5020000.eth-0:00)
[ 12.765916] sunxi-gmac 5020000.eth eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.775526] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
I also upload the pic of ethernet chip.
dts.zip
Edited by buzz89
I don't know anything about this patch, but check this:
* Linux version you are using, vs Linux version corneliius has used
* Try deleting the hunk in the patch that caused the problem you saw, and see if other hunks cause patch failures
* If it is only one hunk causing the problem, look at the file that is affected by the patch drivers/auxdisplay/Makefile: do the lines mentioned in the hunk exist in the Makefile? In the expected line number?
Posted (edited)
@Nick A it has same issue. I thik it is related to the device tree declaration.
Should it be something like this?
Quote
mmc@4021000 {
            compatible = "allwinner,sun50i-h616-mmc\0allwinner,sun50i-a100-mmc";
            reg = <0x4021000 0x1000>;
            clocks = <0x02 0x40 0x02 0x3d>;
            clock-names = "ahb\0mmc";
            resets = <0x02 0x0f>;
            reset-names = "ahb";
            interrupts = <0x00 0x24 0x04>;
            pinctrl-0 = <0x15>;
            status = "okay";
            max-frequency = <50000000>;
            mmc-ddr-1_8v;
            no-sd;
            no-mmc;
            cap-sdio-irq;
            #address-cells = <1>;
            #size-cells = <0>;
            mmc-pwrseq = <0x16>;
            phandle = <0x54>;
            bus-width = <0x04>;
            non-removable;
            vmmc-supply = <0x12>;
            vqmmc-supply = <0x11>;
rfkill {
        compatible = "allwinner,sunxi-rfkill";
        status = "okay";
        chip_en;
        power_en;
        pinctrl-0;
        pinctrl-names;
        clocks;
        phandle = <0xd2>;
            wlan {
                compatible = "allwinner,sunxi-wlan";
                wlan_busnum = <0x01>;
                wlan_power;
                wlan_regon = <&pio 0x06 0x12 0>;
                wlan_hostwake = <&pio 0x06 0x0f 0>;
                wakeup-source;
                phandle = <0xd3>;
            bt {
                compatible = "allwinner,sunxi-bt";
                bt_power;
                bt_rst_n = <&pio 0x06 0x13 1>;
                phandle = <0xd4>;
        btlpm {
            compatible = "allwinner,sunxi-btlpm";
            status = "okay";
            uart_index = <0x01>;
            bt_wake = <&pio 0x06 0x11 0>;
            bt_hostwake = <&pio 0x06 0x10 0>;
            wakeup-source;
            phandle = <0xd6>;
https://github.com/LYU4662/aic8800-sdio-linux-1.0
Edited by dale
Posted (edited)
@Nick A I fixed the wifi issue after warm reboot for x98h with this patch:
Quote
+    reg_vcc_wifi: reg_vcc_wifi {
+        compatible = "regulator-fixed";
+        regulator-name = "vcc-wifi";
+        regulator-min-microvolt = <3300000>;
+        regulator-max-microvolt = <3300000>;
+        gpio = <&pio 6 18 GPIO_ACTIVE_HIGH>; /* PG18 = WL_REG_ON */
+        enable-active-high;
+        regulator-always-on;
+    wifi_pwrseq: wifi_pwrseq {
+        compatible = "mmc-pwrseq-simple";
+        // No reset-gpios needed here, handled by regulator
+        // No external clock needed (chip has its own crystal)
+&mmc1 {
+    vmmc-supply = <&reg_vcc_wifi>;   /* power controlled by PG18 */
+    vqmmc-supply = <&reg_aldo1>;     /* IO voltage (1.8V) */
+    mmc-pwrseq = <&wifi_pwrseq>;
+    bus-width = <4>;
+    non-removable;
+    no-sd;
+    no-mmc;
+    max-frequency = <50000000>;
+    status = "okay";
+    wlan: wifi@1 {
+        reg = <1>;
+        interrupt-parent = <&pio>;
+        interrupts = <6 15 IRQ_TYPE_EDGE_RISING>; /* PG15 WL_HOSTWAKE */
+        interrupt-names = "host-wake";
+        // optional: local-mac-address = [00 11 22 33 44 55];
Edited by dale
On 9/10/2025 at 12:47 AM, kazekami_him said:
@Rodrigo Campos@Nick A This guy seems to have created a u-boot that can get 4gb ram for M98-8K. https://github.com/nitrolack/M98-8K-Linux/blob/main/U-Boot Screen 20-03-2024
Hi @kazekami_him, Thanks for your information, but I have no idea in how to use this content for test it. Maybe @Nick A Could understand what this guy did and how to bring it to his port and help us to detect the correct ram amount.
Posted (edited)
@Rodrigo Campos @kazekami_him I think @nitrolack and @afiftyp had the same Transpeed M98-8k board. It booted fine with my transpeed image. (other than wifi) They didn't have a board that had secure boot. Check if your board is the same. Maybe you could try my older images. It could be the newer u-boot and patches broke the ram detection? Maybe your board is using a different ram?
Edited by Nick A
Hi @Nick A, the armbian in afiftyp board just see 2GB to, at least it was this way in 2024 when he sent me his boot log.
My board is very similar to afiftyp board, except of a number near the QC sticker, that looks like a version number. afiftyp number is 2336 and the mine is 2333. The amout of memory chips is identical to (8 chips), but tha labels is a litle different, but I cant found the label meaning.
I use your image since very old one, so I don't think it is about u-boot update, but I could try an older one. About Secure Boot, A patch that you give me solved it and it isn't a problem any more (thanks again for it).
@afiftyp, if I'm wrong and you already solve your rom amount in armbian, please let us know and if you could, explain us what you did to solve it, thanks.
Posted (edited)
I flashed armbian into my h618, but it won't boot. I have an ubuntu image that boots it, but I don't know the password, so I need to flash armbian again. Can I use this ubuntu image to debug the armbian boot?
Edited by emor acid
U-Boot 2024.01-armbian-2024.01-S866c-Pbc32-Ha9af-V80bb-Bda0a-R448a (Nov 25 2024 - 14:01:12 -0500) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: Transpeed 8K618-T
DRAM:  4 GiB
Core:  61 devices, 22 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from FAT... MMC: no card present
** Bad device specification mmc 0 **
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   apply fix for AC300 ephy bb version bug ...
using AC300 emac1 ephy default config ...
eth0: ethernet@5030000
starting USB...
Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
Bus usb@5101400: USB OHCI 1.0
Bus usb@5200000: USB EHCI 1.00
Bus usb@5200400: USB OHCI 1.0
scanning bus usb@5101000 for devices... 1 USB Device(s) found
scanning bus usb@5101400 for devices... 1 USB Device(s) found
scanning bus usb@5200000 for devices... 1 USB Device(s) found
scanning bus usb@5200400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
No EFI system partition
Failed to persist EFI variables
BootOrder not defined
EFI boot manager: Cannot load any image
Device 0: unknown device
ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-02-00-41-2d-68-a7
Retrieving file: pxelinux.cfg/00000000
what can i do ? and how to do? 3ks
Posted (edited)
@emor acid could be your gpio settings for mmc0. Try the x98h image. If that doesn’t work you need to extract your android dts or use the one from the working Ubuntu.
Edited by Nick A
Posted (edited)
I followed this forum and finally bought a transpeed-8k618-t to use via a micro SD card. It's been a lot of fun and enjoyable. Even though it only displays well on YouTube at 720p/30fps, I understand the box's capabilities.
I'm thinking of installing eMMC, but I'm not sure. Can anyone recommend a proper eMMC installation method? I'd appreciate it.
@Nick A  Are you planning on making a Debian 13 trixie version?
Edited by MeJune
@MeJune You can build your own Debian 13 Trixie version.
git clone https://github.com/NickAlilovic/build.git --branch v20250306
cd build
./compile.sh
choose "Do not change kernel configuration"
choose "Show CSC/WIP/EOS/TVB"
choose "I understand and agree"
choose "transpeed=8k618-t"
choose "edge"
choose "trixie"
rest is up to you.
Your image should be in output/images directory.
7 часов назад, MeJune сказал:
I transferred it on two consoles using armbian-config. There were no problems.
Are there any chances to enable i2c? I use the tv-box as a 3d printing server (klipper)
openvfb is working fine, and I also managed to configure the G-Code Shell Command to display the remaining print time.
I want to connect the g-sensor via the i2c bus, please tell me if possible.
klipper@transpeed-8k618-t:~$ dmesg | grep i2c
[    1.374462] mv64xxx_i2c 5002c00.i2c: can't get pinctrl, bus recovery not supported
[    1.683314] axp20x-i2c 2-0036: AXP20x variant AXP313a found
[    1.683791] axp20x-i2c 2-0036: AXP20X driver loaded
klipper@transpeed-8k618-t:~$ sudo /sbin/i2cdetect -l
Posted (edited)
Thank you very much. I will try it.
cd build
./compile.sh
choose "edge"
choose "trixie"
rest is up to you.
Edited by MeJune
